Signalduino Entwicklung
Begonnen von thoffma3, 05 Juli 2015, 23:01:00
noxx
Hier etwas mehr Daten
2016.01.12 23:08:34 1: Including fhem.cfg
2016.01.12 23:08:34 3: telnetPort: port 7072 opened
2016.01.12 23:08:34 3: WEB: port 8083 opened
2016.01.12 23:08:34 3: WEBphone: port 8084 opened
2016.01.12 23:08:34 3: WEBtablet: port 8085 opened
2016.01.12 23:08:35 2: eventTypes: loaded 30 events from ./log/eventTypes.txt
keys on reference is experimental at ./FHEM/00_SIGNALduino.pm line 1345, <$fh> line 36.
keys on reference is experimental at ./FHEM/00_SIGNALduino.pm line 1524, <$fh> line 36.
2016.01.12 23:08:35 3: Opening sduino device /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
2016.01.12 23:08:35 3: Setting sduino serial parameters to 57600,8,N,1
2016.01.12 23:08:35 3: sduino device opened
2016.01.12 23:08:35 1: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0@57600
2016.01.12 23:08:35 3: Opening DenonX1000 device 192.168.1.101:23
2016.01.12 23:08:35 3: DenonX1000 device opened
2016.01.12 23:08:36 1: Including ./log/fhem.save
2016.01.12 23:08:36 4: initialUsbCheck exec usb create
2016.01.12 23:08:36 1: usb create starting
2016.01.12 23:08:37 4: ### ttyAMA0: checking if it is a CUL
2016.01.12 23:08:37 3: Probing CUL device /dev/ttyAMA0
2016.01.12 23:08:37 3: Can't open /dev/ttyAMA0: Permission denied
2016.01.12 23:08:37 4: cannot open the device
2016.01.12 23:08:37 4: ### ttyUSB0: checking if it is a TCM_ESP3
2016.01.12 23:08:37 4: ttyUSB0 is already used by the fhem device sduino
2016.01.12 23:08:37 1: usb create end
2016.01.12 23:08:37 0: Featurelevel: 5.7
2016.01.12 23:08:37 0: Server started with 19 defined entities (version $Id: fhem.pl 9893 2015-11-15 08:43:05Z rudolfkoenig $, os linux, user fhem, pid 988)
2016.01.12 23:08:37 4: SIGNALduino/msg READ:
2016.01.12 23:08:37 4: sduino: Get freeram called ...
2016.01.12 23:08:40 1: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 disconnected, waiting to reappear (sduino)
2016.01.12 23:08:41 4: Connection accepted from FHEMWEB:192.168.1.12:59720
2016.01.12 23:08:41 3: Setting sduino serial parameters to 57600,8,N,1
2016.01.12 23:08:41 1: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 reappeared (sduino)
2016.01.12 23:08:41 1: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0@57600
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59720 GET /; BUFLEN:0
2016.01.12 23:08:42 4: WEB: redirecting / to /fhem
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59720 GET /fhem; BUFLEN:0
2016.01.12 23:08:42 4: name: /fhem / RL:984 / text/html; charset=UTF-8 / Content-Encoding: gzip
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59720 GET /fhem/pgm2/style.css; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59720 => 304 Not Modified
2016.01.12 23:08:42 4: Connection accepted from FHEMWEB:192.168.1.12:59721
2016.01.12 23:08:42 4: Connection accepted from FHEMWEB:192.168.1.12:59722
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59721 GET /fhem/pgm2/jquery-ui.min.css; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59721 => 304 Not Modified
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59722 GET /fhem/pgm2/jquery.min.js; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59722 => 304 Not Modified
2016.01.12 23:08:42 4: Connection accepted from FHEMWEB:192.168.1.12:59723
2016.01.12 23:08:42 4: Connection accepted from FHEMWEB:192.168.1.12:59724
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59723 GET /fhem/pgm2/jquery-ui.min.js; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59723 => 304 Not Modified
2016.01.12 23:08:42 4: Connection accepted from FHEMWEB:192.168.1.12:59725
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59724 GET /fhem/pgm2/fhemweb.js; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59724 => 304 Not Modified
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59725 GET /fhem/pgm2/fhemweb_colorpicker.js; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59725 => 304 Not Modified
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59720 GET /fhem/pgm2/fhemweb_fbcalllist.js; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59722 GET /fhem/pgm2/fhemweb_readingsGroup.js; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59723 GET /fhem/pgm2/fhemweb_readingsHistory.js; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59721 GET /fhem/pgm2/fhemweb_knob.js; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59725 GET /fhem/pgm2/fhemweb_uzsu.js; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59720 GET /fhem/pgm2/defaultCommon.css; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59724 GET /fhem/pgm2/fhemweb_sortable.js; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59720 GET /fhem/images/default/icoEverything.png; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59722 GET /fhem/pgm2/dashboard_style.css; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59720 GET /fhem/images/default/fhemicon.png; BUFLEN:0
2016.01.12 23:08:42 4: FHEMWEB:192.168.1.12:59720 GET /fhem?XHR=1&inform=type=status;filter=;since=1452636521;fmt=JSON×tamp=1452636517359; BUFLEN:0
2016.01.12 23:08:45 4: Connection closed for FHEMWEB:192.168.1.12:59720: EOF
2016.01.12 23:08:45 4: FHEMWEB:192.168.1.12:59721 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2016-01.log; BUFLEN:0
2016.01.12 23:08:45 4: Connection closed for FHEMWEB:192.168.1.12:59721: EOF
2016.01.12 23:08:45 4: FHEMWEB:192.168.1.12:59723 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2016-01.log; BUFLEN:0
2016.01.12 23:08:46 4: FHEMWEB:192.168.1.12:59723 GET /fhem/FileLog_logWrapper?XHR=1&inform=type=status;filter=;since=1452636524;fmt=JSON×tamp=1452636520471; BUFLEN:0
2016.01.12 23:08:46 3: telnetForBlockingFn: port 54526 opened
2016.01.12 23:08:46 4: BlockingCall created child (998), uses telnetForBlockingFn to connect back
2016.01.12 23:08:46 4: BlockingCall created child (999), uses telnetForBlockingFn to connect back
ping: icmp open socket: Operation not permitted
2016.01.12 23:08:46 4: Connection accepted from telnet:127.0.0.1:46335
2016.01.12 23:08:46 4: Connection accepted from telnet:127.0.0.1:46336
2016.01.12 23:08:57 4: SIGNALduino/msg READ: MU;P0=-1025;P1=929;P2=-549;P3=428;D=0101012323032323210123032323210123230103210103212301230321232323032123232323010323232321230323210101010323232123012303212303232323232320;CP=3;
2016.01.12 23:08:57 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:08:57 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:08:57 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:08:57 4: SIGNALduino/msg READ: MC;LL=-1011;LH=939;SL=-520;SH=455;D=AE16174A2CF3E83154344E00;C=464;
2016.01.12 23:08:57 4: sduino: hideki protocol converted to hex: 7534BA8AF3BE30552C3900 with 96 bits, messagestart 0
2016.01.12 23:08:58 4: Hideki_Parse sduino incomming P12#7534BA8AF3BE30552C3900
2016.01.12 23:08:58 4: Hideki_Parse SensorTyp = 30 decodedString = 755cce9e15c250ff744b00
2016.01.12 23:08:58 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=21.5, humidity=50, bat=ok
2016.01.12 23:08:58 4: SIGNALduino/msg READ: MC;LL=-1007;LH=944;SL=-519;SH=455;D=AE16174A4CF3E83154377A00;C=466;
2016.01.12 23:08:58 4: sduino: hideki protocol converted to hex: 7534BA4AF3BE3055EC2F00 with 96 bits, messagestart 0
2016.01.12 23:08:58 4: Hideki_Parse sduino incomming P12#7534BA4AF3BE3055EC2F00
2016.01.12 23:08:58 4: Hideki_Parse SensorTyp = 30 decodedString = 755ccede15c250ff347100
2016.01.12 23:09:21 4: SIGNALduino/msg READ: MU;P0=-2984;P1=-505;P2=930;P3=-1018;P4=456;P5=230;D=01232321414341232141532153412321414323412323412143232143412143414141414141234141414121414143412321432323232321414143214141434123413;CP=4;
2016.01.12 23:09:21 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:09:21 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:09:21 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:09:22 4: SIGNALduino/msg READ: MC;LL=-1000;LH=939;SL=-512;SH=454;D=BB2E94566020F2D55AAE00;C=464;
2016.01.12 23:09:22 4: SIGNALduino/msg READ: MC;LL=-1016;LH=943;SL=-519;SH=451;D=E5D974A4B3010796AAE630;C=464;
