Funktionsanfrage: hminfo erweiterungen firmware Versionsprüfung
Begonnen von no_Legend, 18 Januar 2016, 11:44:07
DK4RST
#225
kann es daran liegen das meine HM Dvices anders heissen bzw ip devices sind?
hier meine homematic Devices
HMCCUDEV
HM_Fenster_WZ Initialized
HM_Garage initialized
HM_HM_RCV_50_BidCoS_RF Initialized
HM_HM_RC_4_3_NEQ1138746 Initialized
HM_HM_RC_4_3_NEQ1138768Initialized
HM_HmIP_FAL24_C6_000615699CED0A Initialized
HM_WZ_T_r Initialized
HM_Wohnzimmer_Taster Initialized
Heizung und Temperatur
HM_Bad_oben_Therm measured-temp: HM_Bad_oben_Therm.1.ACTUAL_TEMPERATURE
HM_Roland_Therm Initialized
HM_Schlafzimmer_Therm Initialized
HM_Wohnzimmer_Therm Initialized
hier das List des eq3:
[code][code]#Internals:
   BUSY       0
   DEF        http://www.eq-3.de/service/downloads.html 86400
   Interval   86400
   LASTSEND   1520078906.24196
   MainURL    http://www.eq-3.de/service/downloads.html
   MaxAgeEnabled 1
   ModuleVersion 3.4.2 - 10.2.2018
   NAME       eq3
   NR         136
   STATE      <div style="text-align:left">last <a title="eq3-downloads" href="http://www.eq-3.de/downloads.html">homematic</a>-fw-check => 2018-03-03 13:08:27<br><br><pre>| device                  | model                   | old_fw | new_fw | release    |
| no fw-updates needed!                                                            |</pre></div>
   TRIGGERTIME 1520165087.1851
   TRIGGERTIME_FMT 2018-03-04 13:04:47
   TYPE       HTTPMOD
   addr       http://www.eq-3.de:80
   auth       0
   code       200
   compress   1
   conn
   data       suchtext=&suche_in=2&downloadart=11
   displayurl http://www.eq-3.de/service/downloads.html
   header
   host       www.eq-3.de
   httpheader HTTP/1.1 200 OK
Date: Sat, 03 Mar 2018 12:08:26 GMT
Server: Apache/2.4.6 (Red Hat Enterprise Linux) OpenSSL/1.0.1e-fips mod_fcgid/2.3.9
X-Powered-By: PHP/5.6.5
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Expires: Fri, 06 Jun 1975 15:10:00 GMT
Vary: User-Agent
Set-Cookie: PHPSESSID=06bq9je0hdt9re0m9ki5o51eg6; path=/; HttpOnly
Set-Cookie: BE_USER_AUTH=ae5b0c247daaba8a62ad4e3c163a8697177d5329; expires=Fri, 02-Mar-2018 12:08:26 GMT; Max-Age=-86400; path=/; httponly
Set-Cookie: FE_USER_AUTH=c806238b130743716a532b36af07a01675e3a667; expires=Fri, 02-Mar-2018 12:08:26 GMT; Max-Age=-86400; path=/; httponly
Last-Modified: Sat, 03 Mar 2018 12:08:26 GMT
Connection: close
Content-Type: text/html; charset=utf-8
   httpversion 1.0
   hu_blocking 0
   hu_filecount 3
   hu_port    80
   hu_portSfx
   ignoreredirects 0
   loglevel   4
   path       /service/downloads.html
   protocol   http
   redirects  0
   timeout    2
   value      0
   QUEUE:
     2018-03-03 13:08:27   LAST_REQUEST    update
     2018-03-03 13:08:27   MATCHED_READINGS fw_link-01 fw_link-02 fw_link-03 fw_link-04 fw_link-05 fw_link-06 fw_link-07 fw_link-08 fw_link-09 fw_link-10 fw_link-11 fw_link-12 fw_link-13 fw_link-14 fw_link-15 fw_link-16 fw_link-17 fw_link-18 fw_link-19 fw_link-20
     2018-03-03 13:08:27   UNMATCHED_READINGS
     2018-03-03 13:08:27   fw_link-01      http://www.eq-3.de/Downloads/Software/Firmware/hm-mod-re-8_update_V1_2_150911.tgz
     2018-03-03 13:08:27   fw_link-02      http://www.eq-3.de/Downloads/Software/Firmware/hm_dis_ep_wm55_update_V1_2_170129.tgz
     2018-03-03 13:08:27   fw_link-03      http://www.eq-3.de/Downloads/Software/Firmware/HM-LC-Bl1PBU-FM_update_V2_11_1_161212.tgz
     2018-03-03 13:08:27   fw_link-04      http://www.eq-3.de/Downloads/Software/Firmware/HM-ES-PMSw1-Pl-DN-R1_update_V2_5_0009_150217.tgz
     2018-03-03 13:08:27   fw_link-05      http://www.eq-3.de/Downloads/Software/Firmware/HM-Sen-MDIR-WM55_update_V1_2_0_160825.tgz
     2018-03-03 13:08:27   fw_link-06      http://www.eq-3.de/Downloads/Software/Firmware/HM-ES-TX-WM_update_V1_2_160628.tgz
     2018-03-03 13:08:27   fw_link-07      http://www.eq-3.de/Downloads/Software/Firmware/hm-ou-cfm-tw_update_V1_3_160620.tgz
     2018-03-03 13:08:27   fw_link-08      http://www.eq-3.de/Downloads/Software/Firmware/HM-ES-TX-WM_update_V1_1_160318.tgz
     2018-03-03 13:08:27   fw_link-09      http://www.eq-3.de/Downloads/Software/Firmware/HM-LC-Dim1PWM-CV_update_V2_9_0005_150730.tar.gz
     2018-03-03 13:08:27   fw_link-10      http://www.eq-3.de/Downloads/Software/Firmware/HM-LC-Dim1L-Pl-3_update_V2_9_0007_150803.tar.gz
     2018-03-03 13:08:27   fw_link-11      http://www.eq-3.de/Downloads/Software/Firmware/HM-LC-Dim1TPBU-FM_update_V2_9_0005_150730.tar.gz
     2018-03-03 13:08:27   fw_link-12      http://www.eq-3.de/Downloads/Software/Firmware/HM-LC-Dim1T-Pl-3_update_V2_9_0005_150730.tar.gz
     2018-03-03 13:08:27   fw_link-13      http://www.eq-3.de/Downloads/Software/Firmware/hm-mod-re-8_update_V1_2_150911.tgz
     2018-03-03 13:08:27   fw_link-14      http://www.eq-3.de/Downloads/Software/Firmware/hm_tc_it_wm_w_eu_update_V1_3_002_150827.tgz
     2018-03-03 13:08:27   fw_link-15      http://www.eq-3.de/Downloads/Software/Firmware/HM-LC-Sw1PBU-FM_update_V2_8_2_150713.tgz
     2018-03-03 13:08:27   fw_link-16      http://www.eq-3.de/Downloads/Software/Firmware/HM-Sen-MDIR-WM55_update_V1_1_2_150413.tgz
     2018-03-03 13:08:27   fw_link-17      http://www.eq-3.de/Downloads/Software/Firmware/HM-ES-PMSw1-Pl_update_V2_5_0009_150217.tgz
     2018-03-03 13:08:27   fw_link-18      http://www.eq-3.de/Downloads/Software/Firmware/hm_cc_rt_dn_update_V1_4_001_141020.tgz
     2018-03-03 13:08:27   fw_link-19      http://www.eq-3.de/Downloads/Software/Firmware/hm-sen-rd-o_update_V1_4_003_130930.tgz
     2018-03-03 13:08:27   fw_link-20      http://www.eq-3.de/Downloads/Software/Firmware/HM-LC-Bl1PBU-FM_update_V2_3_0002_131204.tgz
     2018-03-03 13:08:27   newFwForDevices no fw-updates needed!
