HM-CC-TC MISSING-ACK bei Einstellen desired-temp
Begonnen von Guest, 29 Oktober 2012, 18:30:27
Guest
Also ich habe insgesamt in meinem Produktiv System 49 FileLogs. Das
Testsystem hat nur das Thermostat definiert ohne FileLog. Ich bin jetzt
etwas verwirrt, daher poste ich hier mal meine Testconfig file:
attr global backupdir /var/media/ftp/FHEMBackups
attr global logfile ./log/fhem-%Y-%m.log
attr global modpath .
attr global motd SecurityCheck:\
WEB,WEBtablet has no basicAuth attribute.\
telnetPort has no password/globalpassword attribute.\
Running with root privileges.\
Restart fhem for a new check if the problem is fixed,\
or set the global attribute motd to none to supress this message.\
attr global statefile ./log/fhem.save
attr global userattr icon webCmd
attr global verbose 0
# pgm2 / autocreate configfile. Take a look at the other examples for more.
define WEBphone FHEMWEB 8084 global
attr WEBphone basicAuth Y2tvaHJ0OjM5NTYqS2Vs
attr WEBphone smallscreen 1
attr WEBtablet touchpad 1
define autocreate autocreate
attr autocreate autosave 1
attr autocreate device_room %TYPE
attr autocreate filelog ./log/%NAME-%Y.log
attr autocreate weblink 1
attr autocreate weblink_room Wetter
define CUNO CUL 192.168.2.34:2323 1234
attr CUNO rfmode HomeMatic
attr CUNO room CUL_HM
define telnetPort telnet 7072 global
define az_Thermostat CUL_HM 1D6A43
attr az_Thermostat actCycle 000:10
attr az_Thermostat actStatus alive
attr az_Thermostat devInfo 00FFFF
attr az_Thermostat firmware 2.1
attr az_Thermostat hmClass receiver
attr az_Thermostat model HM-CC-TC
attr az_Thermostat protCmdDel 11
attr az_Thermostat protLastRcv 2012-10-30 17:50:39
attr az_Thermostat protResndCnt 8
attr az_Thermostat protResndFailCnt 4
attr az_Thermostat protResndFailLast 2012-10-29 21:41:29
attr az_Thermostat protResndLast 2012-10-29 21:41:28
attr az_Thermostat protSndCnt 8
attr az_Thermostat protSndLast 2012-10-29 19:05:12
attr az_Thermostat room Office
attr az_Thermostat serialNr JEQ0195296
attr az_Thermostat subType thermostat
Ich hoffe das hilft. Welches eventlog meinst du? Soll ich mich über telnet
reinhängen? Den Event Monitor auslesen? Das allgemeine Log? Gibt es
vielleicht ein CUNO Log?
Am Freitag, 2. November 2012 08:38:07 UTC+1 schrieb Martin:
> nein- loglevel nicht setzen, besser loeschen.
> Wieviele Logs hatst du angelegt? Ich denke sie sollten im eventlog stehen
> Am Freitag, 2. November 2012 08:22:42 UTC+1 schrieb kohrti:
>> Hallo Martin,
>> wie komme ich denn an die Rohdaten aus dem IO Device (ebi mir CUNO)?
>> attr global verbose 5
>> attr global mseclog 1
>> und getConfig sind mir klar. Ich hatte für obige traces das EventLog
>> verwendet. Muss ich in ein Logfile des CUNO schauen, evtl aktivieren
>> (loglevel etc.)?
