[37_echodevice] Amazon Echo Modul (nicht Alexa)
Begonnen von michael.winkler, 12 Januar 2018, 18:20:12
roadghost
Teil 1
2020.04.13 11:49:52.217 3: [Echo] [echodevice_NPMLoginNew] Node Version 10.20.0
2020.04.13 11:49:52.248 4: [Echo] [echodevice_NPMLoginNew] Check Interface=lo IP=127.0.0.1
2020.04.13 11:49:52.248 4: [Echo] [echodevice_NPMLoginNew] Check Interface=lo IP=::1
2020.04.13 11:49:52.249 4: [Echo] [echodevice_NPMLoginNew] Check Interface=enp3s0 IP=192.168.188.27
2020.04.13 11:49:52.249 4: [Echo] [echodevice_NPMLoginNew]   Result Interface=enp3s0 IP=192.168.188.27
2020.04.13 11:49:52.249 4: [Echo] [echodevice_NPMLoginNew] Check Interface=enp3s0 IP=fe80::baae:edff:fe77:be69
2020.04.13 11:49:52.249 4: [Echo] [echodevice_NPMLoginNew]   Result Interface=enp3s0 IP=fe80::baae:edff:fe77:be69
2020.04.13 11:49:52.249 4: [Echo] [echodevice_NPMLoginNew] Check Interface=tun0 IP=192.178.176.10
2020.04.13 11:49:52.249 4: [Echo] [echodevice_NPMLoginNew]   Result Interface=tun0 IP=192.178.176.10
2020.04.13 11:49:52.289 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port Aktive Internetverbindungen (Server und stehende Verbindungen)
2020.04.13 11:49:52.290 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port Proto Recv-Q Send-Q Local Address           Foreign Address         State
2020.04.13 11:49:52.290 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 *:cisco-sccp            *:*                     LISTEN
2020.04.13 11:49:52.290 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 *:1234                  *:*                     LISTEN
2020.04.13 11:49:52.290 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 *:8083                  *:*                     LISTEN
2020.04.13 11:49:52.290 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 *:8084                  *:*                     LISTEN
2020.04.13 11:49:52.290 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 *:8085                  *:*                     LISTEN
2020.04.13 11:49:52.290 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 *:ssh                   *:*                     LISTEN
2020.04.13 11:49:52.291 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:smtp          *:*                     LISTEN
2020.04.13 11:49:52.291 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 *:8090                  *:*                     LISTEN
2020.04.13 11:49:52.291 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:46720         *:*                     LISTEN
2020.04.13 11:49:52.291 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:44899         *:*                     LISTEN
2020.04.13 11:49:52.291 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:54038         localhost:1234          VERBUNDEN
2020.04.13 11:49:52.291 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:8083   Hoellenlaptop.loc:52192 VERBUNDEN
2020.04.13 11:49:52.291 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp tasmota-1212.loca:59779 VERBUNDEN
2020.04.13 11:49:52.291 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59794         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.291 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54907 LAST_ACK
2020.04.13 11:49:52.291 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59774         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.291 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp ESP_C3ABF9.locald:63142 VERBUNDEN
2020.04.13 11:49:52.292 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59702         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.292 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:8083   Hoellenlaptop.loc:52190 VERBUNDEN
2020.04.13 11:49:52.292 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54906 LAST_ACK
2020.04.13 11:49:52.292 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59760         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.292 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:50282         localhost:46720         TIME_WAIT
2020.04.13 11:49:52.292 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:42828  fritz.box.localdo:49000 TIME_WAIT
2020.04.13 11:49:52.292 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp tasmota-7741.loca:62510 VERBUNDEN
2020.04.13 11:49:52.292 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp tasmota-0897.loca:51648 VERBUNDEN
2020.04.13 11:49:52.292 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:39004  fritz.box.localdom:http TIME_WAIT
2020.04.13 11:49:52.292 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:39002  fritz.box.localdom:http TIME_WAIT
2020.04.13 11:49:52.292 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:8083   Hoellenlaptop.loc:52170 VERBUNDEN
2020.04.13 11:49:52.293 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54898 LAST_ACK
2020.04.13 11:49:52.293 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54900 LAST_ACK
2020.04.13 11:49:52.293 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59762         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.293 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59776         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.293 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59782         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.293 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59764         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.293 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:50274         localhost:46720         TIME_WAIT
2020.04.13 11:49:52.293 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59786         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.293 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59778         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.293 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:39012  fritz.box.localdom:http TIME_WAIT
2020.04.13 11:49:52.293 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:44899         localhost:35910         VERBUNDEN
2020.04.13 11:49:52.294 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59754         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.294 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp ESP_C3F44E.locald:51870 VERBUNDEN
2020.04.13 11:49:52.294 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:50362         localhost:46720         TIME_WAIT
2020.04.13 11:49:52.294 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:8083   Hoellenlaptop.loc:52186 VERBUNDEN
2020.04.13 11:49:52.294 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:33214  fhem.localdomain:8085   TIME_WAIT
2020.04.13 11:49:52.294 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54911 LAST_ACK
2020.04.13 11:49:52.294 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:50518         localhost:46720         TIME_WAIT
2020.04.13 11:49:52.294 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp tasmota-6895.loca:53675 VERBUNDEN
2020.04.13 11:49:52.294 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp ESP_C3BF43.locald:61457 VERBUNDEN
2020.04.13 11:49:52.294 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:59670  v22017084837452117:1200 VERBUNDEN
2020.04.13 11:49:52.341 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54912 LAST_ACK
2020.04.13 11:49:52.342 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp tasmota-0251.loca:65481 VERBUNDEN
2020.04.13 11:49:52.342 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 192.178.176.10:59970    fhem.de:58824           TIME_WAIT
2020.04.13 11:49:52.342 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59772         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.342 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 192.178.176.10:48800    server-143-204-20:https VERBUNDEN
2020.04.13 11:49:52.342 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54903 LAST_ACK
2020.04.13 11:49:52.342 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:55020  192.168.188.30:502      VERBUNDEN
2020.04.13 11:49:52.342 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54905 LAST_ACK
2020.04.13 11:49:52.342 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54904 LAST_ACK
2020.04.13 11:49:52.342 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54902 LAST_ACK
2020.04.13 11:49:52.342 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp tasmota-0927.loca:63883 VERBUNDEN
2020.04.13 11:49:52.342 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:8083   Hoellenlaptop.loc:52169 VERBUNDEN
2020.04.13 11:49:52.343 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:50376         localhost:46720         TIME_WAIT
2020.04.13 11:49:52.343 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59770         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.343 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54908 LAST_ACK
2020.04.13 11:49:52.343 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:35910         localhost:44899         VERBUNDEN
