Re: [CUL] Re: InterTechno Modul für FHEM
Begonnen von Guest, 23 Januar 2012, 19:24:31
Guest
Hi all,
as requested several times I have now build a FHEM-Module for
InterTechno switches.
It's called 10_IT.pm
It defines InterTechno switches/dimmers, needs a 10-digit tri-state
definition and definitions (2 digits) for off/on/dimup/dimdown.
I have also put text for it into commandref.html.
I have tested it with CUNO & CUL433.
Be aware that you NEED to define an IODev attribute, as this is NOT set
automatically.
Feedback is welcome.
Best,
Olaf
Prof. Dr. Olaf Droegehorn
General Manager              Tel.  : +49-2244-918-4080
DHS - Computertechnik GmbH   Fax.  : +49-2244-918-4082
Wilhelm-Liebertz-Str. 2c     E-Mail: O.Droegehorn@dhs-
                                        computertechnik.de
D-53639 Koenigswinter        WEB:    www.dhs-computertechnik.de
Zwiebel
Hallo Olaf,
vielen dank für deine Arbeit.
Leider bekomme ich dein Modul nicht zum laufen.
Ich habe gerade noch ein fhemupdate gemacht. Aber leider scheint der
CUL nicht gefunden zu werden
2012.01.24 20:45:12 2: IT set testlamp1 on
2012.01.24 20:45:12 0: Strange call for nonexistent : GetFn
2012.01.24 20:45:12 2: IT IODev device didn't answer is command
correctly:
Use of uninitialized value $d in hash element at fhem.pl line 2181.
Use of uninitialized value $d in concatenation (.) or string at
fhem.pl line 2182.
Use of uninitialized value $msg in pattern match (m//) at /var/media/
ftp/fhem//FHEM/10_IT.pm line 135.
Use of uninitialized value $msg in concatenation (.) or string at /var/
media/ftp/fhem//FHEM/10_IT.pm line 138.
list CUL
Clients    :FS20:FHT:FHT8V:KS300:USF1000:BS:HMS: :CUL_EM:CUL_WS:CUL_FHTTK:CUL_RFR:CUL_HOERMANN: :ESA2000:CUL_IR:CUL_TX
   DEF        /dev/ttyACM1@38400 2222
   DeviceName /dev/ttyACM1@38400
   FD         7
   FHTID      2222
   NAME       CUL
   NR         3
   PARTIAL
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.44 CUL433
   initString X21
   Matchlist:
     1:USF1000  ^81..(04|0c)..0101a001a5ceaa00....
     2:BS       ^81..(04|0c)..0101a001a5cf
     3:FS20     ^81..(04|0c)..0101a001
     4:FHT      ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     5:KS300    ^810d04..4027a001
     6:CUL_WS   ^K.....
     7:CUL_EM   ^E0.................$
     8:HMS      ^810e04....(1|5|9).a001
     9:CUL_FHTTK ^T[A-F0-9]{8}
     A:CUL_RFR  ^[0-9A-F]{4}U.
     B:CUL_HOERMANN ^R..........
     C:ESA2000  ^S................................$
     D:CUL_IR   ^I............
     E:CUL_TX   ^TX[A-F0-9]{10}
   Softbuffer:
gruß
Zwiebel
On 23 Jan., 19:24, Olaf Droegehorn computertechnik.de> wrote:
> Hi all,
> automatically.
> Best,
> Olaf
>                                         computertechnik.de
Guest
Du hast für das InterTechno Device KEIN IODev-Attribut gesetzt.
Dies muß aber zwingend gemacht werden.
Bitte versuche es NACH dem setzen des IODev Attributes nochmal.
Danke,
Olaf
Am 24.01.2012 20:51, schrieb zwiebel:
> Hallo Olaf,
> correctly:
> fhem.pl line 2182.
> list CUL
> Internals:
>     FD         7
>     FHTID      2222
>     NAME       CUL
>     NR         3
>     PARTIAL
>     STATE      Initialized
>     TYPE       CUL
>     initString X21
>     Matchlist:
>       6:CUL_WS   ^K.....
>     Softbuffer:
> Attributes:
> gruß
> Zwiebel
> On 23 Jan., 19:24, Olaf Droegehorn> computertechnik.de>  wrote:
>> Hi all,
>> I have tested it with CUNO&  CUL433.
>> automatically.
>> Best,
>> Olaf
>>                                          computertechnik.de
                                        computertechnik.de
Zwiebel
Hallo Olaf,
vielen dank! das wars! peinlich....
Zwiebel
On 24 Jan., 20:54, Olaf Droegehorn computertechnik.de> wrote:
> Hi,
> Du hast f�r das InterTechno Device KEIN IODev-Attribut gesetzt.
> Dies mu� aber zwingend gemacht werden.