2016.01.12 23:09:42 4: SIGNALduino/msg READ: MU;P0=-552;P1=-100;P2=928;P3=-1026;P4=426;D=01232320404340404023204340404023204043234023234020432043402040404340204040404323404040402043404023232323404040204320434020434040404040400;CP=4;
2016.01.12 23:09:42 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:09:42 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:09:42 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:09:42 4: SIGNALduino/msg READ: MC;LL=-1007;LH=949;SL=-519;SH=458;D=AE16174A2CF3E83154344E00;C=468;
2016.01.12 23:09:42 4: sduino: hideki protocol converted to hex: 7534BA8AF3BE30552C3900 with 96 bits, messagestart 0
2016.01.12 23:09:42 4: Hideki_Parse sduino incomming P12#7534BA8AF3BE30552C3900
2016.01.12 23:09:42 4: Hideki_Parse SensorTyp = 30 decodedString = 755cce9e15c250ff744b00
2016.01.12 23:09:42 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=21.5, humidity=50, bat=ok
2016.01.12 23:09:43 4: SIGNALduino/msg READ: MC;LL=-1002;LH=949;SL=-520;SH=457;D=AE16174A4CF3E83154377A00;C=468;
2016.01.12 23:09:43 4: sduino: hideki protocol converted to hex: 7534BA4AF3BE3055EC2F00 with 96 bits, messagestart 0
2016.01.12 23:09:43 4: Hideki_Parse sduino incomming P12#7534BA4AF3BE3055EC2F00
2016.01.12 23:09:43 4: Hideki_Parse SensorTyp = 30 decodedString = 755ccede15c250ff347100
2016.01.12 23:09:43 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=21.5, humidity=50, bat=ok
2016.01.12 23:09:57 4: Connection closed for FHEMWEB:192.168.1.12:59723: EOF
2016.01.12 23:09:57 4: FHEMWEB:192.168.1.12:59725 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2016-01.log; BUFLEN:0
2016.01.12 23:09:57 4: FHEMWEB:192.168.1.12:59725 GET /fhem/FileLog_logWrapper?XHR=1&inform=type=status;filter=;since=1452636596;fmt=JSON×tamp=1452636592281; BUFLEN:0
2016.01.12 23:10:08 4: SIGNALduino/msg READ: MC;LL=-1046;LH=902;SL=-557;SH=421;D=010796AAF790;C=440;
2016.01.12 23:10:09 4: SIGNALduino/msg READ: MU;P0=-558;P1=990;P3=415;P4=-1000;P5=646;D=001034301034303030303050145030303010303034301410341413;CP=3;
2016.01.12 23:10:09 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:10:09 4: Found matched Protocol id 9 -> CTW 600
2016.01.12 23:10:09 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:10:09 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:10:09 4: SIGNALduino/msg READ: MC;LL=-1044;LH=903;SL=-563;SH=422;D=ECBA52598083CB00;C=441;
2016.01.12 23:10:27 4: SIGNALduino/msg READ: MU;P0=-552;P1=928;P2=-1027;P3=424;D=001210303230303012103230303012103032123012123010321032301030303230103030303212303030301032303012121212303030103210323010323030303030304;CP=3;
2016.01.12 23:10:27 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:10:27 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:10:27 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:10:27 4: SIGNALduino/msg READ: MC;LL=-1009;LH=947;SL=-516;SH=459;D=AE16174A2CF3E83154344E00;C=468;
2016.01.12 23:10:27 4: sduino: hideki protocol converted to hex: 7534BA8AF3BE30552C3900 with 96 bits, messagestart 0
2016.01.12 23:10:27 4: Hideki_Parse sduino incomming P12#7534BA8AF3BE30552C3900
2016.01.12 23:10:27 4: Hideki_Parse SensorTyp = 30 decodedString = 755cce9e15c250ff744b00
2016.01.12 23:10:27 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=21.5, humidity=50, bat=ok
2016.01.12 23:10:28 4: SIGNALduino/msg READ: MC;LL=-1005;LH=951;SL=-519;SH=456;D=AE16174A4CF3E83154377A00;C=468;
2016.01.12 23:10:28 4: sduino: hideki protocol converted to hex: 7534BA4AF3BE3055EC2F00 with 96 bits, messagestart 0
2016.01.12 23:10:28 4: Hideki_Parse sduino incomming P12#7534BA4AF3BE3055EC2F00
2016.01.12 23:10:28 4: Hideki_Parse SensorTyp = 30 decodedString = 755ccede15c250ff347100
2016.01.12 23:10:28 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=21.5, humidity=50, bat=ok
2016.01.12 23:10:34 4: Closing inactive connection FHEMWEB:192.168.1.12:59722
2016.01.12 23:10:34 4: Closing inactive connection FHEMWEB:192.168.1.12:59724
2016.01.12 23:10:39 4: Connection accepted from FHEMWEB:192.168.1.12:59751
2016.01.12 23:10:39 4: FHEMWEB:192.168.1.12:59751 POST /fhem?cmd=save&XHR=1; BUFLEN:0
2016.01.12 23:10:39 4: name: /fhem?cmd=save&XHR=1 / RL:52 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2016.01.12 23:10:41 4: Connection closed for FHEMWEB:192.168.1.12:59725: EOF
2016.01.12 23:10:41 4: FHEMWEB:192.168.1.12:59751 GET /fhem?room=Unsorted; BUFLEN:0
2016.01.12 23:10:41 4: name: /fhem?room=Unsorted / RL:2054 / text/html; charset=UTF-8 / Content-Encoding: gzip
2016.01.12 23:10:41 4: Connection accepted from FHEMWEB:192.168.1.12:59752
2016.01.12 23:10:41 4: Connection closed for FHEMWEB:192.168.1.12:59751: EOF
2016.01.12 23:10:41 4: FHEMWEB:192.168.1.12:59752 GET /fhem?room=Unsorted; BUFLEN:0
2016.01.12 23:10:41 4: FHEMWEB:192.168.1.12:59752 GET /fhem?XHR=1&inform=type=status;filter=room=Unsorted;since=1452636640;fmt=JSON×tamp=1452636636098; BUFLEN:0
2016.01.12 23:10:47 4: Connection closed for FHEMWEB:192.168.1.12:59752: EOF
2016.01.12 23:10:47 4: Connection accepted from FHEMWEB:192.168.1.12:59754
2016.01.12 23:10:47 4: FHEMWEB:192.168.1.12:59754 GET /fhem?detail=HTPC; BUFLEN:0
2016.01.12 23:10:47 4: name: /fhem?detail=HTPC / RL:2275 / text/html; charset=UTF-8 / Content-Encoding: gzip
2016.01.12 23:10:47 4: FHEMWEB:192.168.1.12:59754 GET /fhem?cmd={ReadingsVal(%22HTPC%22,%22off%22,%22%22)}&XHR=1; BUFLEN:0
2016.01.12 23:10:47 4: name: /fhem?cmd={ReadingsVal(%22HTPC%22,%22off%22,%22%22)}&XHR=1 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2016.01.12 23:10:47 4: Connection accepted from FHEMWEB:192.168.1.12:59755
2016.01.12 23:10:47 4: FHEMWEB:192.168.1.12:59755 GET /fhem?cmd={AttrVal(%22HTPC%22,%22room%22,%22%22)}&XHR=1; BUFLEN:0
2016.01.12 23:10:47 4: name: /fhem?cmd={AttrVal(%22HTPC%22,%22room%22,%22%22)}&XHR=1 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2016.01.12 23:10:47 4: FHEMWEB:192.168.1.12:59754 GET /fhem?XHR=1&inform=type=status;filter=HTPC;since=1452636646;fmt=JSON×tamp=1452636642208; BUFLEN:0
2016.01.12 23:10:55 4: SIGNALduino/msg READ: MC;LL=-1037;LH=908;SL=-577;SH=413;D=A53598083CB557BC80;C=440;
2016.01.12 23:10:56 4: SIGNALduino/msg READ: MC;LL=-1037;LH=918;SL=-534;SH=436;D=BB2E94566020F2D55AAE00;C=451;
2016.01.12 23:10:56 4: SIGNALduino/msg READ: MC;LL=-1012;LH=929;SL=-503;SH=470;D=2ECBA52598083CB5573180;C=466;
2016.01.12 23:11:12 4: SIGNALduino/msg READ: MU;P0=-108;P1=-531;P2=933;P3=-1021;P5=436;D=01232321515351515123215351515123215153235123235121532153512151515351215151515323515151512153515123232323515151215321535121535151515151510;CP=5;
2016.01.12 23:11:12 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:11:12 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:11:12 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:11:12 4: SIGNALduino/msg READ: MC;LL=-1011;LH=939;SL=-520;SH=454;D=AE16174A2CF3E83154344E00;C=464;
2016.01.12 23:11:12 4: sduino: hideki protocol converted to hex: 7534BA8AF3BE30552C3900 with 96 bits, messagestart 0
2016.01.12 23:11:12 4: Hideki_Parse sduino incomming P12#7534BA8AF3BE30552C3900
2016.01.12 23:11:12 4: Hideki_Parse SensorTyp = 30 decodedString = 755cce9e15c250ff744b00
2016.01.12 23:11:12 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=21.5, humidity=50, bat=ok
2016.01.12 23:11:13 4: SIGNALduino/msg READ: MC;LL=-1008;LH=944;SL=-517;SH=455;D=AE16174A4CF3E83154377A00;C=466;
2016.01.12 23:11:13 4: sduino: hideki protocol converted to hex: 7534BA4AF3BE3055EC2F00 with 96 bits, messagestart 0
2016.01.12 23:11:13 4: Hideki_Parse sduino incomming P12#7534BA4AF3BE3055EC2F00
2016.01.12 23:11:13 4: Hideki_Parse SensorTyp = 30 decodedString = 755ccede15c250ff347100
2016.01.12 23:11:13 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=21.5, humidity=50, bat=ok
2016.01.12 23:11:23 4: SIGNALduino/msg READ: MC;LL=-1026;LH=927;SL=-535;SH=440;D=AE00888B8B6181117AAA00;C=455;
2016.01.12 23:11:23 4: sduino: hideki protocol converted to hex: 7580443A6D0C22BD5500 with 88 bits, messagestart 0
2016.01.12 23:11:23 4: Hideki_Parse sduino incomming P12#7580443A6D0C22BD5500
2016.01.12 23:11:23 4: Hideki_Parse SensorTyp = 14 decodedString = 7580cc4eb71466c7ff00
2016.01.12 23:11:23 4: sduino Sensor Typ 14 not supported, please report sensor information!
