HMLAN - Lan-Interface startet dauernd neu
Begonnen von Guest, 27 November 2012, 21:18:48
UliM
bisher keine neuen dosconnect/reapperaed -Meldungen von HMLAN :)
Anbei die verwendete Version von Twilight.pm mit Korrekturen des
http-Aufrufs und bulkupdate.
=8-)
UliM
Am Dienstag, 4. Dezember 2012 00:23:34 UTC+1 schrieb UliM:
Wohl zu früh gefreut :(
2012.12.04 01:46:51.194 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 01:46:56.281 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 01:55:33.743 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 01:57:01.221 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 01:57:06.308 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 02:07:11.256 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 02:07:16.339 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 02:10:33.745 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 02:25:33.814 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 02:27:31.306 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 02:27:36.393 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 02:40:33.743 2: FS20 set hzg_HeizungFreigabeBrenner
off-for-timer 1920
2012.12.04 02:47:51.380 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 02:47:56.459 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 02:55:33.736 2: FS20 set hzg_HeizungFreigabeBrenner
off-for-timer 1920
2012.12.04 02:58:01.414 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 02:58:06.498 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 03:08:11.429 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 03:08:16.513 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 03:10:33.741 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 03:18:21.460 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 03:18:26.556 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 03:25:33.798 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 03:28:31.495 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 03:28:36.579 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 03:38:41.534 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 03:38:46.618 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 03:40:33.736 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 03:55:33.734 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 03:59:01.585 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 03:59:06.672 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 04:10:33.739 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 04:19:21.682 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 04:19:26.766 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 04:25:33.820 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 04:29:31.764 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 04:29:36.844 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 04:40:33.733 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 04:49:51.770 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 04:49:56.853 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 04:55:33.742 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 05:00:01.797 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 05:00:06.880 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 05:10:33.751 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 05:20:21.859 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 05:20:26.942 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 05:25:33.800 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 05:40:41.928 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 05:40:47.024 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 05:40:47.131 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 05:50:51.967 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 05:50:57.047 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 05:55:33.731 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 06:01:02.006 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 06:01:07.090 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 06:10:33.748 2: FS20 set hzg_HeizungFreigabeBrenner on
2012.12.04 06:11:12.033 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 06:11:17.120 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 06:21:22.068 1: 192.168.2.111:1000 disconnected, waiting to
reappear
2012.12.04 06:21:27.151 1: 192.168.2.111:1000 reappeared (HMLAN)
2012.12.04 06:25:33.809 2: FS20 set hzg_HeizungFreigabeBrenner on
 Hmmmmm...
Der gute Teil der Nachricht: Es beliben kosntant 5s, scheinbar kein
Aufschaukeln auf >1 Minute mehr.
=8-)
Guest
Da ich im aktuellen SVN im Twilight kein Problem finde was da auslösen
könnte, so denke ich zumindest:
könnst du das Twilight mal ganz rausnehmen und schauen ob es noch auftritt
Danke und VG
UliM
werde heute Abend das disabled-Attribut reinbauen - sonst laufen mir zu viele abhängige notifies& Progrämmchen auf Poller.
Gruß, Uli
UliM
... Bzw: kannst Du mir bitte sagen, an welcher Stelle das ziehen muss,
damit auch die Timer nicht starten.
Gruß Uli
Am Dienstag, 4. Dezember 2012 schrieb UliM :
> Hi,
> Gruß, Uli
Guest
ich bin noch einmal alle timer durchgegangen, die ich gesehen habe.
es laeuft einer mit 3 min. wenn der drankommt wird der keepalive nach
hinter versetzt. Ich weiss noch nicht, wer den 3min timer betreibt.
Vermutung ist, dass etwas im sortiermechanismus des timerhandling den 3min
timer vorzieht.
fakt ist, wenn "3min" um 00:33:00 enden soll und keepalive um 00:28:00 dann
kommt erst "3min" um 00:33:00 und danach der keepalive - also auch um
00:33:00. das sind dann 5 sec zu spaet.
