72_Fritzbox: No value specified for 'ForceArray' option in call to XMLin()
Begonnen von smmmo, 30 April 2023, 22:05:50
smmmo
nach dem heutigen Update erhalte ich diesen Fehler im log:
2023.04.30 21:50:00 2: FRITZBOX!7530 [Fritzbox: SOAP_Request.5448] - INFO: TR064-RESPONSE-Error: No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5445.
Mein Setup (Zeilen mit device-Namen hab ich entfernt, hoffe das war ok):
define Fritzbox FRITZBOX 192.168.178.1
attr Fritzbox boxUser fhem
attr Fritzbox room Fritzbox,_Kammer
attr Fritzbox userReadings box_DownstreamVDSLRate { my $resp=fhem("get Fritzbox tr064Command WANDSLInterfaceConfig:1 wandslifconfig1 GetInfo",1);;;;\
$resp =~/'NewDownstreamCurrRate' => '(.*)'/;;;;\
$resp =sprintf("%.2f", $1/1024);;;;\
return $resp},\
box_UpstreamVDSLRate { my $resp=fhem("get Fritzbox tr064Command WANDSLInterfaceConfig:1 wandslifconfig1 GetInfo",1);;;;\
$resp =~/'NewUpstreamCurrRate' => '(.*)'/;;;;\
return $resp},\
box_DownstreamNoiseMargin { my $resp=fhem("get Fritzbox tr064Command WANDSLInterfaceConfig:1 wandslifconfig1 GetInfo",1);;;;\
$resp =~/'NewDownstreamNoiseMargin' => '(.*)'/;;;;\
$resp =$1/10;;;;\
return $resp},\
box_UpstreamNoiseMargin { my $resp=fhem("get Fritzbox tr064Command WANDSLInterfaceConfig:1 wandslifconfig1 GetInfo",1);;;;\
$resp =~/'NewUpstreamNoiseMargin' => '(.*)'/;;;;\
$resp =$1/10;;;;\
return $resp}\
#   APICHECKED 1
#   DEF        192.168.178.1
#   FUUID      5c4c4f78-f33f-f8d0-0d45-XXXXXXXXXXXXXXXX
#   HOST       192.168.178.1
#   INTERVAL   300
#   LUADATA    1
#   LUAQUERY   1
#   MODEL      FRITZ!Box 7530 AX
#   NAME       Fritzbox
#   NR         306
#   SECPORT    49443
#   STATE      WLAN: on gWLAN: off
#   TIMEOUT    55
#   TR064      1
#   TYPE       FRITZBOX
#   UPNP       non-emu
#   VERSION    07.50.16b
#   eventCount 2
#   READINGS:
#     2023-02-11 14:51:14   alarm1          Wecker 1
#     2023-02-11 14:51:14   alarm1_state    off
#     2023-02-11 14:51:14   alarm1_target   FON 1
#     2023-02-11 14:51:14   alarm1_time     00:00
#     2023-02-11 14:51:14   alarm1_wdays    daily
#     2023-02-11 14:51:14   alarm2          Wecker 2
#     2023-02-11 14:51:14   alarm2_state    off
#     2023-02-11 14:51:14   alarm2_target   FON 1
#     2023-02-11 14:51:14   alarm2_time     00:00
#     2023-02-11 14:51:14   alarm2_wdays    daily
#     2023-02-11 14:51:14   alarm3          Wecker 3
#     2023-02-11 14:51:14   alarm3_state    off
#     2023-02-11 14:51:14   alarm3_target   FON 1
#     2023-02-11 14:51:14   alarm3_time     00:00
#     2023-02-11 14:51:14   alarm3_wdays    daily
#     2023-04-30 21:50:00   box_DownstreamNoiseMargin 6
#     2023-04-30 21:50:00   box_DownstreamVDSLRate 93.45
#     2023-04-30 21:50:00   box_UpstreamNoiseMargin 6
#     2023-04-30 21:50:00   box_UpstreamVDSLRate 38.37
#     2023-04-30 21:50:00   box_connect     Connected
#     2023-04-30 21:50:00   box_connection_Type IP_Routed
#     2023-04-30 21:50:00   box_cpuTemp     57
#     2023-04-30 21:50:00   box_dect        on
#     2023-04-30 21:50:00   box_dns_Server0 217.237.151.142
#     2023-04-30 21:50:00   box_dns_Server1 217.237.150.188
#     2023-04-30 21:50:00   box_dsl_downStream 93.492
#     2023-04-30 21:50:00   box_dsl_upStream 38.390
#     2023-04-30 21:50:00   box_fon_LogNewest 201 05.04.23 06:26:16
#     2023-04-30 21:50:00   box_fwVersion   256.07.31
#     2023-04-30 21:50:00   box_guestWlan   off
#     2023-04-30 21:50:00   box_guestWlanCount 0
#     2023-04-30 21:50:00   box_guestWlanRemain 0
#     2023-04-30 21:50:00   box_ipv4_Extern 84.164.215.18
#     2023-04-30 21:50:00   box_last_connect_err ERROR_NONE
#     2023-04-30 21:50:00   box_macFilter_active off
#     2023-04-30 21:50:00   box_mac_Address 1C:ED:6F:2E:FC:ED
#     2023-04-30 21:49:48   box_model       FRITZ!Box 7530 AX [avm]
#     2023-04-30 21:50:00   box_moh         default
#     2023-04-30 21:50:00   box_powerRate   43
#     2023-04-30 21:50:00   box_rateDown    33.040
#     2023-04-30 21:50:00   box_rateUp      5.005
#     2023-04-30 21:50:00   box_stdDialPort dect2
#     2023-04-30 21:50:00   box_sys_LogNewest 504 30.04.23 21:49:56
#     2023-04-30 21:50:00   box_tr064       on
#     2023-04-30 21:50:00   box_tr069       off
#     2023-04-30 21:50:00   box_upnp        non-emu
#     2023-04-30 21:50:00   box_upnp_control_activated non-emu
#     2023-04-30 21:50:00   box_uptime      3308640 sec = 38T 07:04:00
#     2023-04-30 21:50:00   box_uptimeConnect 3308494 sec = 38T 07:01:34
#     2023-04-30 21:50:00   box_vdsl_downStreamMaxRate 96.714
#     2023-04-30 21:50:00   box_vdsl_downStreamRate 95.694
#     2023-04-30 21:50:00   box_vdsl_upStreamMaxRate 39.294
#     2023-04-30 21:50:00   box_vdsl_upStreamRate 39.294
#     2023-04-30 21:50:00   box_wlan_2.4GHz on
#     2023-04-30 21:50:00   box_wlan_5GHz   on
#     2023-04-30 21:50:00   box_wlan_Count  15
#     2023-04-30 21:50:00   box_wlan_LogExtended off
#     2023-04-30 21:50:00   box_wlan_LogNewest 786 30.04.23 05:17:09
#     2023-04-30 21:50:00   dect1           C4
#     2023-04-30 21:50:00   dect1_custRingTone file:///var/InternerSpeicher/FRITZ/fonring/1389435105.g722
#     2023-04-30 21:50:00   dect1_custRingToneName xxxxxxxxxxxxxxxxxxxx
#     2023-04-30 21:50:00   dect1_device    61
#     2023-04-30 21:50:00   dect1_fwVersion 4.67
#     2023-04-30 21:50:00   dect1_intRingTone HandsetDefault
#     2023-04-30 21:50:00   dect1_intern    611
#     2023-04-30 21:50:00   dect1_manufacturer AVM
#     2023-04-30 21:50:00   dect1_model     FRITZ!Fon C4
#     2023-04-30 21:50:00   dect1_radio     0 (unknown)
#     2023-04-30 21:50:00   fon70           XXXXXXXXXXXXX
#     2023-04-30 21:50:00   fon70_device    70
#     2023-04-30 21:50:00   fon9            alle Telefone
#     2023-04-30 21:50:00   fon9_device     9
#     2023-04-30 21:50:00   gsm_internet    0
#     2023-04-30 21:50:00   radio00         Deutschlandfunk
#     2023-04-30 21:50:00   radio01         DRadio Kultur
#     2023-04-30 21:50:00   radio02         DRadio Wissen
#     2023-04-30 21:50:00   radio03         Eins Live Diggi
#     2023-04-30 21:50:00   radio04         radioeins
#     2023-04-30 21:50:00   radio05         Radio Fritz
#     2023-04-30 21:50:00   radio06         Sputnik Livestream
#     2023-04-30 21:50:00   radio07         Swissgroove
#     2023-04-30 21:50:00   retStat_lastReadout 398 values captured in 4.25 s
#     2023-04-30 21:50:00   state           WLAN: on gWLAN: off
#     2023-04-30 21:50:00   tam1            AB XXXXXXX
#     2023-04-30 21:50:00   tam1_newMsg     0
#     2023-04-30 21:50:00   tam1_oldMsg     1
#     2023-04-30 21:50:00   tam1_state      on
#     2023-04-30 21:50:00   tam2            ebayNr
#     2023-04-30 21:50:00   tam2_newMsg     0
#     2023-04-30 21:50:00   tam2_oldMsg     0
#     2023-04-30 21:50:00   tam2_state      on
#     2023-02-11 14:51:14   user01          (guest)
#     2023-02-11 14:51:14   user01_thisMonthTime 0:00
#     2023-02-11 14:51:14   user01_todaySeconds 0
#     2023-02-11 14:51:14   user01_todayTime 0:00
#     2023-02-11 14:51:14   user01_type     Guest
#     2023-04-30 21:50:00   userTicket01    950399
#   fhem:
#     LOCAL      0
#     definedHost 192.168.178.1
#     fd_61      C4
#     fd_70      XXXXXXXXXXXXXXXXXXXX
#     fd_9       alle Telefone
#     fdn_C4     61
#     fdn_FRITZ!