2016.01.12 23:11:23 4: Dropped (P12#7580443A6D0C22BD5500) due to short time or equal msg
2016.01.12 23:11:23 4: SIGNALduino/msg READ: MU;P0=-118;P1=138;P2=-517;P3=933;P4=-1018;P5=460;D=01012343432525452525252525252523452523452523452523432525254523432543254525252325452525252523452523452523432525252525452325452525252521;CP=5;
2016.01.12 23:11:23 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:11:23 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:11:23 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:11:24 4: SIGNALduino/msg READ: MC;LL=-1014;LH=939;SL=-526;SH=452;D=AE00888BAB61811178EC00;C=463;
2016.01.12 23:11:24 4: sduino: hideki protocol converted to hex: 758044BA6D0C223D3700 with 88 bits, messagestart 0
2016.01.12 23:11:24 4: Hideki_Parse sduino incomming P12#758044BA6D0C223D3700
2016.01.12 23:11:24 4: Hideki_Parse SensorTyp = 14 decodedString = 7580ccceb71466475900
2016.01.12 23:11:24 4: sduino Sensor Typ 14 not supported, please report sensor information!
2016.01.12 23:11:24 4: Dropped (P12#758044BA6D0C223D3700) due to short time or equal msg
2016.01.12 23:11:42 4: SIGNALduino/msg READ: MC;LL=-1008;LH=924;SL=-554;SH=438;D=4A6B3010796AAF7900;C=453;
2016.01.12 23:11:43 4: SIGNALduino/msg READ: MU;P0=-172;P1=-1014;P2=439;P3=-570;P4=720;P5=939;D=0123415323215123515123235151532123532123232323232351232323235323232123515321530;CP=2;
2016.01.12 23:11:43 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:11:43 4: Found matched Protocol id 9 -> CTW 600
2016.01.12 23:11:43 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:11:43 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:11:43 4: SIGNALduino/msg READ: MC;LL=-1018;LH=945;SL=-511;SH=454;D=2ECBA52598083CB5573180;C=466;
2016.01.12 23:11:57 4: SIGNALduino/msg READ: MU;P0=-544;P1=-1512;P2=935;P3=-1017;P4=432;D=01232320404340404023204340404023204043234023234020432043402040404340204040404323404040402043404023232323404040204320434020434040404040400;CP=4;
2016.01.12 23:11:57 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:11:57 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:11:57 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:11:57 4: SIGNALduino/msg READ: MC;LL=-1007;LH=945;SL=-520;SH=456;D=AE16174A2CF3E83154344E00;C=466;
2016.01.12 23:11:57 4: sduino: hideki protocol converted to hex: 7534BA8AF3BE30552C3900 with 96 bits, messagestart 0
2016.01.12 23:11:57 4: Hideki_Parse sduino incomming P12#7534BA8AF3BE30552C3900
2016.01.12 23:11:57 4: Hideki_Parse SensorTyp = 30 decodedString = 755cce9e15c250ff744b00
2016.01.12 23:11:57 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=21.5, humidity=50, bat=ok
2016.01.12 23:11:58 4: SIGNALduino/msg READ: MC;LL=-1007;LH=946;SL=-520;SH=457;D=AE16174A4CF3E83154377A00;C=467;
2016.01.12 23:11:58 4: sduino: hideki protocol converted to hex: 7534BA4AF3BE3055EC2F00 with 96 bits, messagestart 0
2016.01.12 23:11:58 4: Hideki_Parse sduino incomming P12#7534BA4AF3BE3055EC2F00
2016.01.12 23:11:58 4: Hideki_Parse SensorTyp = 30 decodedString = 755ccede15c250ff347100
2016.01.12 23:11:58 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=21.5, humidity=50, bat=ok
2016.01.12 23:12:21 4: SIGNALduino/msg READ: MU;P0=-529;P1=-152;P2=427;P3=-1022;P5=947;D=01232020202020205320202020532020202020202020202054;CP=2;
2016.01.12 23:12:21 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:12:21 4: Found matched Protocol id 9 -> CTW 600
2016.01.12 23:12:21 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:12:21 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:12:29 4: SIGNALduino/msg READ: MC;LL=-1033;LH=917;SL=-556;SH=421;D=A6B3010796AAF790;C=445;
2016.01.12 23:12:30 4: SIGNALduino/msg READ: MC;LL=-1053;LH=902;SL=-558;SH=414;D=AE5D974A2B3010796AAD5700;C=438;
2016.01.12 23:12:30 4: sduino: hideki protocol converted to hex: 75DDBA8ACD4078ADB5 with 81 bits, messagestart 0
2016.01.12 23:12:30 4: Hideki_Parse sduino incomming P12#75DDBA8ACD4078ADB5
2016.01.12 23:12:30 4: Hideki_Parse SensorTyp = 30 decodedString = 7567ce9e57c088f7df
2016.01.12 23:12:30 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=67, channel=3, temp=5.7, humidity=88, bat=ok
2016.01.12 23:12:30 4: SIGNALduino/msg READ: MU;P0=-104;P1=-552;P2=920;P3=-1033;P4=423;D=01232321414341232141432143412321414323412323412341232143412143414141414141234141414121414143412321432323232321414341214341412143413;CP=4;
2016.01.12 23:12:30 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:12:30 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:12:30 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:12:34 4: Closing inactive connection FHEMWEB:192.168.1.12:59755
2016.01.12 23:12:42 4: SIGNALduino/msg READ: MU;P0=-544;P1=-1010;P2=936;P4=433;D=01212120404140404021204140404021204041214021214020412041402040404140204040404121404040402041404021212121404040204120414020414040404040400;CP=4;
2016.01.12 23:12:42 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:12:42 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:12:42 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:12:42 4: SIGNALduino/msg READ: MC;LL=-1010;LH=944;SL=-520;SH=456;D=AE16174A2CF3E83154344E00;C=466;
2016.01.12 23:12:42 4: sduino: hideki protocol converted to hex: 7534BA8AF3BE30552C3900 with 96 bits, messagestart 0
2016.01.12 23:12:42 4: Hideki_Parse sduino incomming P12#7534BA8AF3BE30552C3900
2016.01.12 23:12:42 4: Hideki_Parse SensorTyp = 30 decodedString = 755cce9e15c250ff744b00
2016.01.12 23:12:42 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=21.5, humidity=50, bat=ok
2016.01.12 23:12:43 4: SIGNALduino/msg READ: MC;LL=-1008;LH=946;SL=-521;SH=455;D=AE16174A4CF3E83154377A00;C=466;
2016.01.12 23:12:43 4: sduino: hideki protocol converted to hex: 7534BA4AF3BE3055EC2F00 with 96 bits, messagestart 0
2016.01.12 23:12:43 4: Hideki_Parse sduino incomming P12#7534BA4AF3BE3055EC2F00
2016.01.12 23:12:43 4: Hideki_Parse SensorTyp = 30 decodedString = 755ccede15c250ff347100
2016.01.12 23:12:43 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=21.5, humidity=50, bat=ok
2016.01.12 23:13:16 4: SIGNALduino/msg READ: MC;LL=-1024;LH=916;SL=-526;SH=460;D=B9765D29ACC041E5AABDE400;C=458;
2016.01.12 23:13:16 4: SIGNALduino/msg READ: MU;P0=-2044;P1=232;P2=916;P3=-1024;P4=-583;P5=460;D=2324545354232454532453542324545323542323542453232453542453545454545454235454545424545453542324532323232324545453245454535423540144;CP=5;
2016.01.12 23:13:16 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:13:16 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:13:16 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:13:17 4: SIGNALduino/msg READ: MU;P0=-508;P1=-340;P2=942;P3=-991;P4=482;D=012340402323204340204340404040404023404040402040404340232043232323232043232323204043405;CP=4;
2016.01.12 23:13:17 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:13:17 4: Found matched Protocol id 9 -> CTW 600
2016.01.12 23:13:17 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:13:17 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:13:17 4: SIGNALduino/msg READ: MC;LL=-1025;LH=940;SL=-518;SH=442;D=C041E5AAB98C;C=460;
2016.01.12 23:13:40 4: sduino: Get freeram called ...