>> Vielen Dank für die Hilfe,
>> kohrti
Guest
Ich habe jetzt nochmal den allgemeinen Log genommen und hoffe das ist der
richtige (sieht zumindest rivhtig aus). Ich habe versucht die wichtigen
(aus meiner Sicht) Zeilen Fett zu markieren:
2012.11.02 09:57:59.232 4: Connection closed for FHEMWEB:192.168.2.20:54686
2012.11.02 09:57:59.236 4: Connection accepted from
FHEMWEB:192.168.2.20:54688
2012.11.02 09:57:59.236 4: HTTP FHEMWEB:192.168.2.20:54688 GET
/fhem?cmd=style%20eventMonitor
2012.11.02 09:57:59.312 4: /fhem?cmd=style%20eventMonitor / RL: 848 /
text/html; charset=UTF-8 / Content-Encoding: gzip
2012.11.02 09:58:00.356 4: HTTP FHEMWEB:192.168.2.20:54688 GET
/fhem?XHR=1&inform=console
*2012.11.02 09:58:10.100 5: CUL/RAW: /A0CEC86701D6A4300000000E436FF
2012.11.02 09:58:10.100 5: CUNO: A0CEC86701D6A4300000000E436 -74.5
2012.11.02 09:58:10.104 5: CUNO dispatch A0CEC86701D6A4300000000E436*
*2012.11.02 09:58:10.116 5: Triggering az_Thermostat (3 changes)*
2012.11.02 09:58:10.120 5: az_Thermostat trigger: Checking
FileLog_ActionDetector for notify
2012.11.02 09:58:10.124 5: az_Thermostat trigger: Checking
FileLog_Aussentemperatur for notify
FileLog_CUL_HM_dimmer_184110 for notify
2012.11.02 09:58:10.128 5: az_Thermostat trigger: Checking
FileLog_CUL_HM_remote_19C179 for notify
FileLog_CUL_HM_remote_19C179Btn_1 for notify
2012.11.02 09:58:10.132 5: az_Thermostat trigger: Checking
FileLog_CUL_HM_remote_19C179Btn_2 for notify
2012.11.02 09:58:10.136 5: az_Thermostat trigger: Checking
FileLog_CUL_HM_switch_185AA8Sw_1 for notify
FileLog_CUL_HM_switch_185AA8Sw_2 for notify
2012.11.02 09:58:10.140 5: az_Thermostat trigger: Checking
FileLog_CUL_HM_switch_1A5B7A for notify
FileLog_IEQ0536117 for notify
2012.11.02 09:58:10.144 5: az_Thermostat trigger: Checking
FileLog_Schaltadapter1 for notify
FileLog_Vorlauftemperatur for notify
2012.11.02 09:58:10.148 5: az_Thermostat trigger: Checking
FileLog_az2_PIDPWM for notify
2012.11.02 09:58:10.152 5: az_Thermostat trigger: Checking
FileLog_az_PIDPWM for notify
FileLog_az_Rauchmelder for notify
2012.11.02 09:58:10.156 5: az_Thermostat trigger: Checking
FileLog_az_Stehlampe for notify
FileLog_az_Stehlampe2 for notify
2012.11.02 09:58:10.160 5: az_Thermostat trigger: Checking
FileLog_az_Thermostat for notify
2012.11.02 09:58:10.172 5: az_Thermostat trigger: Checking
FileLog_az_Thermostat_Climate for notify
2012.11.02 09:58:10.176 5: az_Thermostat trigger: Checking
FileLog_az_Thermostat_Weather for notify
FileLog_az_Thermostat_WindowRec for notify
2012.11.02 09:58:10.180 5: az_Thermostat trigger: Checking
FileLog_ba_PIDPWM for notify
FileLog_ba_Thermostat for notify
2012.11.02 09:58:10.184 5: az_Thermostat trigger: Checking
FileLog_fl_Rauchmelder for notify
FileLog_gz_PIDPWM for notify
2012.11.02 09:58:10.188 5: az_Thermostat trigger: Checking
FileLog_gz_Thermostat for notify
2012.11.02 09:58:10.192 5: az_Thermostat trigger: Checking
FileLog_ka_Heizkreis1 for notify
FileLog_ka_Heizkreis2 for notify
2012.11.02 09:58:10.196 5: az_Thermostat trigger: Checking
FileLog_ka_Heizkreis3 for notify
FileLog_ka_Heizkreis4 for notify
2012.11.02 09:58:10.200 5: az_Thermostat trigger: Checking
FileLog_ka_Heizkreis5 for notify
FileLog_ka_Heizkreis6 for notify
2012.11.02 09:58:10.204 5: az_Thermostat trigger: Checking
FileLog_ka_Heizkreis7 for notify
FileLog_ka_Heizkreis8 for notify
2012.11.02 09:58:10.208 5: az_Thermostat trigger: Checking
FileLog_ku_PIDPWM for notify
2012.11.02 09:58:10.212 5: az_Thermostat trigger: Checking
FileLog_ku_Rauchmelder for notify
FileLog_ku_Thermostat for notify
2012.11.02 09:58:10.216 5: az_Thermostat trigger: Checking
FileLog_sz_PIDPWM for notify
FileLog_sz_Thermostat for notify
2012.11.02 09:58:10.220 5: az_Thermostat trigger: Checking
FileLog_wz_PIDPWM for notify
FileLog_wz_TasterEsstisch for notify
2012.11.02 09:58:10.224 5: az_Thermostat trigger: Checking
FileLog_wz_Thermostat for notify
2012.11.02 09:58:10.224 5: az_Thermostat trigger: Checking Logfile for
notify
2012.11.02 09:58:10.228 5: az_Thermostat trigger: Checking WEB for notify
2012.11.02 09:58:10.228 5: az_Thermostat trigger: Checking WEBphone for
notify
2012.11.02 09:58:10.228 5: az_Thermostat trigger: Checking WEBtablet for
notify
2012.11.02 09:58:10.232 5: az_Thermostat trigger: Checking autocreate for
notify
2012.11.02 09:58:10.232 5: az_Thermostat trigger: Checking telnetPort for
notify