   REQUEST:
     header
     ignoreredirects 0
     retryCount 0
     type       update
     value      0
   defptr:
     readingBase:
       fw_link-01 reading
       fw_link-02 reading
       fw_link-03 reading
       fw_link-04 reading
       fw_link-05 reading
       fw_link-06 reading
       fw_link-07 reading
       fw_link-08 reading
       fw_link-09 reading
       fw_link-10 reading
       fw_link-11 reading
       fw_link-12 reading
       fw_link-13 reading
       fw_link-14 reading
       fw_link-15 reading
       fw_link-16 reading
       fw_link-17 reading
       fw_link-18 reading
       fw_link-19 reading
       fw_link-20 reading
     readingNum:
       fw_link-01 01
       fw_link-02 01
       fw_link-03 01
       fw_link-04 01
       fw_link-05 01
       fw_link-06 01
       fw_link-07 01
       fw_link-08 01
       fw_link-09 01
       fw_link-10 01
       fw_link-11 01
       fw_link-12 01
       fw_link-13 01
       fw_link-14 01
       fw_link-15 01
       fw_link-16 01
       fw_link-17 01
       fw_link-18 01
       fw_link-19 01
       fw_link-20 01
     readingOutdated:
     readingSubNum:
       fw_link-01 -1
       fw_link-02 -2
       fw_link-03 -3
       fw_link-04 -4
       fw_link-05 -5
       fw_link-06 -6
       fw_link-07 -7
       fw_link-08 -8
       fw_link-09 -9
       fw_link-10 -10
       fw_link-11 -11
       fw_link-12 -12
       fw_link-13 -13
       fw_link-14 -14
       fw_link-15 -15
       fw_link-16 -16
       fw_link-17 -17
       fw_link-18 -18
       fw_link-19 -19
       fw_link-20 -20
     requestReadings:
       update:
         fw_link-01 reading 01-1
         fw_link-02 reading 01-2
         fw_link-03 reading 01-3
         fw_link-04 reading 01-4
         fw_link-05 reading 01-5
         fw_link-06 reading 01-6
         fw_link-07 reading 01-7
         fw_link-08 reading 01-8
         fw_link-09 reading 01-9
         fw_link-10 reading 01-10
         fw_link-11 reading 01-11
         fw_link-12 reading 01-12
         fw_link-13 reading 01-13
         fw_link-14 reading 01-14
         fw_link-15 reading 01-15
         fw_link-16 reading 01-16
         fw_link-17 reading 01-17
         fw_link-18 reading 01-18
         fw_link-19 reading 01-19
         fw_link-20 reading 01-20
   sslargs:
   enableControlSet 1
   event-on-change-reading .*
   event-on-update-reading LAST_ERROR,MATCHED_READINGS
   reading01AutoNumLen 2
   reading01Format http://www.eq-3.de/%s
   reading01Name fw_link
   reading01RegOpt g
   reading01Regex <a.href="(Downloads\/Software\/Firmware\/[^"]+)
   readingMaxAge 10
   readingMaxAgeReplacementMode delete
   requestData.* suchtext=&suche_in=2&downloadart=11
   room       eq3
   showError  1
   showMatched 1
   stateFormat {eq3StateFormat}
   userReadings newFwForDevices:MATCHED_READINGS:.* {
  my $ret = "";
  my @data;
  my @eq3FwList = map{@data = ReadingsVal("eq3","fw_link-".$_,"?") =~ m/Firmware\/(.*?)_update_V([\d_]+)_(\d\d)(\d\d)(\d\d)/;
            $data[0] =~ s/_/-/g;
            sprintf("%s:%s:%s.%s.%s:%s",$data[0],$data[1],$data[4],$data[3],"20".$data[2],$_);
            } ReadingsVal("eq3","MATCHED_READINGS","?") =~ m/fw_link-(\d\d)/g;
  foreach my $dev (devspec2array("TYPE=CUL_HM:FILTER=DEF=......:FILTER=subType!=(virtual|)")) {
    my $md = AttrVal($dev,"model","?");
    my $v = AttrVal($dev,"firmware","0.0");
    my ($h,$l) = split('\.',$v);
    foreach my $newFw (grep m/^${md}:/i,@eq3FwList) {
      my ($nh,$nl,$no,$date,$idx) = $newFw =~ m/^[^:]+:(\d+)_(\d+)_?(\d*):([^:]+):(\d\d)$/;
      if(($nh > $h) || (($nh == $h) && ($nl > $l))) {
        $ret .= "," if($ret ne "");
        $ret .= $dev." (".$md." | fw_".$v." => fw".$idx."_".$nh.".".$nl.($no?sprintf(".%d",$no):"")." | ".$date.")";
  return ($ret eq "")?"no fw-updates needed!":$ret;
   userattr   enableControlSet event-on-change-reading event-on-update-reading reading01AutoNumLen reading01Format reading01Name reading01RegOpt reading01RegOpt:s,i,g reading01Regex readingMaxAge readingMaxAgeReplacementMode readingMaxAgeReplacementMode:text,expression,delete readingMaxAgeReplacementMode:text,reading,internal,expression,delete requestData.* showError showMatched stateFormat userReadings webCmd
   webCmd     reread
[/code][/code]
Hatte ich wieder den Hinweis auf die CodeTags vergessen: die # taste über dem  :-X Smiley. Also list bitte in Codetags!