2016.01.12 23:13:43 1: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 disconnected, waiting to reappear (sduino)
2016.01.12 23:13:44 3: Setting sduino serial parameters to 57600,8,N,1
2016.01.12 23:13:44 1: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 reappeared (sduino)
2016.01.12 23:13:44 1: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0@57600
2016.01.12 23:14:03 4: SIGNALduino/msg READ: MU;P0=92;P1=-539;P2=911;P3=-1036;P5=428;D=123232151535123215153215351232101532351232351215323215351215351515151515123515151512151515351232153232323232151515321515153512350;CP=5;
2016.01.12 23:14:04 4: SIGNALduino/msg READ: MC;LL=-1007;LH=950;SL=-565;SH=432;D=CBA51598083CB500;C=460;
2016.01.12 23:14:04 4: SIGNALduino/msg READ: MC;LL=-1029;LH=930;SL=-523;SH=446;D=2ECBA52598083CB0;C=458;
2016.01.12 23:14:04 4: SIGNALduino/msg READ: MU;P1=928;P2=-1000;P4=446;P5=-523;D=424512154542154245121545421245121245124512154245154245454545454512454545451545454245121541211;CP=4;
2016.01.12 23:14:04 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:14:04 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:14:04 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:14:04 4: SIGNALduino/msg READ: MU;P0=224;P1=928;P2=-948;P4=489;P5=-523;D=424512154542154245121545421245121245124512154245154245454545454512454545451545454245121541210245;CP=4;
2016.01.12 23:14:04 4: SIGNALduino/msg READ: MC;LL=-1066;LH=902;SL=-523;SH=489;D=2ECBA52598083CBA;C=463;
2016.01.12 23:14:04 4: SIGNALduino/msg READ: MC;LL=-1066;LH=902;SL=-523;SH=472;D=2ECBA52598083CBA;C=457;
2016.01.12 23:14:04 4: SIGNALduino/msg READ: MU;P0=453;P1=908;P2=-1051;P5=-563;D=0205121505021502051215050212051212051205121502051502050505050505120505050515050502051215012102002120005020515020505150201;CP=0;
2016.01.12 23:14:04 4: SIGNALduino/msg READ: MU;P0=453;P1=908;P2=-1051;P4=50;P5=-563;D=02051215050215020512150502120512120512051215020515020505050505051205050505150505020512150121020021200050205150205051502045;CP=0;
2016.01.12 23:14:04 4: SIGNALduino/msg READ: MU;P0=414;P1=908;P2=-1051;P4=50;P5=-563;D=020512150502150205121505021205121205120512150205150205050505050512050505051505050205121501210200212000502051502050515020403;CP=0;
2016.01.12 23:14:04 4: SIGNALduino/msg READ: MU;P0=414;P1=908;P2=-1095;P4=83;P5=-563;D=020512150502150205121505021205121205120512150205150205050505050512050505051505050205121501210200212000502051502050515020404242;CP=0;
2016.01.12 23:14:12 4: SIGNALduino/msg READ: MU;P0=-1014;P1=-2852;P2=927;P4=-546;P5=426;D=01202024545054545420245054545420245450205420205424502450542454545054245454545020245450545424502020202054245024505420245450245450540;CP=5;
2016.01.12 23:14:12 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:14:12 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:14:12 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:14:12 4: SIGNALduino/msg READ: MC;LL=-1007;LH=945;SL=-522;SH=456;D=AE16174A2CF3EB8D54DB5900;C=466;
2016.01.12 23:14:13 4: SIGNALduino/msg READ: MC;LL=-1008;LH=946;SL=-519;SH=454;D=AE16174A4CF3EB8D54D86D00;C=466;
2016.01.12 23:14:26 4: SIGNALduino/msg READ: MC;LL=-1022;LH=934;SL=-534;SH=436;D=AE00888B8B6181117AAA00;C=456;
2016.01.12 23:14:26 4: sduino: hideki protocol converted to hex: 7580443A6D0C22BD5500 with 88 bits, messagestart 0
2016.01.12 23:14:26 4: Hideki_Parse sduino incomming P12#7580443A6D0C22BD5500
2016.01.12 23:14:26 4: Hideki_Parse SensorTyp = 14 decodedString = 7580cc4eb71466c7ff00
2016.01.12 23:14:26 4: sduino Sensor Typ 14 not supported, please report sensor information!
2016.01.12 23:14:26 4: SIGNALduino/msg READ: MU;P0=-1005;P1=-8360;P2=939;P4=-531;P5=444;D=01202024545054545454545454542054542054542054542024545450542024502450545454245054545454542054542054542024545454545054245054545454540;CP=5;
2016.01.12 23:14:26 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:14:26 4: Found matched Protocol id 9 -> CTW 600
2016.01.12 23:14:26 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:14:26 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:14:27 4: SIGNALduino/msg READ: MC;LL=-1014;LH=937;SL=-529;SH=449;D=AE00888BAB61811178EC00;C=461;
2016.01.12 23:14:27 4: sduino: hideki protocol converted to hex: 758044BA6D0C223D3700 with 88 bits, messagestart 0
2016.01.12 23:14:27 4: Hideki_Parse sduino incomming P12#758044BA6D0C223D3700
2016.01.12 23:14:27 4: Hideki_Parse SensorTyp = 14 decodedString = 7580ccceb71466475900
2016.01.12 23:14:27 4: sduino Sensor Typ 14 not supported, please report sensor information!
2016.01.12 23:14:27 4: Dropped (P12#758044BA6D0C223D3700) due to short time or equal msg
2016.01.12 23:14:50 4: SIGNALduino/msg READ: MC;LL=-1022;LH=929;SL=-543;SH=434;D=AE5D974A6B3010796AAF7900;C=454;
2016.01.12 23:14:50 4: sduino: hideki protocol converted to hex: 75DDBACACD4078ADF54F00 with 96 bits, messagestart 0
2016.01.12 23:14:50 4: Hideki_Parse sduino incomming P12#75DDBACACD4078ADF54F00
2016.01.12 23:14:50 4: Hideki_Parse SensorTyp = 30 decodedString = 7567ce5e57c088f71fd100
2016.01.12 23:14:50 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=67, channel=3, temp=5.7, humidity=88, bat=ok
2016.01.12 23:14:50 4: Dropped (P12#75DDBACACD4078ADF54F00) due to short time or equal msg
2016.01.12 23:14:51 4: SIGNALduino/msg READ: MC;LL=-1029;LH=913;SL=-523;SH=447;D=74A2B3010796AAD570;C=453;
2016.01.12 23:14:51 4: SIGNALduino/msg READ: MU;P0=-104;P1=-997;P2=484;P3=-508;P4=688;P5=925;D=01234153232151235151235123515321235321232323232323512323232353232321235153215151515153232123532123235321232;CP=2;
2016.01.12 23:14:51 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:14:51 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:14:51 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:14:57 4: SIGNALduino/msg READ: MC;LL=-1024;LH=935;SL=-538;SH=436;D=AE16174A6CF3EB8D54D97700;C=456;
2016.01.12 23:14:57 4: SIGNALduino/msg READ: MU;P0=-1011;P1=944;P2=-519;P3=455;D=0123230323232101230323232101232301032101032321012303212323230321232323230101232303232123010101010321230123012301012303210324;CP=3;
2016.01.12 23:14:57 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.12 23:14:57 4: Found matched Protocol id 9 -> CTW 600
2016.01.12 23:14:57 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.12 23:14:57 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.12 23:14:58 4: SIGNALduino/msg READ: MC;LL=-1008;LH=946;SL=-520;SH=454;D=AE16174A4CF3EB8D54D86D00;C=466;
2016.01.12 23:16:35 4: Connection closed for FHEMWEB:192.168.1.12:59754: EOF
2016.01.12 23:16:35 4: Connection accepted from FHEMWEB:192.168.1.12:59798
2016.01.12 23:16:35 4: FHEMWEB:192.168.1.12:59798 GET /fhem?room=Unsorted; BUFLEN:0
2016.01.12 23:16:35 4: name: /fhem?room=Unsorted / RL:2054 / text/html; charset=UTF-8 / Content-Encoding: gzip
2016.01.12 23:16:35 4: FHEMWEB:192.168.1.12:59798 GET /fhem/images/default/off.png; BUFLEN:0
2016.01.12 23:16:35 4: FHEMWEB:192.168.1.12:59798 => 304 Not Modified
2016.01.12 23:16:35 4: Connection accepted from FHEMWEB:192.168.1.12:59799
2016.01.12 23:16:35 4: FHEMWEB:192.168.1.12:59799 GET /fhem/images/default/on.png; BUFLEN:0
2016.01.12 23:16:35 4: FHEMWEB:192.168.1.12:59799 => 304 Not Modified
2016.01.12 23:16:35 4: FHEMWEB:192.168.1.12:59798 GET /fhem/icons/favicon; BUFLEN:0
2016.01.12 23:16:35 4: FHEMWEB:192.168.1.12:59798 GET /fhem?XHR=1&inform=type=status;filter=room=Unsorted;since=1452636994;fmt=JSON×tamp=1452636989835; BUFLEN:0
2016.01.12 23:18:31 4: Connection closed for FHEMWEB:192.168.1.12:59799: EOF
2016.01.12 23:18:43 4: sduino: Get freeram called ...
2016.01.12 23:18:46 1: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 disconnected, waiting to reappear (sduino)
2016.01.12 23:18:46 4: Connection closed for FHEMWEB:192.168.1.12:59798: EOF
2016.01.12 23:18:46 4: Connection accepted from FHEMWEB:192.168.1.12:59825
2016.01.12 23:18:46 4: FHEMWEB:192.168.1.12:59825 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2016-01.log; BUFLEN:0
pejonp
Zitat von: Sidey am 12 Januar 2016, 08:50:37
Auffällig ist, dass es oft Nachrichten mit 72 Bits gibt. Es sieht fast so aus, als ob der Sync fehlt oder das Signal hält nur irgendwo mittendrin auf geschnappt wurde, was dazu führt, dass es nicht interpretiert werden kann. Mich würde interessieren, ob direkt davor oder danach auch Signaldaten an FHEM übergeben wurde.
Leider fehlen im Log die Verbose 4 Meldungen und damit die Signaldaten.
Hattest Du für den Test den Manchester Decoder nun an oder aus?
Hallo Sidey,
habe einmal um .. den Manchester Decoder ausgeschaltet. Ich hoffe es sind jetzt brauchbare Daten dabei, wenn nicht sage einfach Bescheid.
2016.01.12 09:06:59 5: SW: CDC
2016.01.12 09:06:59 4: set sduino disableMessagetype manchesterMC CDC
Log-Datei gepackt.
Tschüß Jörg
LaCrossGW 868MHz:WT470+TFA+TX37-IT+EMT7110+W136+WH25A HP1003+WH2621
SignalD(CC1101):Bresser+WS-0101(868MHz WH1080)+Velux KLF200+MAX!+HM-MOD-UART:Smoke HM-SEC-SD+VITOSOLIC 200 RESOL VBUS-LAN+SolarEdge SE5K(Modbus)+Sonnen!eco8(10kWh)+TD3511+DRT710M(Modbus)+ZigBee+Z-Wave+MQTT+vitoconnect
GregPac
Ich habe mal eine Frage zu einem Update des Sduino.