⁠App Fon (XXXX) 70
#     fdn_alle Telefone 9
#     is_double_wlan 1
#     lastHour   0
#     modulVersion $Date: 2023-04-28 20:26:52 +0200 (Fri, 28 Apr 2023) $
#     radioCount 40
#     sid        eb6cc04125e7dd6e
#     sidTime    1682884200.7946
#     611:
#       brand      AVM
#       id         2
#       model      C4
#       userId     1
#     landevice:
#                  fritz.repeater
#       1C_ED_6F_2E_FC_F0 landevice7844
#       30_AE_A4_7B_C2_24 landevice2787
#       38_9D_92_B1_3B_D8 landevice9225
#       48_3F_DA_8D_09_F9 landevice7845
#       4C_CC_6A_AF_B7_A1 landevice10440
#       68_37_E9_49_D9_F7 landevice5277
#       8A_72_57_C3_AC_A7 landevice41084
#       94_DB_56_6B_58_FF landevice46451
#       9C_04_EB_8F_14_8C landevice1281
#       AC_6F_BB_4F_E4_CB landevice4932
#       B0_4A_39_2B_DC_4B landevice5971
#       B4_E6_2D_7A_16_2E landevice2648
#       B4_E6_2D_7A_2E_01 landevice4231
#       D2_CE_1E_1A_F3_FE landevice3382
#       D8_BF_C0_51_DA_E7 landevice7846
#       D8_BF_C0_51_DB_16 landevice4693
#       EC_A8_6B_FF_63_43 landevice1287
#       EC_B5_FA_90_B6_A3 landevice134071
#       F0_F0_A4_A5_64_92 landevice55594
#       F6_7D_D9_2C_40_CD landevice6307
#       F8_AD_CB_0B_22_0D landevice9968
#     radio:
#       0          Deutschlandfunk
#       1          DRadio Kultur
#       10
#       11
#       12
#       13
#       14
#       15
#       16
#       17
#       18
#       19
#       2          DRadio Wissen
#       20
#       21
#       22
#       23
#       24
#       25
#       26
#       27
#       28
#       29
#       3          Eins Live Diggi
#       30
#       31
#       32
#       33
#       34
#       35
#       36
#       37
#       38
#       39
#       4          radioeins
#       5          Radio Fritz
#       6          Sputnik Livestream
#       7          Swissgroove
#       8
#       9
#     wlanDevice:
#       00_04_20_F4_DE_97:
#         rssi       -73
#         speed      65
#         speed_rx   58
#       00_24_E4_CF_BF_C0:
#         rssi       0
#         speed      0
#         speed_rx   0
#       00_24_E4_D8_5E_8E:
#         rssi       0
#         speed      0
#         speed_rx   0
#       00_BB_3A_98_3A_2A:
#         rssi       0
#         speed      0
#         speed_rx   0
#       0E_B0_D4_6A_19_1C:
#         rssi       -55
#         speed      866
#         speed_rx   780
#       30_AE_A4_7B_C2_24:
#         rssi       -58
#         speed      52
#         speed_rx   14
#       34_41_5D_C2_A2_9A:
#         rssi       0
#         speed      0
#         speed_rx   0
#       48_3F_DA_8D_09_F9:
#         rssi       -67
#         speed      52
#         speed_rx   54
#       50_3E_AA_DB_7E_9E:
#         rssi       0
#         speed      0
#         speed_rx   0
#       68_37_E9_49_D9_F7:
#         rssi       -69
#         speed      72
#         speed_rx   24
#       84_BA_3B_51_F3_8B:
#         rssi       0
#         speed      0
#         speed_rx   0
#       8A_72_57_C3_AC_A7:
#         rssi       -69
#         speed      351
#         speed_rx   6
#       98_84_E3_AD_CD_1C:
#         rssi       0
#         speed      0
#         speed_rx   0
#       9C_04_EB_8F_14_8C:
#         rssi       -47
#         speed      150
#         speed_rx   150
#       9C_5A_44_DC_D6_50:
#         rssi       0
#         speed      0
#         speed_rx   0
#       B0_4A_39_2B_DC_4B:
#         rssi       -59
#         speed      65
#         speed_rx   72
#       B4_E6_2D_7A_16_2E:
#         rssi       -77
#         speed      28
#         speed_rx   36
#       B4_E6_2D_7A_2E_01:
#         rssi       -74
#         speed      57
#         speed_rx   6
#       C8_F7_33_0C_37_80:
#         rssi       0
#         speed      0
#         speed_rx   0
#       D8_BF_C0_51_DA_E7:
#         rssi       -72
#         speed      21
#         speed_rx   6
#       D8_BF_C0_51_DB_16:
#         rssi       -66
#         speed      43
#         speed_rx   54
#       DC_0B_34_87_7C_9F:
#         rssi       0
#         speed      0
#         speed_rx   0
#       F0_F0_A4_A5_64_92:
#         rssi       -63
#         speed      433
#         speed_rx   433
#       F6_7D_D9_2C_40_CD:
#         rssi       -56
#         speed      866
#         speed_rx   585
#       F8_AD_CB_0B_22_0D:
#         rssi       -47
#         speed      433
#         speed_rx   6
#   helper:
#     TimerCmd   Fritzbox.Cmd
#     TimerReadout Fritzbox.Readout
setstate Fritzbox WLAN: on gWLAN: off
setstate Fritzbox 2023-04-30 21:50:00 .box_TodayBytesReceivedHigh 2
setstate Fritzbox 2023-04-30 21:50:00 .box_TodayBytesReceivedLow 1141653340
setstate Fritzbox 2023-04-30 21:50:00 .box_TodayBytesSentHigh 0
setstate Fritzbox 2023-04-30 21:50:00 .box_TodayBytesSentLow 1664049741
setstate Fritzbox 2023-02-11 14:51:14 alarm1 Wecker 1
setstate Fritzbox 2023-02-11 14:51:14 alarm1_state off
setstate Fritzbox 2023-02-11 14:51:14 alarm1_target FON 1
setstate Fritzbox 2023-02-11 14:51:14 alarm1_time 00:00
setstate Fritzbox 2023-02-11 14:51:14 alarm1_wdays daily
setstate Fritzbox 2023-02-11 14:51:14 alarm2 Wecker 2
setstate Fritzbox 2023-02-11 14:51:14 alarm2_state off
setstate Fritzbox 2023-02-11 14:51:14 alarm2_target FON 1
setstate Fritzbox 2023-02-11 14:51:14 alarm2_time 00:00
setstate Fritzbox 2023-02-11 14:51:14 alarm2_wdays daily
setstate Fritzbox 2023-02-11 14:51:14 alarm3 Wecker 3
setstate Fritzbox 2023-02-11 14:51:14 alarm3_state off
setstate Fritzbox 2023-02-11 14:51:14 alarm3_target FON 1
setstate Fritzbox 2023-02-11 14:51:14 alarm3_time 00:00
setstate Fritzbox 2023-02-11 14:51:14 alarm3_wdays daily
setstate Fritzbox 2023-04-30 21:50:00 box_DownstreamNoiseMargin 6
setstate Fritzbox 2023-04-30 21:50:00 box_DownstreamVDSLRate 93.45
setstate Fritzbox 2023-04-30 21:50:00 box_UpstreamNoiseMargin 6
setstate Fritzbox 2023-04-30 21:50:00 box_UpstreamVDSLRate 38.37
setstate Fritzbox 2023-04-30 21:50:00 box_connect Connected
setstate Fritzbox 2023-04-30 21:50:00 box_connection_Type IP_Routed