:o ::) :'(
Das eq3 Gerät selbst sieht gut aus, siehe Readings. Aber dieses Konstrukt ist eben nur für CUL_HM und classic Homematic!
Hinweis: Nicht alle HM Geräte unterstützen auch ein Firmware Update!
Du hast eine CCU2 und arbeitest mit HMCCU ? Völlig falsch hier  :o
HMIP -> nur über CCU2
So wie ich das sehe musst Du die Updates über die CCU2 machen
DK4RST
ok, schade , das sah sehr gut aus, bist Du sicher das es mit der ccu2 und meinen Devices nicht geht?
und dann noch eine allgemeine Frage, mit dem Hinweis
"Hatte ich wieder den Hinweis auf die CodeTags vergessen: die # taste über dem  :-X Smiley. Also list bitte in Codetags!
:o ::) :'("
kann ich nix anfangen, kannst Du mir das etwas ausführlicher beschreiben??
und eine 2 Frage , gibt es hier im Forum eine möglichkeit die Member anzuschreiben die in meiner Umgebung wohnen, um eventuell mal ein Treffen zu aragieren, wenn Sie möchten??
Roland
#228
Nein ich bin mir nicht sicher, es gibt sicher einen Weg es zum Laufen zu bringen. Aber die eq3 Definition aus dem Wiki bedient sich Funktionen des Moduls CUL_HM und dies setzt Du nicht ein - oder?
Ob das jemand für HMCCU gemacht hat - keine Ahnung. Ich habe das nicht ...
Mit Codes sieht der Code dann so aus. Und lange Listings erhalten Fenster zum scrollen
So hier:
   BUSY       0
   Interval   86400
   LASTSEND   1520034300.0046
   MaxAgeEnabled 1
   ModuleVersion 3.3.11 - 8.5.2017
   NAME       eq3
   NR         500
   STATE      <div style="text-align:left">last <a title="eq3-downloads" href="http://www.eq-3.de/downloads.html">homematic</a>-fw-check => 2018-03-03 00:45:00<br><br><pre>| device                  | model                   | old_fw | new_fw | release    |
   TRIGGERTIME 1520120700
   TRIGGERTIME_FMT 2018-03-04 00:45:00
   TYPE       HTTPMOD
   TimeAlign  1517096700
   TimeAlignFmt 2018-01-28 00:45:00
   buf        HTTP/1.1 200 OK
Date: Fri, 02 Mar 2018 23:45:00 GMT
Pragma: no-cache
Vary: User-Agent
Set-Cookie: PHPSESSID=vilslm7pvinj45p7mg95dab5b3; path=/; HttpOnly
Set-Cookie: BE_USER_AUTH=36cb2d03ce3564a796c522678436889c1eee4685; expires=Thu, 01-Mar-2018 23:45:00 GMT; Max-Age=-86400; path=/; httponly
Set-Cookie: FE_USER_AUTH=3bd38e5c6a401181fc5bec8cce8c4562e870001e; expires=Thu, 01-Mar-2018 23:45:00 GMT; Max-Age=-86400; path=/; httponly
Last-Modified: Fri, 02 Mar 2018 23:45:00 GMT
Connection: close
<!DOCTYPE html>
<html lang="de" class="desktop no-touch unterseite pageDownloads">
<head>
      <meta charset="utf-8">
    <title>Downloads - eQ-3</title>
    <base href="http://www.eq-3.de/">
    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0, shrink-to-fit=no" />
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta http-equiv="cache-control" content="max-age=60" />
<meta http-equiv="expires" content="60" />
<meta http-equiv="pragma" content="60" />
<meta name="google-site-verification" content="xZ5If63u1_b0X9LtJPLkl5NIhCEIbRk0civLFG5ZFe4" />
<link rel="icon" type="image/vnd.microsoft.icon" href="/favicon.png" />
<link rel="shortcut icon" type="image/vnd.microsoft.icon" href="/favicon.png" />
<link rel="shortcut icon" type="image/x-icon" href="/favicon.ico"/>
          <meta name="robots" content="index,follow">
      <meta name="description" content="In unserem Downloadbereich finden Sie aktuelle Informationen zu unseren Produkten und unserem Unternehmen (z. B. Bedienungsanleitungen uvm.).">
      <meta name="keywords" content="">
      <meta name="generator" content="Contao Open Source CMS">
            <link rel="stylesheet" href="assets/css/b4421f92827d.css">
    <script src="//code.jquery.com/jquery-1.11.3.min.js"></script>
<script>window.jQuery || document.write('<script src="assets/jquery/core/1.11.3/jquery.min.js">\x3C/script>')</script>
          <!--[if lt IE 9]><script src="assets/html5shiv/3.7.2/html5shiv-printshiv.min.js"></script><![endif]-->
<link rel='stylesheet' href='/styles/generated_style_eq3.css' type='text/css'/>
<link rel='stylesheet' href='/styles/generated_mobile.css' media="screen and (max-width: 1000px)" type='text/css'/>
<!-- Facebook Pixel Code -->
<script>
!function(f,b,e,v,n,t,s){if(f.fbq)return;n=f.fbq=function(){n.callMethod?