Bei mir habe ich bereits 2 mal über Windows mit dem Programm Xloader eigentlich eine aktuelle Firmwar geflasht. Wenn ich den SDuino aufrufe erscheint aber weiterhin die Anzeige Wersion 3.1.8-HF2 vom 8 November. Mache ich hier was falsch oder wird die Version nicht fortgeschrieben?
Gibt es evtl. Fortschritte zu den Livolo Schaltern?
Greg
FHEM Raspberry, CUL V3 868 // FS-20 Aktoren, div. Funksteckdosen, Homebridge
pejonp
#843
Halo Greg,
bitte einmal in fhem dieses aufrufen: update all https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/dev-r32/controls_signalduino.txt
Danach den Signalduino flashen (siehe Bild). Danach einen Neustart von fhem-Server druchführen.
pejonp
Sidey
Hi Greg,
wenn Du auf die aktuelle Version aktualisiert hast, dann kannst Du Livolo mal testen.
Ich habe da etwas experimentelles eingebaut, was bislang noch nicht getestet wurde.
Achso, das Reading Version musst Du leider manuell mit Get Version aktualisieren.
Grüße Sidey
Maintainer von: SIGNALduino, SD_WS*, fhem-docker, alexa-fhem-docker, fhempy-docker, WebAuth, fhem-mcp, midea-mqtt, whatsmeow-mqtt, alexa-cookie-service
GregPac
Danke für die Rückmeldung.
Über FHEM flashen habe ich noch nicht ans laufen gebracht. Irgendwas stimmt mit meiner AVRDUDE Installation nicht. Daher hole ich mir nach einem Update die HEX Datei und flashe Sie mit Xloader.
Habe jetzt aktualisiert nach dem update all https......
Version V 3.2.0-b10 SIGNALduino - compiled at Dec 22 2015 23:24:35
Einschalten
2016.01.13 19:21:11 4: SIGNALduino/msg READ: MU;P0=105;P1=-260;P2=460;D=0101010101010101010101010101010121010101010101010101010101010101010101012101010101010101010101010101010101010101210101010101010101010101010101010101010121;CP=0;
2016.01.13 19:21:11 4: SIGNALduino/msg READ: MU;P0=-190;P1=182;P3=436;D=010101010101010101010101010101010101030101010101010;CP=1;
2016.01.13 19:21:11 4: SIGNALduino/msg READ: MU;P0=-175;P1=205;P3=454;D=01010101010101010101010103010101010101010101010101010101010101010301010101010101010101010101010101010101030101010101010101010101010101010101010103010101010101010101010101010101010101010301010101010101010101010101010101010101030101010101010;CP=1;O;
2016.01.13 19:21:11 4: SIGNALduino/msg READ: MU;P0=169;P1=-174;P2=460;D=012101010101010101010101010101010101010101210101010101010101010101010101;CP=0;
2016.01.13 19:21:11 4: SIGNALduino/msg READ: MU;P0=-189;P1=140;P2=470;D=01010101010101010101010101010101010101020101010101010101010101010101010101010102010101010101010101010101010101010201010101010101010101010101010101010101020101010101010101010101010101010101010102010101010101010101010101010101010101010201010;CP=1;O;
2016.01.13 19:21:11 4: SIGNALduino/msg READ: MU;P0=180;P1=-152;P2=-299;P3=475;D=01010101020101020201010101010101013101010101010101010101010101010101010101310101010101010101010101010101310101010101010101010101010101010101010131010101010101010101010101010101010101013101010101010101010101010101010101010101310101010101010;CP=0;O;
2016.01.13 19:21:11 4: SIGNALduino/msg READ: MU;P0=161;P1=-158;P2=476;D=0121010101010101010101010101010101010101012101010101010101010101010101010;CP=0;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=179;P1=-153;P2=476;D=01010101010101010101010101010101210101010101010101010101010101010101010121010101010101010101010101010101210101010101010101010101010101010101010121010101010101010101010101010101010101012101010101010101010101010101010101010101210101010101010;CP=0;O;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=-155;P1=163;P2=480;P3=-300;D=0101020131010101010101010101010101010101010102010101010101010101010101010101;CP=1;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=-153;P1=179;P2=480;D=010101010101010102010101010101010101010101010101010101010201010101010101;CP=1;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=-165;P1=146;P2=478;D=0101010101010101010101010201010101010101010101010101010101010101020101010;CP=1;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=477;P1=186;P2=-159;P3=-300;D=0121212021312121212121212121212121212121212121202121212121212121212121212121;CP=1;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=154;P1=-144;P2=476;D=0101010101010101012101010101010101010101010101010101010101210101010101;CP=0;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=-160;P1=184;P2=478;D=01010101010102010101010101010101010101010101010101010201010101010101010101010101010101010101020101010101010101010101010101010101020101010101010101010101010101010101010102010101010101010101010101010101010101010201010101010101010101010101010;CP=1;O;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=150;P1=-239;P2=479;D=01010101012101010101010101010101010101010101010101210101010101010101010101010101010101010121010101010101010101010101010101210101010101010101010101010101010101010121010101010101010101010101010101010101012101010101010101010101010101010101010;CP=0;O;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=-182;P1=146;P2=478;D=01020101010101010101010101010101010101010102010101010101010101010101010101010101010201010101010101010101010101010201010101010101010101010101010101010101020101010101010101010101010101010101010102010101010101010101010101010101010101010201010;CP=1;O;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=-184;P1=191;P2=480;D=0101010102010101010101010101010101010101010101010201010101010101010101010;CP=1;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=150;P1=-152;P2=-296;P3=476;D=01010201010101010101010131010101010101010101010101010101010101013101010101;CP=0;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=163;P1=-148;P3=480;D=0101010101010101010101010101010101010131010101010101010101010101010101;CP=0;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=229;P1=-227;P2=480;D=010101010121010101010101010101010101010101010101012101010101010101010101;CP=0;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=-159;P1=232;P2=139;P3=476;D=01020202010101030101010101010101010101010101010101010103010101010101010101010101010101010101010301010101010101010101010101010101010301010101010101010101010101010101010101030101010101010101010101010101010101010103010101010101010101010101010;CP=1;O;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=-162;P1=144;P3=476;D=01010101010101010101010103010101010101010101010101010101010101010301010;CP=1;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=-183;P1=192;P2=480;D=01010101010101010201010101010101010101010101010101010101020101010101010101010101010101010101010102010101010101010101010101010101010101020101010101010101010101010101010101010102010101010101010101010101010101010101010201010101010101010101010;CP=1;O;
2016.01.13 19:21:12 4: SIGNALduino/msg READ: MU;P0=143;P1=-224;P2=479;D=0101010101010101210101010101010101010101010101010101010121010101010101010101010101010101010101012101;CP=0;
2016.01.13 19:21:13 4: SIGNALduino/msg READ: MU;P0=2610;P1=-1057;P4=-2527;D=01040401010101040101001104010101010101010104010401040;CP=0;
2016.01.13 19:21:16 4: SIGNALduino/msg READ: MU;P0=164;P1=-263;P3=487;D=010101010101010101010101010131010101010101010101010101010101010101013101010101010101010101010101010101010101310101010101010101010101010101;CP=0;
2016.01.13 19:21:16 4: SIGNALduino/msg READ: MU;P0=-181;P1=137;P2=449;P3=-336;D=01010102010101010101010101010101010101010101010201010101010101310101310101010101010101020101010101010101010101010101010101010102010101010101010101010101010101010101010201010101010101010101010101010101010101020101010101010101010101010101010;CP=1;O;
2016.01.13 19:21:16 4: SIGNALduino/msg READ: MU;P0=-163;P1=136;P2=460;D=010101010101010102010101010101010101010101010101010101010201010101010;CP=1;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=-164;P1=226;P2=471;D=01010101010201010101010101010101010101010101010101020101010101010101010101010101010101010102010101010101010101010101010101010101010201010101010101010101010101010101010101020101010101010101010101010101010101010102010101010101010101010101010;CP=1;O;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=146;P1=-155;P2=-300;P3=474;D=010201010101010101010131010101010101010101010101010101010101013101010101;CP=0;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=-159;P1=136;P3=476;D=010101010101010101010101010103010101010101010101010101010101010101010;CP=1;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=-242;P1=142;P3=476;D=01010101010101010101010101010101030101010101010101010101010101010101010103010101010101010101010101010101010101010301010101010101010101010101010101010101030101010101010101010101010101010101010103010101010101010101010101010101010101010301010;CP=1;O;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=167;P1=-222;P2=478;D=01010101010101010101012101010101012101010101010101010101010101010101010101210101010101010101010101010121010101010101010101010101010101010101012101010101010101010101010101010101010101210101010101010101010101010101010101010121010101010101010;CP=0;O;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=-161;P1=144;P2=476;D=0101010101010101010101010101010201010101010101010101010101010101010101;CP=1;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=147;P1=-224;P2=479;D=01010101010101010101010101010101012101010101010101010101010101010101010101210101010101010101010101010101010101010121010101010101010101010101010101010101012101010101010101010101010101010101010101210101010101010101010101010101010101010121010;CP=0;O;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=234;P1=-158;P2=480;D=0121010101010101010101010101010101010101012101010101010101010101010101;CP=0;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=-183;P1=151;P2=479;D=01020101010101010101010101010101010101010102010101010101010101010101010101010101010201010101010101010101010101010101010101020101010101010101010101010101010101010102010101010101010101010101010101010101010201010101010101010101010101010101010;CP=1;O;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=-159;P1=162;P3=478;D=010101030101010101010101010101010101010101010103010101010101010101;CP=1;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=156;P1=-184;P3=479;D=01010101010101310101010101010101010101010101010101010131010101010101010101010101010101010101013101010101010101010101010101010101010101310101010101010101010101010101010101010131010101010101010101010101010101010101013101010101010101010101010;CP=0;O;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=149;P1=-162;P2=-296;P3=478;D=0102010101010101010101310101010101010101010101010101010101010131010101;CP=0;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=-261;P1=229;P3=477;D=01010101010101010101030101010101010101010101010101010101010103010101010101010101010101010101010101010301010101010101010101010101010101010301010101010101010101010101010101010101030101010101010101010101010101010101010103010101010101010101010;CP=1;O;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=148;P1=-259;P3=478;D=010101010101010101010101310101010101010101010101010101010101010131010;CP=0;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=182;P1=-151;P2=-296;P3=476;D=01010201010101010101010131010101010101010101010101010101010101013101010101010101010101010101010101010101310101010101010101010101010101010101010131010101010101010101010101010101010101013101010101010101010101010101010101010101310101010101010;CP=0;O;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=152;P1=-159;P2=480;D=0101010101010101010101010101010121010101010101010101010101010101010101;CP=0;