FHEMWEB:192.168.2.20:54688 for notify
2012.11.02 09:58:10.347 4: Connection accepted from
FHEMWEB:192.168.2.20:54689
2012.11.02 09:58:10.347 4: HTTP FHEMWEB:192.168.2.20:54689 GET
2012.11.02 09:58:26.546 4: Connection accepted from
FHEMWEB:192.168.2.20:54690
2012.11.02 09:58:26.805 4: HTTP FHEMWEB:192.168.2.20:54690 GET
/fhem?room=Office&cmd=set+az_Thermostat+getConfig
*2012.11.02 09:58:26.809 5: Cmd: >set az_Thermostat getConfig<
2012.11.02 09:58:26.817 3: CUL_HM set az_Thermostat getConfig
2012.11.02 09:58:26.817 5: Triggering az_Thermostat (1 changes)
*2012.11.02 09:58:26.825 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.829 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.833 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.837 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.841 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.845 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.849 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.853 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.857 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.861 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.865 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.869 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.873 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.877 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.881 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.885 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.889 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.893 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.896 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.900 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.904 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.908 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.912 5: az_Thermostat trigger: Checking
2012.11.02 09:58:26.912 5: az_Thermostat trigger: Checking Logfile for
notify
2012.11.02 09:58:26.916 5: az_Thermostat trigger: Checking WEB for notify
2012.11.02 09:58:26.916 5: az_Thermostat trigger: Checking WEBphone for
notify
2012.11.02 09:58:26.920 5: az_Thermostat trigger: Checking WEBtablet for
notify
2012.11.02 09:58:26.920 5: az_Thermostat trigger: Checking autocreate for
notify
2012.11.02 09:58:26.920 5: az_Thermostat trigger: Checking telnetPort for
notify
FHEMWEB:192.168.2.20:54689 for notify
2012.11.02 09:58:26.928 4: HTTP FHEMWEB:192.168.2.20:54690 GET
/fhem?room=Office
2012.11.02 09:58:27.048 4: /fhem?room=Office / RL: 1985 / text/html;
2012.11.02 09:58:27.080 4: HTTP FHEMWEB:192.168.2.20:54690 GET
2012.11.02 09:58:27.088 4: Connection accepted from
FHEMWEB:192.168.2.20:54691
2012.11.02 09:58:27.112 4: HTTP FHEMWEB:192.168.2.20:54691 GET
/fhem?cmd=showlog%20weblink_Desired_az_Thermostat%20FileLog_az_Thermostat%20temp4desired%20az_Thermostat-2012.log&pos=
2012.11.02 09:58:27.155 5: plotcommand: get FileLog_az_Thermostat
az_Thermostat-2012.log INT 2012-11-02 2012-11-03 4:desired-temp:0:
2012.11.02 09:58:27.155 5: Cmd: >get FileLog_az_Thermostat
az_Thermostat-2012.log INT 2012-11-02 2012-11-03 4:desired-temp:0:<
2012.11.02 09:58:27.446 4:
/ RL: 1833 / image/svg+xml / Content-Encoding: gzip
2012.11.02 09:58:27.450 4: Connection accepted from
FHEMWEB:192.168.2.20:54692
2012.11.02 09:58:27.454 4: HTTP FHEMWEB:192.168.2.20:54692 GET
/fhem?cmd=showlog%20weblink_az_Thermostat%20FileLog_az_Thermostat%20temp4hum6%20az_Thermostat-2012.log&pos=
2012.11.02 09:58:27.494 5: plotcommand: get FileLog_az_Thermostat
az_Thermostat-2012.log INT 2012-11-02 2012-11-03 4:T\x3a:0: 6:H\x3a:0:
2012.11.02 09:58:27.494 5: Cmd: >get FileLog_az_Thermostat
az_Thermostat-2012.log INT 2012-11-02 2012-11-03 4:T\x3a:0: 6:H\x3a:0:<
2012.11.02 09:58:28.402 4:
/ RL: 3088 / image/svg+xml / Content-Encoding: gzip
2012.11.02 09:58:28.406 4: Connection accepted from
FHEMWEB:192.168.2.20:54693
2012.11.02 09:58:28.410 4: Connection accepted from
FHEMWEB:192.168.2.20:54694
2012.11.02 09:58:28.414 4: HTTP FHEMWEB:192.168.2.20:54693 GET
/fhem?cmd=showlog%20weblink_ka_Heizkreis6%20FileLog_ka_Heizkreis6%20fs20%20ka_Heizkreis6-2012.log&pos=
2012.11.02 09:58:28.454 5: plotcommand: get FileLog_ka_Heizkreis6
ka_Heizkreis6-2012.log INT 2012-11-02 2012-11-03 3::0:$fld[2]=~"on"?1:0
2012.11.02 09:58:28.458 5: Cmd: >get FileLog_ka_Heizkreis6
ka_Heizkreis6-2012.log INT 2012-11-02 2012-11-03 3::0:$fld[2]=~"on"?1:0<