n.callMethod.apply(n,arguments):n.queue.push(arguments)};if(!f._fbq)f._fbq=n;
n.push=n;n.loaded=!0;n.version='2.0';n.queue=[];t=b.createElement(e);t.async=!0;
t.src=v;s=b.getElementsByTagName(e)[0];s.parentNode.insertBefore(t,s)}(window,
document,'script','https://connect.facebook.net/en_US/fbevents.js');
fbq('init', '1770760929836366');
fbq('track', "PageView");</script>
<noscript><img height="1" width="1" style="display:none"
src="https://www.facebook.com/tr?id=1770760929836366&ev=PageView&noscript=1"
/></noscript>
<!-- End Facebook Pixel Code -->
</head>
<body id="top" class="unknown other  standardlayout">
    <div id="wrapper">
                        <header id="header">
            <div class="inside">
<a id="logo" href=""></a>
<div id="top_mobile">
<div id="nav_icon" class="open"><span class="lines"></span></div>
<div id="search_icon"></div>
</div>
<div id="menu_wrap" class="level0">
<div class="suche_box">
<ul id="sprachenwechsler">
<li class="de active">de</li>
<li class="en"><a href="http://www.eq-3.com/service/downloads.html">en</a></li>
</ul>
<form action="suche.html" method="post">
<input type="hidden" name="REQUEST_TOKEN" value="f95ee2f23ecf363b948751de79f400ba" />
<input type="text" class="text" name="keywords" value="" placeholder="Suche..."/>
</form>
</div>
<p class="h1">Hauptmenü</p>
<!-- indexer::stop -->
<nav class="mod_navigation main-nav block">
  <a href="service/downloads.html#skipNavigation6" class="invisible">Navigation überspringen</a>
  <ul class="level_1" role="menubar">
            <li class="submenu mittel-header first item_1"><a href="produkte.html" title="Produkte" class="submenu mittel-header first" role="menuitem" aria-haspopup="true">Produkte</a><ul class="level_2" role="menu">
            <li class="desktop_hidden first item_1"><a href="produkte.html" title="Produkte Übersicht" class="desktop_hidden first" role="menuitem">Produkte Übersicht</a></li>
                <li class="submenu homematic mittel-header item_2"><a href="produkte/homematic.html" title="HomeMatic" class="submenu homematic mittel-header" role="menuitem" aria-haspopup="true">HomeMatic</a><ul class="level_3" role="menu">
            <li class="homematic desktop_hidden first item_1"><a href="produkte/homematic.html" title="Homematic System" class="homematic desktop_hidden first" role="menuitem">Homematic System</a></li>
                <li class="homematic item_2"><a href="produkte/homematic/zentralen-und-gateways.html" title="Zentralen und Gateways" class="homematic" role="menuitem">Zentralen und Gateways</a></li>
                <li class="homematic item_3"><a href="produkte/homematic/heizung-und-klima.html" title="Heizung und Klima" class="homematic" role="menuitem">Heizung und Klima</a></li>
                <li class="homematic item_4"><a href="produkte/homematic/licht.html" title="Licht" class="homematic" role="menuitem">Licht</a></li>
                <li class="homematic item_5"><a href="produkte/homematic/rolllaeden-und-markisen.html" title="Rollläden und Markisen" class="homematic" role="menuitem">Rollläden und Markisen</a></li>
                <li class="homematic item_6"><a href="produkte/homematic/sicherheit-und-ueberwachung.html" title="Sicherheit und Überwachung" class="homematic" role="menuitem">Sicherheit und Überwachung</a></li>
                <li class="homematic item_7"><a href="produkte/homematic/fenster-und-tueren.html" title="Fenster und Türen" class="homematic" role="menuitem">Fenster und Türen</a></li>
                <li class="homematic item_8"><a href="produkte/homematic/fernbedienung-und-wandtaster.html" title="Fernbedienungen und Wandtaster" class="homematic" role="menuitem">Fernbedienungen und Wandtaster</a></li>
                <li class="homematic item_9"><a href="produkte/homematic/wetter-und-umwelt.html" title="Wetter und Umwelt" class="homematic" role="menuitem">Wetter und Umwelt</a></li>
                <li class="homematic item_10"><a href="produkte/homematic/schalten-und-messen.html" title="Schalten und Messen" class="homematic" role="menuitem">Schalten und Messen</a></li>
                <li class="homematic item_11"><a href="produkte/homematic/homematic-in-der-elektroverteilung.html" title="HomeMatic in der Elektroverteilung" class="homematic" role="menuitem">HomeMatic in der Elektroverteilung</a></li>
                <li class="homematic item_12"><a href="produkte/homematic/internationale-produktvarianten.html" title="Internationale Produktvarianten" class="homematic" role="menuitem">Internationale Produktvarianten</a></li>
                <li class="homematic item_13"><a href="produkte/homematic/adapter-fuer-markenschalter.html" title="Adapter für Markenschalter" class="homematic" role="menuitem">Adapter für Markenschalter</a></li>
                <li class="submenu homematic last item_14"><a href="produkte/homematic/software-und-apps.html" title="Software und Apps" class="submenu homematic last" role="menuitem" aria-haspopup="true">Software und Apps</a><ul class="level_4" role="menu">
            <li class="desktop_hidden first item_1"><a href="produkte/homematic/software-und-apps.html" title="Software und Apps Übersicht" class="desktop_hidden first" role="menuitem">Software und Apps Übersicht</a></li>
                <li class="homematic item_2"><a href="produkte/homematic/homematic-webui.html" title="Die Homematic Benutzeroberfläche WebUI" class="homematic" role="menuitem">Homematic WebUI</a></li>
                <li class="homematic item_3"><a href="produkte/homematic/software-und-apps/mediola-aio-creator-neo.html" title="Mediola AIO CREATOR NEO Homematic Edition" class="homematic" role="menuitem">Mediola AIO CREATOR NEO</a></li>
                <li class="homematic item_4"><a href="produkte/homematic/software-und-apps/die-orbylon-app.html" title="Die Orbylon App für Windows Phone, iOS und Android" class="homematic" role="menuitem">Die Orbylon App</a></li>
                <li class="homematic item_5"><a href="produkte/homematic/software-und-apps/pocket-control-hm.html" title="Pocket control HM" class="homematic" role="menuitem">Pocket control HM</a></li>
