HMLAN - Lan-Interface startet dauernd neu
Begonnen von Guest, 27 November 2012, 21:18:48
Guest
Hallo Martin,
anbei das gewünschte Log mit dem angehangenen HMLAN Modul.
Markus
2012.12.02 22:58:26 1: Including /var/log/fhem/fhem.save
2012.12.02 22:58:26 0: Server started (version Fhem 5.3 (DEVELOPMENT), $Id: fhem.pl 2190 2012-11-25 11:10:19Z borisneubert $, pid 15725)
2012.12.02 22:58:26 1: General remove timer:NRW
2012.12.02 22:58:26 1: General timer Start:9 :NRW time:1354489202.56369
2012.12.02 22:58:27 3: Update structure 'Gesamte_Wohnung' to undefined because device 'AV_Receiver' has changed
2012.12.02 22:58:27 1: General timer Start:10 :HASH(0x991ada8) time:1354485537.83997
2012.12.02 22:58:28 2: FB_CALLMONITOR: loading cache file /tmp/cachefile
2012.12.02 22:58:50 1: General FD:8
2012.12.02 22:58:50 1: HMLAN_Send:  K
2012.12.02 22:58:50 1: General remove timer:keepAlive:LANCUL
2012.12.02 22:58:50 1: General timer Start:11 :keepAlive:LANCUL time:1354485555.46493
2012.12.02 22:58:50 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7A560B d2:0000
2012.12.02 22:58:57.884 1: General timer Start:12 :HASH(0x991ada8) time:1354485567.88392
2012.12.02 22:58:58.388 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A7A74F2 d:FF r:FFC9     m:B8 8670 1936C3 000000 00BA38
2012.12.02 22:58:58.391 1: RCV L:0C N:B8 F:86 CMD:70 SRC:Heizung_Wohnzimmer DST:broadcast 00BA38 (WeatherEvent TEMP:18.6 HUM:56) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 22:59:15.482 1: General FD:8
2012.12.02 22:59:15.482 1: HMLAN_Send:  K
2012.12.02 22:59:15.482 1: General remove timer:keepAlive:LANCUL
2012.12.02 22:59:15.483 1: General timer Start:13 :keepAlive:LANCUL time:1354485580.48303
2012.12.02 22:59:15.488 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7AB7C7 d2:0000
2012.12.02 22:59:18.388 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A7AC315 d:FF r:FFC9     m:B8 A258 1936C3 19399E 0020
2012.12.02 22:59:18.391 1: RCV L:0B N:B8 F:A2 CMD:58 SRC:Heizung_Wohnzimmer DST:Stellantrieb_Wohnzimmer 0020 (ClimateEvent CMD:0x00 ValvePos:32) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 22:59:18.520 1: HMLAN_Parse: LANCUL S:E19399E   stat:0000 t:0A7AC399 d:FF r:FFC8     m:B8 8202 19399E 1936C3 0101180031
2012.12.02 22:59:18.523 1: RCV L:0E N:B8 F:82 CMD:02 SRC:Stellantrieb_Wohnzimmer DST:Heizung_Wohnzimmer 0101180031 (ACK_STATUS CHANNEL:0x01 STATUS:0x18 UP:0 DOWN:0 LOWBAT:0 RSSI:-49) (,WAKEMEUP,RPTEN)
2012.12.02 22:59:25.007 1: General timer Start:14 :0 time:1354485625
2012.12.02 22:59:27.905 1: General timer Start:15 :HASH(0x991ada8) time:1354485597.90496
2012.12.02 22:59:40.496 1: General FD:8
2012.12.02 22:59:40.496 1: HMLAN_Send:  K
2012.12.02 22:59:40.496 1: General remove timer:keepAlive:LANCUL
2012.12.02 22:59:40.496 1: General timer Start:16 :keepAlive:LANCUL time:1354485605.49675
2012.12.02 22:59:40.502 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7B1982 d2:0000
2012.12.02 22:59:57.939 1: General timer Start:17 :HASH(0x991ada8) time:1354485627.9391
2012.12.02 23:00:05.504 1: General FD:8
2012.12.02 23:00:05.505 1: HMLAN_Send:  K
2012.12.02 23:00:05.505 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:00:05.505 1: General timer Start:18 :keepAlive:LANCUL time:1354485630.50544
2012.12.02 23:00:05.510 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7B7B34 d2:0000
2012.12.02 23:00:25.020 1: General timer Start:19 :0 time:1354485685
2012.12.02 23:00:28.002 1: General timer Start:20 :HASH(0x991ada8) time:1354485658.00249
2012.12.02 23:00:30.508 1: General FD:8
2012.12.02 23:00:30.508 1: HMLAN_Send:  K
2012.12.02 23:00:30.775 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:00:30.775 1: General timer Start:21 :keepAlive:LANCUL time:1354485655.77546
2012.12.02 23:00:30.779 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7BDDEE d2:0000
2012.12.02 23:00:48.505 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A7C2326 d:FF r:FFC3     m:F9 8670 19390F 000000 008E40
2012.12.02 23:00:48.508 1: RCV L:0C N:F9 F:86 CMD:70 SRC:Heizung_Schlafzimmer DST:broadcast 008E40 (WeatherEvent TEMP:14.2 HUM:64) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:00:55.783 1: General FD:8
2012.12.02 23:00:55.783 1: HMLAN_Send:  K
2012.12.02 23:00:55.783 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:00:55.783 1: General timer Start:22 :keepAlive:LANCUL time:1354485680.78362
2012.12.02 23:00:55.788 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7C3FA1 d2:0000
2012.12.02 23:00:58.021 1: General timer Start:23 :HASH(0x991ada8) time:1354485688.0215
2012.12.02 23:01:05.940 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A7C6744 d:FF r:FFD0     m:A8 8670 1937BA 000000 00DB30
2012.12.02 23:01:05.943 1: RCV L:0C N:A8 F:86 CMD:70 SRC:Heizung_Bad DST:broadcast 00DB30 (WeatherEvent TEMP:21.9 HUM:48) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:01:08.505 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A7C7149 d:FF r:FFC3     m:F9 A258 19390F 1939BF 0000
2012.12.02 23:01:08.508 1: RCV L:0B N:F9 F:A2 CMD:58 SRC:Heizung_Schlafzimmer DST:Stellantrieb_Schlafzimmer 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:01:15.142 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A7C8B37 d:FF r:FFC9     m:B9 8670 1936C3 000000 00BA38
2012.12.02 23:01:15.145 1: RCV L:0C N:B9 F:86 CMD:70 SRC:Heizung_Wohnzimmer DST:broadcast 00BA38 (WeatherEvent TEMP:18.6 HUM:56) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:01:20.789 1: General FD:8
2012.12.02 23:01:20.789 1: HMLAN_Send:  K
2012.12.02 23:01:20.790 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:01:20.790 1: General timer Start:24 :keepAlive:LANCUL time:1354485705.79028
2012.12.02 23:01:20.795 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7CA154 d2:0000
2012.12.02 23:01:25.005 1: General timer Start:25 :0 time:1354485745
2012.12.02 23:01:25.940 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A7CB566 d:FF r:FFD0     m:A8 A258 1937BA 193C18 00FF
2012.12.02 23:01:25.943 1: RCV L:0B N:A8 F:A2 CMD:58 SRC:Heizung_Bad DST:Stellantrieb_Bad 00FF (ClimateEvent CMD:0x00 ValvePos:255) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:01:26.173 1: HMLAN_Parse: LANCUL S:E193C18   stat:0000 t:0A7CB5EA d:FF r:FFC1     m:A8 8202 193C18 1937BA 0101C8002D
2012.12.02 23:01:26.176 1: RCV L:0E N:A8 F:82 CMD:02 SRC:Stellantrieb_Bad DST:Heizung_Bad 0101C8002D (ACK_STATUS CHANNEL:0x01 STATUS:0xC8 UP:0 DOWN:0 LOWBAT:0 RSSI:-45) (,WAKEMEUP,RPTEN)
2012.12.02 23:01:32.918 1: General remove timer:HASH(0x9cc9b20)
2012.12.02 23:01:32.923 1: General timer Start:26 :HASH(0x9ccff08) time:1354485866.27864
2012.12.02 23:01:33.007 1: General timer Start:27 :HASH(0x991ada8) time:1354485723.00759
2012.12.02 23:01:35.142 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A7CD959 d:FF r:FFC9     m:B9 A258 1936C3 19399E 0020
2012.12.02 23:01:35.145 1: RCV L:0B N:B9 F:A2 CMD:58 SRC:Heizung_Wohnzimmer DST:Stellantrieb_Wohnzimmer 0020 (ClimateEvent CMD:0x00 ValvePos:32) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:01:35.274 1: HMLAN_Parse: LANCUL S:E19399E   stat:0000 t:0A7CD9DE d:FF r:FFC8     m:B9 8202 19399E 1936C3 0101180031
2012.12.02 23:01:35.277 1: RCV L:0E N:B9 F:82 CMD:02 SRC:Stellantrieb_Wohnzimmer DST:Heizung_Wohnzimmer 0101180031 (ACK_STATUS CHANNEL:0x01 STATUS:0x18 UP:0 DOWN:0 LOWBAT:0 RSSI:-49) (,WAKEMEUP,RPTEN)
2012.12.02 23:01:45.801 1: General FD:8
2012.12.02 23:01:45.801 1: HMLAN_Send:  K
2012.12.02 23:01:45.801 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:01:45.802 1: General timer Start:28 :keepAlive:LANCUL time:1354485730.80195
2012.12.02 23:01:45.806 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7D030B d2:0000
2012.12.02 23:02:03.041 1: General timer Start:29 :HASH(0x991ada8) time:1354485753.04139
2012.12.02 23:02:10.810 1: General FD:8
2012.12.02 23:02:10.810 1: HMLAN_Send:  K
2012.12.02 23:02:10.810 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:02:10.810 1: General timer Start:30 :keepAlive:LANCUL time:1354485755.8108
2012.12.02 23:02:10.816 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7D64BF d2:0000
2012.12.02 23:02:25.015 1: General timer Start:31 :0 time:1354485805
2012.12.02 23:02:33.066 1: General timer Start:32 :HASH(0x991ada8) time:1354485783.06628
2012.12.02 23:02:35.814 1: General FD:8
2012.12.02 23:02:35.814 1: HMLAN_Send:  K
2012.12.02 23:02:35.814 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:02:35.814 1: General timer Start:33 :keepAlive:LANCUL time:1354485780.81464
2012.12.02 23:02:35.819 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7DC66E d2:0000
2012.12.02 23:03:00.840 1: General FD:8
2012.12.02 23:03:00.840 1: HMLAN_Send:  K
2012.12.02 23:03:00.840 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:03:00.840 1: General timer Start:34 :keepAlive:LANCUL time:1354485805.84075
2012.12.02 23:03:00.846 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7E2834 d2:0000
