Shelly2 IP Schaltaktor
Begonnen von Prof. Dr. Peter Henning, 08 September 2018, 16:31:30
Bitte etwas mehr Informationen, sonst gibt es keinen Support.
Log-Auszug ?
Welches Gerät ?
Welche Attribute gesetzt ?
pah
kabanett
Log nach Installation der .pm und restart. Gerät angelegt und Verbose 5 gesetzt. Gerät wie vorab erwähnt Shelly 1!
2018.09.12 18:42:15 1: [Shelly_status] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/status
2018.09.12 18:42:15 1: [Shelly_status] has obtained data {"wifi_sta":{"connected":true,"ssid":"Netzwerkname","ip":"192.168.***.***"},"cloud":{"enabled":false,"connected":false},"time":"18:42","serial":1,"has_update":false,"mac":"************","relays" :[{"ison":true, "has_timer":true}],"update":{"status":"idle","has_update":false,"new_version":"20180910-102637/v1.2.0@7b4c6583","old_version":"20180910-102637/v1.2.0@7b4c6583"},"ram_total":51464,"ram_free":42064,"fs_size":233681,"fs_free":174947,"uptime":87889}
2018.09.12 18:42:15 1: PERL WARNING: Use of uninitialized value $ison in substitution (s///) at ./FHEM/36_Shelly.pm line 729.
2018.09.12 18:42:15 1: PERL WARNING: Use of uninitialized value $ison in substitution (s///) at ./FHEM/36_Shelly.pm line 730.
2018.09.12 18:42:47 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=on
2018.09.12 18:42:47 1: [Shelly_onoff] returns without success, cmd=?turn=on but ison=on
2018.09.12 18:42:47 1: PERL WARNING: Use of uninitialized value $overpower in string eq at ./FHEM/36_Shelly.pm line 652.
2018.09.12 18:43:12 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:43:12 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:43:25 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:43:25 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:43:43 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/1?turn=on
2018.09.12 18:43:46 1: [Shelly_onoff] has invalid JSON data
2018.09.12 18:43:55 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=on
2018.09.12 18:43:55 1: [Shelly_onoff] returns without success, cmd=?turn=on but ison=on
2018.09.12 18:44:02 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/1?turn=on
2018.09.12 18:44:02 1: [Shelly_onoff] has invalid JSON data
2018.09.12 18:44:05 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=on
2018.09.12 18:44:05 1: [Shelly_onoff] returns without success, cmd=?turn=on but ison=on
2018.09.12 18:44:08 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:44:08 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:44:10 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:44:10 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:44:15 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/1?turn=off
2018.09.12 18:44:15 1: [Shelly_onoff] has invalid JSON data
2018.09.12 18:44:19 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:44:19 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:44:40 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/1?turn=off
2018.09.12 18:44:40 1: [Shelly_onoff] has invalid JSON data
2018.09.12 18:44:43 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:44:43 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:44:52 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=on
2018.09.12 18:44:52 1: [Shelly_onoff] returns without success, cmd=?turn=on but ison=on
2018.09.12 18:44:58 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:44:58 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:45:04 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:45:04 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:45:12 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=on
2018.09.12 18:45:12 1: [Shelly_onoff] returns without success, cmd=?turn=on but ison=on
2018.09.12 18:45:18 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=on
2018.09.12 18:45:18 1: [Shelly_onoff] returns without success, cmd=?turn=on but ison=on
2018.09.12 18:45:25 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:45:25 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:48:08 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/1?turn=on
2018.09.12 18:48:08 1: [Shelly_onoff] has invalid JSON data
2018.09.12 18:48:18 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/1?turn=off
2018.09.12 18:48:18 1: [Shelly_onoff] has invalid JSON data
2018.09.12 18:48:21 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:48:21 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:48:23 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=on
2018.09.12 18:48:23 1: [Shelly_onoff] returns without success, cmd=?turn=on but ison=on
2018.09.12 18:48:55 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/1?turn=on
2018.09.12 18:48:55 1: [Shelly_onoff] has invalid JSON data
2018.09.12 18:49:01 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=on
2018.09.12 18:49:01 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/1?turn=off
2018.09.12 18:49:01 1: [Shelly_onoff] has invalid JSON data
2018.09.12 18:49:01 1: [Shelly_onoff] returns without success, cmd=?turn=on but ison=on
2018.09.12 18:49:07 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:49:07 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:49:10 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/1?turn=off
2018.09.12 18:49:10 1: [Shelly_onoff] has invalid JSON data
2018.09.12 18:49:13 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:49:13 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
2018.09.12 18:49:18 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/1?turn=on
2018.09.12 18:49:18 1: [Shelly_onoff] has invalid JSON data
2018.09.12 18:49:21 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=on
2018.09.12 18:49:21 1: [Shelly_onoff] returns without success, cmd=?turn=on but ison=on
2018.09.12 18:49:26 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/1?turn=off
2018.09.12 18:49:26 1: [Shelly_onoff] has invalid JSON data
2018.09.12 18:49:32 1: [Shelly_onoff] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/relay/0?turn=off
2018.09.12 18:49:32 1: [Shelly_onoff] returns without success, cmd=?turn=off but ison=off
Hardware: Fhem auf Raspi3 / selbtsbau CUL 433 und 868 MHz / MAX Thermostate / IT-Dosen nur noch Weihnachten / diverse ESP Aktoren/Sensoren / X10 Fernbedienung / Shelly 1, 1L, 2, 2.5, Dimmer, RGB2 / LaCrosseGateway / Zigbee2531 / diverse Zigbee Aktoren/Sensoren
#47
Ah, ok,
ich habe aus Versehen nicht die richtige Version in den ersten Post geladen. Wird umgehend behoben.