setstate Fritzbox 2023-04-30 21:50:00 box_cpuTemp 57
setstate Fritzbox 2023-04-30 21:50:00 box_dect on
setstate Fritzbox 2023-04-30 21:50:00 box_dns_Server0 217.237.151.142
setstate Fritzbox 2023-04-30 21:50:00 box_dns_Server1 217.237.150.188
setstate Fritzbox 2023-04-30 21:50:00 box_dsl_downStream 93.492
setstate Fritzbox 2023-04-30 21:50:00 box_dsl_upStream 38.390
setstate Fritzbox 2023-04-30 21:50:00 box_fon_LogNewest 201 05.04.23 06:26:16
setstate Fritzbox 2023-04-30 21:50:00 box_fwVersion 256.07.31
setstate Fritzbox 2023-04-30 21:50:00 box_guestWlan off
setstate Fritzbox 2023-04-30 21:50:00 box_guestWlanCount 0
setstate Fritzbox 2023-04-30 21:50:00 box_guestWlanRemain 0
setstate Fritzbox 2023-04-30 21:50:00 box_ipv4_Extern 84.164.215.18
setstate Fritzbox 2023-04-30 21:50:00 box_last_connect_err ERROR_NONE
setstate Fritzbox 2023-04-30 21:50:00 box_macFilter_active off
setstate Fritzbox 2023-04-30 21:50:00 box_mac_Address 1C:ED:6F:2E:FC:ED
setstate Fritzbox 2023-04-30 21:49:48 box_model FRITZ!Box 7530 AX [avm]
setstate Fritzbox 2023-04-30 21:50:00 box_moh default
setstate Fritzbox 2023-04-30 21:50:00 box_powerRate 43
setstate Fritzbox 2023-04-30 21:50:00 box_rateDown 33.040
setstate Fritzbox 2023-04-30 21:50:00 box_rateUp 5.005
setstate Fritzbox 2023-04-30 21:50:00 box_stdDialPort dect2
setstate Fritzbox 2023-04-30 21:50:00 box_sys_LogNewest 504 30.04.23 21:49:56
setstate Fritzbox 2023-04-30 21:50:00 box_tr064 on
setstate Fritzbox 2023-04-30 21:50:00 box_tr069 off
setstate Fritzbox 2023-04-30 21:50:00 box_upnp non-emu
setstate Fritzbox 2023-04-30 21:50:00 box_upnp_control_activated non-emu
setstate Fritzbox 2023-04-30 21:50:00 box_uptime 3308640 sec = 38T 07:04:00
setstate Fritzbox 2023-04-30 21:50:00 box_uptimeConnect 3308494 sec = 38T 07:01:34
setstate Fritzbox 2023-04-30 21:50:00 box_vdsl_downStreamMaxRate 96.714
setstate Fritzbox 2023-04-30 21:50:00 box_vdsl_downStreamRate 95.694
setstate Fritzbox 2023-04-30 21:50:00 box_vdsl_upStreamMaxRate 39.294
setstate Fritzbox 2023-04-30 21:50:00 box_vdsl_upStreamRate 39.294
setstate Fritzbox 2023-04-30 21:50:00 box_wlan_2.4GHz on
setstate Fritzbox 2023-04-30 21:50:00 box_wlan_5GHz on
setstate Fritzbox 2023-04-30 21:50:00 box_wlan_Count 15
setstate Fritzbox 2023-04-30 21:50:00 box_wlan_LogExtended off
setstate Fritzbox 2023-04-30 21:50:00 box_wlan_LogNewest 786 30.04.23 05:17:09
setstate Fritzbox 2023-04-30 21:50:00 dect1 C4
setstate Fritzbox 2023-04-30 21:50:00 dect1_custRingTone file:///var/InternerSpeicher/FRITZ/fonring/1389435105.g722
setstate Fritzbox 2023-04-30 21:50:00 dect1_custRingToneName xxxxxx
setstate Fritzbox 2023-04-30 21:50:00 dect1_device 61
setstate Fritzbox 2023-04-30 21:50:00 dect1_fwVersion 4.67
setstate Fritzbox 2023-04-30 21:50:00 dect1_intRingTone HandsetDefault
setstate Fritzbox 2023-04-30 21:50:00 dect1_intern 611
setstate Fritzbox 2023-04-30 21:50:00 dect1_manufacturer AVM
setstate Fritzbox 2023-04-30 21:50:00 dect1_model FRITZ!Fon C4
setstate Fritzbox 2023-04-30 21:50:00 dect1_radio 0 (unknown)
setstate Fritzbox 2023-04-30 21:50:00 fon70 FRITZ!⁠App Fon (xxxxx)
setstate Fritzbox 2023-04-30 21:50:00 fon70_device 70
setstate Fritzbox 2023-04-30 21:50:00 fon9 alle Telefone
setstate Fritzbox 2023-04-30 21:50:00 fon9_device 9
setstate Fritzbox 2023-04-30 21:50:00 gsm_internet 0
setstate Fritzbox 2023-04-30 21:50:00 radio00 Deutschlandfunk
setstate Fritzbox 2023-04-30 21:50:00 radio01 DRadio Kultur
setstate Fritzbox 2023-04-30 21:50:00 radio02 DRadio Wissen
setstate Fritzbox 2023-04-30 21:50:00 radio03 Eins Live Diggi
setstate Fritzbox 2023-04-30 21:50:00 radio04 radioeins
setstate Fritzbox 2023-04-30 21:50:00 radio05 Radio Fritz
setstate Fritzbox 2023-04-30 21:50:00 radio06 Sputnik Livestream
setstate Fritzbox 2023-04-30 21:50:00 radio07 Swissgroove
setstate Fritzbox 2023-04-30 21:50:00 retStat_lastReadout 398 values captured in 4.25 s
setstate Fritzbox 2023-04-30 21:50:00 state WLAN: on gWLAN: off
setstate Fritzbox 2023-04-30 21:50:00 tam1 AB xxxxxx
setstate Fritzbox 2023-04-30 21:50:00 tam1_newMsg 0
setstate Fritzbox 2023-04-30 21:50:00 tam1_oldMsg 1
setstate Fritzbox 2023-04-30 21:50:00 tam1_state on
setstate Fritzbox 2023-04-30 21:50:00 tam2 ebayNr
setstate Fritzbox 2023-04-30 21:50:00 tam2_newMsg 0
setstate Fritzbox 2023-04-30 21:50:00 tam2_oldMsg 0
setstate Fritzbox 2023-04-30 21:50:00 tam2_state on
setstate Fritzbox 2023-02-11 14:51:14 user01 (guest)
setstate Fritzbox 2023-02-11 14:51:14 user01_thisMonthTime 0:00
setstate Fritzbox 2023-02-11 14:51:14 user01_todaySeconds 0
setstate Fritzbox 2023-02-11 14:51:14 user01_todayTime 0:00
setstate Fritzbox 2023-02-11 14:51:14 user01_type Guest
setstate Fritzbox 2023-04-30 21:50:00 userTicket01 950399
log beim Starten:
2023.04.30 21:49:42 1: Including /opt/fhem/fhem.cfg
2023.04.30 21:49:42 2: Switched CUL_0 rfmode to HomeMatic
2023.04.30 21:49:42 2: eventTypes: loaded 3841 lines from log/eventTypes.txt
2023.04.30 21:49:46 1: Including ./log/fhem.save
2023.04.30 21:49:46 2: Hue2: autocreate: created 0/0/0 devices (ignored 0/0/2)
2023.04.30 21:49:46 2: alexa: starting alexa-fhem: /usr/local/bin/alexa-fhem -c /opt/fhem/alexa-fhem.cfg -a xx:xx
2023.04.30 21:49:46 0: Featurelevel: 6.2
2023.04.30 21:49:46 0: Server started with 273 defined entities (fhem.pl:27410/2023-04-07 perl:5.036000 os:linux user:fhem pid:11315)
2023.04.30 21:49:46 1: 192.168.178.34:1883 reappeared (myBroker)
2023.04.30 21:49:47 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/31_HUEDevice.pm line 1800.
2023.04.30 21:49:47 2: AttrTemplates: got 283 entries
2023.04.30 21:49:47 1: PERL WARNING: Invalid conversion in sprintf: end of string at ./FHEM/98_FReplacer.pm line 451, <$tmpl> line 707.
2023.04.30 21:49:49 2: Hue2: autocreate: created 0/0/0 devices (ignored 0/0/2)
2023.04.30 21:49:55 2: roborock: connecting
2023.04.30 21:50:12 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/30_HUEBridge.pm line 2596.
2023.04.30 21:55:00 2: FRITZBOX!7530 [Fritzbox: SOAP_Request.5448] - INFO: TR064-RESPONSE-Error: No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5445.
smmmo
JoWiemann
Jörg Wiemann
fettgu
Ich habe das gleiche Thema mit einer Fritzbox 7590 auf FritzOS:7.50...
JoWiemann
es wäre schön, wenn ich ein bisschen mehr Informationen erhalten würde.
- wann war das letzte Update
- Mindestens ein List vom Device. Am Besten ein Log mit verbose 4.
So kann ich nur raten. Vor allem da dieser Fehler bei allen Testern nicht aufgetreten ist.
Danke und Grüße Jörg
Jörg Wiemann
fettgu
ja klar,
hier ein list
define FritzBox FRITZBOX 192.168.178.1
attr FritzBox boxUser fritz2470
attr FritzBox devStateIcon .*on.*off:WLAN_on_gWLAN_off .*on.*on.*:WLAN_on_gWLAN_on WLAN..off.*:WLAN_off