                <li class="homematic item_6"><a href="produkte/homematic/software-und-apps/cloudmatic.html" title="CloudMaticconnect, SmartHome und notify me" class="homematic" role="menuitem">CloudMatic</a></li>
                <li class="homematic item_7"><a href="produkte/homematic/software-und-apps/die-homenow-app.html" title="Die homeNOW App für iOS und Android" class="homematic" role="menuitem">Die homeNOW App</a></li>
                <li class="homematic last item_8"><a href="produkte/homematic/software/homeputer-cl-studio.html" title="homeputer CL Studio" class="homematic last" role="menuitem">homeputer CL Studio</a></li>
      </ul>
</li>
      </ul>
</li>
                <li class="submenu homematic homematic_ip mittel-header item_3"><a href="produkte/homematic-ip.html" title="Homematic IP" class="submenu homematic homematic_ip mittel-header" role="menuitem" aria-haspopup="true">Homematic IP</a><ul class="level_3" role="menu">
            <li class="desktop_hidden first item_1"><a href="produkte/homematic-ip.html" title="Homematic IP System" class="desktop_hidden first" role="menuitem">Homematic IP System</a></li>
                <li class="homematic item_2"><a href="produkte/homematic-ip/heizung-und-klima.html" title="Heizung und Klima" class="homematic" role="menuitem">Heizung und Klima</a></li>
                <li class="homematic item_3"><a href="produkte/homematic-ip/licht.html" title="Licht" class="homematic" role="menuitem">Licht</a></li>
                <li class="homematic item_4"><a href="produkte/homematic-ip/rolllaeden-jalousien-und-markisen.html" title="Rollläden, Jalousien und Markisen" class="homematic" role="menuitem">Rollläden, Jalousien und Markisen</a></li>
                <li class="homematic item_5"><a href="produkte/homematic-ip/sicherheit-und-ueberwachung.html" title="Sicherheit und Überwachung" class="homematic" role="menuitem">Sicherheit und Überwachung</a></li>
                <li class="homematic item_6"><a href="produkte/homematic-ip/internationale-produktvarianten.html" title="Internationale Produktvarianten" class="homematic" role="menuitem">Internationale Produktvarianten</a></li>
                <li><a href="produkte/homematic-ip/sprachsteuerung.html" title="Sprachsteuerung" role="menuitem">Sprachsteuerung</a></li>
                <li class="homematic item_8"><a href="produkte/homematic-ip/wetter-und-umwelt.html" title="Wetter und Umwelt" class="homematic" role="menuitem">Wetter und Umwelt</a></li>
                <li class="homematic last item_9"><a href="produkte/homematic-ip/adapter-fuer-markenschalter.html" title="Adapter für Markenschalter" class="homematic last" role="menuitem">Adapter für Markenschalter</a></li>
      </ul>
</li>
                <li class="submenu mittel-header item_4"><a href="produkte/max.html" title="MAX!" class="submenu mittel-header" role="menuitem" aria-haspopup="true">MAX!</a><ul class="level_3" role="menu">
            <li class="desktop_hidden first item_1"><a href="produkte/max.html" title="MAX! System" class="desktop_hidden first" role="menuitem">MAX! System</a></li>
                <li class="mittel-header item_2"><a href="produkte/max-heizungssteuerung/max-heizkoerperloesung.html" title="MAX! Heizkörperlösung" class="mittel-header" role="menuitem">MAX! Heizkörperlösung</a></li>
                <li class="mittel-header item_3"><a href="produkte/max-heizungssteuerung/max-raumloesung.html" title="MAX! Raumlösung" class="mittel-header" role="menuitem">MAX! Raumlösung</a></li>
                <li class="submenu mittel-header item_4"><a href="produkte/max-heizungssteuerung/max-hausloesung.html" title="MAX! Hauslösung" class="submenu mittel-header" role="menuitem" aria-haspopup="true">MAX! Hauslösung</a><ul class="level_4" role="menu">
            <li class="mittel-header first last item_1"><a href="produkte/max/max-hausloesung/das-max-portal.html" title="Das MAX! Portal" class="mittel-header first last" role="menuitem">Das MAX! Portal</a></li>
      </ul>
</li>
                <li class="mittel-header last item_5"><a href="produkte/max/max-als-oem-loesung.html" title="MAX! als OEM Lösung" class="mittel-header last" role="menuitem">MAX! als OEM Lösung</a></li>
      </ul>
</li>
                <li class="mittel-header item_5"><a href="produkte/eqiva.html" title="eqiva" class="mittel-header" role="menuitem">eqiva</a></li>
                <li class="mittel-header last item_6"><a href="produkte/zubehoer.html" title="Zubehör" class="mittel-header last" role="menuitem">Zubehör</a></li>
      </ul>
</li>
                <li class="submenu mittel-header item_2"><a href="loesungen.html" title="Lösungen" class="submenu mittel-header" role="menuitem" aria-haspopup="true">Lösungen</a><ul class="level_2" role="menu">
            <li class="desktop_hidden first item_1"><a href="loesungen.html" title="Lösungen Übersicht" class="desktop_hidden first" role="menuitem">Lösungen Übersicht</a></li>
                <li class="submenu item_2"><a href="loesungen/smart-home.html" title="Smart Home" class="submenu" role="menuitem" aria-haspopup="true">Smart Home</a><ul class="level_3" role="menu">
            <li class="first item_1"><a href="loesungen/smart-home/heizen-mit-homematic.html" title="Heizen mit Homematic" class="first" role="menuitem">Heizen mit Homematic</a></li>
                <li><a href="loesungen/smart-home/absichern-mit-homematic.html" title="Absichern mit Homematic" role="menuitem">Absichern mit Homematic</a></li>
                <li><a href="loesungen/smart-home/beleuchten-und-beschatten-mit-homematic.html" title="Beleuchten und Beschatten mit Homematic" role="menuitem">Beleuchten und Beschatten mit Homematic</a></li>
                <li class="last item_4"><a href="loesungen/smart-home/rollladen-und-markisensteuerung-mit-homematic.html" title="Rollladen- und Markisensteuerung mit Homematic" class="last" role="menuitem">Rollladen- und Markisensteuerung mit Homematic</a></li>
      </ul>
</li>
                <li><a href="loesungen/smart-home-im-neubau.html" title="Smart Home im Neubau" role="menuitem">Smart Home im Neubau</a></li>
                <li><a href="loesungen/smart-home-nachruesten.html" title="Smart Home zum Nachrüsten" role="menuitem">Smart Home zum Nachrüsten</a></li>