FHEMWEB muss ich noch etwas überlisten, die WebCmds funktionieren wegen der zwei Kanäle beim Shelly2 noch nicht richtig. Vorerst also immer "set <device> on|off channel" benutzen
pah
kabanett
Ich hab die neue Version installiert. Jetzt bekomme ich ein "Error:wrong channel"!
2018.09.12 20:14:55 1: [Shelly_status] called with only hash  => Issue a non-blocking call to http://192.168.***.***:80/status
2018.09.12 20:14:55 1: [Shelly_status] has obtained data {"wifi_sta":{"connected":true,"ssid":"WLan_Name!!!","ip":"192.168.***.***"},"cloud":{"enabled":false,"connected":false},"time":"20:14","serial":1,"has_update":false,"mac":"************","relays" :[{"ison":false, "has_timer":false}],"update":{"status":"idle","has_update":false,"new_version":"20180910-102637/v1.2.0@7b4c6583","old_version":"20180910-102637/v1.2.0@7b4c6583"},"ram_total":51464,"ram_free":42104,"fs_size":233681,"fs_free":174947,"uptime":93449}
2018.09.12 20:14:55 1: PERL WARNING: Use of uninitialized value $ison in substitution (s///) at ./FHEM/36_Shelly.pm line 735.
2018.09.12 20:14:55 1: PERL WARNING: Use of uninitialized value $ison in substitution (s///) at ./FHEM/36_Shelly.pm line 736.
2018.09.12 20:15:07 1: PERL WARNING: Use of uninitialized value $channel in pattern match (m//) at ./FHEM/36_Shelly.pm line 345.
2018.09.12 20:15:07 1: PERL WARNING: Use of uninitialized value $channel in concatenation (.) or string at ./FHEM/36_Shelly.pm line 346.
2018.09.12 20:15:07 1: [Shelly_Set]
2018.09.12 20:15:50 1: [Shelly_Set]
CoolTux
So lange Du nicht mehr Infos lieferst, wie ein list vom Device behaupte ich das Deine Shelly 3 kaputt ist.
Das TuxNet Wiki:
https://www.cooltux.net
kabanett
Immer noch Shelly 1 ;)
Sorry, ich bin da nicht so fit und weiß nicht was man alles benötigt! Das ist keine Absicht!!! Ich versuche dazu zu lernen.... hoffentlich klapp es :)
   BLOCKED    0
   CFGFN
   DEF        192.168.***.***
   DURATION   0
   NAME       Garage_Licht
   NR         127
   STATE      OK
   TCPIP      192.168.***.***:80
   TYPE       Shelly
   DATA:
     2018-09-12 20:14:55   cloud           disabled
     2018-09-12 20:14:55   firmware        v1.2.0
     2018-09-12 20:14:55   relay_0         off
     2018-09-12 20:14:55   state           OK
marvin78
Angepinnte Beiträge im Anfängerbereich lesen, dann bist du fit.
Bartimaus
Mal nebenbei gefragt: Wie lange habt Ihr auf die Bestellung aus Vulgarien gewartet, bzw. wie lange war das Paket unterwegs ?
B.
FHEM@AMD-Ryzen7-5700U@Debian-LXC (ProxmoxHOST), CUL1101,FS20,IT,DS18B20,DS2413(Heizungslogger),DS2423(Stromlogger)Homematic,HM-LAN,ZWave,MiniCULs,Shelly
Papa Romeo
..waren schon 1 1/2 bis 2 Wochen.
carlos
Ich habe bei amazon bestellt und ist jetzt ca. 2 Wochen her.
Leider noch nicht angekommen, da per UPS versandt wurde und ich Packstation angegeben habe.
Also Vorsicht bei Versenden an Packstation.
Soll aber demnächst kommen.
Carlos
FHEM svn auf Intel NUC mit proxmox, 3 Raspberry Pi, signalduino, nanoCUL,  toom Baumarkt Funksteckdosen, einige sonoffs, hue, shelly
CoolTux
   BLOCKED    0
   CFGFN
   DEF        192.168.***.***
   DURATION   0
   NAME       Garage_Licht
   NR         127
   STATE      OK
   TYPE       Shelly
   DATA:
Kann es sein das da Attribute fehlen? Was sagt die Commandref zu dem Thema?
Das TuxNet Wiki:
Bartimaus
Das Modul ist doch noch garnicht offizieller Bestandteil von FHEM.... in der CR finde ich momentan nix
B.
CoolTux
Die musst Du schon erstellen oder eben ein Update von FHEM machen so das FHEM sie für Dich nach dem Update erstellt.
selber machen
cd /opt/fhem/
/usr/bin/perl contrib/commandref_join.pl
oder so ähnlich. Findet man aber schnell raus.
Voraussetzung ist natürlich das pah eine geschrieben hat im Modul.
Das TuxNet Wiki:
CoolTux
Kurz geschaut und natürlich hat er eine geschrieben, sonst wäre er nicht pah
Das TuxNet Wiki:
Bartimaus
B.