2020.04.13 11:49:52.343 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59758         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.343 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59768         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.343 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:39080  fritz.box.localdom:http TIME_WAIT
2020.04.13 11:49:52.343 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp tasmota-3821.loca:65379 VERBUNDEN
2020.04.13 11:49:52.343 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:8083   Hoellenlaptop.loc:52171 VERBUNDEN
2020.04.13 11:49:52.343 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59780         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.343 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:1234          localhost:54038         VERBUNDEN
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54899 LAST_ACK
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:44848  fritz.box.localdom:1012 VERBUNDEN
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:50288         localhost:46720         TIME_WAIT
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59788         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59796         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:8083          localhost:59752         VERBUNDEN
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      1 fhem.localdomain:8090   Galaxy-Tab-A-2016:54901 LAST_ACK
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 192.178.176.10:59988    fhem.de:58824           VERBUNDEN
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdomain:39024  fritz.box.localdom:http TIME_WAIT
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:50388         localhost:46720         TIME_WAIT
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp ESP_C370CA.locald:63783 VERBUNDEN
2020.04.13 11:49:52.344 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 fhem.localdo:cisco-sccp tasmota-7767.loca:54049 VERBUNDEN
2020.04.13 11:49:52.345 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59752         localhost:8083          VERBUNDEN
2020.04.13 11:49:52.345 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp        0      0 localhost:59756         localhost:8083          TIME_WAIT
2020.04.13 11:49:52.345 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp6       0      0 [::]:ssh                [::]:*                  LISTEN
2020.04.13 11:49:52.345 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port tcp6       0      0 localhost:smtp          [::]:*                  LISTEN
2020.04.13 11:49:52.345 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port udp        0      0 *:bootpc                *:*
2020.04.13 11:49:52.345 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port Aktive Sockets in der UNIX-Domäne (Server und stehende Verbindungen)
2020.04.13 11:49:52.345 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port Proto RefCnt Flags       Type       State         I-Node   Pfad
2020.04.13 11:49:52.345 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21542    private/error
2020.04.13 11:49:52.346 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21545    private/retry
2020.04.13 11:49:52.346 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     SEQPAKET   HÖRT         10592    /run/udev/control
2020.04.13 11:49:52.346 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21548    private/discard
2020.04.13 11:49:52.346 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21551    private/local
2020.04.13 11:49:52.346 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         16761    /var/lib/lxd/unix.socket
2020.04.13 11:49:52.346 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21554    private/virtual
2020.04.13 11:49:52.346 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21557    private/lmtp
2020.04.13 11:49:52.346 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21560    private/anvil
2020.04.13 11:49:52.347 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21563    private/scache
2020.04.13 11:49:52.347 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21566    private/maildrop
2020.04.13 11:49:52.347 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21569    private/uucp
2020.04.13 11:49:52.347 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21572    private/ifmail
2020.04.13 11:49:52.347 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    15830    /var/spool/postfix/dev/log
2020.04.13 11:49:52.347 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21575    private/bsmtp
2020.04.13 11:49:52.347 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21578    private/scalemail-backend
2020.04.13 11:49:52.347 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21581    private/mailman
2020.04.13 11:49:52.348 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    10585    /run/systemd/cgroups-agent
2020.04.13 11:49:52.348 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         10586    /run/systemd/private
2020.04.13 11:49:52.348 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         10590    /run/lvm/lvmetad.socket
2020.04.13 11:49:52.348 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         10596    /run/lvm/lvmpolld.socket
2020.04.13 11:49:52.348 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         10597    /run/systemd/journal/stdout
2020.04.13 11:49:52.348 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  6      [ ]         DGRAM                    10598    /run/systemd/journal/socket
2020.04.13 11:49:52.348 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    11459    /run/systemd/journal/syslog
2020.04.13 11:49:52.348 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         11465    /run/systemd/fsck.progress
2020.04.13 11:49:52.349 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         16756    /run/snapd.socket
2020.04.13 11:49:52.349 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  11     [ ]         DGRAM                    11476    /run/systemd/journal/dev-log
2020.04.13 11:49:52.349 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         16757    /run/snapd-snap.socket
2020.04.13 11:49:52.349 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         16758    /var/run/dbus/system_bus_socket
2020.04.13 11:49:52.349 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         16759    /run/uuidd/request
2020.04.13 11:49:52.349 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         16760    /run/acpid.socket
2020.04.13 11:49:52.349 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         19447    public/pickup
2020.04.13 11:49:52.349 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         19451    public/cleanup
2020.04.13 11:49:52.349 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         18641    @ISCSIADM_ABSTRACT_NAMESPACE
2020.04.13 11:49:52.350 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         19454    public/qmgr
2020.04.13 11:49:52.350 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21506    private/tlsmgr
2020.04.13 11:49:52.350 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21509    private/rewrite
2020.04.13 11:49:52.350 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21512    private/bounce
2020.04.13 11:49:52.350 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21515    private/defer
2020.04.13 11:49:52.350 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21518    private/trace
2020.04.13 11:49:52.350 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21521    private/verify
2020.04.13 11:49:52.350 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21524    public/flush
2020.04.13 11:49:52.351 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         DGRAM                    10584    /run/systemd/notify
2020.04.13 11:49:52.351 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21527    private/proxymap
2020.04.13 11:49:52.351 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21530    private/proxywrite
2020.04.13 11:49:52.351 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21533    private/smtp
2020.04.13 11:49:52.351 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21536    private/relay
2020.04.13 11:49:52.351 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ACC ]     STREAM     HÖRT         21539    public/showq
2020.04.13 11:49:52.351 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21535
2020.04.13 11:49:52.351 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21507
2020.04.13 11:49:52.352 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21534
2020.04.13 11:49:52.352 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21577
2020.04.13 11:49:52.352 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21517