2012.11.02 09:58:28.992 4:
/ RL: 2033 / image/svg+xml / Content-Encoding: gzip
2012.11.02 09:58:28.996 4: HTTP FHEMWEB:192.168.2.20:54694 GET
/fhem?cmd=showlog%20weblink_ka_Heizkreis7%20FileLog_ka_Heizkreis7%20fs20%20ka_Heizkreis7-2012.log&pos=
2012.11.02 09:58:29.036 5: plotcommand: get FileLog_ka_Heizkreis7
ka_Heizkreis7-2012.log INT 2012-11-02 2012-11-03 3::0:$fld[2]=~"on"?1:0
2012.11.02 09:58:29.040 5: Cmd: >get FileLog_ka_Heizkreis7
ka_Heizkreis7-2012.log INT 2012-11-02 2012-11-03 3::0:$fld[2]=~"on"?1:0<
2012.11.02 09:58:29.558 4:
*2012.11.02 09:58:36.139 5: CUL/RAW:
/A1AED84001D6A430000002100394A4551303139353239365800FFFFF6
2012.11.02 09:58:36.139 5: CUNO:
A1AED84001D6A430000002100394A4551303139353239365800FFFF -79
2012.11.02 09:58:36.143 5: CUNO dispatch
2012.11.02 09:58:36.159 3: Device az_Thermostat added to ActionDetector
with 000:10 time
2012.11.02 09:58:36.263 5: CUNO sending As104CA001F112341D6A4300040000000000
2012.11.02 09:58:36.263 5: SW: As104CA001F112341D6A4300040000000000*
2012.11.02 09:58:36.275 5: Triggering az_Thermostat (0 changes)
2012.11.02 09:58:36.283 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.286 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.290 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.294 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.298 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.302 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.306 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.310 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.314 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.318 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.322 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.326 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.330 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.338 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.342 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.346 5: az_Thermostat trigger: Checking Logfile for
notify
2012.11.02 09:58:36.346 5: az_Thermostat trigger: Checking WEB for notify
2012.11.02 09:58:36.346 5: az_Thermostat trigger: Checking WEBphone for
notify
2012.11.02 09:58:36.346 5: az_Thermostat trigger: Checking WEBtablet for
notify
2012.11.02 09:58:36.350 5: az_Thermostat trigger: Checking autocreate for
notify
2012.11.02 09:58:36.350 5: az_Thermostat trigger: Checking telnetPort for
notify
FHEMWEB:192.168.2.20:54690 for notify
*2012.11.02 09:58:36.633 5: CUL/RAW:
/A1A4C80101D6A43F11234020100020105000AF10B120C340F000000FF
2012.11.02 09:58:36.637 5: CUNO:
A1A4C80101D6A43F11234020100020105000AF10B120C340F000000 -74.5
2012.11.02 09:58:36.637 5: CUNO dispatch
2012.11.02 09:58:36.757 5: CUNO sending As104DA001F112341D6A4302040000000005
2012.11.02 09:58:36.757 5: SW: As104DA001F112341D6A4302040000000005*
*2012.11.02 09:58:36.769 5: Triggering az_Thermostat (0 changes)*
2012.11.02 09:58:36.777 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.781 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.784 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.788 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.792 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.796 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.800 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.804 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.808 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.812 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.816 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.820 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.824 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.828 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.832 5: az_Thermostat trigger: Checking
2012.11.02 09:58:36.832 5: az_Thermostat trigger: Checking Logfile for
notify
2012.11.02 09:58:36.836 5: az_Thermostat trigger: Checking WEB for notify
2012.11.02 09:58:36.836 5: az_Thermostat trigger: Checking WEBphone for
notify
2012.11.02 09:58:36.836 5: az_Thermostat trigger: Checking WEBtablet for
notify
2012.11.02 09:58:36.840 5: az_Thermostat trigger: Checking autocreate for
notify
2012.11.02 09:58:36.840 5: az_Thermostat trigger: Checking telnetPort for
notify
*2012.11.02 09:58:37.131 5: CUL/RAW:
/A1A4DA0101D6A43F11234030109292C261828005800002426302C4EF9
2012.11.02 09:58:37.131 5: CUNO:
