FS20-DI4 Dimmer anlernen funktioniert nicht
Begonnen von HansDampfHH, 05 Februar 2017, 09:40:21
HansDampfHH
Hallo, vielleicht kann mir jemand auf die Sprünge helfen?
Mein Steckdosendimmer ist wie folgt eingebunden:
define FS20Dimmer1 FS20 1b39 80
attr FS20Dimmer1 IODev nanoCUL868
attr FS20Dimmer1 eventMap /on:Ein/off:Aus/
attr FS20Dimmer1 webCmd Ein:dim:Aus
   BTN        01
   CFGFN
   DEF        7777 01
   IODev      nanoCUL868
   NAME       FS20Dimmer1
   NR         206482
   STATE      Ein
   TYPE       FS20
   XMIT       7777
   Code:
     1          7777 01
   Readings:
     2017-02-01 22:59:12   state           on
   IODev      nanoCUL868
   alias      Steckdosen-Dimmer
   room       Wohnzimmer
   webCmd     Ein:dim:Aus
Hier ein list vom CUL:
   CMDS       BCFiAZEkGMKUYRTVWXefltx
   Clients    :FS20:FHT.*:KS300:USF1000:BS:HMS: :CUL_EM:CUL_WS:CUL_FHTTK:CUL_HOERMANN: :ESA2000:CUL_IR:CUL_TX:Revolt:IT:UNIRoll:SOMFY: :STACKABLE_CC:TSSTACKED:CUL_RFR::CUL_TCM97001:CUL_REDIRECT:
   DEF        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03SKLQ-if00-port0@38400 0000
   DeviceName /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI03SKLQ-if00-port0@38400
   FD         13
   FHTID      0000
   NAME       nanoCUL868
   NR         151
   NR_CMD_LAST_H 27
   PARTIAL
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.65 nanoCUL868
   initString X21
   Matchlist:
     1:USF1000  ^81..(04|0c)..0101a001a5ceaa00....
     2:BS       ^81..(04|0c)..0101a001a5cf
     3:FS20     ^81..(04|0c)..0101a001
     4:FHT      ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     5:KS300    ^810d04..4027a001
     6:CUL_WS   ^K.....
     7:CUL_EM   ^E0.................$
     8:HMS      ^810e04....(1|5|9).a001
     9:CUL_FHTTK ^T[A-F0-9]{8}
     A:CUL_RFR  ^[0-9A-F]{4}U.
     B:CUL_HOERMANN ^R..........
     C:ESA2000  ^S................................$
     D:CUL_IR   ^I............
     E:CUL_TX   ^TX[A-F0-9]{10}
     F:Revolt   ^r......................$
     G:IT       ^i......
     H:STACKABLE_CC ^\*
     I:UNIRoll  ^[0-9A-F]{5}(B|D|E)
     J:SOMFY    ^Y[r|t|s]:?[A-F0-9]+
     K:CUL_TCM97001 ^s[A-F0-9]+
     L:CUL_REDIRECT ^o+
     M:TSSTACKED ^\*
   Readings:
     2017-02-01 22:40:19   ccconf          freq:800.000MHz bWidth:203KHz rAmpl:33dB sens:8dB
     2017-01-24 00:15:15   cmds             B C F i A Z E k G M K U Y R T V W X e f l t x
     2016-03-19 18:11:17   raw             V 1.65 nanoCUL868
     2017-01-24 00:15:15   state           Initialized
     2016-02-20 08:38:56   uptime          0 00:00:43
   XMIT_TIME:
     1485984675.09458
     1485984922.05187
     1485984924.30567
     1485984925.65409
     1485984927.77673
     1485984929.6673
     1485984931.71806
     1485984933.49509
     1485984935.51387
     1485984936.89039
     1485984938.22811
     1485984979.60715
     1485984980.29402
     1485985100.77152
     1485985134.27132
     1485985135.8365
     1485985136.5625
     1485985137.76672
     1485985138.94438
     1485985140.20821
     1485986344.2257
     1485986346.18336
     1485986347.57374
     1485986349.00881
     1485986349.73288
     1485986351.19528
     1485986352.48622
   group      CUL
   icon       cul_868
   rfmode     SlowRF
   room       Steuerung
Wenn ich die Steckdose in den Anlernmodus versetze und in FHEM on/off klicke, wechselweise/mehrfach tut sich leider nichts.
Mit der Definition des Hauscodes stehe ich ehrlicherweise noch auf Kriegsfuss.
1b30 80 oder 7777 01 haben bisher keinen Unterschied gemacht.
Könnte mir jemand bitte weiterhelfen oder einen Hinweis geben, wie ich dem Problem auf die Spur komme?
FHEM Docker, CUL868, Zigbee, CCU2, Jeelink
Thorsten Pferdekaemper
mit FS20 kenne ich mich nicht aus, aber ich bin mir sicher, dass die, die sich auskennen, gerne ein "list FS20Dimmer1" und ein "list nanoCUL868" haben würden.
   Thorsten
FUIP
FranzB94
Hi HansdampfHH!
Deine Definition sieht eher nach HM aus. Mein Dimmer ist mit dem Hauscode 12121212 definiert. Die weiteren Adresssen sind: Gerät 2313, Funktionsgruppe 4411, local Master 2344, general Master 4444.
define wz_Lichtschiene1 12121212 2313 fg 4411 lm 2344 gm 4444
Hast Du autocreate an?. Dann müsste fhem aber das Teil erkannt haben.
HansDampfHH
@Thorsten
Danke, hast du natürlich Recht. Habe ich mal ergänzt.
@FranzB94
Hat mich auch gewundert, aber über autocreate kam der Dimmer nicht.
Ich habe ihn entsprechend diesem Thread nach manuell eingebunden:
https://forum.fhem.de/index.php?topic=19417.0