2012.12.02 23:03:03.085 1: General timer Start:35 :HASH(0x991ada8) time:1354485813.08502
2012.12.02 23:03:17.395 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A7E68D5 d:FF r:FFC9     m:BA 8670 1936C3 000000 00BA38
2012.12.02 23:03:17.398 1: RCV L:0C N:BA F:86 CMD:70 SRC:Heizung_Wohnzimmer DST:broadcast 00BA38 (WeatherEvent TEMP:18.6 HUM:56) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:03:25.008 1: General timer Start:36 :0 time:1354485865
2012.12.02 23:03:25.842 1: General FD:8
2012.12.02 23:03:25.842 1: HMLAN_Send:  K
2012.12.02 23:03:25.842 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:03:25.842 1: General timer Start:37 :keepAlive:LANCUL time:1354485830.8426
2012.12.02 23:03:25.847 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7E89E1 d2:0000
2012.12.02 23:03:33.117 1: General timer Start:38 :HASH(0x991ada8) time:1354485843.11759
2012.12.02 23:03:36.258 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A7EB286 d:FF r:FFC3     m:FA 8670 19390F 000000 008D40
2012.12.02 23:03:36.261 1: RCV L:0C N:FA F:86 CMD:70 SRC:Heizung_Schlafzimmer DST:broadcast 008D40 (WeatherEvent TEMP:14.1 HUM:64) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:03:37.396 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A7EB6F8 d:FF r:FFC9     m:BA A258 1936C3 19399E 0020
2012.12.02 23:03:37.398 1: RCV L:0B N:BA F:A2 CMD:58 SRC:Heizung_Wohnzimmer DST:Stellantrieb_Wohnzimmer 0020 (ClimateEvent CMD:0x00 ValvePos:32) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:03:37.529 1: HMLAN_Parse: LANCUL S:E19399E   stat:0000 t:0A7EB77D d:FF r:FFC8     m:BA 8202 19399E 1936C3 0101180031
2012.12.02 23:03:37.532 1: RCV L:0E N:BA F:82 CMD:02 SRC:Stellantrieb_Wohnzimmer DST:Heizung_Wohnzimmer 0101180031 (ACK_STATUS CHANNEL:0x01 STATUS:0x18 UP:0 DOWN:0 LOWBAT:0 RSSI:-49) (,WAKEMEUP,RPTEN)
2012.12.02 23:03:40.195 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A7EC1E8 d:FF r:FFD0     m:A9 8670 1937BA 000000 00DB30
2012.12.02 23:03:40.198 1: RCV L:0C N:A9 F:86 CMD:70 SRC:Heizung_Bad DST:broadcast 00DB30 (WeatherEvent TEMP:21.9 HUM:48) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:03:50.853 1: General FD:8
2012.12.02 23:03:50.853 1: HMLAN_Send:  K
2012.12.02 23:03:50.854 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:03:50.854 1: General timer Start:39 :keepAlive:LANCUL time:1354485855.85428
2012.12.02 23:03:50.858 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7EEB98 d2:0000
2012.12.02 23:03:56.258 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A7F00A8 d:FF r:FFC3     m:FA A258 19390F 1939BF 0000
2012.12.02 23:03:56.261 1: RCV L:0B N:FA F:A2 CMD:58 SRC:Heizung_Schlafzimmer DST:Stellantrieb_Schlafzimmer 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:03:56.494 1: HMLAN_Parse: LANCUL S:E1939BF   stat:0000 t:0A7F012E d:FF r:FFBB     m:FA 8202 1939BF 19390F 0101000030
2012.12.02 23:03:56.497 1: RCV L:0E N:FA F:82 CMD:02 SRC:Stellantrieb_Schlafzimmer DST:Heizung_Schlafzimmer 0101000030 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:-48) (,WAKEMEUP,RPTEN)
2012.12.02 23:04:00.195 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A7F100B d:FF r:FFD0     m:A9 A258 1937BA 193C18 00FF
2012.12.02 23:04:00.198 1: RCV L:0B N:A9 F:A2 CMD:58 SRC:Heizung_Bad DST:Stellantrieb_Bad 00FF (ClimateEvent CMD:0x00 ValvePos:255) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:04:00.329 1: HMLAN_Parse: LANCUL S:E193C18   stat:0000 t:0A7F108F d:FF r:FFC0     m:A9 8202 193C18 1937BA 0101C8002D
2012.12.02 23:04:00.332 1: RCV L:0E N:A9 F:82 CMD:02 SRC:Stellantrieb_Bad DST:Heizung_Bad 0101C8002D (ACK_STATUS CHANNEL:0x01 STATUS:0xC8 UP:0 DOWN:0 LOWBAT:0 RSSI:-45) (,WAKEMEUP,RPTEN)
2012.12.02 23:04:03.137 1: General timer Start:40 :HASH(0x991ada8) time:1354485873.13686
2012.12.02 23:04:15.867 1: General FD:8
2012.12.02 23:04:15.867 1: HMLAN_Send:  K
2012.12.02 23:04:15.868 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:04:15.868 1: General timer Start:41 :keepAlive:LANCUL time:1354485880.8681
2012.12.02 23:04:15.872 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7F4D51 d2:0000
2012.12.02 23:04:25.010 1: General timer Start:42 :0 time:1354485925
2012.12.02 23:04:33.759 1: General remove timer:HASH(0x9ccff08)
2012.12.02 23:04:33.764 1: General timer Start:43 :HASH(0x9ed3048) time:1354486046.27864
2012.12.02 23:04:33.784 1: General timer Start:44 :HASH(0x991ada8) time:1354485903.78478
2012.12.02 23:04:40.875 1: General FD:8
2012.12.02 23:04:40.876 1: HMLAN_Send:  K
2012.12.02 23:04:40.876 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:04:40.876 1: General timer Start:45 :keepAlive:LANCUL time:1354485905.87632
2012.12.02 23:04:40.882 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A7FAF05 d2:0000
2012.12.02 23:05:03.824 1: General timer Start:46 :HASH(0x991ada8) time:1354485933.82445
2012.12.02 23:05:05.878 1: General FD:8
2012.12.02 23:05:05.879 1: HMLAN_Send:  K
2012.12.02 23:05:05.879 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:05:05.879 1: General timer Start:47 :keepAlive:LANCUL time:1354485930.87945
2012.12.02 23:05:05.887 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8010B7 d2:0000
2012.12.02 23:05:25.019 1: General timer Start:48 :0 time:1354485985
2012.12.02 23:05:30.885 1: General FD:8
2012.12.02 23:05:31.006 1: HMLAN_Send:  K
2012.12.02 23:05:31.007 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:05:31.007 1: General timer Start:49 :keepAlive:LANCUL time:1354485956.00738
2012.12.02 23:05:31.013 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8072E0 d2:0000
2012.12.02 23:05:33.844 1: General timer Start:50 :HASH(0x991ada8) time:1354485963.84405
2012.12.02 23:05:43.334 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A80A2FB d:FF r:FFAC     m:95 A410 1D63FB C26BB2 0601C80080C8
2012.12.02 23:05:43.337 1: RCV L:0F N:95 F:A4 CMD:10 SRC:Licht_Schlafzimmer DST:C26BB2 0601C80080C8 (INFO_ACTUATOR_STATUS RSSI:-128 CHANNEL:0x01 STATUS:0xC8 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2012.12.02 23:05:43.394 1: HMLAN: Skip ACK
2012.12.02 23:05:43.395 1: SND L:0A N:95 F:80 CMD:02 SRC:C26BB2 DST:Licht_Schlafzimmer 00 (ACK) (,RPTEN)
2012.12.02 23:05:43.405 3: Update structure 'Gesamtes_Licht' to undefined because device 'Licht_Schlafzimmer' has changed
2012.12.02 23:05:47.229 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A80B233 d:FF r:FFAD     m:95 A410 1D63FB C26BB2 0601C80080C8
2012.12.02 23:05:51.474 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A80C2C9 d:FF r:FFB3     m:95 A410 1D63FB C26BB2 0601C80080C8
2012.12.02 23:05:56.012 1: General FD:8
2012.12.02 23:05:56.012 1: HMLAN_Send:  K
2012.12.02 23:05:56.012 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:05:56.013 1: General timer Start:51 :keepAlive:LANCUL time:1354485981.01299
2012.12.02 23:05:56.017 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A80D490 d2:0000
2012.12.02 23:05:56.469 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A80D64C d:FF r:FFBF     m:95 A410 1D63FB C26BB2 0601C80080C8
2012.12.02 23:06:00.201 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A80E4E1 d:FF r:FFCE     m:AA 8670 1937BA 000000 00DB30
2012.12.02 23:06:00.204 1: RCV L:0C N:AA F:86 CMD:70 SRC:Heizung_Bad DST:broadcast 00DB30 (WeatherEvent TEMP:21.9 HUM:48) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:06:03.460 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A80F19C d:FF r:FFBD     m:95 A410 1D63FB C26BB2 0601C80080C8
2012.12.02 23:06:03.861 1: General timer Start:52 :HASH(0x991ada8) time:1354485993.86148
2012.12.02 23:06:09.400 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A8108D1 d:FF r:FFCB     m:BB 8670 1936C3 000000 00B938
2012.12.02 23:06:09.403 1: RCV L:0C N:BB F:86 CMD:70 SRC:Heizung_Wohnzimmer DST:broadcast 00B938 (WeatherEvent TEMP:18.5 HUM:56) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:06:09.760 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A810A39 d:FF r:FFC3     m:FB 8670 19390F 000000 008D40
2012.12.02 23:06:09.763 1: RCV L:0C N:FB F:86 CMD:70 SRC:Heizung_Schlafzimmer DST:broadcast 008D40 (WeatherEvent TEMP:14.1 HUM:64) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:06:14.447 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A811C88 d:FF r:FFBC     m:95 A410 1D63FB C26BB2 0601C80080C8
2012.12.02 23:06:20.201 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A813304 d:FF r:FFD0     m:AA A258 1937BA 193C18 00FF
2012.12.02 23:06:20.204 1: RCV L:0B N:AA F:A2 CMD:58 SRC:Heizung_Bad DST:Stellantrieb_Bad 00FF (ClimateEvent CMD:0x00 ValvePos:255) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:06:20.333 1: HMLAN_Parse: LANCUL S:E193C18   stat:0000 t:0A813388 d:FF r:FFBC     m:AA 8202 193C18 1937BA 0101C8002D
2012.12.02 23:06:20.336 1: RCV L:0E N:AA F:82 CMD:02 SRC:Stellantrieb_Bad DST:Heizung_Bad 0101C8002D (ACK_STATUS CHANNEL:0x01 STATUS:0xC8 UP:0 DOWN:0 LOWBAT:0 RSSI:-45) (,WAKEMEUP,RPTEN)