2020.04.13 11:49:52.352 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     17814    /run/systemd/journal/stdout
2020.04.13 11:49:52.352 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18041
2020.04.13 11:49:52.352 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21576
2020.04.13 11:49:52.352 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21508
2020.04.13 11:49:52.352 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     19452
2020.04.13 11:49:52.353 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    16745
2020.04.13 11:49:52.353 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21532
2020.04.13 11:49:52.353 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18044    /var/run/dbus/system_bus_socket
2020.04.13 11:49:52.353 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    18016
2020.04.13 11:49:52.353 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     19455
2020.04.13 11:49:52.353 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21531
2020.04.13 11:49:52.353 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     19446
2020.04.13 11:49:52.353 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21582
2020.04.13 11:49:52.354 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    19427
2020.04.13 11:49:52.354 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21529
2020.04.13 11:49:52.354 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21580
2020.04.13 11:49:52.354 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    15327
2020.04.13 11:49:52.354 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     15130
2020.04.13 11:49:52.354 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21528
2020.04.13 11:49:52.354 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21579
2020.04.13 11:49:52.354 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     20495
2020.04.13 11:49:52.355 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    18633
2020.04.13 11:49:52.355 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21570
NUC/Ubuntu 22.04 m. FHEM, div. Tasmota-Steckdosen, HMCFGUSB-2 für 12x HM-CC-RT-DN + 8x HM-TC-IT-WW
Rademacher DuoFern für 12 Jalousien, JeeLink für LaCrosse Temp.Sensor, WLAN-smart-Plugs,
NUKI smartlock, 2xIP-CAM, Pylontech Speicher + Sungrow WR, Unifi-AP´s + Controller auf weiterem NUC
roadghost
Teil 2
2020.04.13 11:49:52.355 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     19456
2020.04.13 11:49:52.355 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18318    /run/systemd/journal/stdout
2020.04.13 11:49:52.355 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     16956    /var/run/dbus/system_bus_socket
2020.04.13 11:49:52.355 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21526
2020.04.13 11:49:52.355 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     17813
2020.04.13 11:49:52.355 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    18038
2020.04.13 11:49:52.355 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     16955
2020.04.13 11:49:52.356 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21525
2020.04.13 11:49:52.356 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21568
2020.04.13 11:49:52.356 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21567
2020.04.13 11:49:52.356 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     17269
2020.04.13 11:49:52.356 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21523
2020.04.13 11:49:52.356 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     15725
2020.04.13 11:49:52.356 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21574
2020.04.13 11:49:52.356 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21522
2020.04.13 11:49:52.357 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21573
2020.04.13 11:49:52.357 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18716    /run/systemd/journal/stdout
2020.04.13 11:49:52.357 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21516
2020.04.13 11:49:52.357 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     15704    /run/systemd/journal/stdout
2020.04.13 11:49:52.357 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18045    /var/run/dbus/system_bus_socket
2020.04.13 11:49:52.357 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18810    /run/systemd/journal/stdout
2020.04.13 11:49:52.357 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21520
2020.04.13 11:49:52.357 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21571
2020.04.13 11:49:52.357 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21559
2020.04.13 11:49:52.357 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     15694
2020.04.13 11:49:52.358 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21562
2020.04.13 11:49:52.358 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     20728    /var/run/dbus/system_bus_socket
2020.04.13 11:49:52.358 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21561
2020.04.13 11:49:52.358 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21564
2020.04.13 11:49:52.358 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    10667
2020.04.13 11:49:52.358 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18013
2020.04.13 11:49:52.358 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21565
2020.04.13 11:49:52.358 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     14866    /run/systemd/journal/stdout
2020.04.13 11:49:52.358 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    16363
2020.04.13 11:49:52.358 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21552
2020.04.13 11:49:52.359 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     19453
2020.04.13 11:49:52.359 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     16498
2020.04.13 11:49:52.359 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     16331
2020.04.13 11:49:52.359 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         DGRAM                    14901
2020.04.13 11:49:52.359 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21553
2020.04.13 11:49:52.359 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     15696    /run/systemd/journal/stdout
2020.04.13 11:49:52.359 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21556
2020.04.13 11:49:52.359 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     16787
2020.04.13 11:49:52.359 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     15724    /run/systemd/journal/stdout
2020.04.13 11:49:52.359 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21555
2020.04.13 11:49:52.359 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18043    /var/run/dbus/system_bus_socket
2020.04.13 11:49:52.360 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18618
2020.04.13 11:49:52.360 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21558
2020.04.13 11:49:52.360 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    17951
2020.04.13 11:49:52.360 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18030
2020.04.13 11:49:52.360 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21550
2020.04.13 11:49:52.360 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21549
2020.04.13 11:49:52.360 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    21587
2020.04.13 11:49:52.360 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18025    /run/systemd/journal/stdout
2020.04.13 11:49:52.360 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21547
2020.04.13 11:49:52.360 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21546
2020.04.13 11:49:52.360 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21583
2020.04.13 11:49:52.361 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     19449
2020.04.13 11:49:52.361 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21544
2020.04.13 11:49:52.361 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21543
2020.04.13 11:49:52.361 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21519
2020.04.13 11:49:52.361 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    132467
2020.04.13 11:49:52.361 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21541
2020.04.13 11:49:52.361 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21540
2020.04.13 11:49:52.361 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     18042
2020.04.13 11:49:52.361 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     19448
2020.04.13 11:49:52.361 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21538
2020.04.13 11:49:52.362 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21537
2020.04.13 11:49:52.362 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     10791    /run/systemd/journal/stdout
2020.04.13 11:49:52.362 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     17950
2020.04.13 11:49:52.362 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     12713
2020.04.13 11:49:52.362 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     137550
2020.04.13 11:49:52.362 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     137042