                <li><a href="loesungen/unabhaengig-im-alter.html" title="Unabhängig im Alter" role="menuitem">Unabhängig im Alter</a></li>
                <li class="last item_6"><a href="loesungen/heizungsregelung.html" title="Heizungsregelung" class="last" role="menuitem">Heizungsregelung</a></li>
      </ul>
</li>
                <li class="submenu mittel-header item_3"><a href="partner.html" title="Partner" class="submenu mittel-header" role="menuitem" aria-haspopup="true">Partner</a><ul class="level_2" role="menu">
            <li class="desktop_hidden first item_1"><a href="partner.html" title="Partner Übersicht" class="desktop_hidden first" role="menuitem">Partner Übersicht</a></li>
                <li><a href="partner/partnerprogramm.html" title="Partnerprogramm" role="menuitem">Partnerprogramm</a></li>
                <li class="submenu item_3"><a href="partner/unsere-partner.html" title="Unsere Partner" class="submenu" role="menuitem" aria-haspopup="true">Unsere Partner</a><ul class="level_3" role="menu">
            <li class="first item_1"><a href="partner/unsere-partner/elv-elektronik-ag.html" title="ELV Elektronik AG" class="first" role="menuitem">ELV Elektronik AG</a></li>
                <li><a href="partner/unsere-partner/qivicon.html" title="QIVICON" role="menuitem">QIVICON</a></li>
                <li><a href="partner/unsere-partner/contronics-gmbh.html" title="Contronics GmbH" role="menuitem">Contronics GmbH</a></li>
                <li class="last item_4"><a href="partner/unsere-partner/conrad-electronic-se.html" title="Conrad Electronic SE" class="last" role="menuitem">Conrad Electronic SE</a></li>
      </ul>
</li>
                <li><a href="partner/bezugsquellen.html" title="Bezugsquellen" role="menuitem">Bezugsquellen</a></li>
                <li class="last item_5"><a href="partner/grosshandel.html" title="Großhandel" class="last" role="menuitem">Großhandel</a></li>
      </ul>
</li>
                <li class="submenu trail mittel-header item_4"><a href="service.html" title="Service" class="submenu trail mittel-header" role="menuitem" aria-haspopup="true">Service</a><ul class="level_2" role="menu">
            <li class="desktop_hidden sibling first item_1"><a href="service.html" title="Service Übersicht" class="desktop_hidden sibling first" role="menuitem">Service Übersicht</a></li>
                <li class="sibling item_2"><a href="service/support.html" title="Support" class="sibling" role="menuitem">Support</a></li>
                <li class="sibling item_3"><a href="service/faq.html" title="FAQ" class="sibling" role="menuitem">FAQ</a></li>
                <li class="active item_4"><span class="active" role="menuitem">Downloads</span></li>
                <li class="sibling last item_5"><a href="service/sitemap.html" title="Sitemap" class="sibling last" role="menuitem">Sitemap</a></li>
      </ul>
</li>
                <li class="submenu mittel-header item_5"><a href="aktuelles.html" title="Aktuelles" class="submenu mittel-header" role="menuitem" aria-haspopup="true">Aktuelles</a><ul class="level_2" role="menu">
            <li class="desktop_hidden first item_1"><a href="aktuelles.html" title="Übersicht" class="desktop_hidden first" role="menuitem">Übersicht</a></li>
                <li class="kleiner-header item_2"><a href="aktuelles/news.html" title="News" class="kleiner-header" role="menuitem">News</a></li>
                <li class="kleiner-header item_3"><a href="aktuelles/events.html" title="Events" class="kleiner-header" role="menuitem">Events</a></li>
                <li class="kleiner-header item_4"><a href="aktuelles/presse.html" title="Presse" class="kleiner-header" role="menuitem">Presse</a></li>
                <li class="last item_5"><a href="aktuelles/eq-3-in-the-news.html" title="eQ-3 in the news" class="last" role="menuitem">eQ-3 in the news</a></li>
      </ul>
</li>
                <li class="submenu site_themen last item_6"><a href="themen/fuer-verbraucher.html" title="Themen" class="submenu site_themen last" role="menuitem" aria-haspopup="true">Themen</a><ul class="level_2" role="menu">
            <li class="nav-teaser-extra grosser-header first item_1"><a href="themen/fuer-verbraucher.html" title="Für Verbraucher" class="nav-teaser-extra grosser-header first" role="menuitem">Für Verbraucher</a></li>
                <li class="grosser-header nav-teaser-extra item_2"><a href="themen/fuer-vertriebspartner.html" title="Für Vertriebspartner" class="grosser-header nav-teaser-extra" role="menuitem">Für Vertriebspartner</a></li>
                <li class="grosser-header nav-teaser-extra last item_3"><a href="themen/fuer-entwickler.html" title="Für Entwickler" class="grosser-header nav-teaser-extra last" role="menuitem">Für Entwickler</a></li>
      </ul>
</li>
      </ul>
  <a id="skipNavigation6" class="invisible">&nbsp;</a>
</nav>
<!-- indexer::continue -->
<nav class="mod_customnav block" id="nav-top">
  <a href="service/downloads.html#skipNavigation28" class="invisible">Navigation überspringen</a>
            <li class="first item_1"><a href="unternehmen.html" title="Über eQ-3" class="first" role="menuitem">Über eQ-3</a></li>
                <li><a href="unternehmen/karriere.html" title="Karriere" role="menuitem">Karriere</a></li>
                <li><a href="service/faq.html" title="FAQ" role="menuitem">FAQ</a></li>
                <li class="last item_5"><a href="kontakt.html" title="Kontakt" class="last" role="menuitem">Kontakt</a></li>
      </ul>
  <a id="skipNavigation28" class="invisible">&nbsp;</a>
</nav>
</div>            </div>
            <div id="teaser" class="">
<div class="t_inner">
<span id="dek_left_top"></span>
<span id="dek_dach"></span>
        <span id="dek_right_bottom"></span>
</div>
</div><!-- /#teaser -->
          </header>
              <div id="container">
                      <div id="main">
<article>
<div class="mod_article first last block" id="downloads-711">
<div class="ce_text first block">
      <h1>Downloads</h1>
  <div class='text_wrap'><p>In unserem Downloadbereich finden Sie aktuelle Informationen zu unseren Produkten und unserem Unternehmen, wie z.B. Bedienungsanleitungen, Software-Updates, Informationsbroschüren und vieles mehr.</p>