2016.01.13 19:21:17 4: SIGNALduino/msg READ: MU;P0=-146;P1=223;P3=477;D=01010101010101010101010103010101010101010101010101010101010101010301010101010101010101010101010101010101030101010101010101010101010101010101010103010101010101010101010101010101010101010301010101010101010101010101010101010101030101010101010;CP=1;O;
2016.01.13 19:21:18 4: SIGNALduino/msg READ: MU;P0=148;P1=-162;P3=476;P4=-32001;P5=3524;D=010101010101010101010101013101010101010101010101010101010101010101310101010101010101010101010101010101045;CP=0;
Ausschalten:
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=141;P1=-162;P2=473;D=00101010101010101010101010101210101010101010101010101010101010101010121010101010101010101010101010101010101012101010101010101010101010101010101010101210101010101010101010101010101010101010121010101010101010101010101010101010101012101010101;CP=0;O;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=124;P1=-206;P3=456;D=0101010101010131010101010101010101010101010101010101013101010;CP=0;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=155;P1=-172;P2=451;D=01010101010101010101010121010101010101010101010101010101010101012101010101010101010101010101010101010101210101010101010101010101010101010101010121010101010101010101010101010101010101012101010101010101010101010101010101010101210101010101010;CP=0;O;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=-236;P1=219;P2=-157;P3=467;D=01212101212101010101010103010101010101010101010101010101010101010301010101010101010101010101010101010101030101010101010101010101010101010301010101010101010101010101010101010101030101010101010101010101010101010101010103010101010101010101010;CP=1;O;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=139;P1=-166;P2=472;D=01010101010101010121010101010101010101012101010101010101012101010101010101010101010101010101010101210101010101010101010121010101010101010101010101010101010101012101010101010101010101010101010101010101210101010101010101010101010101010101010;CP=0;O;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=150;P1=-164;P3=476;D=01010101010101010101010101310101010101010101010101010101010101;CP=0;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=-149;P1=143;P3=473;D=01010101010101010101010101010101010103010101010101010101010101010101010101010301010101010101010101010101010101010101030101010101010101010101010101010101010103010101010101010101010101010101010101010301010101010101010101010101010101010101030;CP=1;O;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=150;P1=-149;P3=475;D=01010101010101010101010101010101010101010101010101010101010101010101010101010131010101010101010101010101010101010101010101010101010101010101010101013101010101010101010101010101010101010101310101010101010101010101010101010101010131010101010;CP=0;O;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=-228;P1=225;P2=136;P3=477;D=01020101010101010101010101010301010101010101010101010101010101010101030101010101010101010101010101010101010103010101010101010101010101010301010101010101010101010101010101010101030101010101010101010101010101010101010103010101010101010101010;CP=1;O;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=157;P1=-241;P2=480;D=010121010101010101010101010101010101010101012101010101010101010;CP=0;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=150;P1=-226;P2=479;D=01012101010101010101010101010101010101010101210101010101010101010101010101010101010121010101010101010101010101010101010101012101010101010101010101010101010101010101210101010101010101010101010101010101010121010101010101010101010101010101010;CP=0;O;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=-152;P1=145;P2=479;D=01010201010101010101010101010101010102010101010101010101010101010101010101010101010102010101010101010101010101010101020101010101010101010101010101010101010102010101010101010101010101010101010101010201010101010101010101010101010101010101020;CP=1;O;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=144;P1=-162;P2=-300;P3=480;D=010102010101010101010101310101010101010101010101010101010101010;CP=0;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=146;P1=-224;P2=482;D=01010101010101010101010101010101012101010101010101010101010101010101010101210101010101010101010101010101010101010121010101010101010101010101010101010101012101010101010101010101010101010101010101210101010101010101010101010101010101010121010;CP=0;O;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=142;P1=-145;P3=478;D=010101010101010101013101010101010101010101010101010101010101310;CP=0;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=143;P1=-152;P3=479;D=01010101010101010101010101013101010101010101010101010101010101010101310101010101010101010101010101010101010131010101010101010101010101010101010101013101010101010101010101010101010101010101310101010101010101010101010101010101010131010101010;CP=0;O;
2016.01.13 19:23:35 4: SIGNALduino/msg READ: MU;P0=-161;P1=161;P2=477;D=01010101010101010101010101010201010101010101010101010101010101010101020101010101010101010101010101010101010102010101010101010101010101010102010101010101010101010101010101010101010201010101010101010101010101010101010101020101010101010101010;CP=1;O;
2016.01.13 19:23:36 4: SIGNALduino/msg READ: MU;P0=161;P1=-160;P3=401;P4=-32001;P5=-580;D=010101010101010101013101010101010101010101010101010101010101310101010101010101010101010101010101010131010101010101010104353;CP=0;
2016.01.13 19:23:36 4: Found matched Protocol id 16 -> Dooya shutter
Greg
Burny4600
Hat sich bei den Oregon etwas geändert?
V 3.2.0-b10 SIGNALduino - compiled at Dec 22 2015 23:24:52
Die Sensoren werden wieder in dieser Form angelegt THGR810_e3_1 anstatt THGR810_1.
define sduino SIGNALduino /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03D7H7-if00-port0@57600
attr sduino alias SIGNALduino
attr sduino debug 1
attr sduino devStateIcon Initialized:cul_usb@green:Open Open:cul_usb@red:Initialized
attr sduino flashCommand avrdude -c arduino -b 57600 -P [PORT] -p atmega328p -vv -U flash:w:[HEXFILE] 2>[LOGFILE]
attr sduino hardware nano328
attr sduino icon cul_usb
attr sduino room _RxTx
attr sduino verbose 1
attr sduino whitelist_IDs 7,8,10
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
Pythonf
Ich habe heute ein Update auf die Dev32 Version aus dem Git gemacht und habe nun folgende angelegte Geräte mit denen ich nichts anfangen kann.
RSL_0BBF22_3_2
RSL_0BCF22_3_2
RSL_0BDF22_3_2
RSL_0BDF23_3_2
RSL_0BEF23_3_2
RSL_0BFF22_3_2
RSL_0BFF24_3_2
Ein Beispiel ist:
   CFGFN
   DEF        0BDF22_3_2
   IODev      sduino
   LASTInputDev sduino
   MSGCNT     2
   NAME       RSL_0BDF22_3_2
   NR         434
   OffCode    671866658
   OnCode     537648930
   STATE      off
   TYPE       SIGNALduino_RSL
   sduino_DMSG r6A80BDF22
   sduino_MSGCNT 2
   sduino_RAWMSG MS;P0=-503;P1=470;P2=-995;P3=-3919;D=13121010121012101210121212121212121012101010101210101010101212101212121012;CP=1;SP=3;O;
   sduino_TIME 2016-01-14 17:56:16
   Readings:
     2016-01-14 17:56:16   state           off
   Rsl_0bdf22_3_2:
   IODev      sduino
   room       SIGNALduino_RSL
Hat jemand eine Vermutung um was es sich handeln könnte.
Beste Grüße
Ralf9
Nein bei dem Oregon Modul hat sich nichts geändert. Hast Du in letzter Zeit das longids Attribut gelöscht?
Setze mal das longids Attribut auf 0
Das debug Attribut kannst Du löschen, dies wird im normalen Betrieb nicht benötigt.
Ist das OSV3 für Dich inzwischen brauchbar?
In welchem Abstand werden im Schnitt Werte in die Filelogs der Sensoren geschrieben?
Gruß Ralf
Burny4600
Danke für die Info.
Kann bei eventuell bei der Neuinstallation passiert sein, dass das longids Attribut verloren gegangen ist.
LG Chris
Burny4600
Trotz Eintrag longids Attribut auf 0 werden die Sensoren immer noch in der Form angelegt.
THGR810_e3_1
WGR800_b0
Sollten aber so aussehen:
THGR810_1
WGR800
LG Chris
Ralf9
THGR810_e3_1
WGR800_b0
THGR810_1
WGR800
bei mir funktioniert es
2016.01.15 19:59:58 4: Calling Getting Attr sub with args: set longids = 0
2016.01.15 20:00:25 4: sduinoD/msg get raw: MC;LL=-1059;LH=892;SL=-523;SH=395;D=7FFFFF5891200D0D03620420123300;C=428;
2016.01.15 20:00:25 4: sduinoD Found manchester Protocol id 10 clock 428 -> OSV2o3
2016.01.15 20:00:25 4: WGR800 decoded Oregon: W: 4.6 WA: 4.2 WD: 247.5  WDN: WSW  BAT: ok
Es gibt eine neue Version. Ich habe im Oregon Modul das event-min-interval und einen log-Eintrag zugefügt.
Gruß Ralf
noxx
Hallo
wie bekomme ich eigentlich raus, ob die Daten die SignalDuino empfängt, zu meiner
Wetterstation gehört?