A1A4DA0101D6A43F11234030109292C261828005800002426302C4E -77.5
2012.11.02 09:58:37.135 5: CUNO dispatch
2012.11.02 09:58:37.147 5: Triggering az_Thermostat (0 changes)*
2012.11.02 09:58:37.155 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.159 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.163 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.167 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.171 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.175 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.179 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.183 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.187 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.191 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.195 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.199 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.203 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.207 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.211 5: az_Thermostat trigger: Checking
2012.11.02 09:58:37.215 5: az_Thermostat trigger: Checking Logfile for
notify
2012.11.02 09:58:37.215 5: az_Thermostat trigger: Checking WEB for notify
2012.11.02 09:58:37.215 5: az_Thermostat trigger: Checking WEBphone for
notify
2012.11.02 09:58:37.219 5: az_Thermostat trigger: Checking WEBtablet for
notify
2012.11.02 09:58:37.219 5: az_Thermostat trigger: Checking autocreate for
notify
2012.11.02 09:58:37.219 5: az_Thermostat trigger: Checking telnetPort for
notify
2012.11.02 09:58:37.223 5: az_Thermostat trigger: Checking
*2012.11.02 09:58:38.255 5: CUNO sending
As104EA001F112341D6A4302040000000006
2012.11.02 09:58:38.255 5: SW: As104EA001F112341D6A4302040000000006
2012.11.02 09:58:38.266 5: Triggering az_Thermostat (1 changes)*
2012.11.02 09:58:38.270 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.274 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.278 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.282 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.286 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.290 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.294 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.298 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.302 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.306 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.314 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.318 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.322 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.326 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.330 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.338 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.342 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.346 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.350 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.354 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.358 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.362 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.366 5: az_Thermostat trigger: Checking
2012.11.02 09:58:38.366 5: az_Thermostat trigger: Checking Logfile for
notify
2012.11.02 09:58:38.370 5: az_Thermostat trigger: Checking WEB for notify
2012.11.02 09:58:38.370 5: az_Thermostat trigger: Checking WEBphone for
notify
2012.11.02 09:58:38.370 5: az_Thermostat trigger: Checking WEBtablet for
notify
2012.11.02 09:58:38.374 5: az_Thermostat trigger: Checking autocreate for
notify
2012.11.02 09:58:38.374 5: az_Thermostat trigger: Checking telnetPort for
notify
2012.11.02 09:58:38.486 4: HTTP FHEMWEB:192.168.2.20:54692 GET
Guest
Ich hänge mich mal hier mit rein, ich habe vor 2 Tagen von 5.2 auf 5.3
geupdated, ca. 1/3 meiner Rollläden (wechselnd) laufen seit dem nicht mehr
wie gewohnt.
z.B.
2012-11-02_07:25:00 KuecheRoll oben
2012-11-02_07:25:04 KuecheRoll MISSING ACK
Nutze den HMLAN und kein CUL.
Kann eigentlich bei "MISSING ACK" der Befehl nicht einfach nocheinmal
gesendet werden?
Guest
ich denke nicht, dass die Probleme identisch sind, da in diesem Thread der
HM-CC-TC mit einem CUL/CUNO verwendet wird.
kannst du bitte einen neuen Thread öffnen? Dabei auch angeben welche
Devices verwendet wurden.
Danke.
kohrti
Am Freitag, 2. November 2012 11:56:18 UTC+1 schrieb elo:
> wie gewohnt.
> z.B.
> gesendet werden?
Guest
Hallo Kohrti
die traces waren die, die ich brauche.