2012.12.02 23:06:21.014 1: General FD:8
2012.12.02 23:06:21.014 1: HMLAN_Send:  K
2012.12.02 23:06:21.014 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:06:21.014 1: General timer Start:53 :keepAlive:LANCUL time:1354486006.01474
2012.12.02 23:06:21.021 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A81363D d2:0000
2012.12.02 23:06:25.004 1: General timer Start:54 :0 time:1354486045
2012.12.02 23:06:29.400 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A8156F4 d:FF r:FFCB     m:BB A258 1936C3 19399E 0020
2012.12.02 23:06:29.403 1: RCV L:0B N:BB F:A2 CMD:58 SRC:Heizung_Wohnzimmer DST:Stellantrieb_Wohnzimmer 0020 (ClimateEvent CMD:0x00 ValvePos:32) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:06:29.534 1: HMLAN_Parse: LANCUL S:E19399E   stat:0000 t:0A815779 d:FF r:FFC3     m:BB 8202 19399E 1936C3 010118002E
2012.12.02 23:06:29.537 1: RCV L:0E N:BB F:82 CMD:02 SRC:Stellantrieb_Wohnzimmer DST:Heizung_Wohnzimmer 010118002E (ACK_STATUS CHANNEL:0x01 STATUS:0x18 UP:0 DOWN:0 LOWBAT:0 RSSI:-46) (,WAKEMEUP,RPTEN)
2012.12.02 23:06:29.760 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A81585C d:FF r:FFC2     m:FB A258 19390F 1939BF 0000
2012.12.02 23:06:29.763 1: RCV L:0B N:FB F:A2 CMD:58 SRC:Heizung_Schlafzimmer DST:Stellantrieb_Schlafzimmer 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:06:33.883 1: General timer Start:55 :HASH(0x991ada8) time:1354486023.88354
2012.12.02 23:06:46.027 1: General FD:8
2012.12.02 23:06:46.027 1: HMLAN_Send:  K
2012.12.02 23:06:46.027 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:06:46.028 1: General timer Start:56 :keepAlive:LANCUL time:1354486031.02796
2012.12.02 23:06:46.032 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8197F6 d2:0000
2012.12.02 23:07:03.930 1: General timer Start:57 :HASH(0x991ada8) time:1354486053.92987
2012.12.02 23:07:11.035 1: General FD:8
2012.12.02 23:07:11.035 1: HMLAN_Send:  K
2012.12.02 23:07:11.036 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:07:11.036 1: General timer Start:58 :keepAlive:LANCUL time:1354486056.03613
2012.12.02 23:07:11.040 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A81F9A9 d2:0000
2012.12.02 23:07:25.014 1: General timer Start:59 :0 time:1354486105
2012.12.02 23:07:34.101 1: General remove timer:HASH(0x9ed3048)
2012.12.02 23:07:34.106 1: General timer Start:60 :HASH(0x9f67828) time:1354486226.27864
2012.12.02 23:07:34.129 1: General timer Start:61 :HASH(0x991ada8) time:1354486084.12963
2012.12.02 23:07:36.038 1: General FD:8
2012.12.02 23:07:36.038 1: HMLAN_Send:  K
2012.12.02 23:07:36.039 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:07:36.039 1: General timer Start:62 :keepAlive:LANCUL time:1354486081.03917
2012.12.02 23:07:36.043 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A825B58 d2:0000
2012.12.02 23:08:01.064 1: General FD:8
2012.12.02 23:08:01.064 1: HMLAN_Send:  K
2012.12.02 23:08:01.065 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:08:01.065 1: General timer Start:63 :keepAlive:LANCUL time:1354486106.06528
2012.12.02 23:08:01.069 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A82BD1D d2:0000
2012.12.02 23:08:04.156 1: General timer Start:64 :HASH(0x991ada8) time:1354486114.15657
2012.12.02 23:08:05.706 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A82CF33 d:FF r:FFD0     m:AB 8670 1937BA 000000 00DA30
2012.12.02 23:08:05.709 1: RCV L:0C N:AB F:86 CMD:70 SRC:Heizung_Bad DST:broadcast 00DA30 (WeatherEvent TEMP:21.8 HUM:48) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:08:25.019 1: General timer Start:65 :0 time:1354486165
2012.12.02 23:08:25.705 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A831D55 d:FF r:FFD0     m:AB A258 1937BA 193C18 00FF
2012.12.02 23:08:25.708 1: RCV L:0B N:AB F:A2 CMD:58 SRC:Heizung_Bad DST:Stellantrieb_Bad 00FF (ClimateEvent CMD:0x00 ValvePos:255) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:08:25.948 1: HMLAN_Parse: LANCUL S:E193C18   stat:0000 t:0A831DDA d:FF r:FFBC     m:AB 8202 193C18 1937BA 0101C8002D
2012.12.02 23:08:25.951 1: RCV L:0E N:AB F:82 CMD:02 SRC:Stellantrieb_Bad DST:Heizung_Bad 0101C8002D (ACK_STATUS CHANNEL:0x01 STATUS:0xC8 UP:0 DOWN:0 LOWBAT:0 RSSI:-45) (,WAKEMEUP,RPTEN)
2012.12.02 23:08:26.065 1: General FD:8
2012.12.02 23:08:26.066 1: HMLAN_Send:  K
2012.12.02 23:08:26.066 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:08:26.066 1: General timer Start:66 :keepAlive:LANCUL time:1354486131.06642
2012.12.02 23:08:26.070 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A831ECA d2:0000
2012.12.02 23:08:28.762 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A832946 d:FF r:FFC2     m:FC 8670 19390F 000000 008D40
2012.12.02 23:08:28.765 1: RCV L:0C N:FC F:86 CMD:70 SRC:Heizung_Schlafzimmer DST:broadcast 008D40 (WeatherEvent TEMP:14.1 HUM:64) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:08:34.178 1: General timer Start:67 :HASH(0x991ada8) time:1354486144.17849
2012.12.02 23:08:46.906 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A837028 d:FF r:FFCA     m:BC 8670 1936C3 000000 00BA38
2012.12.02 23:08:46.909 1: RCV L:0C N:BC F:86 CMD:70 SRC:Heizung_Wohnzimmer DST:broadcast 00BA38 (WeatherEvent TEMP:18.6 HUM:56) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:08:48.762 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A837769 d:FF r:FFC1     m:FC A258 19390F 1939BF 0000
2012.12.02 23:08:48.765 1: RCV L:0B N:FC F:A2 CMD:58 SRC:Heizung_Schlafzimmer DST:Stellantrieb_Schlafzimmer 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:08:48.895 1: HMLAN_Parse: LANCUL S:E1939BF   stat:0000 t:0A8377EE d:FF r:FFBB     m:FC 8202 1939BF 19390F 0101000030
2012.12.02 23:08:48.898 1: RCV L:0E N:FC F:82 CMD:02 SRC:Stellantrieb_Schlafzimmer DST:Heizung_Schlafzimmer 0101000030 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:-48) (,WAKEMEUP,RPTEN)
2012.12.02 23:08:51.069 1: General FD:8
2012.12.02 23:08:51.069 1: HMLAN_Send:  K
2012.12.02 23:08:51.069 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:08:51.069 1: General timer Start:68 :keepAlive:LANCUL time:1354486156.06967
2012.12.02 23:08:51.076 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A83807B d2:0000
2012.12.02 23:09:04.254 1: General timer Start:69 :HASH(0x991ada8) time:1354486174.25431
2012.12.02 23:09:06.905 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A83BE4A d:FF r:FFC1     m:BC A258 1936C3 19399E 0020
2012.12.02 23:09:06.908 1: RCV L:0B N:BC F:A2 CMD:58 SRC:Heizung_Wohnzimmer DST:Stellantrieb_Wohnzimmer 0020 (ClimateEvent CMD:0x00 ValvePos:32) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:09:07.150 1: HMLAN_Parse: LANCUL S:E19399E   stat:0000 t:0A83BECF d:FF r:FFC1     m:BC 8202 19399E 1936C3 010118002E
2012.12.02 23:09:07.153 1: RCV L:0E N:BC F:82 CMD:02 SRC:Stellantrieb_Wohnzimmer DST:Heizung_Wohnzimmer 010118002E (ACK_STATUS CHANNEL:0x01 STATUS:0x18 UP:0 DOWN:0 LOWBAT:0 RSSI:-46) (,WAKEMEUP,RPTEN)
2012.12.02 23:09:16.079 1: General FD:8
2012.12.02 23:09:16.079 1: HMLAN_Send:  K
2012.12.02 23:09:16.079 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:09:16.079 1: General timer Start:70 :keepAlive:LANCUL time:1354486181.07964
2012.12.02 23:09:16.084 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A83E22E d2:0000
2012.12.02 23:09:25.009 1: General timer Start:71 :0 time:1354486225
2012.12.02 23:09:34.280 1: General timer Start:72 :HASH(0x991ada8) time:1354486204.28015
2012.12.02 23:09:36.249 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A8430EE d:FF r:FFC1     m:97 A410 1D63FB C26BB2 060100008000
2012.12.02 23:09:36.252 1: RCV L:0F N:97 F:A4 CMD:10 SRC:Licht_Schlafzimmer DST:C26BB2 060100008000 (INFO_ACTUATOR_STATUS RSSI:-128 CHANNEL:0x01 STATUS:0x00 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2012.12.02 23:09:36.306 1: HMLAN: Skip ACK
2012.12.02 23:09:36.306 1: SND L:0A N:97 F:80 CMD:02 SRC:C26BB2 DST:Licht_Schlafzimmer 00 (ACK) (,RPTEN)
2012.12.02 23:09:40.693 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A84424B d:FF r:FFBA     m:97 A410 1D63FB C26BB2 060100008000
2012.12.02 23:09:41.080 1: General FD:8
2012.12.02 23:09:41.080 1: HMLAN_Send:  K
2012.12.02 23:09:41.081 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:09:41.081 1: General timer Start:73 :keepAlive:LANCUL time:1354486206.08109
2012.12.02 23:09:41.087 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8443DC d2:0000
2012.12.02 23:09:45.188 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A8453DB d:FF r:FFBB     m:97 A410 1D63FB C26BB2 060100008000
2012.12.02 23:09:50.682 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A846951 d:FF r:FFBB     m:97 A410 1D63FB C26BB2 060100008000
2012.12.02 23:09:58.422 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A84878E d:FF r:FFBA     m:97 A410 1D63FB C26BB2 060100008000
2012.12.02 23:09:59.736 2: CUL_HM set Heizung_Bad desired-temp 15.0 rxt:12