Ich vermisse meinen Wind und Regenmesser :-) meiner TFA Nexus. Hier mal ein paar Auszüge
der LOG, hoffe damit kann einer was anfangen.
2016.01.15 20:45:44 4: SIGNALduino/msg READ: MU;P0=226;P1=-546;P2=450;P3=934;P4=-1033;P5=652;D=001212121212121213421312121242121212121212121212134212121212121212121212121212121212121212121212121212121212121210150;CP=2;
2016.01.15 20:45:44 4: SIGNALduino/msg READ: MU;P0=-216;P1=421;P2=-1021;P3=-595;P4=933;P5=226;D=01213134213431242131342131313424313131213131313131313131313421343131312135353132;CP=1;
2016.01.15 20:45:44 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.15 20:45:44 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.15 20:45:44 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.15 20:45:44 4: SIGNALduino/msg READ: MU;P0=-240;P1=410;P2=-538;P3=931;P4=-1039;D=0121212121212321412121212343212141234121212321413;CP=1;
2016.01.15 20:45:44 4: SIGNALduino/msg READ: MU;P0=-562;P1=-353;P2=931;P3=-1005;P4=435;D=01232040434040234020414340402340204323404023404023413;CP=4;
2016.01.15 20:45:44 4: SIGNALduino/msg READ: MU;P0=-535;P1=445;P3=931;P4=-1013;D=00101010101010103410101010101010101010101010101010101010101010101010101010101010103014101010103430143410101034103415;CP=1;
2016.01.15 20:45:44 4: SIGNALduino_unknown incomming msg: u16#00000000
2016.01.15 20:45:44 4: SIGNALduino_unknown rawData: 00000000
2016.01.15 20:45:44 4: SIGNALduino_unknown Protocol: 16
2016.01.15 20:45:44 4: SIGNALduino_unknown converted to bits: 00000000000000000000000000000000
2016.01.15 20:45:46 4: SIGNALduino/msg READ: MU;P0=-1320;P1=-989;P2=955;P4=-510;P5=465;D=01212124545154545421245154545421245451215421215424512454545454545451542454545451212154545454245121212121542154542154212451542121540;CP=5;
2016.01.15 20:45:46 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.15 20:45:46 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.15 20:45:46 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.15 20:45:46 4: Found matched Protocol id 9 -> CTW 600
2016.01.15 20:45:47 4: SIGNALduino/msg READ: MC;LL=-1006;LH=948;SL=-517;SH=459;D=AE16174A2FF3EA0D548B4B00;C=468;
2016.01.15 20:45:47 4: sduino: hideki protocol converted to hex: 7534BA8AFFBEC155D16900 with 96 bits, messagestart 0
2016.01.15 20:45:47 4: Hideki_Parse sduino incomming P12#7534BA8AFFBEC155D16900
2016.01.15 20:45:47 4: Hideki_Parse SensorTyp = 30 decodedString = 755cce9e01c243ff73bb00
2016.01.15 20:45:47 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=20.1, humidity=43, bat=ok
Hideki_10, Hideki_20, Hideki_30 sind Temperaturmesser...
Einhell Garagetor scheint vom Nachbarn zu sein, ich habe sowas nicht
2016.01.15 20:30:36 4: SIGNALduino/msg READ: MC;LL=-1077;LH=871;SL=-587;SH=391;D=AE4C974A687012396A295600;C=420;
2016.01.15 20:30:37 4: SIGNALduino/msg READ: MC;LL=-1042;LH=913;SL=-549;SH=423;D=AE4C974A487012396A28;C=445;
2016.01.15 20:30:37 4: sduino: hideki protocol converted to hex: 7599BA4AE14071AD14 with 80 bits, messagestart 0
2016.01.15 20:30:37 4: Hideki_Parse sduino incomming P12#7599BA4AE14071AD14
2016.01.15 20:30:37 4: Hideki_Parse SensorTyp = 30 decodedString = 75abcede23c093f73c
2016.01.15 20:30:37 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=ab, channel=4, temp=2.3, humidity=93, bat=ok
2016.01.15 20:30:46 4: SIGNALduino/msg READ: MU;P0=-1001;P1=-510;P2=953;P3=465;D=01202021313031313120213031313120213130203120203121302131313131313130312131313130202031313131213020202020312031312031202130312020310;CP=3;
2016.01.15 20:30:46 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.15 20:30:46 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.15 20:30:46 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.15 20:30:46 4: Found matched Protocol id 9 -> CTW 600
2016.01.15 20:30:47 4: SIGNALduino/msg READ: MC;LL=-1005;LH=948;SL=-517;SH=458;D=AE16174A2FF3EA0D548B4B00;C=468;
2016.01.15 20:30:47 4: sduino: hideki protocol converted to hex: 7534BA8AFFBEC155D16900 with 96 bits, messagestart 0
2016.01.15 20:30:47 4: Hideki_Parse sduino incomming P12#7534BA8AFFBEC155D16900
2016.01.15 20:30:47 4: Hideki_Parse SensorTyp = 30 decodedString = 755cce9e01c243ff73bb00
2016.01.15 20:30:47 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=20.1, humidity=43, bat=ok
2016.01.15 20:30:47 4: SIGNALduino/msg READ: MC;LL=-1020;LH=938;SL=-533;SH=440;D=AE16174A4FF3EA0D54887F00;C=459;
2016.01.15 20:30:47 4: sduino: hideki protocol converted to hex: 7534BA4AFFBEC155117F00 with 96 bits, messagestart 0
2016.01.15 20:30:47 4: Hideki_Parse sduino incomming P12#7534BA4AFFBEC155117F00
2016.01.15 20:30:47 4: Hideki_Parse SensorTyp = 30 decodedString = 755ccede01c243ff338100
2016.01.15 20:30:53 4: SIGNALduino/msg READ: MU;P0=-559;P1=-104;P2=922;P3=-1020;P4=430;D=012323204043404023402040434040234020432340402340402043402040434040404040404040404023404020404340404040404040404040234040404040404040404040404040404040404040404040404040404040404040404023404040234040234040404020432342;CP=4;
2016.01.15 20:30:53 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.15 20:30:53 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.15 20:30:53 4: SIGNALduino_unknown incomming msg: u16#000000000
2016.01.15 20:30:53 4: SIGNALduino_unknown rawData: 000000000
2016.01.15 20:30:53 4: SIGNALduino_unknown Protocol: 16
2016.01.15 20:30:53 4: SIGNALduino_unknown converted to bits: 000000000000000000000000000000000000
2016.01.15 20:30:53 4: SIGNALduino_unknown / shutter Dooya 000000000000000000000000000000000000 received
2016.01.15 20:30:53 4: SIGNALduino_unknown found shutter from Dooya. id=0, channel=0, direction=unknown, all_shutters=1
2016.01.15 20:30:53 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.15 20:30:53 4: SIGNALduino/msg READ: MU;P0=-144;P1=915;P2=-552;P3=433;P4=-1029;D=0123234323214321234143232143232321432123234323232323232323232321432321232343232323232323232323214323232323232323232323232323232323232323232323232323232323232323232321432323214323232323212343232143232;CP=3;
2016.01.15 20:30:53 4: Dropped (u16#000000000) due to short time or equal msg
2016.01.15 20:30:53 4: SIGNALduino/msg READ: MU;P0=-560;P1=421;P2=928;P3=-1020;D=0102010131010231020132310102310102310102010131010101010101010101023101020101310101010101010101010231010101010101010101010101010101010101010101010101010101010101010101023101010231010201310232310101012;CP=1;
2016.01.15 20:31:18 4: SIGNALduino/msg READ: MU;P0=120;P1=1248;P2=-1932;P3=1942;P4=-3914;D=01232343434323432323432343432343432323232323232323432323232343434343432323234323434323432323432323434343434343434323434343432323234343232323430;CP=3;
2016.01.15 20:20:26 4: SIGNALduino/msg READ: MU;P0=-547;P1=441;P2=-1025;P3=921;P4=-192;P5=1348;D=012101032103010121014521030123210103210101032103010121010101010101010101032101030101210101010101010101010321010101010101010101010101010101010101010101010101010101010101032103012101030121010321010101010103210;CP=1;
2016.01.15 20:20:26 4: SIGNALduino/msg READ: MU;P0=-216;P1=456;P2=-531;P3=927;P4=-1024;D=00123412321214121234123214341212341212341212321214121212121212121212123412123212141212121212121212121234121212121212121212121212121212121212121212121212121212121212123412321412123214123412341234321411;CP=1;
2016.01.15 20:20:26 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.15 20:20:26 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.15 20:20:26 4: SIGNALduino_unknown incomming msg: u16#00000000
2016.01.15 20:20:26 4: SIGNALduino_unknown rawData: 00000000
2016.01.15 20:20:26 4: SIGNALduino_unknown Protocol: 16
2016.01.15 20:20:26 4: SIGNALduino_unknown converted to bits: 00000000000000000000000000000000
2016.01.15 20:10:17 1: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 reappeared (sduino)
2016.01.15 20:10:17 1: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0@57600
2016.01.15 20:10:17 4: SIGNALduino/msg READ:
2016.01.15 20:10:17 4: Connection accepted from telnet:127.0.0.1:42908