2020.04.13 11:49:52.362 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21513
2020.04.13 11:49:52.362 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     137554
2020.04.13 11:49:52.362 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         DGRAM                    12915
2020.04.13 11:49:52.362 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     10856    /run/systemd/journal/stdout
2020.04.13 11:49:52.362 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    14894
2020.04.13 11:49:52.363 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     19445
2020.04.13 11:49:52.363 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    10195
2020.04.13 11:49:52.363 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         DGRAM                    12914
2020.04.13 11:49:52.363 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     12860
2020.04.13 11:49:52.363 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     137549
2020.04.13 11:49:52.363 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21511
2020.04.13 11:49:52.363 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         DGRAM                    14900
2020.04.13 11:49:52.363 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21510
2020.04.13 11:49:52.363 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     137553
2020.04.13 11:49:52.363 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     137551
2020.04.13 11:49:52.363 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  2      [ ]         DGRAM                    11522
2020.04.13 11:49:52.364 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         DGRAM                    14898
2020.04.13 11:49:52.364 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     21514
2020.04.13 11:49:52.364 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     137552
2020.04.13 11:49:52.364 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         STREAM     VERBUNDEN     137043
2020.04.13 11:49:52.364 4: [Echo] [echodevice_NPMLoginNew] Result Proxy Port unix  3      [ ]         DGRAM                    14899
2020.04.13 11:49:52.364 3: [Echo] [echodevice_NPMLoginNew] Proxy Port 3002 is free
2020.04.13 11:49:52.364 3: [Echo] [echodevice_NPMLoginNew] Proxy IP 192.168.188.27
2020.04.13 11:49:52.935 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Use as Login-Amazon-URL: amazon.de
2020.04.13 11:49:52.938 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Use as User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36
2020.04.13 11:49:52.938 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Use as Accept-Language: de-DE
2020.04.13 11:49:52.938 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Proxy-Mode enabled if needed: 192.168.188.27:3002 to listen on 192.168.188.27
2020.04.13 11:49:52.938 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Step 1: get first cookie and authentication redirect
2020.04.13 11:49:52.939 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Sending Request with {"host":"alexa.amazon.de","path":"","method":"GET","headers":{"DNT":"1","Upgrade-Insecure-Requests":"1","User-Agent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36","Accept-Language":"de-DE","Connection":"keep-alive","Accept":"*/*"}}
2020.04.13 11:49:53.267 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Response (302) - Redirect to https://www.amazon.de/ap/signin?showRmrMe=1&openid.return_to=https%3A%2F%2Falexa.amazon.de%2F&openid.identity=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&openid.assoc_handle=amzn_dp_project_dee_de&openid.mode=checkid_setup&openid.claimed_id=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&openid.ns=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0&
2020.04.13 11:49:53.279 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Sending Request with {"host":"www.amazon.de","path":"/ap/signin?showRmrMe=1&openid.return_to=https%3A%2F%2Falexa.amazon.de%2F&openid.identity=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&openid.assoc_handle=amzn_dp_project_dee_de&openid.mode=checkid_setup&openid.claimed_id=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&openid.ns=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0&","method":"GET","headers":{"DNT":"1","Upgrade-Insecure-Requests":"1","User-Agent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36","Accept-Language":"de-DE","Connection":"keep-alive","Accept":"*/*","Cookie":""},"body":""}
2020.04.13 11:49:53.549 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Response (200)
2020.04.13 11:49:53.616 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Add Cookie session-id = 260-3796361-1699504
2020.04.13 11:49:53.617 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Add Cookie session-id-time = 2217491393l
2020.04.13 11:49:54.934 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Step 2: login empty to generate session
2020.04.13 11:49:54.934 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Sending Request with {"host":"www.amazon.de","path":"/ap/signin","method":"POST","headers":{"DNT":"1","Upgrade-Insecure-Requests":"1","User-Agent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36","Accept-Language":"de-DE","Connection":"keep-alive","Content-Type":"application/x-www-form-urlencoded","Referer":"https://www.amazon.de/ap/signin?showRmrMe=1&openid.return_to=https%3A%2F%2Falexa.amazon.de%2F&openid.identity=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&openid.assoc_handle=amzn_dp_project_dee_de&openid.mode=checkid_setup&openid.claimed_id=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&openid.ns=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0&","Cookie":"session-id=260-3796361-1699504; session-id-time=2217491393l","Accept":"*/*"},"gzip":true,"body":"appActionToken=gj2B1wwd4wFhj2BxHew6dzXKWzpIslsj3D&appAction=SIGNIN&openid.return_to=ape%3AaHR0cHM6Ly9hbGV4YS5hbWF6b24uZGUv&prevRID=ape%3ANFNQNEQ3WEg3OEtHRjVCTkhNS1M%3D&workflowState=eyJ6aXAiOiJERUYiLCJlbmMiOiJBMjU2R0NNIiwiYWxnIjoiQTI1NktXIn0.wlfZaxPdoiaR2ia5AEl0k3uoqRvguXEyBqYhRV3wLyErvYVDkEWQkw.k6ZmgxO9HZ5xo5AD.JK4xn5ksuXoeUHkAebWTLOMzR6qgTyqKi2LNJSMFtXD-lZZuG7EhIl2SfScHpY2M-IHKHToBrT7TnyUyhgsUVL17-37PAs7GOax4vOAoqsGROXOMQdfHnoIefBgMO2fNSsQOOK1NY0UVjqEzVU1p7rGDahj73lJnS-pKLQMDF_ZIqkMLDSbBCACqu-xujB3qLzOeyJd2215o158lqG---NZd15hjxp7MMfjZK30FYZJt4D-RmpGyYcZdFWMTCCbZR3pFGIoli1wU_E-ccpsWLUAzUDx92VMd2n_JpJWq4Uk.HKjwKeftM0FmGaIcvsTOaQ&showPasswordChecked=false"}
2020.04.13 11:49:55.209 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Response (200)
2020.04.13 11:49:55.279 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Update Cookie session-id-time = 2217491395l
2020.04.13 11:49:55.280 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Add Cookie ubid-acbde = 260-9815786-1133851
2020.04.13 11:49:56.601 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Step 3: login with filled form, referer contains session id
2020.04.13 11:49:56.602 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Sending Request with {"host":"www.amazon.de","path":"/ap/signin","method":"POST","headers":{"DNT":"1","Upgrade-Insecure-Requests":"1","User-Agent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36","Accept-Language":"de-DE","Connection":"keep-alive","Content-Type":"application/x-www-form-urlencoded","Referer":"https://www.amazon.de/ap/signin/260-3796361-1699504","Cookie":"session-id=260-3796361-1699504; session-id-time=2217491395l; ubid-acbde=260-9815786-1133851","Accept":"*/*"},"gzip":true,"body":"appActionToken=gj2B1wwd4wFhj2BxHew6dzXKWzpIslsj3D&appAction=SIGNIN&openid.return_to=ape%3AaHR0cHM6Ly9hbGV4YS5hbWF6b24uZGUv&prevRID=ape%3ATkdHMzhISzRUMThDSzhONVNDR0Q%3D&workflowState=eyJ6aXAiOiJERUYiLCJlbmMiOiJBMjU2R0NNIiwiYWxnIjoiQTI1NktXIn0.QezmXKhH4L620ezhZji4aJ3DfUE8AM1xb-7SNBzIBf3GjDTzes3hjw.-S05g3g0wKGKj9IK.4FLHEPhomPftwXHYL1dLpcpQvxttH3edSxGmRaHHwNpu9JyxnnodI8_24MumC4YFICsn8nHdOWr4wrEXgmo_A8C_ygHFnZ5AO1iQEqpYNu2vODbX6COBMIpfs_eFKJ7gRJWZOJqTaB5qNqanEcJ6hxF65U5FXRk3dlhLhmSgf4u-aTaKCNW2mWnzPBeNZLIw-C0ae2Bs6KTyBUC0n9NXlq2Mtt2_gU6xov8nXxk3sQwtqAU_YF2QC2HATNJWXuUZI4i4U8f-k41kTUo6r9yTCOvM.6RYYVp8Ee1-csZgK0-Mavw&showPasswordChecked=false&email=LoginFHEM&password=xxxx"}
2020.04.13 11:49:56.942 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Response (200)
2020.04.13 11:49:57.027 3: [Echo] [echodevice_NPMLoginNew] Result [HPM] Proxy created: !/cookie-success  -> https://alexa.amazon.com
2020.04.13 11:49:57.030 3: [Echo] [echodevice_NPMLoginNew] Result [HPM] Proxy rewrite rule created: "^/www.amazon.com" ~> ""
2020.04.13 11:49:57.030 3: [Echo] [echodevice_NPMLoginNew] Result [HPM] Proxy rewrite rule created: "^/alexa..amazon.com" ~> ""
2020.04.13 11:49:57.057 3: [Echo] [echodevice_NPMLoginNew] Result Alexa-Cookie: Proxy-Server listening on port 3002
2020.04.13 11:49:57.058 3: [Echo] [echodevice_NPMLoginNew] Result: Bitte den Link anklicken und die Amazonanmeldung durchfuehren.