attr FritzBox event-on-update-reading state
attr FritzBox group Schalter
attr FritzBox icon it_router
attr FritzBox realRoom Haus
attr FritzBox room GoogleAssistant,System->LAN
attr FritzBox verbose 4
#   APICHECKED 1
#   DEF        192.168.178.1
#   FUUID      5c46310a-f33f-c8fc-35e5-a2ac43022b330103
#   FVERSION   72_FRITZBOX.pm:0.274950/2023-04-28
#   INTERVAL   300
#   LUADATA    1
#   LUAQUERY   1
#   MODEL      FRITZ!Box 7590
#   NAME       FritzBox
#   NR         37
#   SECPORT    49443
#   TIMEOUT    55
#   TR064      1
#   TYPE       FRITZBOX
#   UPNP       1
#   VERSION    07.50.16b
#   eventCount 28
#   READINGS:
#     2023-01-11 22:04:22   alarm1          Wecker 1
#     2023-01-11 22:04:22   alarm1_state    off
#     2023-01-11 22:04:22   alarm1_target   FON 1
#     2023-01-11 22:04:22   alarm1_time     00:00
#     2023-01-11 22:04:22   alarm1_wdays    daily
#     2023-01-11 22:04:22   alarm2          Wecker 2
#     2023-01-11 22:04:22   alarm2_state    off
#     2023-01-11 22:04:22   alarm2_target   FON 1
#     2023-01-11 22:04:22   alarm2_time     00:00
#     2023-01-11 22:04:22   alarm2_wdays    daily
#     2023-01-11 22:04:22   alarm3          Wecker 3
#     2023-01-11 22:04:22   alarm3_state    off
#     2023-01-11 22:04:22   alarm3_target   FON 1
#     2023-01-11 22:04:22   alarm3_time     00:00
#     2023-01-11 22:04:22   alarm3_wdays    daily
#     2023-04-30 22:37:27   box_connect     Connected
#     2023-04-30 22:37:27   box_connection_Type IP_Routed
#     2023-04-30 22:37:27   box_cpuTemp     79
#     2023-04-30 22:37:27   box_dect        off
#     2023-04-30 22:37:27   box_dns_Server0 2001:1438:2:3::8
#     2023-04-30 22:37:27   box_dns_Server1 2001:1438:2:4::8
#     2023-04-30 22:37:27   box_dsl_downStream 114.103
#     2023-04-30 22:37:27   box_dsl_upStream 36.147
#     2023-04-30 22:37:27   box_fon_LogNewest none
#     2023-04-30 22:37:27   box_fwVersion   154.07.50
#     2023-04-30 22:37:27   box_guestWlan   off
#     2023-04-30 22:37:27   box_guestWlanCount 0
#     2023-04-30 22:37:27   box_guestWlanRemain 0
#     2023-04-30 22:37:27   box_ipv4_Extern 2001:16b8:3002:3c77:de39:6fff:fecb:580e
#     2023-04-23 21:17:55   box_ipv6_Extern 2001:16b8:3003:5311:de39:6fff:fecb:580e
#     2023-04-23 21:17:55   box_ipv6_Prefix 2001:16b8:31f6:1300::
#     2023-04-30 22:37:27   box_last_connect_err ERROR_NONE
#     2023-04-30 22:37:27   box_macFilter_active off
#     2023-04-30 22:37:27   box_mac_Address DC:39:5F:CB:58:0F
#     2023-04-30 22:37:27   box_meshRole    master
#     2023-04-30 20:36:59   box_model       FRITZ!Box 7590 [avm]
#     2023-04-30 22:37:27   box_moh         default
#     2023-04-30 22:37:27   box_powerRate   31
#     2023-04-30 22:37:27   box_rateDown    284.390
#     2023-04-30 22:37:27   box_rateUp      25.312
#     2023-04-30 22:37:27   box_stdDialPort fon1
#     2023-04-30 22:37:27   box_sys_LogNewest 500 30.04.23 22:24:53
#     2023-04-30 22:37:27   box_tr064       on
#     2023-04-30 22:37:27   box_tr069       on
#     2023-04-30 22:37:27   box_upnp        on
#     2023-04-30 22:37:27   box_upnp_control_activated on
#     2023-04-30 22:37:27   box_uptime      12788100 sec = 148T 00:15:00
#     2023-04-30 22:37:27   box_uptimeConnect 68397 sec = 0T 18:59:57
#     2023-04-30 22:37:27   box_vdsl_downStreamMaxRate 135.987
#     2023-04-30 22:37:27   box_vdsl_downStreamRate 116.79
#     2023-04-30 22:37:27   box_vdsl_upStreamMaxRate 40.791
#     2023-04-30 22:37:27   box_vdsl_upStreamRate 36.999
#     2023-04-30 22:37:27   box_wlan_2.4GHz on
#     2023-04-30 22:37:27   box_wlan_5GHz   on
#     2023-04-30 22:37:27   box_wlan_Count  29
#     2023-04-30 22:37:27   box_wlan_LogExtended off
#     2023-04-30 22:37:27   box_wlan_LogNewest 786 30.04.23 20:56:32
#     2023-04-30 22:37:27   fon1            Telefon WZ
#     2023-04-30 22:37:27   fon1_device     1
#     2023-04-30 22:37:27   fon1_intern     1
#     2023-04-30 22:37:27   fon1_out        SIP0#
#     2023-04-30 22:37:27   fon2            xxx
#     2023-04-30 22:37:27   fon2_device     2
#     2023-04-30 22:37:27   fon2_intern     2
#     2023-04-30 22:37:27   fon2_out        SIP0#
#     2023-04-30 22:37:27   fon50           xxx
#     2023-04-30 22:37:27   fon50_device    50
#     2023-04-30 22:37:27   fon70           FRITZ!Box
#     2023-04-30 22:37:27   fon70_device    70
#     2023-04-30 22:37:27   fon9            alle Telefone
#     2023-04-30 22:37:27   fon9_device     9
#     2023-04-30 22:37:27   gsm_internet    0
#     2023-04-30 22:37:27   mac_00_06....
#     2023-04-30 22:37:27   retStat_lastReadout 763 values captured in 16.09 s
#     2023-04-30 22:37:27   state           WLAN: on gWLAN: off
#     2023-04-30 22:37:27   tam1            Anrufbeantworter
#     2023-04-30 22:37:27   tam1_newMsg     0
#     2023-04-30 22:37:27   tam1_oldMsg     0
#     2023-04-30 22:37:27   tam1_state      off
#     2023-01-11 22:04:22   user01   ...    543477
#   fhem:
#     LOCAL      0
#     is_double_wlan 1
#     lastHour   0
#     radioCount 40
#     sid        e60197d7f8eb4558
#     sidTime    1682887047.42615
#     landevice:
#     radio:
#     wlanDevice:
# ... truncated to 50k, original length 71155
Hier der Logeintrag (oben ist alt)
Zitat2023.04.30 22:37:27 4: FRITZBOX!7590 [FritzBox: Readout_Run_Web.3548] - INFO: Captured 873 values
2023.04.30 22:37:27 4: FRITZBOX!7590 [FritzBox: Readout_Run_Web.3519] - DEBUG: SOAP-ERROR -> No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5445.
2023.04.30 22:37:27 2: FRITZBOX!7590 [FritzBox: SOAP_Request.5448] - INFO: TR064-RESPONSE-Error: No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5445.
2023.04.30 22:37:27 4: FRITZBOX!7590 [FritzBox: Readout_Run_Web.3501] - DEBUG: SOAP-ERROR -> No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5445.
2023.04.30 22:37:25 4: FRITZBOX!7590 [FritzBox: readPassword.7075] - INFO: Read FritzBox password from file
2023.04.30 22:37:25 4: FRITZBOX!7590 [FritzBox: Readout_Run_Web.3218] - DEBUG: wrong Fritz!OS: 07.50 or AVM-Model: FRITZ!Box 7590 for docsis informations.
2023.04.30 22:37:24 4: FRITZBOX!7590 [FritzBox: Lua_Data.5902] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.04.30 22:37:24 4: FRITZBOX!7590 [FritzBox: Lua_Data.5898] - INFO: Request data via API dataQuery.
2023.04.30 22:37:24 4: FRITZBOX!7590 [FritzBox: Web_OpenCon.5770] - DEBUG: using old SID from 22:32:21
2023.04.30 22:37:20 4: FRITZBOX!7590 [FritzBox: Lua_Data.5902] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.04.30 22:37:20 4: FRITZBOX!7590 [FritzBox: Lua_Data.5898] - INFO: Request data via API dataQuery.
2023.04.30 22:37:20 4: FRITZBOX!7590 [FritzBox: Web_OpenCon.5770] - DEBUG: using old SID from 22:32:21
2023.04.30 22:37:19 4: FRITZBOX!7590 [FritzBox: Lua_Data.5902] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.04.30 22:37:19 4: FRITZBOX!7590 [FritzBox: Lua_Data.5898] - INFO: Request data via API dataQuery.
2023.04.30 22:37:19 4: FRITZBOX!7590 [FritzBox: Web_OpenCon.5770] - DEBUG: using old SID from 22:32:21
2023.04.30 22:37:18 4: FRITZBOX!7590 [FritzBox: Lua_Data.5902] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.04.30 22:37:18 4: FRITZBOX!7590 [FritzBox: Lua_Data.5898] - INFO: Request data via API dataQuery.
2023.04.30 22:37:18 4: FRITZBOX!7590 [FritzBox: Web_OpenCon.5770] - DEBUG: using old SID from 22:32:21
2023.04.30 22:37:18 4: FRITZBOX!7590 [FritzBox: Readout_Run_Web.2212] - INFO: sip for box-model: 7590
2023.04.30 22:37:17 4: FRITZBOX!7590 [FritzBox: Lua_Data.5902] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.04.30 22:37:17 4: FRITZBOX!7590 [FritzBox: Lua_Data.5898] - INFO: Request data via API dataQuery.
2023.04.30 22:37:17 4: FRITZBOX!7590 [FritzBox: Web_OpenCon.5770] - DEBUG: using old SID from 22:32:21
2023.04.30 22:37:11 4: FRITZBOX!7590 [FritzBox: Web_Query.5824] - DEBUG: Request data via API luaQuery
2023.04.30 22:37:11 4: FRITZBOX!7590 [FritzBox: Web_OpenCon.5770] - DEBUG: using old SID from 22:32:21
2023.04.30 22:37:11 4: FRITZBOX!7590 [FritzBox: Readout_Run_Web.1961] - ReadOut gestartet: &radio=configd:settings/WEBRADIO/list(Name)&box_dect=dect:settings/enabled&handsetCount=dect:settings/Handset/count&handset=dect:settings/Handset/list(User,Manufacturer,Model,FWVersion,Productname)&wlanList=wlan:settings/wlanlist/list(mac,speed,speed_rx,rssi,is_guest)&wlanListNew=wlan:settings/wlanlist/list(mac,speed,rssi)&lanDevice=landevice:settings/landevice/list(mac,ip,ethernet,ethernet_port,ethernetport,guest,name,active,online,wlan,speed,UID)&lanDeviceNew=landevice:settings/landevice/list(mac,ip,ethernet,guest,name,active,online,wlan,speed,UID)&init=telcfg:settings/Foncontrol&box_stdDialPort=telcfg:settings/DialPort&dectUser=telcfg:settings/Foncontrol/User/list(Id,Name,Intern,IntRingTone,AlarmRingTone0,RadioRingID,ImagePath,G722RingTone,G722RingToneName)&fonPort=telcfg:settings/MSN/Port/list(Name,MSN)&diversity=telcfg:settings/Diversity/list(MSN,Active,Destination)&box_moh=telcfg:settings/MOHType&box_uptimeHours=uimodlogic:status/uptime_hours&box_uptimeMinutes=uimodlogic:status/uptime_minutes&box_fwVersion=logic:status/nspver&box_fwVersion_neu=uimodlogic:status/nspver&box_powerRate=power:status/rate_sumact&tam=tam:settings/TAM/list(Name,Display,Active,NumNewMessages,NumOldMessages)&box_cpuTemp=power:status/act_temperature&box_tr064=tr064:settings/enabled&box_tr069=tr069:settings/enabled&box_upnp=box:settings/upnp_activated&box_upnpCtrl=box:settings/upnp_control_activated&box_fwUpdate=updatecheck:status/update_available_hint&is_double_wlan=wlan:settings/feature_flags/DBDC&box_wlan_24GHz=wlan:settings/ap_enabled&box_wlan_5GHz=wlan:settings/ap_enabled_scnd&box_guestWlan=wlan:settings/guest_ap_enabled&box_guestWlanRemain=wlan:settings/guest_time_remain&box_macFilter_active=wlan:settings/is_macfilter_active&TodayBytesReceivedHigh=inetstat:status/Today/BytesReceivedHigh&TodayBytesReceivedLow=inetstat:status/Today/BytesReceivedLow&TodayBytesSentHigh=inetstat:status/Today/BytesSentHigh&TodayBytesSentLow=inetstat:status/Today/BytesSentLow&GSM_RSSI=gsm:settings/RSSI&GSM_NetworkState=gsm:settings/NetworkState&GSM_AcT=gsm:settings/AcT&UMTS_enabled=umts:settings/enabled&userTicket=userticket:settings/ticket/list(id)&dslStatGlobalIn=dslstatglobal:status/in&dslStatGlobalOut=dslstatglobal:status/out
2023.04.30 22:37:11 4: FRITZBOX!7590 [FritzBox: Readout_Run_Web.1851] - INFO: Prepare query string for luaQuery.
2023.04.30 22:37:11 4: FRITZBOX!7590 [FritzBox: Readout_Start.1585] - INFO: Fork process FRITZBOX_Readout_Run_Web
JoWiemann
Jörg Wiemann
smmmo
Zitat von: JoWiemann am 30 April 2023, 22:09:43welche Fritz!OS hast Du auf der 7530?
Hallo Jörg,
meine 7530 AX hat die Firmware 07.31.
Hier noch mein log:
2023.05.01 08:24:56 4: FRITZBOX!7530 [Fritzbox: Readout_Start.1585] - INFO: Fork process FRITZBOX_Readout_Run_Web
2023.05.01 08:24:56 4: FRITZBOX!7530 [Fritzbox: Readout_Run_Web.1851] - INFO: Prepare query string for luaQuery.