2012.12.02 23:10:04.301 1: General timer Start:74 :HASH(0x991ada8) time:1354486234.30095
2012.12.02 23:10:06.083 1: General FD:8
2012.12.02 23:10:06.083 1: HMLAN_Send:  K
2012.12.02 23:10:06.083 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:10:06.084 1: General timer Start:75 :keepAlive:LANCUL time:1354486231.084
2012.12.02 23:10:06.088 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A84A589 d2:0000
2012.12.02 23:10:10.158 1: HMLAN_Parse: LANCUL S:E1D63FB   stat:0000 t:0A84B568 d:FF r:FFBC     m:97 A410 1D63FB C26BB2 060100008000
2012.12.02 23:10:13.211 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A84C155 d:FF r:FFC4     m:9A A410 1D63F2 C26BB2 0601C80080C8
2012.12.02 23:10:13.214 1: RCV L:0F N:9A F:A4 CMD:10 SRC:Licht_Bad DST:C26BB2 0601C80080C8 (INFO_ACTUATOR_STATUS RSSI:-128 CHANNEL:0x01 STATUS:0xC8 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2012.12.02 23:10:13.269 1: HMLAN: Skip ACK
2012.12.02 23:10:13.269 1: SND L:0A N:9A F:80 CMD:02 SRC:C26BB2 DST:Licht_Bad 00 (ACK) (,RPTEN)
2012.12.02 23:10:18.257 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A84D50C d:FF r:FFC8     m:9A A410 1D63F2 C26BB2 0601C80080C8
2012.12.02 23:10:23.501 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A84E989 d:FF r:FFC7     m:9A A410 1D63F2 C26BB2 0601C80080C8
2012.12.02 23:10:25.002 1: General timer Start:76 :0 time:1354486285
2012.12.02 23:10:34.104 1: General remove timer:HASH(0x9f67828)
2012.12.02 23:10:34.109 1: General timer Start:77 :HASH(0x9f66d88) time:1354486406.27864
2012.12.02 23:10:34.113 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8502E9 d:FF r:FFC8     m:9A A410 1D63F2 C26BB2 0601C80080C8
2012.12.02 23:10:34.116 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A850FAD d:FF r:FFC2     m:FD 8670 19390F 000000 008D40
2012.12.02 23:10:34.119 1: RCV L:0C N:FD F:86 CMD:70 SRC:Heizung_Schlafzimmer DST:broadcast 008D40 (WeatherEvent TEMP:14.1 HUM:64) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:10:34.189 1: General FD:8
2012.12.02 23:10:34.189 1: HMLAN_Send:  K
2012.12.02 23:10:34.190 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:10:34.190 1: General timer Start:78 :keepAlive:LANCUL time:1354486259.19023
2012.12.02 23:10:34.195 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A851357 d2:0000
2012.12.02 23:10:34.349 1: General timer Start:79 :HASH(0x991ada8) time:1354486264.34908
2012.12.02 23:10:38.489 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A852417 d:FF r:FFC8     m:9A A410 1D63F2 C26BB2 0601C80080C8
2012.12.02 23:10:50.978 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8554E2 d:FF r:FFC7     m:9A A410 1D63F2 C26BB2 0601C80080C8
2012.12.02 23:10:53.264 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A855DD0 d:FF r:FFC1     m:FD A258 19390F 1939BF 0000
2012.12.02 23:10:53.267 1: RCV L:0B N:FD F:A2 CMD:58 SRC:Heizung_Schlafzimmer DST:Stellantrieb_Schlafzimmer 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:10:59.196 1: General FD:8
2012.12.02 23:10:59.196 1: HMLAN_Send:  K
2012.12.02 23:10:59.196 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:10:59.197 1: General timer Start:80 :keepAlive:LANCUL time:1354486284.19706
2012.12.02 23:10:59.201 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A857509 d2:0000
2012.12.02 23:11:00.712 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A857AE9 d:FF r:FFD2     m:AC 8670 1937BA 000000 00DA30
2012.12.02 23:11:00.715 1: RCV L:0C N:AC F:86 CMD:70 SRC:Heizung_Bad DST:broadcast 00DA30 (WeatherEvent TEMP:21.8 HUM:48) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:11:00.769 1: HMLAN_Send:  +1937BA,00,00,
2012.12.02 23:11:00.812 1: HMLAN_Send:         S:S5DAC255D stat:  00 t:00000000 d:01 r:5DAC255D m:9B A112 C26BB2 1937BA
2012.12.02 23:11:00.813 1: SND L:09 N:9B F:A1 CMD:12 SRC:C26BB2 DST:Heizung_Bad  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
2012.12.02 23:11:00.820 1: General timer Start:81 :HASH(0x9b9e6d0) time:1354486262.81992
2012.12.02 23:11:00.975 1: HMLAN_Parse: LANCUL S:R5DAC255D stat:0001 t:0A857BF7 d:FF r:FFD2     m:9B 8002 1937BA C26BB2 00
2012.12.02 23:11:00.975 1: HMLAN_Send:  +1937BA
2012.12.02 23:11:00.978 1: RCV L:0A N:9B F:80 CMD:02 SRC:Heizung_Bad DST:C26BB2 00 (ACK) (,RPTEN)
2012.12.02 23:11:00.984 1: General remove timer:HASH(0x9b9e6d0)
2012.12.02 23:11:01.075 1: HMLAN_Send:         S:S5DAC263A stat:  00 t:00000000 d:01 r:5DAC263A m:9C A011 C26BB2 1937BA 02021E
2012.12.02 23:11:01.076 1: SND L:0C N:9C F:A0 CMD:11 SRC:C26BB2 DST:Heizung_Bad 02021E (SET CHANNEL:0x02 VALUE:0x1E) (,BIDI,RPTEN)
2012.12.02 23:11:01.082 1: General timer Start:82 :HASH(0x9b9e6d0) time:1354486263.0827
2012.12.02 23:11:01.386 1: HMLAN_Parse: LANCUL S:R5DAC263A stat:0001 t:0A857D91 d:FF r:FFD2     m:9C 8002 1937BA C26BB2 01021E0032
2012.12.02 23:11:01.386 1: HMLAN_Send:  +1937BA
2012.12.02 23:11:01.389 1: RCV L:0E N:9C F:80 CMD:02 SRC:Heizung_Bad DST:C26BB2 01021E0032 (ACK_STATUS CHANNEL:0x02 STATUS:0x1E UP:0 DOWN:0 LOWBAT:0 RSSI:-50) (,RPTEN)
2012.12.02 23:11:01.508 1: General remove timer:HASH(0x9b9e6d0)
2012.12.02 23:11:04.390 1: General timer Start:83 :HASH(0x991ada8) time:1354486294.38983
2012.12.02 23:11:09.909 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A859ED7 d:FF r:FFC9     m:BD 8670 1936C3 000000 00BA38
2012.12.02 23:11:09.912 1: RCV L:0C N:BD F:86 CMD:70 SRC:Heizung_Wohnzimmer DST:broadcast 00BA38 (WeatherEvent TEMP:18.6 HUM:56) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:11:20.710 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A85C90C d:FF r:FFD2     m:AC A258 1937BA 193C18 00FF
2012.12.02 23:11:20.713 1: RCV L:0B N:AC F:A2 CMD:58 SRC:Heizung_Bad DST:Stellantrieb_Bad 00FF (ClimateEvent CMD:0x00 ValvePos:255) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:11:20.941 1: HMLAN_Parse: LANCUL S:E193C18   stat:0000 t:0A85C98F d:FF r:FFBF     m:AC 8202 193C18 1937BA 0101C8002E
2012.12.02 23:11:20.944 1: RCV L:0E N:AC F:82 CMD:02 SRC:Stellantrieb_Bad DST:Heizung_Bad 0101C8002E (ACK_STATUS CHANNEL:0x01 STATUS:0xC8 UP:0 DOWN:0 LOWBAT:0 RSSI:-46) (,WAKEMEUP,RPTEN)
2012.12.02 23:11:24.200 1: General FD:8
2012.12.02 23:11:24.201 1: HMLAN_Send:  K
2012.12.02 23:11:24.201 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:11:24.201 1: General timer Start:84 :keepAlive:LANCUL time:1354486309.2014
2012.12.02 23:11:24.205 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A85D6B9 d2:0001
2012.12.02 23:11:25.002 1: General timer Start:85 :0 time:1354486345
2012.12.02 23:11:29.909 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A85ECFA d:FF r:FFC9     m:BD A258 1936C3 19399E 0323
2012.12.02 23:11:29.912 1: RCV L:0B N:BD F:A2 CMD:58 SRC:Heizung_Wohnzimmer DST:Stellantrieb_Wohnzimmer 0323 (ClimateEvent CMD:0x03 ValvePos:35) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:11:30.041 1: HMLAN_Parse: LANCUL S:E19399E   stat:0000 t:0A85ED7E d:FF r:FFC7     m:BD 8202 19399E 1936C3 010118102E
2012.12.02 23:11:30.044 1: RCV L:0E N:BD F:82 CMD:02 SRC:Stellantrieb_Wohnzimmer DST:Heizung_Wohnzimmer 010118102E (ACK_STATUS CHANNEL:0x01 STATUS:0x18 UP:1 DOWN:0 LOWBAT:0 RSSI:-46) (,WAKEMEUP,RPTEN)
2012.12.02 23:11:34.412 1: General timer Start:86 :HASH(0x991ada8) time:1354486324.41214
2012.12.02 23:11:49.216 1: General FD:8
2012.12.02 23:11:49.216 1: HMLAN_Send:  K
2012.12.02 23:11:49.217 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:11:49.217 1: General timer Start:87 :keepAlive:LANCUL time:1354486334.21727
2012.12.02 23:11:49.221 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A863874 d2:0001
2012.12.02 23:12:04.444 1: General timer Start:88 :HASH(0x991ada8) time:1354486354.44392
2012.12.02 23:12:14.227 1: General FD:8
2012.12.02 23:12:14.227 1: HMLAN_Send:  K
2012.12.02 23:12:14.228 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:12:14.228 1: General timer Start:89 :keepAlive:LANCUL time:1354486359.22813
2012.12.02 23:12:14.232 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A869A2B d2:0001
2012.12.02 23:12:25.011 1: General timer Start:90 :0 time:1354486405
2012.12.02 23:12:34.510 1: General timer Start:91 :HASH(0x991ada8) time:1354486384.51018
2012.12.02 23:12:39.233 1: General FD:8
2012.12.02 23:12:39.233 1: HMLAN_Send:  K
2012.12.02 23:12:39.233 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:12:39.234 1: General timer Start:92 :keepAlive:LANCUL time:1354486384.23398
2012.12.02 23:12:39.239 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A86FBDD d2:0001
2012.12.02 23:13:04.259 1: General FD:8
2012.12.02 23:13:04.259 1: HMLAN_Send:  K
2012.12.02 23:13:04.260 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:13:04.260 1: General timer Start:93 :keepAlive:LANCUL time:1354486409.26009
2012.12.02 23:13:04.264 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A875DA2 d2:0001
2012.12.02 23:13:04.531 1: General timer Start:94 :HASH(0x991ada8) time:1354486414.5312