2020.04.13 11:49:57.102 3: CUL_HM set HWR_TC statusRequest
2020.04.13 11:50:00.062 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:01.066 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:02.075 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:04.574 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:05.607 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:06.066 4: [Echo] [echodevice_SendCommand] [getnotifications] START
2020.04.13 11:50:06.066 4: [Echo] [echodevice_SendCommand] [getnotifications] PushToCmdQueue SendURL =https://layla.amazon.de/api/notifications
2020.04.13 11:50:06.066 4: [Echo] [echodevice_SendCommand] [getnotifications] PushToCmdQueue SendData=
2020.04.13 11:50:06.066 4: [Echo] [echodevice_HandleCmdQueue] [getnotifications] send command=https://layla.amazon.de/api/notifications Data=
2020.04.13 11:50:06.067 4: [Echo] [echodevice_SendCommand] [alarmvolume] START
2020.04.13 11:50:06.067 4: [Echo] [echodevice_SendCommand] [alarmvolume] PushToCmdQueue SendURL =https://layla.amazon.de/api/device-notification-state?_=1586771406
2020.04.13 11:50:06.067 4: [Echo] [echodevice_SendCommand] [alarmvolume] PushToCmdQueue SendData=
2020.04.13 11:50:06.068 4: [Echo] [echodevice_SendCommand] [bluetoothstate] START
2020.04.13 11:50:06.068 4: [Echo] [echodevice_SendCommand] [bluetoothstate] PushToCmdQueue SendURL =https://layla.amazon.de/api/bluetooth?cached=true&_=1586771406
2020.04.13 11:50:06.068 4: [Echo] [echodevice_SendCommand] [bluetoothstate] PushToCmdQueue SendData=
2020.04.13 11:50:06.068 4: [Echo] [echodevice_SendCommand] [getdnd] START
2020.04.13 11:50:06.068 4: [Echo] [echodevice_SendCommand] [getdnd] PushToCmdQueue SendURL =https://layla.amazon.de/api/dnd/device-status-list?_=1586771406
2020.04.13 11:50:06.068 4: [Echo] [echodevice_SendCommand] [getdnd] PushToCmdQueue SendData=
2020.04.13 11:50:06.069 4: [Echo] [echodevice_SendCommand] [wakeword] START
2020.04.13 11:50:06.069 4: [Echo] [echodevice_SendCommand] [wakeword] PushToCmdQueue SendURL =https://layla.amazon.de/api/wake-word?_=1586771406
2020.04.13 11:50:06.069 4: [Echo] [echodevice_SendCommand] [wakeword] PushToCmdQueue SendData=
2020.04.13 11:50:06.069 4: [Echo] [echodevice_SendCommand] [listitems_task] START
2020.04.13 11:50:06.069 4: [Echo] [echodevice_SendCommand] [listitems_task] PushToCmdQueue SendURL =https://layla.amazon.de/api/todos?size=100&startTime=&endTime=&completed=false&type=TASK&deviceSerialNumber=&deviceType=&_=1586771406
2020.04.13 11:50:06.070 4: [Echo] [echodevice_SendCommand] [listitems_task] PushToCmdQueue SendData=TASK
2020.04.13 11:50:06.070 4: [Echo] [echodevice_SendCommand] [listitems_shopping] START
2020.04.13 11:50:06.070 4: [Echo] [echodevice_SendCommand] [listitems_shopping] PushToCmdQueue SendURL =https://layla.amazon.de/api/todos?size=100&startTime=&endTime=&completed=false&type=SHOPPING_ITEM&deviceSerialNumber=&deviceType=&_=1586771406
2020.04.13 11:50:06.070 4: [Echo] [echodevice_SendCommand] [listitems_shopping] PushToCmdQueue SendData=SHOPPING_ITEM
2020.04.13 11:50:06.070 4: [Echo] [echodevice_SendCommand] [getdevicesettings] START
2020.04.13 11:50:06.070 4: [Echo] [echodevice_SendCommand] [getdevicesettings] PushToCmdQueue SendURL =https://layla.amazon.de/api/device-preferences
2020.04.13 11:50:06.071 4: [Echo] [echodevice_SendCommand] [getdevicesettings] PushToCmdQueue SendData=
2020.04.13 11:50:06.071 4: [Echo] [echodevice_SendCommand] [getisonline] START
2020.04.13 11:50:06.071 4: [Echo] [echodevice_SendCommand] [getisonline] PushToCmdQueue SendURL =https://layla.amazon.de/api/devices-v2/device?cached=true&_=1586771406
2020.04.13 11:50:06.071 4: [Echo] [echodevice_SendCommand] [getisonline] PushToCmdQueue SendData=
2020.04.13 11:50:06.071 4: [Echo] [echodevice_SendCommand] [devicesstate] START
2020.04.13 11:50:06.071 4: [Echo] [echodevice_SendCommand] [devicesstate] PushToCmdQueue SendURL =https://layla.amazon.de/api/devices-v2/device?cached=true&_=1586771406
2020.04.13 11:50:06.072 4: [Echo] [echodevice_SendCommand] [devicesstate] PushToCmdQueue SendData=
2020.04.13 11:50:06.072 4: [Echo] [echodevice_SendLoginCommand] [cookielogin6]
2020.04.13 11:50:06.075 4: [Echo] [echodevice_SendCommand] [activities] START
2020.04.13 11:50:06.075 4: [Echo] [echodevice_SendCommand] [activities] PushToCmdQueue SendURL =https://layla.amazon.de/api/activities?startTime=&size=50&offset=1&_=1586771406
2020.04.13 11:50:06.075 4: [Echo] [echodevice_SendCommand] [activities] PushToCmdQueue SendData=
2020.04.13 11:50:06.075 4: [Echo] [echodevice_SendCommand] [getbehavior] START
2020.04.13 11:50:06.075 4: [Echo] [echodevice_SendCommand] [getbehavior] PushToCmdQueue SendURL =https://layla.amazon.de/api/behaviors/automations?limit=100
2020.04.13 11:50:06.076 4: [Echo] [echodevice_SendCommand] [getbehavior] PushToCmdQueue SendData=
2020.04.13 11:50:06.076 4: [Echo] [echodevice_SendCommand] [getsettingstraffic] START
2020.04.13 11:50:06.076 4: [Echo] [echodevice_SendCommand] [getsettingstraffic] PushToCmdQueue SendURL =https://layla.amazon.de/api/traffic/settings
2020.04.13 11:50:06.076 4: [Echo] [echodevice_SendCommand] [getsettingstraffic] PushToCmdQueue SendData=
2020.04.13 11:50:06.076 4: [Echo] [echodevice_GetSettings] Timer INTERVAL = 60
2020.04.13 11:50:06.280 4: [Echo] [echodevice_Parse] [getnotifications]
2020.04.13 11:50:06.329 4: [Echo] [echodevice_HandleCmdQueue] [getsettingstraffic] send command=https://layla.amazon.de/api/traffic/settings Data=