Zu sehen ist, dass es gut beginnt. Dein TC schickt die ersten Daten der
List0 vollstaendig. Danach wird List5 von Channel 2 (climate) angefragt.Das
ist eine Lange liste, da werden 15 messages empfangen. Es kommt aber nur
die erste an.
Das kann ich nicht steuern, die 15 Nachrichten kommen autonom aus dem TC.
Wenn ich davon ausgehe, dass dein TC i.O. ist hat die CUL ein Problem, oder
die FHEM-CUL sw.
CUL_HM ist also ok (jedenfalls bei diesem Versuch) - ich suche mal wieder
weiter unten
Gruss
Martin
Guest
Am Mittwoch, 31. Oktober 2012 23:25:48 UTC+1 schrieb Martin:
> Die alte Version (5.2) akzeptiert mindestens 50 % der Kommandos. Die neue
>> Version hat leider 0% Erfolg.
>> Folgende Fehlermeldungen tauchen bei mir in der Konsole auf:
> habe noch keine Erklaerung.  Welche Versin CUL_HM war bei dir in 5.2?
> Arbeitsr du mit CUL oder HMLAN?
Ich habe HMLAN im Einsatz. CUL_HM Version 1407 2012-04-04 10:54:55Z
Sehr seltsam. Ich kann alle sonstigen HomeMatic Geräte mit der aktuellsten
Version bedienen. Nur beim HM_CC_TC bekomme ich deterministisch nur MISSING
ACKs
>> [/opt/share/fhem/FHEM] # Use of uninitialized value in bitwise or (|) at
>> /opt/share/fhem/FHEM/10_CUL_HM.pm line 1948.
> kann es sein, dass in deinen Readings ein falscher Wert steht, vor dem
> Kommando?
> Schicke bitte ein 'list ' vor und nach dem Fehler
> Use of uninitialized value in substitution (s///) at
>> /opt/share/fhem/FHEM/10_CUL_HM.pm line 3107.
> Nach welchem Kommando kommt de Fehler?
Ich habe heute ein Update gemacht. Seitdem tauchen die Fehler nicht mehr
auf.
Ich habe beide Versionen auf meinem NAS und starte sie mit der selben
fhem.cfg. Natürlich nicht gleichzeitig.
Mit der alten Version klappen wie gesagt gefühlt 50-70%.
Martin was meinst Du mit falschen Werten in den Readings? Wie kann ich
diese zurücksetzen?
Meine Trace befinden sich im anderen Thread (link siehe mein vorheriger
Post in diesem Thread)
Danke für die Unterstützung!
Grüße,
Merhan
Guest
> rudolfkoenig
> ACKs
Die meisten andern sind auch nicht so störrisch :-(
> auf.
gut
> diese zurücksetzen?
In der Alten Version wirden nicht alle Werte komplett geprüft. Da konnte
man schon mal einen falschen eingeben. Die neue Prüft alle (also mehr).
Readings kann man nicht einfach rücksetzen. Waere aber sinnvoll - da man
sonst uralte Werte nicht los bekommt. Ein Verbesserungsvorschlag
> Muss ich noch bearbeiten - heute leider nicht mehr :-(
Guest
Hallo Martin et al,
ich sehe hier gerade dass noch massiv am HM-CC-TC gebastelt wird, das
scheint ja auch ein Biest zu sein.
Jedenfalls habe ich hier:
4 x HM-CC-TC
5 x VD
2 Fenster/Türkontakte
1 HMLAN
2 CUl-Sticks (eig. für FS20 und RFR genutzt)
Wenn ich testmäßig was beitragen kann z.B. Mitloggen von Anlernvorgängen
usw. dann sagt mir bitte was ich tun soll und ich stelle es hier ein.
Bei mir lässt sich auch die Temperatur nur in gefühlten 50% der Fälle
setzen (bei denen im WOR Mode scheint es nicht unbedingt besser zu klappen)
und auch das Setzen der Automatik-Temperaturen und -Zeiten ist nicht
zuverlässig, soweit ich weiss, wird das auch nicht durch Auslesen
verifiziert.
Ich habe die Dinger inzwischen auch mit dem HM-Config-Tool angelernt - also
fhem stoppen, HM-Config Tool starten und dann damit anlernen, die HM-ID ist
identisch - so habe ich zurzeit die Automatik-WErte konfiguriert weil das
zuverlässiger ging. Vll. kann ich auch solche Sachen noch irgendwie loggen,
falls sinnvoll.