> Danke,
> Gru�,
> Olaf
> > Hallo Olaf,
> > vielen dank f�r deine Arbeit.
> > correctly:
> > fhem.pl line 2182.
> > list CUL
> > Internals:
> >     FD         7
> >     FHTID      2222
> >     NAME       CUL
> >     NR         3
> >     PARTIAL
> >     STATE      Initialized
> >     TYPE       CUL
> >     initString X21
> >     Matchlist:
> >       6:CUL_WS   ^K.....
> >     Softbuffer:
> > Attributes:
> > gru�
> > Zwiebel
> > On 23 Jan., 19:24, Olaf Droegehorn> > computertechnik.de>  wrote:
> >> Hi all,
> >> automatically.
> >> Best,
> >> Olaf
> >>                                          computertechnik.de
>                                         computertechnik.de
Guest
Hello,
I''m new to FHEM, new to Home Automation...and not native German speaking
I have started using the Homematic system, and particularly the HM-CC-TC.
I noticed that setpoints are now logged, but also noticed that not all
setpoint changes are registered.
Learning Perl is probably the next step, but until I have mastered the
basics, I would like to share some information regarding the logging
of desired-temps.
For what its worth, I logged some received commands from a HM-CC-TC on
a BidCos PC. I am using a HM Lan adapter, which is separate from the
actual system (other PC, not paired with anything), and only receives
information sent by the thermostat.
I hope someone can do more with this information than I am currently
capable of.
Feel free to respond in German, I have no problem speaking or reading.
Johan
Here's the log capture:
change temp on thermostat in manu mode
Thermostat broadcasts the information, without request:
RX for HEQ0132796: @288678974 RSSI=-46dB 0x1375C2 -> 0x0EFFDA
INFO_ACTUATOR_STATUS [IEQ0245464]:
  CNT=77,RPTEN=1,RPTED=0,BIDI=1,BURST=0,WAKEUP=0,WAKEMEUP=0,BCAST=1,TYPE=0x10
  CHANNEL = 2
  STATUS = 39
  STATE = 0
  CLOCK = 0
  LOWBAT = 0
  DUTY_CYCLE = 0
  RSSI = 0
Event: HEQ0132796:2.SETPOINT=19.500000
Recorded in LogFile as desired-temp, Status in WebInterface updated
Change Temp from FHEM, thermostat in Manu mode
RX for HEQ0132796: @289093408 RSSI=-48dB 0x1375C2 -> 0x0EFFDA
ACK_STATUS [IEQ0245464]:
  CNT=14,RPTEN=1,RPTED=0,BIDI=0,BURST=0,WAKEUP=0,WAKEMEUP=0,BCAST=0,TYPE=0x02
  CHANNEL = 2
  STATUS = 26
  STATE = 0
  CLOCK = 0
  LOWBAT = 0
  DUTY_CYCLE = 0
  RSSI = 57
Event: HEQ0132796:2.SETPOINT=13.000000
Command appears in logfile when set (desired-temp), but actual
confirmation (above) from thermostat does not. This confirmation came
about a minute later, when the thermostat changed also its displayed
set temperature.
WebInterface is not updated
Change temp from thermostat while in Cent Mode
RX for HEQ0132796: @289599772 RSSI=-46dB 0x1375C2 -> 0x0EFFDA
  CNT=83,RPTEN=1,RPTED=0,BIDI=1,BURST=0,WAKEUP=0,WAKEMEUP=0,BCAST=1,TYPE=0x10
  CHANNEL = 2
  STATUS = 30
  STATE = 0
  CLOCK = 0
  LOWBAT = 0
  DUTY_CYCLE = 0
  RSSI = 0
Event: HEQ0132796:2.SETPOINT=15.000000
Broadcasting desired temp, goes in logfile, no status update on WebInterface
Just a bit later, thermostat falls back to earlier setpoint, and
broadcasts this as well
RX for HEQ0132796: @289701528 RSSI=-52dB 0x1375C2 -> 0x0EFFDA
  CNT=84,RPTEN=1,RPTED=0,BIDI=1,BURST=0,WAKEUP=0,WAKEMEUP=0,BCAST=1,TYPE=0x10
  CHANNEL = 2
  STATUS = 26
  STATE = 0
  CLOCK = 0
  LOWBAT = 0
  DUTY_CYCLE = 0
  RSSI = 0
Event is not logged in FHEM
Guest
Thx for your work, Olaf!
Can I use FHEM to send a code that the receivers will pick up or do I
need another InterTechno sender?
How is the InterTechno quality and reliability compared to FS20?
CHeers
Joachim
tiptronic
The InterTechno reliability is much worse than FS20. Also distances are a bigger problem as in FS20. Intertechno switches need to stay closer to the sender in order to function properly.
Anyway, anything missing a back channel is not really reliable.