2012.12.02 23:13:18.663 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A8795DB d:FF r:FFCA     m:BE 8670 1936C3 000000 00BA38
2012.12.02 23:13:18.666 1: RCV L:0C N:BE F:86 CMD:70 SRC:Heizung_Wohnzimmer DST:broadcast 00BA38 (WeatherEvent TEMP:18.6 HUM:56) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:13:25.132 1: General timer Start:95 :HASH(0x9ac1e60) time:1354487305
2012.12.02 23:13:25.133 1: General timer Start:96 :0 time:1354486465
2012.12.02 23:13:33.008 1: General remove timer:HASH(0x9f66d88)
2012.12.02 23:13:33.012 1: General timer Start:97 :HASH(0x9f54048) time:1354486586.27864
2012.12.02 23:13:33.017 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A87B872 d:FF r:FFC1     m:FE 8670 19390F 000000 008D40
2012.12.02 23:13:33.020 1: RCV L:0C N:FE F:86 CMD:70 SRC:Heizung_Schlafzimmer DST:broadcast 008D40 (WeatherEvent TEMP:14.1 HUM:64) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:13:33.081 1: General FD:8
2012.12.02 23:13:33.082 1: HMLAN_Send:  K
2012.12.02 23:13:33.082 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:13:33.082 1: General timer Start:98 :keepAlive:LANCUL time:1354486438.08235
2012.12.02 23:13:33.086 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A87CE3C d2:0001
2012.12.02 23:13:34.573 1: General timer Start:99 :HASH(0x991ada8) time:1354486444.57305
2012.12.02 23:13:38.662 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A87E3FD d:FF r:FFCA     m:BE A258 1936C3 19399E 0023
2012.12.02 23:13:38.665 1: RCV L:0B N:BE F:A2 CMD:58 SRC:Heizung_Wohnzimmer DST:Stellantrieb_Wohnzimmer 0023 (ClimateEvent CMD:0x00 ValvePos:35) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:13:38.799 1: HMLAN_Parse: LANCUL S:E19399E   stat:0000 t:0A87E482 d:FF r:FFC7     m:BE 8202 19399E 1936C3 010118002F
2012.12.02 23:13:38.802 1: RCV L:0E N:BE F:82 CMD:02 SRC:Stellantrieb_Wohnzimmer DST:Heizung_Wohnzimmer 010118002F (ACK_STATUS CHANNEL:0x01 STATUS:0x18 UP:0 DOWN:0 LOWBAT:0 RSSI:-47) (,WAKEMEUP,RPTEN)
2012.12.02 23:13:41.466 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A87EEF3 d:FF r:FFD1     m:AD 8670 1937BA 000000 00DB3D
2012.12.02 23:13:41.469 1: RCV L:0C N:AD F:86 CMD:70 SRC:Heizung_Bad DST:broadcast 00DB3D (WeatherEvent TEMP:21.9 HUM:61) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:13:47.517 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A880695 d:FF r:FFC2     m:FE A258 19390F 1939BF 0000
2012.12.02 23:13:47.520 1: RCV L:0B N:FE F:A2 CMD:58 SRC:Heizung_Schlafzimmer DST:Stellantrieb_Schlafzimmer 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:13:47.651 1: HMLAN_Parse: LANCUL S:E1939BF   stat:0000 t:0A88071A d:FF r:FFBE     m:FE 8202 1939BF 19390F 0101000030
2012.12.02 23:13:47.654 1: RCV L:0E N:FE F:82 CMD:02 SRC:Stellantrieb_Schlafzimmer DST:Heizung_Schlafzimmer 0101000030 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:-48) (,WAKEMEUP,RPTEN)
2012.12.02 23:13:58.093 1: General FD:8
2012.12.02 23:13:58.093 1: HMLAN_Send:  K
2012.12.02 23:13:58.093 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:13:58.094 1: General timer Start:100 :keepAlive:LANCUL time:1354486463.09388
2012.12.02 23:13:58.100 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A882FF5 d2:0001
2012.12.02 23:14:01.466 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A883D16 d:FF r:FFD1     m:AD A258 1937BA 193C18 0300
2012.12.02 23:14:01.469 1: RCV L:0B N:AD F:A2 CMD:58 SRC:Heizung_Bad DST:Stellantrieb_Bad 0300 (ClimateEvent CMD:0x03 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:14:01.700 1: HMLAN_Parse: LANCUL S:E193C18   stat:0000 t:0A883D9A d:FF r:FFBB     m:AD 8202 193C18 1937BA 0101C8202D
2012.12.02 23:14:01.703 1: RCV L:0E N:AD F:82 CMD:02 SRC:Stellantrieb_Bad DST:Heizung_Bad 0101C8202D (ACK_STATUS CHANNEL:0x01 STATUS:0xC8 UP:0 DOWN:1 LOWBAT:0 RSSI:-45) (,WAKEMEUP,RPTEN)
2012.12.02 23:14:04.619 1: General timer Start:101 :HASH(0x991ada8) time:1354486474.61904
2012.12.02 23:14:23.112 1: General FD:8
2012.12.02 23:14:23.113 1: HMLAN_Send:  K
2012.12.02 23:14:23.113 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:14:23.113 1: General timer Start:102 :keepAlive:LANCUL time:1354486488.11345
2012.12.02 23:14:23.119 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8891B3 d2:0001
2012.12.02 23:14:25.002 1: General timer Start:103 :0 time:1354486525
2012.12.02 23:14:34.645 1: General timer Start:104 :HASH(0x991ada8) time:1354486504.6452
2012.12.02 23:14:48.127 1: General FD:8
2012.12.02 23:14:48.127 1: HMLAN_Send:  K
2012.12.02 23:14:48.127 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:14:48.128 1: General timer Start:105 :keepAlive:LANCUL time:1354486513.128
2012.12.02 23:14:48.132 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A88F36C d2:0001
2012.12.02 23:15:04.681 1: General timer Start:106 :HASH(0x991ada8) time:1354486534.68107
2012.12.02 23:15:13.136 1: General FD:8
2012.12.02 23:15:13.137 1: HMLAN_Send:  K
2012.12.02 23:15:13.137 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:15:13.137 1: General timer Start:107 :keepAlive:LANCUL time:1354486538.13756
2012.12.02 23:15:13.143 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A895521 d2:0001
2012.12.02 23:15:25.012 1: General timer Start:108 :0 time:1354486585
2012.12.02 23:15:34.760 1: General timer Start:109 :HASH(0x991ada8) time:1354486564.76023
2012.12.02 23:15:38.141 1: General FD:8
2012.12.02 23:15:38.141 1: HMLAN_Send:  K
2012.12.02 23:15:38.141 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:15:38.142 1: General timer Start:110 :keepAlive:LANCUL time:1354486563.14203
2012.12.02 23:15:38.146 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A89B6D0 d2:0001
2012.12.02 23:16:03.167 1: General FD:8
2012.12.02 23:16:03.167 1: HMLAN_Send:  K
2012.12.02 23:16:03.168 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:16:03.168 1: General timer Start:111 :keepAlive:LANCUL time:1354486588.16814
2012.12.02 23:16:03.172 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8A1896 d2:0001
2012.12.02 23:16:04.782 1: General timer Start:112 :HASH(0x991ada8) time:1354486594.78277
2012.12.02 23:16:07.272 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A8A2890 d:FF r:FFC1     m:FF 8670 19390F 000000 008D40
2012.12.02 23:16:07.275 1: RCV L:0C N:FF F:86 CMD:70 SRC:Heizung_Schlafzimmer DST:broadcast 008D40 (WeatherEvent TEMP:14.1 HUM:64) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:16:07.721 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A8A2A56 d:FF r:FFD2     m:AE 8670 1937BA 000000 00E054
2012.12.02 23:16:07.724 1: RCV L:0C N:AE F:86 CMD:70 SRC:Heizung_Bad DST:broadcast 00E054 (WeatherEvent TEMP:22.4 HUM:84) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:16:16.918 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A8A4E42 d:FF r:FFCA     m:BF 8670 1936C3 000000 00B938
2012.12.02 23:16:16.921 1: RCV L:0C N:BF F:86 CMD:70 SRC:Heizung_Wohnzimmer DST:broadcast 00B938 (WeatherEvent TEMP:18.5 HUM:56) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:16:25.008 1: General timer Start:113 :0 time:1354486645
2012.12.02 23:16:33.661 1: General remove timer:HASH(0x9f54048)
2012.12.02 23:16:33.665 1: General timer Start:114 :HASH(0x9ee4e08) time:1354486766.27864
2012.12.02 23:16:33.670 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A8A76B3 d:FF r:FFC1     m:FF A258 19390F 1939BF 0000
2012.12.02 23:16:33.673 1: RCV L:0B N:FF F:A2 CMD:58 SRC:Heizung_Schlafzimmer DST:Stellantrieb_Schlafzimmer 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:16:33.736 1: HMLAN_Parse: LANCUL S:E1939BF   stat:0000 t:0A8A7738 d:FF r:FFBF     m:FF 8202 1939BF 19390F 0101000030
2012.12.02 23:16:33.739 1: RCV L:0E N:FF F:82 CMD:02 SRC:Stellantrieb_Schlafzimmer DST:Heizung_Schlafzimmer 0101000030 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:-48) (,WAKEMEUP,RPTEN)
2012.12.02 23:16:33.754 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A8A7879 d:FF r:FFD1     m:AE A258 1937BA 193C18 0000
2012.12.02 23:16:33.757 1: RCV L:0B N:AE F:A2 CMD:58 SRC:Heizung_Bad DST:Stellantrieb_Bad 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:16:33.777 1: HMLAN_Parse: LANCUL S:E193C18   stat:0000 t:0A8A78FD d:FF r:FFBD     m:AE 8202 193C18 1937BA 010100002D
2012.12.02 23:16:33.780 1: RCV L:0E N:AE F:82 CMD:02 SRC:Stellantrieb_Bad DST:Heizung_Bad 010100002D (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:-45) (,WAKEMEUP,RPTEN)
2012.12.02 23:16:33.795 1: General FD:8
2012.12.02 23:16:33.796 1: HMLAN_Send:  K
2012.12.02 23:16:33.796 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:16:33.796 1: General timer Start:115 :keepAlive:LANCUL time:1354486618.79656
2012.12.02 23:16:33.802 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8A903F d2:0001
2012.12.02 23:16:34.815 1: General timer Start:116 :HASH(0x991ada8) time:1354486624.81568
2012.12.02 23:16:36.918 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A8A9C65 d:FF r:FFC9     m:BF A258 1936C3 19399E 0023