Falls es noch weiter hilft, in der Schublade ist noch eine CCU mit der
gleichen HMID ...da ich die gerade nicht benutze würde ich sie auch
jemandem leihen, wenn das der Weiterentwicklung der Bedienung von
HM-Komponenten zuträglich ist.
VG!
UliM
Mitschneiden des Anlernvorgangs VD an CC wäre gut, damit ein virtuelles VD
gebaut werden kann.
Was da wie aufgezeichnet werden muss - Rudi, Martin?
Gruß Uli
Am Samstag, 3. November 2012 schrieb unimatrix :
> Hallo Martin et al,
> 4 x HM-CC-TC
> 5 x VD
> 1 HMLAN
> verifiziert.
> also fhem stoppen, HM-Config Tool starten und dann damit anlernen, die
> HM-ID ist identisch - so habe ich zurzeit die Automatik-WErte konfiguriert
> weil das zuverlässiger ging. Vll. kann ich auch solche Sachen noch
> irgendwie loggen, falls sinnvoll.
> VG!
> fhem-users+unsubscribe@googlegroups.com > 'fhem-users%2Bunsubscribe@googlegroups.com');>
Guest
also einfach hmProtocolEvents auf 5 und dann anlernen mit der Original
HMLAN-Vorgangs?
Weil das ist ja eig. kein anlernen. Es wird erst das CC angelernt, dann das
VD und dann wird per COnfig-Software eine Verknüpfung zwischen CC und VD
hergestellt.
Am Samstag, 3. November 2012 14:36:54 UTC+1 schrieb UliM:
> Hi,
> gebaut werden kann.
> Gruß Uli
>> Hallo Martin et al,
>> 4 x HM-CC-TC
>> 5 x VD
>> 1 HMLAN
>> verifiziert.
>> VG!
Guest
sorry ich meinte natürlich mit der Originalsoftware des HM
Konfigurationsadapters.
locodriver
Hallo Miteinander,
heute will ich mich - wie angekündigt - wieder melden und mein Log-File zur
Auswertung zur Verfügung stellen.
Erstmal zur Korrektur: wenn ich weiter oben vom CC geschrieben habe, so
meinte ich natürlich den TC (war nicht zu Hause und habe das aus dem Kopf
geschrieben).
Nun zu meinem LOG:
Erstmal ein paar Erklärungen. Hk0 und Hk1 sind zwei vom TC WZ_Regler
geregelte Heizkörper, WZ_Balkon ist ein gepairter RHS (Three State
Fensterkontakt).
Die VDs und den RHS habe ich erst mit dem TC gepaired und dann alles mit
Fhem. Ich habe noch Version 5.2 mit neuer Struktur.
Aus dem Log habe ich offensichtlich nicht erforderliche Geräte gelöscht und
das Log mit verbose 5 laufen lassen.
Ab ca. 19:18 habe ich den RHS von zu nach offen und dann gekippt betätigt
und dann wieder zurück. Das Fenstersymbol im TC erscheint auch nach kurzer
Verzögerung.
Ab ca. 19:19:34 habe ich mit Fhem die Disired-temp auf 24°C gesetzt - nach
einiger Zeit kam das Missing-Ack zurück. Danach habe ich noch am TC manuell
24°C eingestellt - das hat er akzeptiert und Fhem hat es dann auch auf der
Weboberfläche zurückgegeben.
Ich hoffe es hilft weiter. Das Log hat allerdings noch rund 800 Zeilen (ich
wollte nichts wichtiges löschen).
Uwe
Am Freitag, 2. November 2012 19:02:56 UTC+1 schrieb Martin:
> Hallo Kohrti
> die erste an.
> die FHEM-CUL sw.
> weiter unten
> Gruss
> Martin
fhem 6.0 auf Rpi3 Bookworm
HM-LAN-CFG (FW 0.965), HM-MOD-UART, 2x HM-TC-IT-WM-W-EU, 4x HM-Sec-RHS und 3x HM-CC-RT-DN, 6x HM-LC-Bl1-FM mit je 1x Somfy-Motor,
2x HM-LC-SW2-FM für Licht und Lüfter, 2x HM-PB-6-WM55, Alexa, Jeelinkcross, CUL, CUNO2, IR-Blaster
locodriver
Leider bekomme ich das Log-File nicht hochgeladen (Server Fehler 340). ich
versuche, es direkt an Martin zu schicken.
Am Samstag, 3. November 2012 20:35:36 UTC+1 schrieb Uwe:
> Hallo Miteinander,
> zur Auswertung zur Verfügung stellen.
