Neues Modul readingsGroup
Begonnen von Niko, 24 August 2013, 11:59:11
franky08
#1305
Das Anführunszeichen bei column 2, dass hatte ich schon geändert. Kopiere den Code gleich nochmal.
Danke dir Andre, jetzt läuft es. Schönen Abend noch.
Frank
Debian Bookworm auf HUNSN / Debian Bullseye auf 2.ter HUNSN F2F an 2x RaspiB
mit FHEM aktuell
3xHMLAN mit vccu, raspmatic_rpi3, HMIP-HCU1
cotecmania
bei mir funktionieren cellStyle bzw. nameStyle nicht mehr.
   DEF
  MeinWetter:<Heute>,fc2_day_of_week,fc3_day_of_week,fc4_day_of_week,fc5_day_of_week
  MeinWetter:fc1_icon,fc2_icon,fc3_icon,fc4_icon,fc5_icon
  MeinWetter:fc1_high_c,fc2_high_c,fc3_high_c,fc4_high_c,fc5_high_c
  MeinWetter:fc1_low_c,fc2_low_c,fc3_low_c,fc4_low_c,fc5_low_c
  Wetter_PP:fc0_chOfRainDay,fc1_chOfRainDay,fc2_chOfRainDay,fc3_chOfRainDay,fc4_chOfRainDay
   NAME       RG_MeinWetter
   NR         603
   NTFY_ORDER 50-RG_MeinWetter
   STATE      Initialized
   TYPE       readingsGroup
   mayBeVisible 1
   Content:
     MeinWetter 1
     Wetter_PP  1
   Content2:
   DEVICES:
     ARRAY(0x15e0d90)
     ARRAY(0x1313a30)
     ARRAY(0x1ad2be8)
     ARRAY(0x22b7c58)
     ARRAY(0x22d4c90)
   Fhem:
     lastDefChange 53
     last_update 1428767148.32525
   Helper:
     DEF
     nameStyle  style="text-align:center"
     valueIcon  {'%VALUE'}
     valueStyle style="text-align:right"
     Valueformat:
       fc0_chOfRainDay %.0f%
       fc1_chOfRainDay %.0f%
       fc1_high_c %.0f°C
       fc1_low_c  %.0f°C
       fc2_chOfRainDay %.0f%
       fc2_high_c %.0f°C
       fc2_low_c  %.0f°C
       fc3_chOfRainDay %.0f%
       fc3_high_c %.0f°C
       fc3_low_c  %.0f°C
       fc4_chOfRainDay %.0f%
       fc4_high_c %.0f°C
       fc4_low_c  %.0f°C
       fc5_high_c %.0f°C
       fc5_low_c  %.0f°C
   fp_Tablet  600,-13,0,,
   fp_Test    600,-13,0,,
   noheading  1                                 #damit die Überschrift ausgeblendet wird
   nolinks    1                                 #Die Namen nicht als Links
   nonames    1
   room       Wetter
   valueFormat {"fc1_low_c" => "%.0f°C", "fc1_high_c" => "%.0f°C", "fc2_low_c" => "%.0f°C", "fc2_high_c" => "%.0f°C", "fc3_low_c" => "%.0f°C", "fc3_high_c" => "%.0f°C", "fc4_low_c" => "%.0f°C", "fc4_high_c" => "%.0f°C", "fc5_low_c" => "%.0f°C", "fc5_high_c" => "%.0f°C", "fc0_chOfRainDay" => "%.0f%", "fc1_chOfRainDay" => "%.0f%", "fc2_chOfRainDay" => "%.0f%", "fc3_chOfRainDay" => "%.0f%", "fc4_chOfRainDay" => "%.0f%", }
Die Überschrift ist nicht zentriert und die Werte nicht rechtsbündig ...
Ideen ?
FHEM auf Debian 13 in Proxmox VM
MAX!/HM/Sonoff-Thermostate, HM-Rolladenschalter, Shellys aller Art, LevelJet-Ölstandsmessung, KM271, IPCAM, TAB13" FTUI3
Tommy82
ich hab nach jedem neustart diese Meldung im Log
2015.04.17 19:03:01.796 1: PERL WARNING: Argument "-" isn't numeric in sprintf at ./FHEM/33_readingsGroup.pm line 734 in 734 steht
Zitat$v = sprintf( $value_format, $v );
Fhem Cubitruck  Armbian Buster with Linux 5.3.9-sunxi
HM-CC_RT-DN, HM-Sec-RHS,HM-Sec-SD, HM-Sec-SCo,IT1500,1xIT GRR-3500 Fritz!Dect200,Powerline546E,Enigma2 Modul mit 3 Vu+,Wol Modul für WinServer2016 und WinServer 2019,FB6590
Allnetl Wandtablett mit FTUI
Dduieh
#1308
ich habe eine readingsgroup in einem Raum eingefügt. Nun möchte ich, dass die readingsgroup ganz oben vor den anderen Groups angezeigt wird.
Ist das möglich?
Joker
Ja klar, hat aber nix mit readingsGroup zu tun.
Du kannst alle Devices mit dem attribut "sortBy" für die Anzeige in FHEMWEB sortieren. Siehe commandref unter FHEMWEB.
Dduieh
Danke für die schnelle Antwort, aber bei mir funktioniert das nicht ... oder ich stehe auf dem Schlauch?
Siehe Anhang
Joker
Hm, eigentlich nicht. Bin der Meinung das müsste so stimmen. Da kann ich Dir grad nicht weiter helfen.
kvo1
Worauf bezieht sich das.   sortby=6. ?
RPi1: mit CUL: HM-CC-RT-DN,HM-ES-PMSw1-Pl,HM-LC-BL1-FM,HM-LC-Bl1PBU-FM,HM-LC-SW1-PL2,HM-SCI-3-FM,HM-SEC-SC-2,KFM-Sensor
RPi2: Viessmann(optolink) mit 99_VCONTROL.pm,
Cubietruck: Wheezy / Apache / Owncloud
Cubietruck: Armbian(Jessie) / fhem 5.7 / LMS 7.9
RPi3: (Test) mit 7" Touch  &  HM-MOD-RPI-PCB
Dduieh
Joker
Äh, warte mal. Du musst das sortby natürlich der ReadingsGroup zuweisen, wenn Du die eine ReadingsGroup vor der andern haben willst  ;)
Hast Du das so?
kvo1
Hast Du das so?
Genau das meint ich  ;)
Dduieh
Das UNIRoll ist aber keine ReadingsGroup, sondern ein ganz normales Device.
moonsorrox
du kannst in den Räumen nichts sortieren, da gibt es hier im Forum schon diverse Wünsche...!
In einer Group geht das mit sortby...
justme1968
man kann sowohl in der raum übersicht als auch innerhalb einer gruppe (und auch innerhalb einer readingsGroup) mit sortby sortieren.
das problem hier ist das es zwei arten von fhem devices gibt. die 'normalen' und die 'at end'. zu letzteren gehört alles was kein device icon hat sondern direkt html zur darstellung verwendet. also vor allem svg, weblink und readingsGroup.
beim seitenaufbau werden zuerst alle 'normalen' devices untereinander korrekt sortier angezeigt und danach alle 'at end' devices. diese wiederum untereinander sortiert.
aber beide arten werden nicht vermischt.
  andre
justme1968
@Tommy82: du hast einen wert der nicht als zahl erkannt wird. du musst valueFormat entsprechend wählen das dieser fall getrennt berückichtigt wird.
  andre