2020.04.13 11:50:06.424 4: [Echo] [echodevice_ParseAuth] [cookielogin6]
2020.04.13 11:50:06.429 4: [Echo] [echodevice_ParseAuth] JSON OK = {authentication}{authenticated}
2020.04.13 11:50:06.481 4: [Echo] [echodevice_Parse] [getsettingstraffic]
2020.04.13 11:50:06.487 4: [Echo] [echodevice_HandleCmdQueue] [getbehavior] send command=https://layla.amazon.de/api/behaviors/automations?limit=100 Data=
2020.04.13 11:50:06.616 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:06.671 4: [Echo] [echodevice_Parse] [getbehavior]
2020.04.13 11:50:06.676 4: [Echo] [echodevice_HandleCmdQueue] [activities] send command=https://layla.amazon.de/api/activities?startTime=&size=50&offset=1&_=1586771406 Data=
2020.04.13 11:50:07.276 4: [Echo] [echodevice_Parse] [activities]
2020.04.13 11:50:07.289 4: [Echo] [echodevice_HandleCmdQueue] [devicesstate] send command=https://layla.amazon.de/api/devices-v2/device?cached=true&_=1586771406 Data=
2020.04.13 11:50:07.625 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:07.667 4: [Echo] [echodevice_Parse] [devicesstate]
2020.04.13 11:50:07.698 4: [Echo] [echodevice_HandleCmdQueue] [getisonline] send command=https://layla.amazon.de/api/devices-v2/device?cached=true&_=1586771406 Data=
2020.04.13 11:50:08.110 4: [Echo] [echodevice_Parse] [getisonline]
2020.04.13 11:50:08.142 4: [Echo] [echodevice_HandleCmdQueue] [getdevicesettings] send command=https://layla.amazon.de/api/device-preferences Data=
2020.04.13 11:50:08.635 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:09.555 4: [Echo] [echodevice_Parse] [getdevicesettings]
2020.04.13 11:50:09.572 4: [Echo] [echodevice_HandleCmdQueue] [listitems_shopping] send command=https://layla.amazon.de/api/todos?size=100&startTime=&endTime=&completed=false&type=SHOPPING_ITEM&deviceSerialNumber=&deviceType=&_=1586771406 Data=
2020.04.13 11:50:09.641 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:09.674 4: [Echo] [echodevice_Parse] [listitems_shopping]
2020.04.13 11:50:09.678 4: [Echo] [echodevice_HandleCmdQueue] [listitems_task] send command=https://layla.amazon.de/api/todos?size=100&startTime=&endTime=&completed=false&type=TASK&deviceSerialNumber=&deviceType=&_=1586771406 Data=
2020.04.13 11:50:09.774 4: [Echo] [echodevice_Parse] [listitems_task]
2020.04.13 11:50:09.780 4: [Echo] [echodevice_HandleCmdQueue] [wakeword] send command=https://layla.amazon.de/api/wake-word?_=1586771406 Data=
2020.04.13 11:50:09.994 4: [Echo] [echodevice_Parse] [wakeword]
2020.04.13 11:50:10.020 4: [Echo] [echodevice_HandleCmdQueue] [getdnd] send command=https://layla.amazon.de/api/dnd/device-status-list?_=1586771406 Data=
2020.04.13 11:50:10.649 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:10.879 4: [Echo] [echodevice_Parse] [getdnd]
2020.04.13 11:50:10.902 4: [Echo] [echodevice_HandleCmdQueue] [bluetoothstate] send command=https://layla.amazon.de/api/bluetooth?cached=true&_=1586771406 Data=
2020.04.13 11:50:11.583 4: [Echo] [echodevice_Parse] [bluetoothstate]
2020.04.13 11:50:11.604 4: [Echo] [echodevice_HandleCmdQueue] [alarmvolume] send command=https://layla.amazon.de/api/device-notification-state?_=1586771406 Data=
2020.04.13 11:50:11.655 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:12.335 4: [Echo] [echodevice_LoginStart] Alter COOKIE=1391/6000
2020.04.13 11:50:12.335 4: [Echo] [echodevice_LoginStart] [enable] set next internal timer start in 60 seconds.
2020.04.13 11:50:12.662 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:12.701 4: [Echo] [echodevice_Parse] [alarmvolume]
2020.04.13 11:50:13.669 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:14.682 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:15.688 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:16.701 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:17.708 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:18.720 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:19.733 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:20.747 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:21.760 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:22.775 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:23.788 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:24.800 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:25.814 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:26.827 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:27.840 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:28.850 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] wait for refreshtoken / refreshtoken unkown!! refreshtoken=null EXIST 795create-cookie.js = true
2020.04.13 11:50:29.852 3: [Echo] [echodevice_NPMWaitForCookie] [NPM Login New Mon Apr 13 11:49:52 2020] write new refreshtoken
michael.winkler
#3917
Vielen Dank fürs testen. Leider gefällt mir das Ergebnis noch nicht. Könntest Du die angehängte Version kurz mal testen?
Logtechnisch würde mir dieser Bereich reichen.
Zitat von: roadghost am 13 April 2020, 11:53:29
Teil 1
fh168
hallo gemeinde,
ich höre nur die Glocken, nicht den Text
defmod Octoprint_finish_DOIF DOIF (([3dPrint:progress_completion_percent] eq "100") and ([?08:00-23:00])) (set ECHO_G000JN0573370BS sounds glocken, set ECHO_G000JN0573370BS speak Der drei D Druck ist beendet)
attr Octoprint_finish_DOIF room Logik
liebe Grüsse
robin
Hue, Lacrosse, PCA301, MySensors, V 1.67 CUL 868 V3.4, Lacrosse-WLAN-Gateway, Tasmota RF-
volschin
Müssen die set-Befehle nicht mit einem Semikolon getrennt werden oder ist das bei DOIF anders?