> geschrieben).
> Nun zu meinem LOG:
> Fensterkontakt).
> und das Log mit verbose 5 laufen lassen.
> Verzögerung.
> (ich wollte nichts wichtiges löschen).
> Uwe
>> Hallo Kohrti
>> die erste an.
>> die FHEM-CUL sw.
>> weiter unten
>> Gruss
>> Martin
Guest
Hallo Martin,
vielen Dank für die Erklärung. Nun sind wir ja schon einen riesigen Schritt
weiter. Es tut mir Leid, dass irgendwie vieles an dir hängen bleibt. Mit
der neuen Erkenntnis haben sich die Möglichkeiten aus meiner obigen
Zusammenfassung reduziert:
*Zusammenfassung:
1. Es gibt die Idee das Protokoll mitzulauschen zwischen CC und
Fenterkontakt, der anscheinend eine sofortige Wirkung am CC hat. D.h. man
muß nicht warten bis der CC aufwacht. -->Idee von Uwe
*--> Aufgrund des Anratens von Rudolf und der Tatsache dass ein höherer
Energieverbarauch damit einhergeht sollte das als letzte Möglichkeit
betrachtet werden.*
2. Die eingebrachte Zeitdauer von 205ms (-->von fhem-hm-knecht) scheint
nicht haltbar zu sein, obwohl ich daran glaube. Aus obigem Post sieht man
aber, dass die Zeitdifferenz von 115ms + Kommunikation CC<->fhem
anscheinend länger ist. Wie man End2End messen soll weiß ich nicht. Selbst
mit Wireshark würde man nicht die Strecke CUNO-CC mitmessen. Reduktion des
Loggings und LogFiles brachte keine Besserung. --> von kohrti*
--> Mit den neuen Erkenntnissen von Martin sollte die Timing Geschichte nun
klar sein: Es gibt dieses Timing Fenster wirklich, aber es war hier
(wahrscheinlich) nicht der Fehler. (Die Zeitmessung nehme ich vor wenn
Martin evtl. mehr aus seinem Graben "weiter unten" als in seinem Modul
fertig ist.*)
3. Anscheinend hatte das setzen von desired-temp in einer älteren fhem
Version besser funktioniert. -->von Merhan
*-->Soweit ich überblickt habe wird hier noch getestet und weitergearbeitet.
4. Das Beschleunigen des fhem Prozesses brachte keine Abhilfe. --> von
kohrti
*PS
Wenn es nervt, dass ich ab und zu eine Zusammenfassung mache bitte melden.
Ich verliere sonst den Überblick. Es werden hier zwei Probleme diskutiert:
1. HM-CC-TC/VD/fhem und 2.
HM-CC-TC/fhem aber mindestens beide haben eben Problem mit "desired-temp"
setzen.
> Hallo Kohrti
> die erste an.
> die FHEM-CUL sw.
> weiter unten
> Gruss
> Martin
Guest
Hi Hary,
ich warte nochmal die Erkenntnisse von Martin (s.u.) ab und werde
anschließend die Messungen vornehmen. Ich hab's nicht vergessen :)
kohrti
Am Mittwoch, 31. Oktober 2012 14:01:43 UTC+1 schrieb fhem-hm-knecht:
> ich hatte folgenden Prüf-messaufbau
> 1.fhem auf 7390 mit ersten hmlan ip 192.168.2.80
> 2.ccu
> 3.fhem auf win7 mit zweiten hmlan ip 192.168.2.81 und wireshark um
> direkt am HMlan zu schnüffeln,
> damit man die Ergebnisse irgendwie vergleichen kann
> Eintreffen der Nachricht vom TC<-->Eintreffen Nachricht (Have Data)  =
> Zeitdifferenz Luftschnittstelle
> CCU ok = 202 - 205 msec
> 7390 ok = 200 msec
> 7390 nok = 208 msec
> win7 ok = 110 msec
> Messungen die noch fehlen sind:
> fhem mit cul, (cuno habe ich nicht)
> fhem vom letzen Winter
> fhem 5.2
> fhem 5.3
> es interessiert mich noch, da fhem gewachsen ist, fhem.pl , telnet
> ausgelagert, https, usw
> ob, und welche zeit da(wo) liegen gelassen wird.
> Allerdings macht es keinen Spass dieses auf der 7390 zu messen,
> da ich jedesmal mein Produktivsystem umbauen muß.
> Mal schauen, wann ich die Woche mir mein paar viele Stunden rauseiern
> kann
> Hary
