Timeout during API check
Begonnen von HarryT, 05 Oktober 2026, 21:51:07
HarryT
It seems my issues are not complete solved.
I get now in the logging:
2026.10.05 21:42:59 3: Timeout for Fritz::Fritz_Readout_API_Check reached, terminated process 4821
2026.10.05 21:42:59 2: [FritzBox||113.07.62|Readout_Aborted.10726] - SIGNIFICANT:Error: [285 | BlockingKill] Timeout during API check.
2026.10.05 21:43:09 3: [FritzBox||113.07.62|Readout_API_Check.11209] - BASIC:checkAPIs: started
2026.10.05 21:43:09 3: [FritzBox|FRITZ!Box 7490|113.07.62|Readout_API_Check.11314] - BASIC:Read 'jason_boxinfo.xml' from 172.27.8.1
2026.10.05 21:43:10 3: [FritzBox|FRITZ!Box 7490|113.07.62|Readout_API_Check.11539] - BASIC:boxUser is set to: fritzxxx
2026.10.05 21:43:16 3: [FritzBox|FRITZ!Box 7490|113.07.62|Readout_API_Check.11847] - BASIC:open Web_Connection succeeded
In the readings I get:
retStat_lastReadout     Error: [285 | BlockingKill] Timeout during API check. 2026-10-05 21:46:14
retStat_processReadout  0.01 s                                                2026-10-05 21:20:55
state                   Error: [285 | BlockingKill] Timeout during API check. 2026-10-05 21:46:24
I have another fhem instance running but I think that should be possible.
Google and a search on the forum didn't give me a clue
Anybody an idea what is wrong?
FHEM 6.4 auf Raspberry Pi3  (1,2 Ghz)
RFXTRX433XL, ZWave, KFL200 and ConBeeIII
Raspberry Pi1 (0,7 Ghz), Raspberry Pi4 and RaspberryPi 5 for testing
German reading skills are good.
HarryT
I see the message  https://forum.fhem.de/index.php?topic=145288.0 which has identical problems. But I see no solution for  me.
My fritzbox: 7490 with fritzos 7.62
The 72_FritzSmart module is from 2026-09-15
JoWiemann
Harry,
unfortunately, there is a bit too little information.
Please provide a list of the device and a log with verbose level 4.
Regards, Jörg
Jörg Wiemann
HarryT
Hi Jörg
Unfortunately it seems the issue solved itself.
For background, I did a complete fresh install. OS and Fhem. I rebooted several times but that didn't fix it. Now the raspberry was turned of for at least 30 minutes and rebooted to produce the list. Maybe there was an issue in the network which survived the reboots.
If you still want to investigate. I guess the list you want is:
https://docs.google.com/document/d/13gx-IoDjapLXwsU8HcsiWtaZt1SPZpHuHOzxF-i3OIE/edit?usp=sharing
The logging was, if I remember correct with verbose 5.
Thanks for your quick answer and all your work