2016.01.15 20:10:17 5: [HTPC] ping succesful - state = on
2016.01.15 20:10:17 5: [HTPC] WOL_SetNextTimer to 60
2016.01.15 20:10:17 5: [HTPC] removing Timer: HTPC_ping
2016.01.15 20:10:17 5: [HTPC] setting  Timer: HTPC_ping 2016-01-15 20:11:17
2016.01.15 20:10:17 5: [Server] ping succesful - state = on
2016.01.15 20:10:17 5: [Server] WOL_SetNextTimer to 60
2016.01.15 20:10:17 5: [Server] removing Timer: Server_ping
2016.01.15 20:10:17 5: [Server] setting  Timer: Server_ping 2016-01-15 20:11:17
2016.01.15 20:10:19 4: SIGNALduino/msg READ: MU;P0=-1007;P1=-188;P2=948;P3=-516;P4=459;D=01202023434043434343434343432043432043432043432023434043434343434343202043432340434343434320434320434343434343234340432343402020430;CP=4;
2016.01.15 20:10:19 4: SIGNALduino/msg READ: MU;P0=-32001;P1=922;P2=-1024;P3=-532;P4=441;D=01212134342434343434343434312434312434312434312134343424343434343431212434313424343434343124343124343434343431342434343431243434343430;CP=4;
2016.01.15 20:10:19 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.15 20:10:19 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.15 20:10:19 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.15 20:10:20 4: SIGNALduino/msg READ: MC;LL=-1013;LH=937;SL=-526;SH=452;D=AE00888BA05181101EAC00;C=462;
2016.01.15 20:10:20 4: sduino: hideki protocol converted to hex: 758044BAA00C22F03500 with 88 bits, messagestart 0
2016.01.15 20:05:16 4: SIGNALduino/msg READ: MC;LL=-1003;LH=947;SL=-513;SH=461;D=AE16174A67F3EA0D54096A00;C=469;
2016.01.15 20:05:17 4: SIGNALduino/msg READ: MC;LL=-1023;LH=928;SL=-532;SH=443;D=AE16174A27F3EA0D540B4400;C=456;
2016.01.15 20:05:17 4: sduino: hideki protocol converted to hex: 7534BA8AFEBEC155D01100 with 96 bits, messagestart 0
2016.01.15 20:05:17 4: Hideki_Parse sduino incomming P12#7534BA8AFEBEC155D01100
2016.01.15 20:05:17 4: Hideki_Parse SensorTyp = 30 decodedString = 755cce9e02c243ff703300
2016.01.15 20:05:17 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=5c, channel=2, temp=20.2, humidity=43, bat=ok
2016.01.15 20:05:17 4: SIGNALduino/msg READ: MC;LL=-1013;LH=939;SL=-524;SH=450;D=AE16174A47F3EA0D54087000;C=462;
2016.01.15 20:05:17 4: sduino: hideki protocol converted to hex: 7534BA4AFEBEC155100700 with 96 bits, messagestart 0
2016.01.15 20:05:17 4: Hideki_Parse sduino incomming P12#7534BA4AFEBEC155100700
2016.01.15 20:05:17 4: Hideki_Parse SensorTyp = 30 decodedString = 755ccede02c243ff300900
2016.01.15 20:05:17 4: SIGNALduino/msg READ: MC;LL=-1031;LH=916;SL=-547;SH=434;D=AE4C974A6F8012396A565300;C=449;
2016.01.15 20:05:17 4: sduino: hideki protocol converted to hex: 7599BACA1F4071AD6A6500 with 96 bits, messagestart 0
2016.01.15 20:05:17 4: Hideki_Parse sduino incomming P12#7599BACA1F4071AD6A6500
2016.01.15 20:05:17 4: Hideki_Parse SensorTyp = 30 decodedString = 75abce5e21c093f7beaf00
2016.01.15 20:05:17 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=ab, channel=4, temp=2.1, humidity=93, bat=ok
2016.01.15 20:05:17 4: SIGNALduino/msg READ: MC;LL=-1037;LH=916;SL=-553;SH=424;D=B9325D28BE0048E5A951F4;C=446;
2016.01.15 20:05:18 4: SIGNALduino/msg READ: MC;LL=-1038;LH=918;SL=-547;SH=425;D=AE4C974A4F8012396A574900;C=447;
2016.01.15 20:05:18 4: sduino: hideki protocol converted to hex: 7599BA4A1F4071ADEA with 73 bits, messagestart 0
2016.01.15 20:05:18 4: Hideki_Parse sduino incomming P12#7599BA4A1F4071ADEA
2016.01.15 20:05:18 4: Hideki_Parse SensorTyp = 30 decodedString = 75abcede21c093f73e
2016.01.15 20:05:18 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=ab, channel=4, temp=2.1, humidity=93, bat=ok
2016.01.15 20:05:35 4: SIGNALduino/msg READ: MU;P0=660;P1=-541;P2=432;P3=-1020;P4=929;D=012123212121212121212121214321214121232121212121212121212143214123212121212121212121212121212121212121212121212121212121212143212141212321432121432141234320;CP=2;
2016.01.15 20:05:35 4: Found matched Protocol id 8 -> TX3 Protocol
2016.01.15 20:05:35 4: Found matched Protocol id 16 -> Dooya shutter
2016.01.15 20:05:35 4: SIGNALduino_unknown incomming msg: u16#00000000
2016.01.15 20:05:35 4: SIGNALduino_unknown rawData: 00000000
2016.01.15 20:05:35 4: SIGNALduino_unknown Protocol: 16
2016.01.15 20:05:35 4: SIGNALduino_unknown converted to bits: 00000000000000000000000000000000
2016.01.15 20:05:35 4: Found matched Protocol id 21 -> einhell garagedoor
2016.01.15 20:05:35 4: SIGNALduino/msg READ: MU;P0=-532;P1=438;P2=927;P3=-1025;D=010201323101023101010231020101310101010101010101010231010201013101010101010101010102310201310101010101010101010101010101010101010101010101010101010102310102010131020131010231010231010;CP=1;
2016.01.15 20:05:35 4: Dropped (u16#00000000) due to short time or equal msg
2016.01.15 20:05:35 4: SIGNALduino/msg READ: MU;P0=-170;P1=921;P2=-553;P3=502;P4=-1051;P5=140;D=001232343232143212323432321432123414323214323214323212323432323232323232323232143232123234323232323232323232321432123250300;CP=3;
2016.01.15 20:05:35 4: SIGNALduino/msg READ: MU;P0=-168;P1=456;P2=-506;P3=944;P4=-1006;D=01212121212121212121212121212121212121212121212121212121234121232121412343432143412121213;CP=1;
2016.01.15 20:05:35 4: Found matched Protocol id 9 -> CTW 600
2016.01.15 20:00:11 4: SIGNALduino/msg READ:
2016.01.15 20:00:11 5: [Server] ping succesful - state = on
2016.01.15 20:00:11 5: [Server] WOL_SetNextTimer to 60
2016.01.15 20:00:11 5: [Server] removing Timer: Server_ping
2016.01.15 20:00:11 5: [Server] setting  Timer: Server_ping 2016-01-15 20:01:11
2016.01.15 20:00:18 4: SIGNALduino/msg READ: MU;P0=-1288;P1=-660;P2=1955;P3=-1952;P4=-3908;D=01232323232323232423232323242424242423232324232424232423232423232424242424242424232424242423232324242323232420;CP=2;
2016.01.15 20:00:23 4: SIGNALduino/msg READ: MC;LL=-1077;LH=877;SL=-584;SH=391;D=B9325D29BE0048E5A9594C;C=422;
2016.01.15 20:00:23 4: SIGNALduino/msg READ: MC;LL=-1039;LH=913;SL=-549;SH=425;D=5C992E945F002472D4A8FA00;C=445;
2016.01.15 20:00:24 4: SIGNALduino/msg READ: MC;LL=-1038;LH=913;SL=-551;SH=427;D=AE4C974A4F8012396A574900;C=446;
2016.01.15 20:00:24 4: sduino: hideki protocol converted to hex: 7599BA4A1F4071ADEA with 73 bits, messagestart 0
2016.01.15 20:00:24 4: Hideki_Parse sduino incomming P12#7599BA4A1F4071ADEA
2016.01.15 20:00:24 4: Hideki_Parse SensorTyp = 30 decodedString = 75abcede21c093f73e
2016.01.15 20:00:24 4: sduino decoded Hideki protocol model=Hideki_30, sensor id=ab, channel=4, temp=2.1, humidity=93, bat=ok
Sidey
Tia, schwierig. Deine Station wird vermutlich keinen Sender haben. Bleiben also die Sensoren.
Werden die Temperaturen dieser Sensoren denn in der Station angezeigt?
Nach meinen Recherchen empfängt die Station das Hideki Protokoll. Also senden Wind und Regenmesser mit diesem Protokoll.
Suche in deinem Log doch bitte mal nach folgenden Meldungen:
crc failed
decrypt failed
Sensor Typ ...... not supported, please report sensor information!
Achso, welche Version des SIGNALduino setzt Du ein?
Grüße Sidey
Sidey
ich habe die Firmware 3.2.0-b11 in den dev-32 Zweig geladen.
Es gibt ein paar Änderungen, die sich bei mir sehr positiv ausgewirkt haben:
1. Ich habe auf eine andere Entwicklungsumgebung umgestellt. Die Firmware wird nun mit neuen toolchains und librarys compiliert.
Durch den Einsatz aktuellere Librarys, sind (hoffentlich) auch weniger Fehler enthalten.
2. Habe ich den code etwas entrümpelt und zusammengefasst.
Letztlich habe ich damit ein paar Aufrufe und etwas speicher gespart.
3. Habe ich mir erlaubt, sobald 32000 mikrosekunden lang nichts mehr empfangen wurde die Messung zu unterbrechen um die Daten umgehend verarbeiten zu können.
Das hilft um Daten an FHEM zu übertragen, sobald die Übertragung beendet ist.
Zumindest kann ich feststellen, dass der Arduino seit 3 Tagen durchläuft ohne reconnects oder ähnliches.
Der Empfang funktioniert mindestens so gut wie vorher.
Ich habe weniger Probleme festgestellt, wenn ein get Befehl abgesendet wird.
Grüße Sidey