2023.05.01 08:24:56 4: FRITZBOX!7530 [Fritzbox: Readout_Run_Web.1961] - ReadOut gestartet: &radio=configd:settings/WEBRADIO/list(Name)&box_dect=dect:settings/enabled&handsetCount=dect:settings/Handset/count&handset=dect:settings/Handset/list(User,Manufacturer,Model,FWVersion,Productname)&wlanList=wlan:settings/wlanlist/list(mac,speed,speed_rx,rssi,is_guest)&wlanListNew=wlan:settings/wlanlist/list(mac,speed,rssi)&lanDevice=landevice:settings/landevice/list(mac,ip,ethernet,ethernet_port,ethernetport,guest,name,active,online,wlan,speed,UID)&lanDeviceNew=landevice:settings/landevice/list(mac,ip,ethernet,guest,name,active,online,wlan,speed,UID)&init=telcfg:settings/Foncontrol&box_stdDialPort=telcfg:settings/DialPort&dectUser=telcfg:settings/Foncontrol/User/list(Id,Name,Intern,IntRingTone,AlarmRingTone0,RadioRingID,ImagePath,G722RingTone,G722RingToneName)&fonPort=telcfg:settings/MSN/Port/list(Name,MSN)&diversity=telcfg:settings/Diversity/list(MSN,Active,Destination)&box_moh=telcfg:settings/MOHType&box_uptimeHours=uimodlogic:status/uptime_hours&box_uptimeMinutes=uimodlogic:status/uptime_minutes&box_fwVersion=logic:status/nspver&box_fwVersion_neu=uimodlogic:status/nspver&box_powerRate=power:status/rate_sumact&tam=tam:settings/TAM/list(Name,Display,Active,NumNewMessages,NumOldMessages)&box_cpuTemp=power:status/act_temperature&box_tr064=tr064:settings/enabled&box_tr069=tr069:settings/enabled&box_upnp=box:settings/upnp_activated&box_upnpCtrl=box:settings/upnp_control_activated&box_fwUpdate=updatecheck:status/update_available_hint&is_double_wlan=wlan:settings/feature_flags/DBDC&box_wlan_24GHz=wlan:settings/ap_enabled&box_wlan_5GHz=wlan:settings/ap_enabled_scnd&box_guestWlan=wlan:settings/guest_ap_enabled&box_guestWlanRemain=wlan:settings/guest_time_remain&box_macFilter_active=wlan:settings/is_macfilter_active&TodayBytesReceivedHigh=inetstat:status/Today/BytesReceivedHigh&TodayBytesReceivedLow=inetstat:status/Today/BytesReceivedLow&TodayBytesSentHigh=inetstat:status/Today/BytesSentHigh&TodayBytesSentLow=inetstat:status/Today/BytesSentLow&GSM_RSSI=gsm:settings/RSSI&GSM_NetworkState=gsm:settings/NetworkState&GSM_AcT=gsm:settings/AcT&UMTS_enabled=umts:settings/enabled&userTicket=userticket:settings/ticket/list(id)&dslStatGlobalIn=dslstatglobal:status/in&dslStatGlobalOut=dslstatglobal:status/out
2023.05.01 08:24:56 4: FRITZBOX!7530 [Fritzbox: Web_OpenCon.5770] - DEBUG: using old SID from 08:20:01
2023.05.01 08:24:56 4: FRITZBOX!7530 [Fritzbox: Web_Query.5824] - DEBUG: Request data via API luaQuery
2023.05.01 08:24:57 4: FRITZBOX!7530 [Fritzbox: Web_OpenCon.5770] - DEBUG: using old SID from 08:20:01
2023.05.01 08:24:57 4: FRITZBOX!7530 [Fritzbox: Lua_Data.5898] - INFO: Request data via API dataQuery.
2023.05.01 08:24:57 4: FRITZBOX!7530 [Fritzbox: Lua_Data.5902] - INFO: URL: http://192.168.178.1/data.lua?sid=eb6cc04125e7dd6e
2023.05.01 08:24:57 4: FRITZBOX!7530 [Fritzbox: Readout_Run_Web.2212] - INFO: sip for box-model: 7530
2023.05.01 08:24:58 4: FRITZBOX!7530 [Fritzbox: Web_OpenCon.5770] - DEBUG: using old SID from 08:20:01
2023.05.01 08:24:58 4: FRITZBOX!7530 [Fritzbox: Lua_Data.5898] - INFO: Request data via API dataQuery.
2023.05.01 08:24:58 4: FRITZBOX!7530 [Fritzbox: Lua_Data.5902] - INFO: URL: http://192.168.178.1/data.lua?sid=eb6cc04125e7dd6e
2023.05.01 08:24:59 4: FRITZBOX!7530 [Fritzbox: Web_OpenCon.5770] - DEBUG: using old SID from 08:20:01
2023.05.01 08:24:59 4: FRITZBOX!7530 [Fritzbox: Lua_Data.5898] - INFO: Request data via API dataQuery.
2023.05.01 08:24:59 4: FRITZBOX!7530 [Fritzbox: Lua_Data.5902] - INFO: URL: http://192.168.178.1/data.lua?sid=eb6cc04125e7dd6e
2023.05.01 08:24:59 4: FRITZBOX!7530 [Fritzbox: Readout_Run_Web.3218] - DEBUG: wrong Fritz!OS: 07.31 or AVM-Model: FRITZ!Box 7530 AX for docsis informations.
2023.05.01 08:25:00 2: FRITZBOX!7530 [Fritzbox: SOAP_Request.5448] - INFO: TR064-RESPONSE-Error: No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5445.
2023.05.01 08:25:00 4: FRITZBOX!7530 [Fritzbox: Readout_Run_Web.3501] - DEBUG: SOAP-ERROR -> No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5445.
2023.05.01 08:25:00 4: FRITZBOX!7530 [Fritzbox: Readout_Run_Web.3519] - DEBUG: SOAP-ERROR -> No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5445.
2023.05.01 08:25:00 4: FRITZBOX!7530 [Fritzbox: Readout_Run_Web.3548] - INFO: Captured 420 values
2023.05.01 08:25:00 3: FRITZBOX!7530 [Fritzbox: Get.1390] - INFO: get Fritzbox tr064Command WANDSLInterfaceConfig:1 wandslifconfig1 GetInfo
2023.05.01 08:25:01 3: FRITZBOX!7530 [Fritzbox: Get.1390] - INFO: get Fritzbox tr064Command WANDSLInterfaceConfig:1 wandslifconfig1 GetInfo
smmmo
JoWiemann
würdet ihr bitte einmal die angehängte Version ausprobieren. Ich habe hier nur die Fehlermeldung erweitert und hoffe so Informationen zu bekommen.
Jörg Wiemann
fettgu
Vielen Dank,
das steht mit der runtergeladenen Versionen bei mir im Log mit Verbose 4
2023.05.01 19:32:23 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.3552] - INFO: Captured 854 values
2023.05.01 19:32:23 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.3523] - DEBUG: SOAP-ERROR -> No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5449.
2023.05.01 19:32:23 2: FRITZBOX!7590(154.07.50) [FritzBox: SOAP_Request.5460] - INFO: TR064-RESPONSE-Error: No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5449.
2023.05.01 19:32:23 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.3505] - DEBUG: SOAP-ERROR -> No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5449.
2023.05.01 19:32:23 1: PERL WARNING: Use of uninitialized value $fTmp in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 5460.
2023.05.01 19:32:21 4: FRITZBOX!7590(154.07.50) [FritzBox: readPassword.7093] - INFO: Read FritzBox password from file
2023.05.01 19:32:21 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.3220] - DEBUG: wrong Fritz!OS: 07.50 or AVM-Model: FRITZ!Box 7590 for docsis informations.
2023.05.01 19:32:20 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.05.01 19:32:20 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 19:32:20 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 19:27:23
2023.05.01 19:32:17 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.05.01 19:32:17 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 19:32:17 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 19:27:23
2023.05.01 19:32:15 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.05.01 19:32:15 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 19:32:15 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 19:27:23
2023.05.01 19:32:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.05.01 19:32:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 19:32:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 19:27:23
2023.05.01 19:32:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.2214] - INFO: sip for box-model: 7590
2023.05.01 19:32:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_Query.5842] - DEBUG: Request data via API luaQuery
2023.05.01 19:32:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 19:27:23
2023.05.01 19:32:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.1963] - ReadOut gestartet: &radio=configd:settings/WEBRADIO/list(Name)&box_dect=dect:settings/enabled&handsetCount=dect:settings/Handset/count&handset=dect:settings/Handset/list(User,Manufacturer,Model,FWVersion,Productname)&wlanList=wlan:settings/wlanlist/list(mac,speed,speed_rx,rssi,is_guest)&wlanListNew=wlan:settings/wlanlist/list(mac,speed,rssi)&lanDevice=landevice:settings/landevice/list(mac,ip,ethernet,ethernet_port,ethernetport,guest,name,active,online,wlan,speed,UID)&lanDeviceNew=landevice:settings/landevice/list(mac,ip,ethernet,guest,name,active,online,wlan,speed,UID)&init=telcfg:settings/Foncontrol&box_stdDialPort=telcfg:settings/DialPort&dectUser=telcfg:settings/Foncontrol/User/list(Id,Name,Intern,IntRingTone,AlarmRingTone0,RadioRingID,ImagePath,G722RingTone,G722RingToneName)&fonPort=telcfg:settings/MSN/Port/list(Name,MSN)&diversity=telcfg:settings/Diversity/list(MSN,Active,Destination)&box_moh=telcfg:settings/MOHType&box_uptimeHours=uimodlogic:status/uptime_hours&box_uptimeMinutes=uimodlogic:status/uptime_minutes&box_fwVersion=logic:status/nspver&box_fwVersion_neu=uimodlogic:status/nspver&box_powerRate=power:status/rate_sumact&tam=tam:settings/TAM/list(Name,Display,Active,NumNewMessages,NumOldMessages)&box_cpuTemp=power:status/act_temperature&box_tr064=tr064:settings/enabled&box_tr069=tr069:settings/enabled&box_upnp=box:settings/upnp_activated&box_upnpCtrl=box:settings/upnp_control_activated&box_fwUpdate=updatecheck:status/update_available_hint&is_double_wlan=wlan:settings/feature_flags/DBDC&box_wlan_24GHz=wlan:settings/ap_enabled&box_wlan_5GHz=wlan:settings/ap_enabled_scnd&box_guestWlan=wlan:settings/guest_ap_enabled&box_guestWlanRemain=wlan:settings/guest_time_remain&box_macFilter_active=wlan:settings/is_macfilter_active&TodayBytesReceivedHigh=inetstat:status/Today/BytesReceivedHigh&TodayBytesReceivedLow=inetstat:status/Today/BytesReceivedLow&TodayBytesSentHigh=inetstat:status/Today/BytesSentHigh&TodayBytesSentLow=inetstat:status/Today/BytesSentLow&GSM_RSSI=gsm:settings/RSSI&GSM_NetworkState=gsm:settings/NetworkState&GSM_AcT=gsm:settings/AcT&UMTS_enabled=umts:settings/enabled&userTicket=userticket:settings/ticket/list(id)&dslStatGlobalIn=dslstatglobal:status/in&dslStatGlobalOut=dslstatglobal:status/out
2023.05.01 19:32:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.1853] - INFO: Prepare query string for luaQuery.