<p>Sie können Ihre Suche ganz bequem in die untere Maske eingeben.</p>
<p>&nbsp;</p></div>
</div>
<p class="anzahl">25 Ergebnis gefunden.</p> <div class="row head">
<div class="col col-1"><p>Name</p></div>
<div class="col col-2"><p>Notes</p></div>
<div class="col col-3"><p>Download</p></div>
</div>
<div class="row even">
<p class="name"><a href="/service/downloads.html?id=278">HM-CCU2 Firmware 2.31.25</a></p>
<p>Download-Art: Firmware</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/HM-CCU2-Firmware_Updates/HM-CCU-2.31.25/HM-CCU2-Changelog-2.31.25.pdf" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">16.01.2018</p>
<p><a href="Downloads/Software/HM-CCU2-Firmware_Updates/HM-CCU-2.31.25/HM-CCU-2.31.25.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">73,77 MB</p>
</div><!-- /.col-3 -->
</div><!-- .row -->
<div class="row odd">
<p class="name"><a href="/service/downloads.html?id=268">HM-CCU2 Firmware 2.29.23</a></p>
<a class="notes" href="Downloads/Software/HM-CCU2-Firmware_Updates/HM-CCU-2.29.23/HM-CCU2-Changelog.pdf" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">11.10.2017</p>
<p><a href="/service/downloads.html?id=268" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">72,3 MB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=266">HM-CCU2 Firmware 2.29.22</a></p>
<a class="notes" href="Downloads/Software/HM-CCU2-Firmware_Updates/HM-CCU-2.29.22/HM-CCU2-Changelog-2.29.22.pdf" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">23.08.2017</p>
<p><a href="Downloads/Software/HM-CCU2-Firmware_Updates/HM-CCU-2.29.22/HM-CCU-2.29.22.tar.gz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">72,29 MB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=265">HomeMatic 8-Kanal Empfangsmodul, Bausatz V1.2</a></p>
<p>Kurz-Bez.: HM-MOD-Re-8</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 132143A2</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_hm-mod-re-8_update_V1_2_150911.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">22.08.2017</p>
<p><a href="Downloads/Software/Firmware/hm-mod-re-8_update_V1_2_150911.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">76,07 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=214">Funk-Statusdisplay mit Taster für 55er Rahmen Firmware V1.2</a></p>
<p>Kurz-Bez.: HM-Dis-EP-WM55</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 142408A0</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_hm_dis_ep_wm55_update_V1_2_170129.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">11.04.2017</p>
<p><a href="Downloads/Software/Firmware/hm_dis_ep_wm55_update_V1_2_170129.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">65,28 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=131">Funk-Rollladenaktor 1-fach für Markenschalter Firmware V2.11.1</a></p>
<p>Kurz-Bez.: HM-LC-Bl1PBU-FM</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 103038</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_HM-LC-Bl1PBU-FM_update_V2_11_1_161212.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p><a href="Downloads/Software/Firmware/HM-LC-Bl1PBU-FM_update_V2_11_1_161212.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">79,26 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=254">HomeMatic Funk-Schaltaktor 1-fach mit Leistungsmessung, Zwischenstecker Firmware V2.5</a></p>
<p>Kurz-Bez.: HM-ES-PMSw1-Pl-DN-R1</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 130248A0</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_HM-ES-PMSw1-Pl-DN-R1_update_V2_5_0009_150217.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">17.02.2017</p>
<p><a href="Downloads/Software/Firmware/HM-ES-PMSw1-Pl-DN-R1_update_V2_5_0009_150217.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">61,79 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=217">Funk-Bewegungsmelder mit Taster Firmware V1.2</a></p>
<p>Kurz-Bez.: HM-Sen-MDIR-WM-55</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 140848</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_HM-Sen-MDIR-WM55_update_V1_2_0_160825.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">25.08.2016</p>
<p><a href="Downloads/Software/Firmware/HM-Sen-MDIR-WM55_update_V1_2_0_160825.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">48,5 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=206">Funk-Sender für Energiezähler-Sensor Firmware 1.2</a></p>
<p>Kurz-Bez.: HM-ES-TX-WM</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 140143</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_HM-ES-TX-WM_update_V1_2_160628.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">28.06.2016</p>
<p><a href="Downloads/Software/Firmware/HM-ES-TX-WM_update_V1_2_160628.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">65,78 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=207">Funk-Kombisignalgeber MP3 Firmware V1.3</a></p>
<p>Kurz-Bez.: HM-OU-CFM-TW</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 142873A0</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_hm-ou-cfm-tw_update_V1_3_160620.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">20.06.2016</p>
<p><a href="Downloads/Software/Firmware/hm-ou-cfm-tw_update_V1_3_160620.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">136,63 KB</p>
</div><!-- .row -->
<div class="row even lazyload">
<p class="name"><a href="/service/downloads.html?id=200">HM-CCU1 Firmware 1.519</a></p>
<a class="notes" href="Downloads/Software/HM-CCU1-Firmware_Updates/1.5.19/CCU1_Licenses_Text.pdf" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">19.05.2016</p>
<p><a href="/service/downloads.html?id=200" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">9,32 MB</p>
</div><!-- .row -->
<div class="row odd lazyload">
<p class="name"><a href="/service/downloads.html?id=196">Funk-Sender für Energiezähler-Sensor Firmware 1.1</a></p>
<a class="notes" href="Downloads/Software/Firmware/changelog_HM-ES-TX-WM_update_V1_1_160318.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">18.03.2016</p>
<p><a href="Downloads/Software/Firmware/HM-ES-TX-WM_update_V1_1_160318.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">64,51 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=174">Funk-Dimmaktor 1-fach, PWM LED, Zwischendeckenmontage Firmware V2.9.5</a></p>