2012.12.02 23:16:36.921 1: RCV L:0B N:BF F:A2 CMD:58 SRC:Heizung_Wohnzimmer DST:Stellantrieb_Wohnzimmer 0023 (ClimateEvent CMD:0x00 ValvePos:35) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:16:37.051 1: HMLAN_Parse: LANCUL S:E19399E   stat:0000 t:0A8A9CEA d:FF r:FFC7     m:BF 8202 19399E 1936C3 010118002F
2012.12.02 23:16:37.054 1: RCV L:0E N:BF F:82 CMD:02 SRC:Stellantrieb_Wohnzimmer DST:Heizung_Wohnzimmer 010118002F (ACK_STATUS CHANNEL:0x01 STATUS:0x18 UP:0 DOWN:0 LOWBAT:0 RSSI:-47) (,WAKEMEUP,RPTEN)
2012.12.02 23:16:58.818 1: General FD:8
2012.12.02 23:16:58.819 1: HMLAN_Send:  K
2012.12.02 23:16:58.819 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:16:58.819 1: General timer Start:117 :keepAlive:LANCUL time:1354486643.81947
2012.12.02 23:16:58.824 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8AF201 d2:0001
2012.12.02 23:17:04.855 1: General timer Start:118 :HASH(0x991ada8) time:1354486654.85551
2012.12.02 23:17:23.838 1: General FD:8
2012.12.02 23:17:23.839 1: HMLAN_Send:  K
2012.12.02 23:17:23.839 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:17:23.839 1: General timer Start:119 :keepAlive:LANCUL time:1354486668.83941
2012.12.02 23:17:23.845 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8B53C2 d2:0001
2012.12.02 23:17:25.002 1: General timer Start:120 :0 time:1354486705
2012.12.02 23:17:34.882 1: General timer Start:121 :HASH(0x991ada8) time:1354486684.88248
2012.12.02 23:17:48.853 1: General FD:8
2012.12.02 23:17:48.854 1: HMLAN_Send:  K
2012.12.02 23:17:48.854 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:17:48.854 1: General timer Start:122 :keepAlive:LANCUL time:1354486693.85457
2012.12.02 23:17:48.859 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8BB57B d2:0001
2012.12.02 23:17:53.516 1: HMLAN_Parse: LANCUL S:E196F33   stat:0000 t:0A8BC7A5 d:FF r:FFB2     m:34 B441 196F33 1937BA 01CDC8
2012.12.02 23:17:53.518 1: RCV L:0C N:34 F:B4 CMD:41 SRC:Fenster_Bad DST:Heizung_Bad 01CDC8 (,CFG,BURST,BIDI,RPTEN)
2012.12.02 23:17:53.751 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A8BC827 d:FF r:FFD0     m:34 8002 1937BA 196F33 00
2012.12.02 23:17:53.754 1: RCV L:0A N:34 F:80 CMD:02 SRC:Heizung_Bad DST:Fenster_Bad 00 (ACK) (,RPTEN)
2012.12.02 23:17:54.069 1: HMLAN_Parse: LANCUL S:E196F33   stat:0000 t:0A8BC9CE d:FF r:FFAF     m:35 B441 196F33 1937BA 01CE64
2012.12.02 23:17:54.071 1: RCV L:0C N:35 F:B4 CMD:41 SRC:Fenster_Bad DST:Heizung_Bad 01CE64 (,CFG,BURST,BIDI,RPTEN)
2012.12.02 23:17:54.255 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A8BCA50 d:FF r:FFD0     m:35 8002 1937BA 196F33 00
2012.12.02 23:17:54.258 1: RCV L:0A N:35 F:80 CMD:02 SRC:Heizung_Bad DST:Fenster_Bad 00 (ACK) (,RPTEN)
2012.12.02 23:17:56.232 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A8BD243 d:FF r:FFD0     m:36 A410 1937BA C26BB2 06021800000000
2012.12.02 23:17:56.235 1: RCV L:10 N:36 F:A4 CMD:10 SRC:Heizung_Bad DST:C26BB2 06021800000000 (INFO_ACTUATOR_STATUS RSSI:0 CHANNEL:0x02 STATUS:0x18 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2012.12.02 23:17:56.295 1: HMLAN: Skip ACK
2012.12.02 23:17:56.296 1: SND L:0A N:36 F:80 CMD:02 SRC:C26BB2 DST:Heizung_Bad 00 (ACK) (,RPTEN)
2012.12.02 23:18:04.912 1: General timer Start:123 :HASH(0x991ada8) time:1354486714.91226
2012.12.02 23:18:13.864 1: General FD:8
2012.12.02 23:18:13.864 1: HMLAN_Send:  K
2012.12.02 23:18:13.864 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:18:13.864 1: General timer Start:124 :keepAlive:LANCUL time:1354486718.86461
2012.12.02 23:18:13.869 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8C1730 d2:0001
2012.12.02 23:18:14.704 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8C1A6C d:FF r:FFC9     m:9C A410 1D63F2 C26BB2 060100008000
2012.12.02 23:18:14.707 1: RCV L:0F N:9C F:A4 CMD:10 SRC:Licht_Bad DST:C26BB2 060100008000 (INFO_ACTUATOR_STATUS RSSI:-128 CHANNEL:0x01 STATUS:0x00 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2012.12.02 23:18:14.714 1: HMLAN: Skip ACK
2012.12.02 23:18:14.714 1: SND L:0A N:9C F:80 CMD:02 SRC:C26BB2 DST:Licht_Bad 00 (ACK) (,RPTEN)
2012.12.02 23:18:16.353 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8C20DD d:FF r:FFC7     m:9C A410 1D63F2 C26BB2 060100008000
2012.12.02 23:18:18.100 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8C27B1 d:FF r:FFC7     m:9C A410 1D63F2 C26BB2 060100008000
2012.12.02 23:18:19.476 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A8C2D13 d:FF r:FFD1     m:AF 8670 1937BA 000000 00E354
2012.12.02 23:18:19.479 1: RCV L:0C N:AF F:86 CMD:70 SRC:Heizung_Bad DST:broadcast 00E354 (WeatherEvent TEMP:22.7 HUM:84) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:18:21.098 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8C3367 d:FF r:FFC7     m:9C A410 1D63F2 C26BB2 060100008000
2012.12.02 23:18:25.004 1: General timer Start:125 :0 time:1354486765
2012.12.02 23:18:26.094 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8C46EC d:FF r:FFC6     m:9C A410 1D63F2 C26BB2 060100008000
2012.12.02 23:18:32.522 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A8C6009 d:FF r:FFBF     m:00 8670 19390F 000000 008D40
2012.12.02 23:18:32.525 1: RCV L:0C N:00 F:86 CMD:70 SRC:Heizung_Schlafzimmer DST:broadcast 008D40 (WeatherEvent TEMP:14.1 HUM:64) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:18:34.951 1: General timer Start:126 :HASH(0x991ada8) time:1354486744.95121
2012.12.02 23:18:35.086 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8C6A0D d:FF r:FFC6     m:9C A410 1D63F2 C26BB2 060100008000
2012.12.02 23:18:38.868 1: General FD:8
2012.12.02 23:18:38.869 1: HMLAN_Send:  K
2012.12.02 23:18:38.869 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:18:38.869 1: General timer Start:127 :keepAlive:LANCUL time:1354486743.86947
2012.12.02 23:18:38.874 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8C78E1 d2:0001
2012.12.02 23:18:39.476 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A8C7B36 d:FF r:FFD0     m:AF A258 1937BA 193C18 0000
2012.12.02 23:18:39.479 1: RCV L:0B N:AF F:A2 CMD:58 SRC:Heizung_Bad DST:Stellantrieb_Bad 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:18:39.609 1: HMLAN_Parse: LANCUL S:E193C18   stat:0000 t:0A8C7BB9 d:FF r:FFC1     m:AF 8202 193C18 1937BA 0101000032
2012.12.02 23:18:39.613 1: RCV L:0E N:AF F:82 CMD:02 SRC:Stellantrieb_Bad DST:Heizung_Bad 0101000032 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:-50) (,WAKEMEUP,RPTEN)
2012.12.02 23:18:39.962 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8C7D1A d:FF r:FFC7     m:9E A410 1D63F2 C26BB2 0601C80080C8
2012.12.02 23:18:39.965 1: RCV L:0F N:9E F:A4 CMD:10 SRC:Licht_Bad DST:C26BB2 0601C80080C8 (INFO_ACTUATOR_STATUS RSSI:-128 CHANNEL:0x01 STATUS:0xC8 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2012.12.02 23:18:40.043 1: HMLAN: Skip ACK
2012.12.02 23:18:40.043 1: SND L:0A N:9E F:80 CMD:02 SRC:C26BB2 DST:Licht_Bad 00 (ACK) (,RPTEN)
2012.12.02 23:18:42.080 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8C8560 d:FF r:FFC7     m:9E A410 1D63F2 C26BB2 0601C80080C8
2012.12.02 23:18:44.579 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8C8F23 d:FF r:FFC6     m:9E A410 1D63F2 C26BB2 0601C80080C8
2012.12.02 23:18:48.075 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8C9CCC d:FF r:FFBC     m:9E A410 1D63F2 C26BB2 0601C80080C8
2012.12.02 23:18:52.522 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A8CAE2B d:FF r:FFC3     m:00 A258 19390F 1939BF 0000
2012.12.02 23:18:52.524 1: RCV L:0B N:00 F:A2 CMD:58 SRC:Heizung_Schlafzimmer DST:Stellantrieb_Schlafzimmer 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:18:53.571 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8CB245 d:FF r:FFC6     m:9E A410 1D63F2 C26BB2 0601C80080C8
2012.12.02 23:18:57.567 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8CC1E1 d:FF r:FFC7     m:A0 A410 1D63F2 C26BB2 060100008000
2012.12.02 23:18:57.570 1: RCV L:0F N:A0 F:A4 CMD:10 SRC:Licht_Bad DST:C26BB2 060100008000 (INFO_ACTUATOR_STATUS RSSI:-128 CHANNEL:0x01 STATUS:0x00 UNKNOWN:0x00) (,CFG,BIDI,RPTEN)
2012.12.02 23:18:57.625 1: HMLAN: Skip ACK
2012.12.02 23:18:57.626 1: SND L:0A N:A0 F:80 CMD:02 SRC:C26BB2 DST:Licht_Bad 00 (ACK) (,RPTEN)
2012.12.02 23:19:00.065 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8CCBA3 d:FF r:FFC8     m:A0 A410 1D63F2 C26BB2 060100008000
2012.12.02 23:19:00.672 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A8CCE03 d:FF r:FFCA     m:C0 8670 1936C3 000000 00B938
2012.12.02 23:19:00.675 1: RCV L:0C N:C0 F:86 CMD:70 SRC:Heizung_Wohnzimmer DST:broadcast 00B938 (WeatherEvent TEMP:18.5 HUM:56) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:19:03.063 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8CD75A d:FF r:FFC8     m:A0 A410 1D63F2 C26BB2 060100008000
2012.12.02 23:19:03.870 1: General FD:8
