[BUG] heutiges Update 10_CUL_HM.pm
Begonnen von raiderxxl, 20 November 2017, 09:07:10
raiderxxl
Hi ich habe folgende fehler nach dem Update... Ihr auch?
2017.11.20 08:51:38 1: reload: Error:Modul 10_CUL_HM deactivated:
Can't use 'defined(%hash)' (Maybe you should just omit the defined()?) at ./FHEM/10_CUL_HM.pm line 7835, <$fh> line 403.
2017.11.20 08:51:38 0: Can't use 'defined(%hash)' (Maybe you should just omit the defined()?) at ./FHEM/10_CUL_HM.pm line 7835, <$fh> line 403.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 148, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 231, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 512, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 568, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 587, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 635, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 936, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 954, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 959, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 996, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 1024, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 1040, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1077, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2955, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3507, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3518, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3536, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_parseSDteam_2 redefined at ./FHEM/10_CUL_HM.pm line 3597, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3658, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3679, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3706, <$fh> line 416.
2017.11.20 08:51:38 1: PERL WARNING: Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3986, <$fh> line 416.
Backup wurde wiederhergestellt die alte Funktioniert wieder...
Grüßle
Pascal
FHEM VM Ubuntu-Server auf Intel® NUC-Kit NUC6i5SYH ESXi 6.5
FHEM auf Raspberry2 OSMC Hyperion und TTS
Homematic,TradfriHub und Lampen,WIFILight,Fritzbox,FritzDECT,NanoCul433,IT Steckdosen,Diverse Nachbar-Sensoren,XiaomiZigbee,
ESP_Signalduino,ESPEasy,Amad,HarmonyHub,WLED,MQTT,Tasmota....
Tedious
Habe ich auch. Bitte setz die Meldung in <code>-Tags, da will keiner seitenweise scrollen...
raiderxxl
Gmorsche,
Code war gesetzt hat es aber abgeschnitten da zu lang.. glaub ich... Ich hab es jetzt gekürzt
Tedious
Ich habe jetzt die 10_CUL_HM.pm aud dem Backup wiederhergestellt, in der Installation ersetzt und neu gestartet (shutdown restart). Läuft soweit wieder alles, als Hotfix.
octek0815
#4
Hier das Selbe. Backup aus dem RestoreDir wieder rein und alles läuft wieder.
Folgende Meldung war im Log zu sehen:
2017.11.20 10:27:12 1: reload: Error:Modul 10_CUL_HM deactivated:
Can't use 'defined(%hash)' (Maybe you should just omit the defined()?) at ./FHEM/10_CUL_HM.pm line 7835, <$fh> line 118.
2017.11.20 10:27:12 0: Can't use 'defined(%hash)' (Maybe you should just omit the defined()?) at ./FHEM/10_CUL_HM.pm line 7835, <$fh> line 118.
Und zwar beim initialisieren von jedem HM Device...
Vielleicht wäre es sinnvoll, den Titel des Threads zu ändern und dort einen Hinweis auf den Bug einzufügen.
raiderxxl
hab ich gemacht...
Danke für den Hinweis...
Wenn man das tut, was die Fehlermeldung als mögliche Lösung bereits vorschlägt:
funktioniert auch die heutige Modulversion ohne Fehlermeldung.
raiderxxl
Na Toll, jetzt steh ich ganz schön dumm da, denn ich habe keine Ahnung was das zu bedeuten hat...
Bin Kein Programmierer ... nur Dummer User (in diesem Fall)
Grüßle
Pascal
octek0815
Ich denke wir sollten hier Ruhe bewahren.
Als Workaround ist ja immer ein Rollback möglich!
Martin liest bestimmt mit und wird das schon zeitnah fixen.
Das denke ich auch. Mein Hinweis oben war auch eher als Hinweis an martin gerichtet ;)
raiderxxl
fstefan1960
#12
Hiiiilfe!
Hallo, ich habe zwar eine alte 10_CUL_HM.pm wieder eingebaut, aber alle Geräte, die für CUL_HM definiert sind, sind weg und kommen trotz mehrfachen "shutdown restart" s nicht wieder ....
Auch "rereadcfg" bringt nix ...
Evtl. ist meine 10_CUL_HM.cfg zu alt. Kann man irgendwo die letzte funktionierende downloaden?
FHEM auf PC: CUL868, CUL 443, HM_LAN, JeeLink
FHEM auf Raspi: CUL868
div. LaCrosse Temp/Hum-Sensoren, HM-Heizkörperventile, Schaltaktoren, etc.
marvin78
Dann hast du vermutlich ein save gemacht. Backup-Config einspielen und alles ist gut.
oder einfach eine Vorgängerversion aus der configDB zurückholen  :P
so eine Datei ist mir unbekannt...
