STV Pushnachricht anzeigen
Begonnen von nocomment, 26 März 2015, 15:32:40
nocomment
Ist es möglich bei dem STV Device
DeviceName
192.168.1.146:55000
FD
51
Host
192.168.1.146
MAC
b8:27:eb:41:e1:ee
MyIP
127.0.1.1
NAME
SamsungTV
NR
1363
PARTIAL
Port
55000
STATE
opened
TYPE
STV
Eine Nachricht auf dem TV anzeigen zu lassen ?
Vaild Commands:
STV] Invalid command call. Use any of:
0 1 2 3 4 5 6 7 8 9
11 12 3SPEED 4_3 16_9 AD ADDDEL ALT_MHP ANGLE ANTENA
ANYNET ANYVIEW APP_LIST ASPECT AUTO_ARC_ANTENNA_AIR AUTO_ARC_ANTENNA_CABLE AUTO_ARC_ANTENNA_SATELLITE AUTO_ARC_ANYNET_AUTO_START AUTO_ARC_ANYNET_MODE_OK AUTO_ARC_AUTOCOLOR_FAIL
AUTO_ARC_AUTOCOLOR_SUCCESS AUTO_ARC_CAPTION_ENG AUTO_ARC_CAPTION_KOR AUTO_ARC_CAPTION_OFF AUTO_ARC_CAPTION_ON AUTO_ARC_C_FORCE_AGING AUTO_ARC_JACK_IDENT AUTO_ARC_LNA_OFF AUTO_ARC_LNA_ON AUTO_ARC_PIP_CH_CHANGE
AUTO_ARC_PIP_DOUBLE AUTO_ARC_PIP_LARGE AUTO_ARC_PIP_LEFT_BOTTOM AUTO_ARC_PIP_LEFT_TOP AUTO_ARC_PIP_RIGHT_BOTTOM AUTO_ARC_PIP_RIGHT_TOP AUTO_ARC_PIP_SMALL AUTO_ARC_PIP_SOURCE_CHANGE AUTO_ARC_PIP_WIDE AUTO_ARC_RESET
AUTO_ARC_USBJACK_INSPECT AUTO_FORMAT AUTO_PROGRAM AV1 AV2 AV3 BACK_MHP BOOKMARK CALLER_ID CAPTION
CATV_MODE CHDOWN CHUP CH_LIST CLEAR CLOCK_DISPLAY COMPONENT1 COMPONENT2 CONTENTS CONVERGENCE
CONVERT_AUDIO_MAINSUB CUSTOM CYAN DEVICE_CONNECT DISC_MENU DMA DNET DNIe DNSe DOOR
DOWN DSS_MODE DTV DTV_LINK DTV_SIGNAL DVD_MODE DVI DVR DVR_MENU DYNAMIC
ENTER ENTERTAINMENT ESAVING EXIT EXT1 EXT2 EXT3 EXT4 EXT5 EXT6
EXT7 EXT8 EXT9 EXT10 EXT11 EXT12 EXT13 EXT14 EXT15 EXT16
EXT17 EXT18 EXT19 EXT20 EXT21 EXT22 EXT23 EXT24 EXT25 EXT26
EXT27 EXT28 EXT29 EXT30 EXT31 EXT32 EXT33 EXT34 EXT35 EXT36
EXT37 EXT38 EXT39 EXT40 EXT41 FACTORY FAVCH FF FF_ FM_RADIO
GAME GREEN GUIDE HDMI HDMI1 HDMI2 HDMI3 HDMI4 HELP HOME
ID_INPUT ID_SETUP INFO INSTANT_REPLAY LEFT LINK LIVE MAGIC_BRIGHT MAGIC_CHANNEL MDC
MENU MIC MORE MOVIE1 MS MTS MUTE NINE_SEPERATE OPEN PANNEL_CHDOWN
PANNEL_CHUP PANNEL_ENTER PANNEL_MENU PANNEL_POWER PANNEL_SOURCE PANNEL_VOLDOW PANNEL_VOLUP PANORAMA PAUSE PCMODE
PERPECT_FOCUS PICTURE_SIZE PIP_CHDOWN PIP_CHUP PIP_ONOFF PIP_SCAN PIP_SIZE PIP_SWAP PLAY PLUS100
PMODE POWER POWEROFF POWERON PRECH PRINT PROGRAM QUICK_REPLAY REC RED
REPEAT RESERVED1 RETURN REWIND REWIND_ RIGHT RSS RSURF SCALE SEFFECT
SETUP_CLOCK_TIMER SLEEP SOUND_MODE SOURCE SRS STANDARD STB_MODE STILL_PICTURE STOP SUB_TITLE
SVIDEO1 SVIDEO2 SVIDEO3 TOOLS TOPMENU TTX_MIX TTX_SUBFACE TURBO TV TV_MODE
UP VCHIP VCR_MODE VOLDOWN VOLUP WHEEL_LEFT WHEEL_RIGHT W_LINK YELLOW ZOOM1
ZOOM2 ZOOM_IN ZOOM_MOVE ZOOM_OUT connect
Patrick
Gerhard
FB6890LTE, cubietruck, orangePi, raspberry 2/3/4, HM/HMIP, shelly > 50, etc.
nocomment
Hallo Gerhard,
danke für die Antwort :)
Also weiter gebracht hat es mich jetzt nicht. Heißt es einfach das es keine Möglichkeit gibt, Tv Geräte die über Port 55000 laufen eine Pushnachricht zu schicken ?
Grüße aus der Mutterstadt  ;D
Gerhard
mann kann mehrere Instanzen anlegen (define SamsungTV1 STV ip-address 55000 ... dann define SamsungTV2 STV ip-address 52235 ...)
Messages, Email, Call etc. werde über den Port 52235, und andere Funktionen über den Port 55000 usw.
Guter Rat, nimm den rusamsung und entdeke das was dein TV unterstützt, und vor allem die richtigen Einstellunge vornehmen, AllShare, ServiceMsg oder wie auch immer das was dein tv unterstützt.
googst du: http://samsung.rainerullrich.de/
G