Twilight habe ich also zu unrecht verdaechting - sorry.
anbei ein fhem.pl mit mehr logs zum timer. Hier sollte zu sehen sein, wir
fhem seine timer sortiert.
Gruss
Martin
Am Dienstag, 4. Dezember 2012 07:54:11 UTC+1 schrieb UliM:
> Hi,
> Gruß, Uli
Guest
nochn update.
ich denke ich habe den Fehler. ist nicht das sortieren sondern das
dispatchen der timer-routine.
Die Datei im Anhang hat immer noch die Logs - und hoffentlich auch einen
fix.
Gruss
Martin
Am Dienstag, 4. Dezember 2012 10:55:07 UTC+1 schrieb Martin:
> Hi,
> timer vorzieht.
> dann kommt erst "3min" um 00:33:00 und danach der keepalive - also auch um
> Gruss
> Martin
>> Hi,
>> Gruß, Uli
Guest
habe noch einmal nachgesehen - sieht vielversprechend aus. Die
Timer-routine liefert keinen Rueckgabewert wenn eine funktion abgearbeitet
wurde. damit wird, wenn ein timer 'ausgetimed' ist immer 5 sec gewartet
(bei nicht MSDOS32!)
Somit kann ein timer um bis zu 5 sec spaeter kommen (plus verzoegerungen
durch andere Prozesse). Und damit kommt der HMLAN keepAlive in den
kritischen Bereich von 30sec. Es kann zu Ausfaellen kommen oder auch nicht,
je nach device.
Der Fehler ist nicht auf HMLAN oder HM beschraenkt. Timern koennen also um
0+5 schwanken....
das letzte files fhem.pl sollte es beheben.
Gruss
Martin
Am Dienstag, 4. Dezember 2012 11:35:41 UTC+1 schrieb Martin:
> nochn update.
> fix.
> Gruss
> Martin
>> Hi,
>> 3min timer vorzieht.
>> wir fhem seine timer sortiert.
>> Gruss
>> Martin
>>> Hi,
>>> Gruß, Uli
Guest
ok kein Problem. Es gibt sicher unabhängig davon Optimierungspotential im
Timer-Modul. Insbesondere die ständige Wetterabfrage. Ich habe es halt vor
allem nach meinen Bedürfnissen entwickelt um es dann anderen auch zur
Verfügung zu stellen.
VG
Guest
Hallo unimatrix,
ah - das Timing modul ist von dir? Ist nur eine kleine Aenderung, dann
sollte es passen.
Das einzige, was dann nicht 100% funktionieren kann ist warten kleiner
5sec. Da liegt die Wartezeit irgenwo
'waitReq' < waitexecute <5sec
+ delays natuerlich
(ausser bei Windows)
muss man wissen, wenn man es benutzt.
Gruss
Martin
Guest
sorry, ich habe mich verschrieben - ich meinte das Twilight-Modul....da
hatte ich zu viel "Timer" im Kopf.
VG
UliM
Am 4. Dezember 2012 12:22 schrieb Martin :
> 0+5 schwanken....
Hab's jetzt reinkopiert, melde mich mit Log-Ergebnissen sobald/sofern
disconnect/reappear auftritt.
=8-)
UliM
Log anbei, 12x disconnect/reappered..
Gruß, Uli
PS: Habe auf die SVN-fhem.pl zurückgestellt, 1,1MB log in 2 Stunden sind
dann doch viel ;-)
Guest
ja, das waren viele traces - war auch nicht zum dauerbetrieb gedacht -
sorry.
Hat aber gezeigt, dass die Annahme des Fehlers korrekt ist - wenigstens das.
anbei ein besserer fix und weniger traces
Gruss
Martin
Am Dienstag, 4. Dezember 2012 21:37:07 UTC+1 schrieb UliM:
> Hi,
> Gruß, Uli
> dann doch viel ;-)
Guest
sorry - war die falsche datei, bitte die korrigierte nehmen - ist langsam
spät...