2023.05.01 19:32:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Start.1587] - INFO: Fork process FRITZBOX_Readout_Run_Web
JoWiemann
Zitat von: fettgu am 01 Mai 2023, 19:35:30das steht mit der runtergeladenen Versionen bei mir im Log mit Verbose 4
Bin irritiert...
Angehängt eine weitere Version zum Testen.
Grüße Jörg
Jörg Wiemann
fettgu
Trotzdem danke für die Hilfe.
Das steht nun da
2023.05.01 20:12:17 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.05.01 20:12:17 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 20:12:17 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 20:07:23
2023.05.01 20:12:15 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.05.01 20:12:15 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 20:12:15 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 20:07:23
2023.05.01 20:12:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.2214] - INFO: sip for box-model: 7590
2023.05.01 20:12:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.05.01 20:12:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 20:12:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 20:07:23
2023.05.01 20:12:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_Query.5842] - DEBUG: Request data via API luaQuery
2023.05.01 20:12:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 20:07:23
2023.05.01 20:12:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.1963] - ReadOut gestartet: &radio=configd:settings/WEBRADIO/list(Name)&box_dect=dect:settings/enabled&handsetCount=dect:settings/Handset/count&handset=dect:settings/Handset/list(User,Manufacturer,Model,FWVersion,Productname)&wlanList=wlan:settings/wlanlist/list(mac,speed,speed_rx,rssi,is_guest)&wlanListNew=wlan:settings/wlanlist/list(mac,speed,rssi)&lanDevice=landevice:settings/landevice/list(mac,ip,ethernet,ethernet_port,ethernetport,guest,name,active,online,wlan,speed,UID)&lanDeviceNew=landevice:settings/landevice/list(mac,ip,ethernet,guest,name,active,online,wlan,speed,UID)&init=telcfg:settings/Foncontrol&box_stdDialPort=telcfg:settings/DialPort&dectUser=telcfg:settings/Foncontrol/User/list(Id,Name,Intern,IntRingTone,AlarmRingTone0,RadioRingID,ImagePath,G722RingTone,G722RingToneName)&fonPort=telcfg:settings/MSN/Port/list(Name,MSN)&diversity=telcfg:settings/Diversity/list(MSN,Active,Destination)&box_moh=telcfg:settings/MOHType&box_uptimeHours=uimodlogic:status/uptime_hours&box_uptimeMinutes=uimodlogic:status/uptime_minutes&box_fwVersion=logic:status/nspver&box_fwVersion_neu=uimodlogic:status/nspver&box_powerRate=power:status/rate_sumact&tam=tam:settings/TAM/list(Name,Display,Active,NumNewMessages,NumOldMessages)&box_cpuTemp=power:status/act_temperature&box_tr064=tr064:settings/enabled&box_tr069=tr069:settings/enabled&box_upnp=box:settings/upnp_activated&box_upnpCtrl=box:settings/upnp_control_activated&box_fwUpdate=updatecheck:status/update_available_hint&is_double_wlan=wlan:settings/feature_flags/DBDC&box_wlan_24GHz=wlan:settings/ap_enabled&box_wlan_5GHz=wlan:settings/ap_enabled_scnd&box_guestWlan=wlan:settings/guest_ap_enabled&box_guestWlanRemain=wlan:settings/guest_time_remain&box_macFilter_active=wlan:settings/is_macfilter_active&TodayBytesReceivedHigh=inetstat:status/Today/BytesReceivedHigh&TodayBytesReceivedLow=inetstat:status/Today/BytesReceivedLow&TodayBytesSentHigh=inetstat:status/Today/BytesSentHigh&TodayBytesSentLow=inetstat:status/Today/BytesSentLow&GSM_RSSI=gsm:settings/RSSI&GSM_NetworkState=gsm:settings/NetworkState&GSM_AcT=gsm:settings/AcT&UMTS_enabled=umts:settings/enabled&userTicket=userticket:settings/ticket/list(id)&dslStatGlobalIn=dslstatglobal:status/in&dslStatGlobalOut=dslstatglobal:status/out
2023.05.01 20:12:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.1853] - INFO: Prepare query string for luaQuery.
2023.05.01 20:12:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Start.1587] - INFO: Fork process FRITZBOX_Readout_Run_Web
2023.05.01 20:07:23 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.3552] - INFO: Captured 854 values
2023.05.01 20:07:23 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.3523] - DEBUG: SOAP-ERROR -> No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5449.
2023.05.01 20:07:23 2: FRITZBOX!7590(154.07.50) [FritzBox: SOAP_Request.5460] - INFO: TR064-RESPONSE-Error: No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5449.
2023.05.01 20:07:23 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.3505] - DEBUG: SOAP-ERROR -> No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5449.
2023.05.01 20:07:23 1: PERL WARNING: Use of uninitialized value $fTmp in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 5460.
2023.05.01 20:07:21 4: FRITZBOX!7590(154.07.50) [FritzBox: readPassword.7093] - INFO: Read FritzBox password from file
2023.05.01 20:07:21 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.3220] - DEBUG: wrong Fritz!OS: 07.50 or AVM-Model: FRITZ!Box 7590 for docsis informations.
2023.05.01 20:07:20 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.05.01 20:07:20 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 20:07:20 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 20:02:23
2023.05.01 20:07:17 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.05.01 20:07:17 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 20:07:17 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 20:02:23
2023.05.01 20:07:15 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.05.01 20:07:15 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 20:07:15 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 20:02:23
2023.05.01 20:07:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.2214] - INFO: sip for box-model: 7590
2023.05.01 20:07:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=e60197d7f8eb4558
2023.05.01 20:07:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 20:07:14 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 20:02:23
2023.05.01 20:07:13 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_Query.5842] - DEBUG: Request data via API luaQuery
2023.05.01 20:07:13 4: FRITZBOX!7590(154.07.50) [FritzBox: Web_OpenCon.5788] - DEBUG: using old SID from 20:02:23
2023.05.01 20:07:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.1963] - ReadOut gestartet: &radio=configd:settings/WEBRADIO/list(Name)&box_dect=dect:settings/enabled&handsetCount=dect:settings/Handset/count&handset=dect:settings/Handset/list(User,Manufacturer,Model,FWVersion,Productname)&wlanList=wlan:settings/wlanlist/list(mac,speed,speed_rx,rssi,is_guest)&wlanListNew=wlan:settings/wlanlist/list(mac,speed,rssi)&lanDevice=landevice:settings/landevice/list(mac,ip,ethernet,ethernet_port,ethernetport,guest,name,active,online,wlan,speed,UID)&lanDeviceNew=landevice:settings/landevice/list(mac,ip,ethernet,guest,name,active,online,wlan,speed,UID)&init=telcfg:settings/Foncontrol&box_stdDialPort=telcfg:settings/DialPort&dectUser=telcfg:settings/Foncontrol/User/list(Id,Name,Intern,IntRingTone,AlarmRingTone0,RadioRingID,ImagePath,G722RingTone,G722RingToneName)&fonPort=telcfg:settings/MSN/Port/list(Name,MSN)&diversity=telcfg:settings/Diversity/list(MSN,Active,Destination)&box_moh=telcfg:settings/MOHType&box_uptimeHours=uimodlogic:status/uptime_hours&box_uptimeMinutes=uimodlogic:status/uptime_minutes&box_fwVersion=logic:status/nspver&box_fwVersion_neu=uimodlogic:status/nspver&box_powerRate=power:status/rate_sumact&tam=tam:settings/TAM/list(Name,Display,Active,NumNewMessages,NumOldMessages)&box_cpuTemp=power:status/act_temperature&box_tr064=tr064:settings/enabled&box_tr069=tr069:settings/enabled&box_upnp=box:settings/upnp_activated&box_upnpCtrl=box:settings/upnp_control_activated&box_fwUpdate=updatecheck:status/update_available_hint&is_double_wlan=wlan:settings/feature_flags/DBDC&box_wlan_24GHz=wlan:settings/ap_enabled&box_wlan_5GHz=wlan:settings/ap_enabled_scnd&box_guestWlan=wlan:settings/guest_ap_enabled&box_guestWlanRemain=wlan:settings/guest_time_remain&box_macFilter_active=wlan:settings/is_macfilter_active&TodayBytesReceivedHigh=inetstat:status/Today/BytesReceivedHigh&TodayBytesReceivedLow=inetstat:status/Today/BytesReceivedLow&TodayBytesSentHigh=inetstat:status/Today/BytesSentHigh&TodayBytesSentLow=inetstat:status/Today/BytesSentLow&GSM_RSSI=gsm:settings/RSSI&GSM_NetworkState=gsm:settings/NetworkState&GSM_AcT=gsm:settings/AcT&UMTS_enabled=umts:settings/enabled&userTicket=userticket:settings/ticket/list(id)&dslStatGlobalIn=dslstatglobal:status/in&dslStatGlobalOut=dslstatglobal:status/out
2023.05.01 20:07:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Run_Web.1853] - INFO: Prepare query string for luaQuery.
2023.05.01 20:07:12 4: FRITZBOX!7590(154.07.50) [FritzBox: Readout_Start.1587] - INFO: Fork process FRITZBOX_Readout_Run_Web
JoWiemann
Zitat von: fettgu am 01 Mai 2023, 20:13:32Trotzdem danke für die Hilfe.
Das steht nun da
Hm, auch hier bringt die Abfrage eine leere Information zurück.