Andy
Am 25.01.2012 um 22:51 schrieb Joachim:
> CHeers
> Joachim
Guest
Hi all,
InterTechno codes can only be sent out from CUL/CUNO at this time. You
could also use another sender, but FHEM won't see this.
InterTechno is less reliable than FS20, as explained before.
But many people do have some of those switches from discounters and at
least could use them now.
If you are buying new things go at least with FS20 or HomeMatic.
Best,
Olaf
Am 25.01.2012 22:51, schrieb Joachim:
> CHeers
> Joachim
                                        computertechnik.de
Guest
Hi all again,
based on, and for the InterTechno fans I have modified also the CUL/CUNO
firmwares another time for InterTechno.
Right now you could send at ALL TIMES InterTechno commands.
If you are using a CUL/CUNO 868-MHZ the device will soft-tune into the
InterTechno frequency to sendout the command, and will return back to
868MHZ.
This works in SlowRF as well as in HomeMatic mode.
This also works if you are using a CUL433 but using it normally in
HomeMatic mode (like I do).
So there is NO need anymore to change frequency by hand down to 433MHZ!
This means also, that softtuning is NOT writing to Eeprom, and therefore
not impacting CUL/CUNOs lifetime.
Best,
Olaf
                                        computertechnik.de
Guest
Hi Olaf,
I use IT with the raw command since a while and really appreciate your
efforts!
Do these recent changes also include receiving capabilities for IT?
Thanks,
Marc
On 26 Jan., 02:15, Olaf Droegehorn computertechnik.de> wrote:
> Hi all again,
> 868MHZ.
> Best,
> Olaf
>                                         computertechnik.de
Guest
No,
still no receiving. If somebody would like to send m some c-Code to
enable reception, I'm happy to integrate.
Thanks,
best,
Olaf
Am 26.01.2012 13:21, schrieb Marc:
> Hi Olaf,
> efforts!
> Thanks,
> Marc
> On 26 Jan., 02:15, Olaf Droegehorn> computertechnik.de>  wrote:
>> Hi all again,
>> 868MHZ.
>> Best,
>> Olaf
>>                                          computertechnik.de
                                        computertechnik.de
erwin
Hi Olaf,
i can confirm the new CUNO2.hex code is working for original IT-Switches.
I am trying to do some documentation on the Wiki, how to "translate" the
rotary swich position into the 10 bit code for defining IT in FHEM.
Many thanks for a great piece of code !!!!
Erwin
FHEM aktuell auf RaspberryPI Mdl 1-4
Maintainer: 00_KNXIO.pm 10_KNX.pm
User: CUNO2 (868 SLOWRF) - HMS100xx, FS20, FHT, 1-Wire  - 2401(iButton), 18x20, 2406, 2413 (AVR), 2450,..,MQTT2, KNX, SONOFF, mySENSORS,....
Hardware:  Busware ROT, Weinzierl IP731, 1-Wire GW,...
erwin
Hi Olaf,
i can confirm that the IT Module is working on a CUNO2 868Mhz! fanatasic
work! Thank you!
As a small contribution to this, i tried to document the way IT Swich
numbers are translated into FHEM IT definitions...
Pls. have a look into FHEM Wiki, Cat: HOWTOs.
Thanks again
Erwin
Guest
I think that I read somewhere that Intertechno and ELRO are more or
less the same. (?)
If that is really the case it should be also possible to control the
ELRO HE501EU from FHEM, right?
I don't have on at the moment but I'm looking to buy "Gurtwickler" for
my house and I'm interested in buying some that I can control via
FHEM.
Sorry for my questions but I'm brand new to FHEM and all the home
automation stuff.
Regards
Uli
MichaS
Hallo Olaf,
ich habe Deinen neues Coding für Intertechno heute auch mal mit meinem
CUL868 und CMR-500 Rolladensteuerungen gestestet - funktioniert
prima !! Bisher schalte ich IT über ein AVR-NET-IO mit RFM12 über
ECMD, was auch gut funktioniert. Ich habe jetzt mal die Hälfte der
Rolladen auf CUL umgestellt und will beobachten, ob es Probleme mit
der Reichweite und Zuverlässigkeit gibt.
Einen Fehler im fhem.log habe ich feststellen können: Er schreibt
jetzt bei jedem Start/Rereadcfg einen Eintrag mit "No I/O device found
for IT....(=MeinDevName) für jedes Device, obwohl ein korrektes IODev
zugewiesen ist (sonst würde es nicht schalten).
Übrigens günstige ELRO Funkschalter lassen sich auch auf Intertechno
umdippen und über Fhem problemlos damit schalten. Erklärung siehe z.B
hier http://isn-systems.com/tools/it2elro/readme.txt Einziger
Nachteil: die original ELRO Fernbedienungen lassen sich dann nicht
mehr verwenden.
Gruss Micha