TomLee
Du führst beide Befehle fast gleichzeitig aus, du musst eine Pause einbauen:
defmod Octoprint_finish_DOIF DOIF (([3dPrint:progress_completion_percent] eq "100") and ([?08:00-23:00])) (set ECHO_G000JN0573370BS sounds glocken) (set ECHO_G000JN0573370BS speak Der drei D Druck ist beendet)
attr Octoprint_finish_DOIF wait 0:2
Thomas
Sailor
Ein herzerfrischendes "Moin" vom actern Diek vorweg!
Ich habe ein AMAZON connect definiert mit
   CFGFN      ./cfg/Alexa.cfg
   DEF        crypt:Geheim! crypt:AuchGeheim!
   FUUID      5c499381-f33f-02bc-5f70-38e57937373d61be
   IODev
   LOGINMODE  NORMAL
   NAME       AC_AmazonCom
   NR         758
   NTFY_ORDER 50-AC_AmazonCom
   STATE      connected
   TYPE       echodevice
   model      ACCOUNT
   OLDREADINGS:
     2020-04-15 12:55:23   2FACode         not used
     2020-04-15 13:05:29   BrowserLanguage de,en-US;q=0.7,en;q=0.3
     2020-04-15 13:05:29   BrowserUserAgent Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:62.0) Gecko/20100101 Firefox/62.0
     2020-04-15 12:56:14   COOKIE_MODE     NORMAL
     2020-04-15 12:55:22   COOKIE_STATE    START
     2020-04-15 12:56:19   COOKIE_TYPE     READING
     2020-04-15 13:05:29   alarm_count     0
     2020-04-15 13:02:32   autocreate_devices running
     2020-04-15 13:05:29   config_address_between -
     2020-04-15 13:05:29   config_address_from -
     2020-04-15 13:05:29   config_address_to -
     2020-04-15 08:29:07   list_SHOPPING_ITEM
     2020-04-15 08:29:07   list_TASK
     2020-04-15 13:05:29   musicalarm_count 0
     2020-04-15 13:05:29   reminder_count  0
     2020-04-15 13:05:29   state           connected
     2020-04-15 13:05:29   timer_count     0
     2020-04-15 13:05:29   timer_id        -
     2020-04-15 13:05:29   timer_remainingtime 0
     2020-04-15 12:56:19   version         0.1.3
   helper:
     CMD_QUEUE
     RUNLOGIN   0
     RUNNING_REQUEST 0
     SERVER     layla.amazon.de
     TWOFA
     echodevice_refreshvoice 0
     echodevice_refreshvoice_lastdate 1586944686.12729
     getsettingstraffic:
       between
       from
       to
     notifications:
       _account:
   DbLogExclude .*
   autocreate_refresh 1
   browser_save_data 1
   icon       echo
   room       Alexa-Control
   server     layla.amazon.de
Was sich auch ganz brav connected.
Wenn ich jetzt mittels "set AC_AmazonCom autocreate_devices" veruche meinen echo zu installieren, erscheint nur:
<html><table align="" border="0" cellspacing="0" cellpadding="3" width="100%" height="100%" class="mceEditable"><tbody><p>Devices:</p><tr><td><strong>Serial</strong></td><td><strong>Family</strong></td><td><strong>Devicetype</strong></td><td><strong>Name</strong></td></tr>
Mach ich was falsch oder ist das ein Bug?
    Sailor
Man wird immer besser...
michael.winkler
   IODev
   LOGINMODE  NORMAL
   NAME       AC_AmazonCom
   NR         758
   STATE      connected
   TYPE       echodevice
   model      ACCOUNT
   OLDREADINGS:
   helper:
     CMD_QUEUE
     RUNLOGIN   0
     RUNNING_REQUEST 0
     TWOFA
     getsettingstraffic:
       between
       from
       to
     notifications:
       _account:
   DbLogExclude .*
   browser_save_data 1
   icon       echo
   room       Alexa-Control
    Sailor
Ich würde Dir empfehlen Deinen Login Modus auf NPM umzustellen. Weitere Infos dazu findest du hier https://mwinkler.jimdo.com/smarthome/eigene-module/echodevice/#Definition%20in%20FHEM
Sailor
Hallo Michael
Erledigt und schwupps funktionierts!
Allerdings musste ich den Befehl "set myAmazonAccount NPM_login new" manuell eingeben, da er nach der Definition des entsprechenden Device nicht in der Auswahlliste auftauchte.
Danach funktionierte alles wie beschrieben.
Ist das ein Bug oder ein Feature?
    Sailor
michael.winkler
Zitat von: Sailor am 15 April 2020, 14:16:04
Hallo Michael
    Sailor
Kannst Du mal ein get status von Deinem Account Device zusenden?
Sailor
Hallo Michael
Klar!
Modul Infos:
Beschreibung    Bereich    Wert
STATE    Reading connected
Version    Reading 0.1.3
COOKIE_STATE    Reading OK
COOKIE_TYPE    Reading NPM_Login
COOKIE_MODE    Reading NORMAL
amazon_refreshtoken    Reading vorhanden
icon    Attribut echo
room    Attribut Alexa-Control
Amazon Cookie:
.COOKIE    Reading {"loginCookie":"frc=....
.COOKIE    Helper session-id=257-34574....
.COMMSID    Helper amzn1.comms.id.perso....
.CSRF    Helper -12....
.DIRECTID    Helper amzn1.account.AHEG4S....
RUNLOGIN    Helper 0
RUNNING_REQUEST    Helper 0
LOGINERROR    Helper 0
   Sailor
michael.winkler
Zitat von: Sailor am 15 April 2020, 15:22:28
Hallo Michael
Klar!
Modul Infos:
icon    Attribut echo
Amazon Cookie:
RUNLOGIN    Helper 0
LOGINERROR    Helper 0
   Sailor
Da ist nichts auffälliges zu sehen. Eventuell hätte ein Aktualisieren der FHEM Webseite die Punkte angezeigt.
Sailor
Hallo Michael
Ich hatte das Device neu angelegt. Von daher...
Vielleicht war was im Cache.
Was solls... Es funzt!
    Sailor
cs-online
ich habe etwas merkwürdiges beobachtet, seit ein paar Tagen habe ich über den Daumen relativ regelmäßig alle 90 (?) Minuten Freezewerte um 5-6 Sekunden, wo das normalerweise bei ca. 1s liegt. Ich habe Freezemon dann mal loggen lassen und bekomme folgendes Log, in dem hauptächlich das Echo-Modul: tmr-echodevice_NPMWaitForCookie(Echos), alle Echos sind verbunden und laufen auch, wenn ich z.B. Sounds wiedergeben lasse. Hat sich irgendwas z.B. mit update geändert, was das erklären könnte ? Ein NPNLogin refresh hat keine Besserung gebracht. Die Einträge habe ich vorher noch nie im Freezemon gesehen.