Von daher mal ein paar Fragen zum Environment:
- auf welcher Hardware läuft Fhem
- welches Betriebssystem
- in einem Container (Docker oder ähnlich)
- gibt es eine Firewall
Grüße Jörg
Jörg Wiemann
fettgu
Danke, die Antworten sind nicht so spannend..
Raspberry 3b
Bullseye
nein
nein, es gibt ein switch zwischen raspberry und Fritzbox. Eine Firewall ist da aber nicht.
Das hier fand ich ziemlich erstaunlich
Ich weiß aber nicht, ob das Modul vorher schon eine merkwürdige Route genommen hat...
smmmo
Und hier das log der 7530 AX:
2023.05.01 20:18:07 4: FRITZBOX!7530(256.07.31) [Fritzbox: Readout_Start.1587] - INFO: Fork process FRITZBOX_Readout_Run_Web
2023.05.01 20:18:07 4: FRITZBOX!7530(256.07.31) [Fritzbox: Readout_Run_Web.1853] - INFO: Prepare query string for luaQuery.
2023.05.01 20:18:07 4: FRITZBOX!7530(256.07.31) [Fritzbox: Readout_Run_Web.1963] - ReadOut gestartet: &radio=configd:settings/WEBRADIO/list(Name)&box_dect=dect:settings/enabled&handsetCount=dect:settings/Handset/count&handset=dect:settings/Handset/list(User,Manufacturer,Model,FWVersion,Productname)&wlanList=wlan:settings/wlanlist/list(mac,speed,speed_rx,rssi,is_guest)&wlanListNew=wlan:settings/wlanlist/list(mac,speed,rssi)&lanDevice=landevice:settings/landevice/list(mac,ip,ethernet,ethernet_port,ethernetport,guest,name,active,online,wlan,speed,UID)&lanDeviceNew=landevice:settings/landevice/list(mac,ip,ethernet,guest,name,active,online,wlan,speed,UID)&init=telcfg:settings/Foncontrol&box_stdDialPort=telcfg:settings/DialPort&dectUser=telcfg:settings/Foncontrol/User/list(Id,Name,Intern,IntRingTone,AlarmRingTone0,RadioRingID,ImagePath,G722RingTone,G722RingToneName)&fonPort=telcfg:settings/MSN/Port/list(Name,MSN)&diversity=telcfg:settings/Diversity/list(MSN,Active,Destination)&box_moh=telcfg:settings/MOHType&box_uptimeHours=uimodlogic:status/uptime_hours&box_uptimeMinutes=uimodlogic:status/uptime_minutes&box_fwVersion=logic:status/nspver&box_fwVersion_neu=uimodlogic:status/nspver&box_powerRate=power:status/rate_sumact&tam=tam:settings/TAM/list(Name,Display,Active,NumNewMessages,NumOldMessages)&box_cpuTemp=power:status/act_temperature&box_tr064=tr064:settings/enabled&box_tr069=tr069:settings/enabled&box_upnp=box:settings/upnp_activated&box_upnpCtrl=box:settings/upnp_control_activated&box_fwUpdate=updatecheck:status/update_available_hint&is_double_wlan=wlan:settings/feature_flags/DBDC&box_wlan_24GHz=wlan:settings/ap_enabled&box_wlan_5GHz=wlan:settings/ap_enabled_scnd&box_guestWlan=wlan:settings/guest_ap_enabled&box_guestWlanRemain=wlan:settings/guest_time_remain&box_macFilter_active=wlan:settings/is_macfilter_active&TodayBytesReceivedHigh=inetstat:status/Today/BytesReceivedHigh&TodayBytesReceivedLow=inetstat:status/Today/BytesReceivedLow&TodayBytesSentHigh=inetstat:status/Today/BytesSentHigh&TodayBytesSentLow=inetstat:status/Today/BytesSentLow&GSM_RSSI=gsm:settings/RSSI&GSM_NetworkState=gsm:settings/NetworkState&GSM_AcT=gsm:settings/AcT&UMTS_enabled=umts:settings/enabled&userTicket=userticket:settings/ticket/list(id)&dslStatGlobalIn=dslstatglobal:status/in&dslStatGlobalOut=dslstatglobal:status/out
2023.05.01 20:18:07 4: FRITZBOX!7530(256.07.31) [Fritzbox: Web_OpenCon.5788] - DEBUG: using old SID from 20:13:12
2023.05.01 20:18:07 4: FRITZBOX!7530(256.07.31) [Fritzbox: Web_Query.5842] - DEBUG: Request data via API luaQuery
2023.05.01 20:18:08 4: FRITZBOX!7530(256.07.31) [Fritzbox: Web_OpenCon.5788] - DEBUG: using old SID from 20:13:12
2023.05.01 20:18:08 4: FRITZBOX!7530(256.07.31) [Fritzbox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 20:18:08 4: FRITZBOX!7530(256.07.31) [Fritzbox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=1390776105ba8cef
2023.05.01 20:18:08 4: FRITZBOX!7530(256.07.31) [Fritzbox: Readout_Run_Web.2214] - INFO: sip for box-model: 7530
2023.05.01 20:18:09 4: FRITZBOX!7530(256.07.31) [Fritzbox: Web_OpenCon.5788] - DEBUG: using old SID from 20:13:12
2023.05.01 20:18:09 4: FRITZBOX!7530(256.07.31) [Fritzbox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 20:18:09 4: FRITZBOX!7530(256.07.31) [Fritzbox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=1390776105ba8cef
2023.05.01 20:18:10 4: FRITZBOX!7530(256.07.31) [Fritzbox: Web_OpenCon.5788] - DEBUG: using old SID from 20:13:12
2023.05.01 20:18:10 4: FRITZBOX!7530(256.07.31) [Fritzbox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 20:18:10 4: FRITZBOX!7530(256.07.31) [Fritzbox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=1390776105ba8cef
2023.05.01 20:18:11 4: FRITZBOX!7530(256.07.31) [Fritzbox: Web_OpenCon.5788] - DEBUG: using old SID from 20:13:12
2023.05.01 20:18:11 4: FRITZBOX!7530(256.07.31) [Fritzbox: Lua_Data.5916] - INFO: Request data via API dataQuery.
2023.05.01 20:18:11 4: FRITZBOX!7530(256.07.31) [Fritzbox: Lua_Data.5920] - INFO: URL: http://192.168.178.1/data.lua?sid=1390776105ba8cef
2023.05.01 20:18:11 4: FRITZBOX!7530(256.07.31) [Fritzbox: Readout_Run_Web.3220] - DEBUG: wrong Fritz!OS: 07.31 or AVM-Model: FRITZ!Box 7530 AX for docsis informations.
2023.05.01 20:18:12 1: PERL WARNING: Use of uninitialized value $fTmp in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 5460.
2023.05.01 20:18:12 2: FRITZBOX!7530(256.07.31) [Fritzbox: SOAP_Request.5460] - INFO: TR064-RESPONSE-Error: No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5449.
2023.05.01 20:18:12 4: FRITZBOX!7530(256.07.31) [Fritzbox: Readout_Run_Web.3505] - DEBUG: SOAP-ERROR -> No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5449.
2023.05.01 20:18:12 4: FRITZBOX!7530(256.07.31) [Fritzbox: Readout_Run_Web.3523] - DEBUG: SOAP-ERROR -> No value specified for 'ForceArray' option in call to XMLin() at ./FHEM/72_FRITZBOX.pm line 5449.
2023.05.01 20:18:12 4: FRITZBOX!7530(256.07.31) [Fritzbox: Readout_Run_Web.3552] - INFO: Captured 419 values
2023.05.01 20:18:12 3: FRITZBOX!7530(256.07.31) [Fritzbox: Get.1392] - INFO: get Fritzbox tr064Command WANDSLInterfaceConfig:1 wandslifconfig1 GetInfo
- Fhem läuft auf einem Intel NUC, nicht in Docker unter diesem Kernel (Debian testing):
Linux nuc 6.1.0-7-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.20-2 (2023-04-08) x86_64 GNU/Linux
- Firewall gibt es keine, aber ebenfalls einen switch.