2012.12.02 23:19:03.871 1: HMLAN_Send:  K
2012.12.02 23:19:03.871 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:19:03.871 1: General timer Start:128 :keepAlive:LANCUL time:1354486768.87133
2012.12.02 23:19:03.877 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8CDA8F d2:0001
2012.12.02 23:19:04.970 1: General timer Start:129 :HASH(0x991ada8) time:1354486774.97014
2012.12.02 23:19:07.059 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8CE6F6 d:FF r:FFC8     m:A0 A410 1D63F2 C26BB2 060100008000
2012.12.02 23:19:13.055 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8CFE63 d:FF r:FFC8     m:A0 A410 1D63F2 C26BB2 060100008000
2012.12.02 23:19:20.673 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A8D1C26 d:FF r:FFC9     m:C0 A258 1936C3 19399E 0023
2012.12.02 23:19:20.676 1: RCV L:0B N:C0 F:A2 CMD:58 SRC:Heizung_Wohnzimmer DST:Stellantrieb_Wohnzimmer 0023 (ClimateEvent CMD:0x00 ValvePos:35) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:19:20.806 1: HMLAN_Parse: LANCUL S:E19399E   stat:0000 t:0A8D1CAB d:FF r:FFC7     m:C0 8202 19399E 1936C3 0101180033
2012.12.02 23:19:20.809 1: RCV L:0E N:C0 F:82 CMD:02 SRC:Stellantrieb_Wohnzimmer DST:Heizung_Wohnzimmer 0101180033 (ACK_STATUS CHANNEL:0x01 STATUS:0x18 UP:0 DOWN:0 LOWBAT:0 RSSI:-51) (,WAKEMEUP,RPTEN)
2012.12.02 23:19:23.046 1: HMLAN_Parse: LANCUL S:E1D63F2   stat:0000 t:0A8D256B d:FF r:FFC8     m:A0 A410 1D63F2 C26BB2 060100008000
2012.12.02 23:19:25.002 1: General timer Start:130 :0 time:1354486825
2012.12.02 23:19:33.328 1: General remove timer:HASH(0x9ee4e08)
2012.12.02 23:19:33.332 1: General timer Start:131 :HASH(0x9ee2698) time:1354486946.27864
2012.12.02 23:19:33.337 1: General FD:8
2012.12.02 23:19:33.337 1: HMLAN_Send:  K
2012.12.02 23:19:33.337 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:19:33.338 1: General timer Start:132 :keepAlive:LANCUL time:1354486798.33794
2012.12.02 23:19:33.342 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8D4DAC d2:0001
2012.12.02 23:19:35.034 1: General timer Start:133 :HASH(0x991ada8) time:1354486805.03431
2012.12.02 23:19:58.361 1: General FD:8
2012.12.02 23:19:58.362 1: HMLAN_Send:  K
2012.12.02 23:19:58.362 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:19:58.362 1: General timer Start:134 :keepAlive:LANCUL time:1354486823.36242
2012.12.02 23:19:58.378 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8DAF7C d2:0001
2012.12.02 23:20:05.059 1: General timer Start:135 :HASH(0x991ada8) time:1354486835.05909
2012.12.02 23:20:23.381 1: General FD:8
2012.12.02 23:20:23.381 1: HMLAN_Send:  K
2012.12.02 23:20:23.381 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:20:23.382 1: General timer Start:136 :keepAlive:LANCUL time:1354486848.38187
2012.12.02 23:20:23.388 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8E1131 d2:0001
2012.12.02 23:20:25.002 1: General timer Start:137 :0 time:1354486885
2012.12.02 23:20:35.085 1: General timer Start:138 :HASH(0x991ada8) time:1354486865.08571
2012.12.02 23:20:48.395 1: General FD:8
2012.12.02 23:20:48.395 1: HMLAN_Send:  K
2012.12.02 23:20:48.396 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:20:48.396 1: General timer Start:139 :keepAlive:LANCUL time:1354486873.39626
2012.12.02 23:20:48.400 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8E72E9 d2:0001
2012.12.02 23:21:05.119 1: General timer Start:140 :HASH(0x991ada8) time:1354486895.11914
2012.12.02 23:21:13.405 1: General FD:8
2012.12.02 23:21:13.405 1: HMLAN_Send:  K
2012.12.02 23:21:13.405 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:21:13.405 1: General timer Start:141 :keepAlive:LANCUL time:1354486898.40563
2012.12.02 23:21:13.410 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8ED49E d2:0001
2012.12.02 23:21:20.731 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A8EF134 d:FF r:FFCF     m:B0 8670 1937BA 000000 00E348
2012.12.02 23:21:20.734 1: RCV L:0C N:B0 F:86 CMD:70 SRC:Heizung_Bad DST:broadcast 00E348 (WeatherEvent TEMP:22.7 HUM:72) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:21:25.005 1: General timer Start:142 :0 time:1354486945
2012.12.02 23:21:27.775 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A8F0CB7 d:FF r:FFC3     m:01 8670 19390F 000000 008D40
2012.12.02 23:21:27.778 1: RCV L:0C N:01 F:86 CMD:70 SRC:Heizung_Schlafzimmer DST:broadcast 008D40 (WeatherEvent TEMP:14.1 HUM:64) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:21:30.179 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A8F1619 d:FF r:FFC9     m:C1 8670 1936C3 000000 00B938
2012.12.02 23:21:30.182 1: RCV L:0C N:C1 F:86 CMD:70 SRC:Heizung_Wohnzimmer DST:broadcast 00B938 (WeatherEvent TEMP:18.5 HUM:56) (,WAKEMEUP,CFG,RPTEN)
2012.12.02 23:21:35.145 1: General timer Start:143 :HASH(0x991ada8) time:1354486925.14575
2012.12.02 23:21:38.409 1: General FD:8
2012.12.02 23:21:38.409 1: HMLAN_Send:  K
2012.12.02 23:21:38.409 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:21:38.410 1: General timer Start:144 :keepAlive:LANCUL time:1354486923.40999
2012.12.02 23:21:38.414 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8F364F d2:0001
2012.12.02 23:21:40.732 1: HMLAN_Parse: LANCUL S:E1937BA   stat:0000 t:0A8F3F58 d:FF r:FFD0     m:B0 A258 1937BA 193C18 0000
2012.12.02 23:21:40.735 1: RCV L:0B N:B0 F:A2 CMD:58 SRC:Heizung_Bad DST:Stellantrieb_Bad 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:21:41.020 1: HMLAN_Parse: LANCUL S:E193C18   stat:0000 t:0A8F3FDC d:FF r:FFC0     m:B0 8202 193C18 1937BA 010100002D
2012.12.02 23:21:41.023 1: RCV L:0E N:B0 F:82 CMD:02 SRC:Stellantrieb_Bad DST:Heizung_Bad 010100002D (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:-45) (,WAKEMEUP,RPTEN)
2012.12.02 23:21:47.775 1: HMLAN_Parse: LANCUL S:E19390F   stat:0000 t:0A8F5AD9 d:FF r:FFC2     m:01 A258 19390F 1939BF 0000
2012.12.02 23:21:47.778 1: RCV L:0B N:01 F:A2 CMD:58 SRC:Heizung_Schlafzimmer DST:Stellantrieb_Schlafzimmer 0000 (ClimateEvent CMD:0x00 ValvePos:0) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:21:47.911 1: HMLAN_Parse: LANCUL S:E1939BF   stat:0000 t:0A8F5B5F d:FF r:FFBF     m:01 8202 1939BF 19390F 0101000030
2012.12.02 23:21:47.914 1: RCV L:0E N:01 F:82 CMD:02 SRC:Stellantrieb_Schlafzimmer DST:Heizung_Schlafzimmer 0101000030 (ACK_STATUS CHANNEL:0x01 STATUS:0x00 UP:0 DOWN:0 LOWBAT:0 RSSI:-48) (,WAKEMEUP,RPTEN)
2012.12.02 23:21:50.177 1: HMLAN_Parse: LANCUL S:E1936C3   stat:0000 t:0A8F643C d:FF r:FFC9     m:C1 A258 1936C3 19399E 0023
2012.12.02 23:21:50.180 1: RCV L:0B N:C1 F:A2 CMD:58 SRC:Heizung_Wohnzimmer DST:Stellantrieb_Wohnzimmer 0023 (ClimateEvent CMD:0x00 ValvePos:35) (,WAKEMEUP,BIDI,RPTEN)
2012.12.02 23:21:50.309 1: HMLAN_Parse: LANCUL S:E19399E   stat:0000 t:0A8F64C0 d:FF r:FFC8     m:C1 8202 19399E 1936C3 0101180031
2012.12.02 23:21:50.312 1: RCV L:0E N:C1 F:82 CMD:02 SRC:Stellantrieb_Wohnzimmer DST:Heizung_Wohnzimmer 0101180031 (ACK_STATUS CHANNEL:0x01 STATUS:0x18 UP:0 DOWN:0 LOWBAT:0 RSSI:-49) (,WAKEMEUP,RPTEN)
2012.12.02 23:22:03.423 1: General FD:8
2012.12.02 23:22:03.423 1: HMLAN_Send:  K
2012.12.02 23:22:03.424 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:22:03.424 1: General timer Start:145 :keepAlive:LANCUL time:1354486948.42416
2012.12.02 23:22:03.429 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A8F9808 d2:0001
2012.12.02 23:22:05.177 1: General timer Start:146 :HASH(0x991ada8) time:1354486955.17739
2012.12.02 23:22:25.020 1: General timer Start:147 :0 time:1354487005
2012.12.02 23:22:34.069 1: General remove timer:HASH(0x9ee2698)
2012.12.02 23:22:34.073 1: General timer Start:148 :HASH(0x9f6a358) time:1354487126.27864
2012.12.02 23:22:34.078 1: 192.168.179.22:1000 disconnected, waiting to reappear
2012.12.02 23:22:34.078 1: General deviceLANCUL closed
2012.12.02 23:22:39.129 1: General Opening LANCUL device 192.168.179.22:1000
2012.12.02 23:22:39.137 1: 192.168.179.22:1000 reappeared (LANCUL)
2012.12.02 23:22:39.138 1: HMLAN_Send:  AC26BB2
2012.12.02 23:22:39.138 1: HMLAN_Send:  C
2012.12.02 23:22:39.138 1: HMLAN_Send:  Y01,01,
2012.12.02 23:22:39.138 1: HMLAN_Send:  Y02,00,
2012.12.02 23:22:39.150 1: HMLAN_Send:  Y03,00,
2012.12.02 23:22:39.150 1: HMLAN_Send:  T184E831F,04,00,00000000
2012.12.02 23:22:39.150 1: General remove timer:keepAlive:LANCUL
2012.12.02 23:22:39.151 1: General timer Start:149 :keepAlive:LANCUL time:1354486984.15095
2012.12.02 23:22:39.175 1: General timer Start:150 :HASH(0x991ada8) time:1354486989.17535
2012.12.02 23:22:39.176 1: HMLAN_Parse: LANCUL V:03C1 sNo:IEQ0244559 d:174270 O:C26BB2 m:0A902391 d2:0001
2012.12.02 23:23:04.173 1: General FD:4
2012.12.02 23:23:04.173 1: HMLAN_Send:  K
2012.12.02 23:23:04.174 1
Guest
Hallo Markus,
zwischenstand:
Es ist sicher ein Timerproblem. Aus dem log ist klar zu sehen, dass es eine
Verzoegerung gibt - kein einfaches delay sondern eine Verscheibung der
Timer. Und das Problem schaukelt sich auf.
