[gelöst] FHEM startet nicht mehr! reload: Error:Modul 10_CUL_HM deactivated:
Begonnen von Burny4600, 11 Februar 2018, 15:57:41
Burny4600
FHEM hat sich nach dem heutigem Update stark verlangsamt.
Nach einem Reboot startet FHEM überhaupt nicht mehr und das LOG wird mit CUL_HM Meldungen nur so aufgefüllt.
2018.02.11 15:49:05.433 1: Including /media/hdd/fhem/mycfg/HM/hm_rasp01.cfg
2018.02.11 15:49:06.036 1: reload: Error:Modul 10_CUL_HM deactivated:
Global symbol "$oldIODevH" requires explicit package name (did you forget to declare "my $oldIODevH"?) at ./FHEM/10_CUL_HM.pm line 9095, <$fh> line 18.
Global symbol "$oldIODevH" requires explicit package name (did you forget to declare "my $oldIODevH"?) at ./FHEM/10_CUL_HM.pm line 9096, <$fh> line 18.
Global symbol "$newIODevH" requires explicit package name (did you forget to declare "my $newIODevH"?) at ./FHEM/10_CUL_HM.pm line 9126, <$fh> line 18.
2018.02.11 15:49:06.037 0: Global symbol "$oldIODevH" requires explicit package name (did you forget to declare "my $oldIODevH"?) at ./FHEM/10_CUL_HM.pm line 9095, <$fh> line 18.
2018.02.11 15:49:06.131 1: PERL WARNING: Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 152, <$fh> line 36.
2018.02.11 15:49:06.142 1: PERL WARNING: Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 235, <$fh> line 36.
2018.02.11 15:49:06.149 1: PERL WARNING: Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 518, <$fh> line 36.
2018.02.11 15:49:06.152 1: PERL WARNING: Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 585, <$fh> line 36.
2018.02.11 15:49:06.155 1: PERL WARNING: Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 604, <$fh> line 36.
2018.02.11 15:49:06.164 1: PERL WARNING: Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 652, <$fh> line 36.
2018.02.11 15:49:06.168 1: PERL WARNING: Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 953, <$fh> line 36.
2018.02.11 15:49:06.170 1: PERL WARNING: Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 971, <$fh> line 36.
2018.02.11 15:49:06.172 1: PERL WARNING: Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 976, <$fh> line 36.
2018.02.11 15:49:06.174 1: PERL WARNING: Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 1013, <$fh> line 36.
2018.02.11 15:49:06.176 1: PERL WARNING: Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 1041, <$fh> line 36.
2018.02.11 15:49:06.178 1: PERL WARNING: Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 1057, <$fh> line 36.
2018.02.11 15:49:06.274 1: PERL WARNING: Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1094, <$fh> line 36.
2018.02.11 15:49:06.311 1: PERL WARNING: Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2970, <$fh> line 36.
2018.02.11 15:49:06.318 1: PERL WARNING: Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3522, <$fh> line 36.
2018.02.11 15:49:06.320 1: PERL WARNING: Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3533, <$fh> line 36.
2018.02.11 15:49:06.323 1: PERL WARNING: Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3551, <$fh> line 36.
2018.02.11 15:49:06.326 1: PERL WARNING: Subroutine CUL_HM_parseSDteam_2 redefined at ./FHEM/10_CUL_HM.pm line 3612, <$fh> line 36.
2018.02.11 15:49:06.329 1: PERL WARNING: Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3673, <$fh> line 36.
2018.02.11 15:49:06.331 1: PERL WARNING: Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3694, <$fh> line 36.
2018.02.11 15:49:06.343 1: PERL WARNING: Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3721, <$fh> line 36.
2018.02.11 15:49:06.471 1: PERL WARNING: Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3987, <$fh> line 36.
2018.02.11 15:49:06.491 1: PERL WARNING: Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 6296, <$fh> line 36.
2018.02.11 15:49:06.494 1: PERL WARNING: Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 6367, <$fh> line 36.
2018.02.11 15:49:06.497 1: PERL WARNING: Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 6399, <$fh> line 36.
2018.02.11 15:49:06.500 1: PERL WARNING: Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 6408, <$fh> line 36.
2018.02.11 15:49:06.503 1: PERL WARNING: Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 6458, <$fh> line 36.
2018.02.11 15:49:06.506 1: PERL WARNING: Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 6522, <$fh> line 36.
Gab es bei der 10_CUL_HM.pm Änderungen?
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
distel
NUC-I37100
Docker: eBus, fhem, ha-bridge, unifi
Hardware: Homematic, FS20, Somfy RTS, 1wire, FBAHA, enOcean
Burny4600
LG Chris