<p>Kurz-Bez.: HM-LC-Dim1PWM-CV</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 99444</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_HM-LC-Dim1PWM-CV_update_V2_9_0005_160113g.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">13.01.2016</p>
<p><a href="Downloads/Software/Firmware/HM-LC-Dim1PWM-CV_update_V2_9_0005_150730.tar.gz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">55,78 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=172">Funk-Dimmaktor 1-fach, Phasenanschnitt, Zwischenstecker Firmware V2.9.7</a></p>
<p>Kurz-Bez.: HM-LC-Dim1L-Pl-3</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 132078</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_HM-LC-Dim1L-Pl-3_update_V2_9_0007_160113.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p><a href="Downloads/Software/Firmware/HM-LC-Dim1L-Pl-3_update_V2_9_0007_150803.tar.gz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">58,41 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=173">Funk-Dimmaktor 1-fach für Markenschalter, Phasenabschnitt, Unterputzmontage Firmware V2.9.5</a></p>
<p>Kurz-Bez.: HM-LC-Dim1TPBU-FM</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 103020</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_HM-LC-Dim1TPBU-FM_update_V2_9_0005_160113.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p><a href="Downloads/Software/Firmware/HM-LC-Dim1TPBU-FM_update_V2_9_0005_150730.tar.gz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">58,36 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=164">Funk-Dimmaktor 1-fach, Phasenabschnitt, Zwischenstecker Firmware V2.9.5</a></p>
<p>Kurz-Bez.: HM-LC-Dim1T-Pl-3</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 132087</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_HM-LC-Dim1T-Pl-3_update_V2_9_0005_160113.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p><a href="Downloads/Software/Firmware/HM-LC-Dim1T-Pl-3_update_V2_9_0005_150730.tar.gz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">58,16 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=148">HomeMatic 8-Kanal Empfangsmodul</a></p>
<p class="datum">11.09.2015</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=139">Funk-Wandthermostat Firmware V1.3</a></p>
<p>Kurz-Bez.: HM-TC-IT-WM-W-EU</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 132030</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_hm_tc_it_wm_w_eu_update_V1_3_002_150827.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">27.08.2015</p>
<p><a href="Downloads/Software/Firmware/hm_tc_it_wm_w_eu_update_V1_3_002_150827.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">70,12 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=132">Funk-Schaltaktor 1-fach für Markenschalter Firmware V2.8.2</a></p>
<p>Kurz-Bez.: HM-LC-Sw1PBU-FM</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 103029</p> </div><!-- /.col-1 -->
<a class="notes" href="Downloads/Software/Firmware/changelog_HM-LC-Sw1PBU-FM.txt" target="_Blank">Changelog</a> </div><!-- /.col-2 -->
<p class="datum">12.08.2015</p>
<p><a href="Downloads/Software/Firmware/HM-LC-Sw1PBU-FM_update_V2_8_2_150713.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">44,46 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=126">Funk-Bewegungsmelder mit Taster Firmware V1.1.2</a></p>
<p class="datum">14.04.2015</p>
<p><a href="Downloads/Software/Firmware/HM-Sen-MDIR-WM55_update_V1_1_2_150413.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">50,36 KB</p>
</div><!-- .row -->
<p class="name"><a href="/service/downloads.html?id=110">HomeMatic Funk-Schaltaktor 1-fach mit Leistungsmessung, Zwischenstecker Firmware V2.5</a></p>
<p>Kurz-Bez.: HM-ES-PMSw1-Pl</p><p>Download-Art: Firmware</p><p class="artnr">Artikel-Nr.: 130248</p> </div><!-- /.col-1 -->
<p class="datum">16.03.2015</p>
<p><a href="Downloads/Software/Firmware/HM-ES-PMSw1-Pl_update_V2_5_0009_150217.tgz" title="Download" ><img src="/img/download.png" alt="Download" title="Download"></a></p>
<p class="size">64,95 KB</p>
Für Usertreffen gibt es das Unterforum Termine und Veranstaltungen
DK4RST
ganz ehrlich, dafür bin ich noch zu wenig im Thema.
aber wie gesagt ich lerne gerne.
Nochmal zu Codes , wie mache ich das??
Könntest Du mir eventuell bei diesen Sachen direkt, ohne Forum etwas helfen?
roland.stephan@web.de?
oder habe ich jetzt schon wieder was falsch gemacht?
Nö Hilfe gibt es nur im Forum!  :D
Drück einfach wie oben beschrieben auf die # Taste, dann hast Du zwei Tags und der Text dazwischen wird so dargestellt wie von mir gezeigt. Du kannst es auch nachträglich tun: Text markieren # taste drücken fertig.
Einfach probieren, da geht nichts kaputt. Du kannst Deine Beiträge jederzeit editieren.
DK4RST
hab es probiert, dann wird der ganze Text durch ein #Zeichen ersetzt!!
DK4RST
DK4RST
sollten wir nicht eher einen anderen Betreff auf machen??
DK4RST
Hallo Otto123, also das mit den Tags würde ich ja schon gerne verstehen, gibst Du mir dafür noch support?
geht nicht
Einen neuen Betreff kannst Du machen in dem Du einen neue Frage/Thread/Thema aufmachst.
Gib mal in der FHEM Kommandozeile list TYPE=CUL_HMein. Bekommst Du da was zurück?
DK4RST
nein es kommt nichts.
und danke, wie kann man Blind sein, jetzt hab ich es gefunden!!
Ich habe noch viele Fragen , weis aber nicht ob das alle anderen Interessiert, wäre aber super wenn jemand wie Du mir Antworten geben würdest. Wie läuft das dann hier?
Gruß aus Langenfeld
Lesen, suchen -> das meiste steht hier schon irgendwo. Du kannst auch bei Google site:forum.fhem.de Suchbegriffeingeben.
Dann einfach fragen, viele Infos liefern. Einer wird schon antworten  ;)
DK4RST
@Otto123, ich probiere seit 3 Tagen das Wettermodul bei mir zum laufen zu bringen, wenn ich da jetzt fragen möchte , würdest Du mir antworten?
Mit Deiner Hilfe komm ich weiter, wie Du siehst!!
Wir sollten den Off Topic Dialog jetzt beenden. Stell die Frage ruhig (neues Thema) aber ich habe vom Wettermodul keine Ahnung. Irgendwer kennt sich sicher damit aus.
Hier findest Du den Hinweis zum richtigen Forumsbereich -> https://fhem.de/MAINTAINER.txt
Gruß otto