Also der keepalive kommt alle 25 sec. Aber um 10:34 dauert es 28 sec, dann
wieder alles normal.
3 min spaeter habe ich +4 sec, also 29 statt 25 sec.
 Nach weiteren 3 min wieder +4 (=29 sec).
nach erneut 3 min sind es schon 5sec (30sec). Damit kommen wir in den
kritischen Bereich.
Alles sehr regelmaessig. Alle 3 min wird ein trigger statt 25 sec auf 25 +x
gesetzt. Und x erhoeht sich jedesmal um etwa 1 sec. Wenn 6 erreicht ist
sind wir ueber 30sec und HMLAN wrid nervoes, setzt den Link zurueck.
=> de Fehler erwarte ich also alle 3min*(6+-2) 12-24min
Es wird weder der timer einfach geloescht noch haben wir Probleme mit dem
file-descriptor.
Auf welcher Platform laeuft dein FHEM?
Gruss
Martin
Am Montag, 3. Dezember 2012 00:00:43 UTC+1 schrieb Markus Bloch:
> Hallo Martin,
> anbei das gewünschte Log mit dem angehangenen HMLAN Modul.
> Gruß
> Markus
UliM
Am Montag, 3. Dezember 2012 10:37:22 UTC+1 schrieb Martin:
Da kannst Du Recht haben:
2012.12.02 13:06:34.881 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 13:06:39.968 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 13:16:44.903 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 13:16:49.995 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 13:24:49.590 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 13:26:02.965 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 13:37:04.985 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 13:37:30.712 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 13:47:15.025 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 13:47:20.116 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 14:00:49.297 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 14:01:03.340 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 14:13:13.194 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 14:14:41.090 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 14:17:45.126 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 14:17:50.209 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 14:25:00.097 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 14:25:09.164 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 14:37:19.998 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 14:38:33.202 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 14:48:15.190 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 14:48:20.274 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 14:49:14.901 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 14:50:56.000 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 15:01:25.799 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 15:01:50.267 1: 192.168.2.111:1000 reappeared (HMLAN)
Dann Aktivität im Sytem, keine weiteren disconnect/reappear. Der nächste
Schwung:
2012.12.02 20:00:36.169 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 20:00:41.268 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 20:20:56.204 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 20:21:01.291 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 20:51:26.457 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 20:51:31.544 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 21:01:36.494 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 21:01:41.582 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 21:32:06.580 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 21:32:11.676 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 21:52:26.672 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 21:52:31.755 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 22:12:46.716 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 22:12:51.811 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 22:22:56.750 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 22:23:01.849 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.02 22:43:16.794 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.02 22:43:21.881 1: 192.168.2.111:1000 reappeared (HMLAN)
Schwung:
2012.12.03 00:23:15.089 2: FS20 set sz_LichtMaster off
2012.12.03 02:56:07.455 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 02:56:12.546 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 03:06:20.808 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 03:06:25.887 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 03:26:37.543 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 03:26:42.635 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 03:46:57.601 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 03:47:02.696 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 03:57:07.638 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 03:57:12.729 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 04:07:17.676 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 04:07:22.764 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 04:17:27.743 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 04:17:32.834 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 04:27:37.754 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 04:27:42.849 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 05:08:17.880 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 05:08:22.967 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 05:18:27.926 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 05:18:33.014 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 05:28:37.993 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 05:28:43.077 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 05:38:48.004 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 05:38:53.099 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 05:48:58.043 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 05:49:03.130 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.03 06:19:28.131 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.03 06:19:33.223 1: 192.168.2.111:1000 reappeared (HMLAN)
Die disconnect/reappear-Meldungen häufen sich also in Zeiten, in denen
HMLAN "idle" ist - abgesehen von HM-CC-TC-Meldungen und
Virtual_VD-Antworten.
Bei mir läuft FHEM auf ner FB7390.
Hilft es Dir ggf, weitere logs zu bekommen? Dann würd ich die oben
angehängte CUL_HM-Version auch mal installieren und Dir die logs schicken...
Gruß, Uli
Guest
Hallo Martin,
bei mir läuft FHEM auf einem aktuellen Debian Squeeze auf einem eee-pc
Netbook.
Markus
Guest
Habt ihr das twilight modul am laufen?
Am Montag, 3. Dezember 2012 11:23:49 UTC+1 schrieb Markus Bloch:
> Hallo Martin,
> Netbook.
> Gruß
> Markus
UliM
Am Montag, 3. Dezember 2012 13:06:44 UTC+1 schrieb Martin:
> Ja.
Guest
die uebergeben leider einen string anstelle eines float an den timer. Ich
denke, das koennte das Problem sein.
Anbei einmal ein Versuch eines repairs.
Das Problem sollte von den Verantwortlichen uebernommen werden
Gruss
Martin
Am Montag, 3. Dezember 2012 13:09:55 UTC+1 schrieb UliM:
>> Ja.
Guest
Ja, ich habe ebenfalls Twilight im Einsatz.
Markus
Guest
Also das ist schon einmal ein Unterschied zu meinem Setup..
Falls ihr das modul (oben) einmal testet - vielleich ist der Fehler
behoben.
Gruss
Martin
Am Montag, 3. Dezember 2012 13:23:12 UTC+1 schrieb Markus Bloch:
> Gruß
> Markus
Guest
Ich bekomme damit bei heutigem SVN-Stand diese Meldung:
Too many arguments for main::GetHttpFile at ./FHEM/59_Twilight.pm line 271,
near "4.0)"
Am Montag, 3. Dezember 2012 13:22:59 UTC+1 schrieb Martin:
UliM
Am Montag, 3. Dezember 2012 15:53:40 UTC+1 schrieb Ralf:
> 271, near "4.0)"
>>> War bei mir auch so.
In 59_Twilight.pm in Zeile 271 ersetzen:
my $xml =
GetHttpFile("weather.yahooapis.com:80","/forecastrss?w=".$location."&u=c",4.0);
my $xml = GetFileFromURL("weather.yahooapis.com:80","/forecastrss?w=".$location."&u=c",4.0);
Wieso zieht das Ding selbst nen Wetterbericht, wenn doch sowieso ein
Weather-Modul läuft? Egal..
Nächster Fehler:
[TWILIGHT] No Weather location found at yahoo weather for location ID:
20066988
Undefined subroutine &main::readingsUpdate called at
/var/InternerSpeicher/fhem/FHEM/59_Twilight.pm line 186, <$fh> line 686.
Und fhem schmiert ab...
In der SVN-Version von Twilight.pm gibt's diesen Aufruf nicht...
Martin?
Gruß, Uli
Guest
bin jetzt hier auf das Problem aufmerksam gemacht worden und schaue es mir
an.
Das Modul zieht selbst einen Wetterbericht - ja. Nur bei Yahoo sind die
Weather-Conditions klar dokumentiert, bei Google leider nicht. Daher der
eigene Abruf. Sicher unschön, mir fiel damals nichts besseres ein.
Das mit dem String und dem Float wundert mich, aber ich schaue es mir genau
an und melde mich wieder.
Guest
@Uli, hat es sich denn bei dir gebessert? Falls es benötigt würde, würde
ich das ganze bei mir mal auch ausprobieren
Guest
nochmal @Uli: ersetze mal readingsUpdate durch readings*Bulk*Update
Markus
UliM
Am Montag, 3. Dezember 2012 17:44:09 UTC+1 schrieb Markus Bloch:
Sehr gut, danke, damit läuft's. Hab eben erfolgreich "reloaded", melde mich
beim nächsten disconnect/reappear.
Gruß, Uli