2020.04.16 00:39:54 5: [Freezemon] myfreezemon: ----------- Starting Freeze handling at 2020.04.16 00:39:54.593 ---------------------
2020.04.16 00:39:54 5: [Freezemon] myfreezemon found something that's not a REF HMUARTLGW_CheckCredits
2020.04.16 00:39:54 1: [Freezemon] myfreezemon: possible freeze starting at 00:39:49, delay is 5.593 possibly caused by: tmr-at_Exec(Stromwerte_Timer2) tmr-HMUARTLGW_CheckCredits(HM_Gateway) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_LoginStart(Echos) tmr-ENIGMA2_GetStatus(Dreambox_Schlafzimmer) tmr-SYSMON_Update(Sysmon)
2020.04.16 00:39:54 5: [Freezemon] myfreezemon: ----------- Ending Freeze handling at 2020.04.16 00:39:54.655 after 0.062082 --------
2020.04.16 02:21:01 5: [Freezemon] myfreezemon: ----------- Starting Freeze handling at 2020.04.16 02:21:01.358 ---------------------
2020.04.16 02:21:01 1: [Freezemon] myfreezemon: possible freeze starting at 02:20:56, delay is 5.358 possibly caused by: tmr-echodevice_LoginStart(Echos) tmr-ENIGMA2_GetStatus(Dreambox_Schlafzimmer) tmr-SYSMON_Update(Sysmon) tmr-PRESENCE_StartLocalScan(Gewaechshaus_Ping) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos)
2020.04.16 02:21:01 5: [Freezemon] myfreezemon: ----------- Ending Freeze handling at 2020.04.16 02:21:01.402 after 0.044075 --------
2020.04.16 04:02:08 5: [Freezemon] myfreezemon: ----------- Starting Freeze handling at 2020.04.16 04:02:08.057 ---------------------
2020.04.16 04:02:08 1: [Freezemon] myfreezemon: possible freeze starting at 04:02:02, delay is 6.057 possibly caused by: tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_LoginStart(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-ENIGMA2_GetStatus(Dreambox_Schlafzimmer) tmr-SYSMON_Update(Sysmon) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos)
2020.04.16 04:02:08 5: [Freezemon] myfreezemon: ----------- Ending Freeze handling at 2020.04.16 04:02:08.110 after 0.053469 --------
2020.04.16 05:43:14 5: [Freezemon] myfreezemon: ----------- Starting Freeze handling at 2020.04.16 05:43:14.277 ---------------------
2020.04.16 05:43:14 1: [Freezemon] myfreezemon: possible freeze starting at 05:43:09, delay is 5.276 possibly caused by: tmr-echodevice_LoginStart(Echos) tmr-ENIGMA2_GetStatus(Dreambox_Schlafzimmer) tmr-SYSMON_Update(Sysmon) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos)
2020.04.16 05:43:14 5: [Freezemon] myfreezemon: ----------- Ending Freeze handling at 2020.04.16 05:43:14.321 after 0.044963 --------
2020.04.16 07:24:20 5: [Freezemon] myfreezemon: ----------- Starting Freeze handling at 2020.04.16 07:24:20.395 ---------------------
2020.04.16 07:24:20 1: [Freezemon] myfreezemon: possible freeze starting at 07:24:15, delay is 5.394 possibly caused by: tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_LoginStart(Echos) tmr-ENIGMA2_GetStatus(Dreambox_Schlafzimmer) tmr-SYSMON_Update(Sysmon)
2020.04.16 07:24:20 5: [Freezemon] myfreezemon: ----------- Ending Freeze handling at 2020.04.16 07:24:20.451 after 0.055883 --------
2020.04.16 09:05:26 5: [Freezemon] myfreezemon: ----------- Starting Freeze handling at 2020.04.16 09:05:26.710 ---------------------
2020.04.16 09:05:26 1: [Freezemon] myfreezemon: possible freeze starting at 09:05:21, delay is 5.71 possibly caused by: tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_LoginStart(Echos)
2020.04.16 09:05:26 5: [Freezemon] myfreezemon: ----------- Ending Freeze handling at 2020.04.16 09:05:26.729 after 0.018987 --------
2020.04.16 09:54:57 0: ERROR: Cannot autoload SD_GT
2020.04.16 10:46:32 5: [Freezemon] myfreezemon: ----------- Starting Freeze handling at 2020.04.16 10:46:32.813 ---------------------
2020.04.16 10:46:32 1: [Freezemon] myfreezemon: possible freeze starting at 10:46:27, delay is 5.813 possibly caused by: tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_LoginStart(Echos)
2020.04.16 10:46:32 5: [Freezemon] myfreezemon: ----------- Ending Freeze handling at 2020.04.16 10:46:32.833 after 0.020776 --------
2020.04.16 12:27:39 5: [Freezemon] myfreezemon: ----------- Starting Freeze handling at 2020.04.16 12:27:39.839 ---------------------
2020.04.16 12:27:39 1: [Freezemon] myfreezemon: possible freeze starting at 12:27:34, delay is 5.838 possibly caused by: tmr-echodevice_LoginStart(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-ENIGMA2_GetStatus(Dreambox_Schlafzimmer) tmr-SYSMON_Update(Sysmon) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos) tmr-echodevice_NPMWaitForCookie(Echos)
2020.04.16 12:27:39 5: [Freezemon] myfreezemon: ----------- Ending Freeze handling at 2020.04.16 12:27:39.887 after 0.047815 --------
FHEM auf RPI 4 4GB, HM-WLAN-Gateway, einige HM-Aktoren,2x EBUSD an Heizung+Solar, ESP8266/32 am Strom-,Gas-,Wasserzähler, in WLAN-Steckdosen und Relaisleisten, Sonoff S20+S26,Shelly1/2/2.5, Lacrosse-Gateway und Sensoren,Sduino,Alexa-Fhem,Huawei PV+Speicher, alles auf einem RPI und da geht noch mehr
michael.winkler
Zitat von: cs-online am 16 April 2020, 13:10:42
Hast Du an Deinem FHEM "global" Device den DNS Server gesetzt? Wenn nicht solltes Du das mal machen. https://mwinkler.jimdo.com/smarthome/fhem/grundkonfiguration/
Wenn es keine Besserung bringt, dann mal bitte das Account Device auf Verbose 4 stellen und einen login refresh anstarten. Eventuell kann man da sehen was bei Dir genau passiert.