- Perl-Version (falls das eine Rolle spielt):
#perl -V
Summary of my perl5 (revision 5 version 36 subversion 0) configuration:
  Platform:
    osname=linux
    osvers=4.19.0
    archname=x86_64-linux-gnu-thread-multi
    uname='linux localhost 4.19.0 #1 smp debian 4.19.0 x86_64 gnulinux '
    config_args='-Dmksymlinks -Dusethreads -Duselargefiles -Dcc=x86_64-linux-gnu-gcc -Dcpp=x86_64-linux-gnu-cpp -Dld=x86_64-linux-gnu-gcc -Dccflags=-DDEBIAN -Wdate-time -D_FORTIFY_SOURCE=2 -g -O2 -ffile-prefix-map=/dummy/build/dir=. -fstack-protector-strong -Wformat -Werror=format-security -Dldflags= -Wl,-z,relro -Dlddlflags=-shared -Wl,-z,relro -Dcccdlflags=-fPIC -Darchname=x86_64-linux-gnu -Dprefix=/usr -Dprivlib=/usr/share/perl/5.36 -Darchlib=/usr/lib/x86_64-linux-gnu/perl/5.36 -Dvendorprefix=/usr -Dvendorlib=/usr/share/perl5 -Dvendorarch=/usr/lib/x86_64-linux-gnu/perl5/5.36 -Dsiteprefix=/usr/local -Dsitelib=/usr/local/share/perl/5.36.0 -Dsitearch=/usr/local/lib/x86_64-linux-gnu/perl/5.36.0 -Dman1dir=/usr/share/man/man1 -Dman3dir=/usr/share/man/man3 -Dsiteman1dir=/usr/local/man/man1 -Dsiteman3dir=/usr/local/man/man3 -Duse64bitint -Dman1ext=1 -Dman3ext=3perl -Dpager=/usr/bin/sensible-pager -Uafs -Ud_csh -Ud_ualarm -Uusesfio -Uusenm -Ui_libutil -Ui_xlocale -Uversiononly -DDEBUGGING=-g -Doptimize=-O2 -dEs -Duseshrplib -Dlibperl=libperl.so.5.36.0'
    hint=recommended
    useposix=true
    d_sigaction=define
    useithreads=define
    usemultiplicity=define
    use64bitint=define
    use64bitall=define
    uselongdouble=undef
    usemymalloc=n
    default_inc_excludes_dot=define
  Compiler:
    cc='x86_64-linux-gnu-gcc'
    ccflags ='-D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fwrapv -fno-strict-aliasing -pipe -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64'
    optimize='-O2 -g'
    cppflags='-D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fwrapv -fno-strict-aliasing -pipe -I/usr/local/include'
    ccversion=''
    gccversion='12.2.0'
    gccosandvers=''
    intsize=4
    longsize=8
    ptrsize=8
    doublesize=8
    byteorder=12345678
    doublekind=3
    d_longlong=define
    longlongsize=8
    d_longdbl=define
    longdblsize=16
    longdblkind=3
    ivtype='long'
    ivsize=8
    nvtype='double'
    nvsize=8
    Off_t='off_t'
    lseeksize=8
    alignbytes=8
    prototype=define
  Linker and Libraries:
    ld='x86_64-linux-gnu-gcc'
    ldflags =' -fstack-protector-strong -L/usr/local/lib'
    libpth=/usr/local/lib /usr/lib/x86_64-linux-gnu /usr/lib /lib/x86_64-linux-gnu /lib
    libs=-lgdbm -lgdbm_compat -ldb -ldl -lm -lpthread -lc -lcrypt
    perllibs=-ldl -lm -lpthread -lc -lcrypt
    libc=/lib/x86_64-linux-gnu/libc.so.6
    so=so
    useshrplib=true
    gnulibc_version='2.36'
  Dynamic Linking:
    dlsrc=dl_dlopen.xs
    dlext=so
    d_dlsymun=undef
    ccdlflags='-Wl,-E'
    cccdlflags='-fPIC'
    lddlflags='-shared -L/usr/local/lib -fstack-protector-strong'
Characteristics of this binary (from libperl):
  Compile-time options:
    HAS_TIMES
    MULTIPLICITY
    PERLIO_LAYERS
    PERL_COPY_ON_WRITE
    PERL_DONT_CREATE_GVSV
    PERL_MALLOC_WRAP
    PERL_OP_PARENT
    PERL_PRESERVE_IVUV
    USE_64_BIT_ALL
    USE_64_BIT_INT
    USE_ITHREADS
    USE_LARGE_FILES
    USE_LOCALE
    USE_LOCALE_COLLATE
    USE_LOCALE_CTYPE
    USE_LOCALE_NUMERIC
    USE_LOCALE_TIME
    USE_PERLIO
    USE_PERL_ATOF
    USE_REENTRANT_API
    USE_THREAD_SAFE_LOCALE
  Locally applied patches:
    DEBPKG:debian/cpan_definstalldirs - Provide a sensible INSTALLDIRS default for modules installed from CPAN.
    DEBPKG:debian/db_file_ver - https://bugs.debian.org/340047 Remove overly restrictive DB_File version check.
    DEBPKG:debian/doc_info - Replace generic man(1) instructions with Debian-specific information.
    DEBPKG:debian/enc2xs_inc - https://bugs.debian.org/290336 Tweak enc2xs to follow symlinks and ignore missing @INC directories.
    DEBPKG:debian/errno_ver - https://bugs.debian.org/343351 Remove Errno version check due to upgrade problems with long-running processes.
    DEBPKG:debian/libperl_embed_doc - https://bugs.debian.org/186778 Note that libperl-dev package is required for embedded linking
    DEBPKG:fixes/respect_umask - Respect umask during installation
    DEBPKG:debian/writable_site_dirs - Set umask approproately for site install directories
    DEBPKG:debian/extutils_set_libperl_path - EU:MM: set location of libperl.a under /usr/lib
    DEBPKG:debian/no_packlist_perllocal - Don't install .packlist or perllocal.pod for perl or vendor
    DEBPKG:debian/fakeroot - Postpone LD_LIBRARY_PATH evaluation to the binary targets.
    DEBPKG:debian/instmodsh_doc - Debian policy doesn't install .packlist files for core or vendor.
    DEBPKG:debian/ld_run_path - Remove standard libs from LD_RUN_PATH as per Debian policy.
    DEBPKG:debian/libnet_config_path - Set location of libnet.cfg to /etc/perl/Net as /usr may not be writable.
    DEBPKG:debian/perlivp - https://bugs.debian.org/510895 Make perlivp skip include directories in /usr/local
    DEBPKG:debian/squelch-locale-warnings - https://bugs.debian.org/508764 Squelch locale warnings in Debian package maintainer scripts
    DEBPKG:debian/patchlevel - https://bugs.debian.org/567489 List packaged patches for 5.36.0-7 in patchlevel.h
    DEBPKG:fixes/document_makemaker_ccflags - https://bugs.debian.org/628522 [rt.cpan.org #68613] Document that CCFLAGS should include $Config{ccflags}
    DEBPKG:debian/find_html2text - https://bugs.debian.org/640479 Configure CPAN::Distribution with correct name of html2text
    DEBPKG:debian/perl5db-x-terminal-emulator.patch - https://bugs.debian.org/668490 Invoke x-terminal-emulator rather than xterm in perl5db.pl
    DEBPKG:debian/cpan-missing-site-dirs - https://bugs.debian.org/688842 Fix CPAN::FirstTime defaults with nonexisting site dirs if a parent is writable
    DEBPKG:fixes/memoize_storable_nstore - [rt.cpan.org #77790] https://bugs.debian.org/587650 Memoize::Storable: respect 'nstore' option not respected
    DEBPKG:debian/makemaker-pasthru - https://bugs.debian.org/758471 Pass LD settings through to subdirectories
    DEBPKG:debian/makemaker-manext - https://bugs.debian.org/247370 Make EU::MakeMaker honour MANnEXT settings in generated manpage headers
    DEBPKG:debian/kfreebsd-softupdates - https://bugs.debian.org/796798 Work around Debian Bug#796798
    DEBPKG:fixes/memoize-pod - [rt.cpan.org #89441] Fix POD errors in Memoize
    DEBPKG:debian/hurd-softupdates - https://bugs.debian.org/822735 Fix t/op/stat.t failures on hurd
    DEBPKG:fixes/math_complex_doc_great_circle - https://bugs.debian.org/697567 [rt.cpan.org #114104] Math::Trig: clarify definition of great_circle_midpoint
    DEBPKG:fixes/math_complex_doc_see_also - https://bugs.debian.org/697568 [rt.cpan.org #114105] Math::Trig: add missing SEE ALSO
    DEBPKG:fixes/math_complex_doc_angle_units - https://bugs.debian.org/731505 [rt.cpan.org #114106] Math::Trig: document angle units
    DEBPKG:fixes/cpan_web_link - https://bugs.debian.org/367291 CPAN: Add link to main CPAN web site
    DEBPKG:debian/hppa_op_optimize_workaround - https://bugs.debian.org/838613 Temporarily lower the optimization of op.c on hppa due to gcc-6 problems
    DEBPKG:debian/installman-utf8 - https://bugs.debian.org/840211 Generate man pages with UTF-8 characters
    DEBPKG:debian/hppa_opmini_optimize_workaround - https://bugs.debian.org/869122 Lower the optimization level of opmini.c on hppa
    DEBPKG:debian/sh4_op_optimize_workaround - https://bugs.debian.org/869373 Also lower the optimization level of op.c and opmini.c on sh4
    DEBPKG:debian/perldoc-pager - https://bugs.debian.org/870340 [rt.cpan.org #120229] Fix perldoc terminal escapes when sensible-pager is less
    DEBPKG:debian/prune_libs - https://bugs.debian.org/128355 Prune the list of libraries wanted to what we actually need.
    DEBPKG:debian/mod_paths - Tweak @INC ordering for Debian
    DEBPKG:debian/deprecate-with-apt - https://bugs.debian.org/747628 Point users to Debian packages of deprecated core modules
    DEBPKG:debian/disable-stack-check - https://bugs.debian.org/902779 [GH #16607] Disable debugperl stack extension checks for binary compatibility with perl
    DEBPKG:debian/perlbug-editor - https://bugs.debian.org/922609 Use "editor" as the default perlbug editor, as per Debian policy
    DEBPKG:debian/eu-mm-perl-base - https://bugs.debian.org/962138 Suppress an ExtUtils::MakeMaker warning about our non-default @INC
    DEBPKG:fixes/io_socket_ip_ipv6 - Disable getaddrinfo(3) AI_ADDRCONFIG for localhost and IPv4 numeric addresses
    DEBPKG:debian/usrmerge-lib64 - https://bugs.debian.org/914128 Configure / libpth.U: Do not adjust glibpth when /usr/lib64 is present.
    DEBPKG:debian/usrmerge-realpath - https://bugs.debian.org/914128 Configure / libpth.U: use realpath --no-symlinks on Debian
    DEBPKG:debian/configure-regen - https://bugs.debian.org/762638 Regenerate Configure et al. after probe unit changes
    DEBPKG:fixes/x32-io-msg-skip - https://bugs.debian.org/922609 Skip io/msg.t on x32 due to broken System V message queues
    DEBPKG:debian/hurd-eumm-workaround - https://bugs.debian.org/1018289 Work around a MakeMaker regression breaking GNU/Hurd hint files
    DEBPKG:fixes/json-pp-warnings - https://bugs.debian.org/1019757 Call unimport first to silence warnings
    DEBPKG:fixes/readline-stream-errors - [80c1f1e] [GH #6799] https://bugs.debian.org/1016369 only clear the stream error state in readline() for glob()
    DEBPKG:fixes/readline-stream-errors-test - [0b60216] [GH #6799] https://bugs.debian.org/1016369 test that <> doesn't clear the stream error state
    DEBPKG:fixes/lto-test-fix - [69b4fa3] [GH #20518] https://bugs.debian.org/1015579 skip checking categorization of libperl symbols for LTO builds
  Built under linux
  Compiled at Jan  8 2023 21:28:47
  @INC:
    /etc/perl
    /usr/share/perl5
    /usr/lib/x86_64-linux-gnu/perl-base
    /usr/local/lib/site_perl
smmmo
JoWiemann
Zitat von: fettgu am 01 Mai 2023, 20:25:43Das hier fand ich ziemlich erstaunlich
Das ist schon Ok. Es gibt Informationen, die nur bei Cable Boxen abgeholt werden. Die Debug Rückmeldung zeigt nur, dass die abgefragte Box keine Cable ist und welches Fritz!OS erkannt worden ist. Über die Formulierung kann man streiten ;-)
Dein Environment ist somit Standard. Es gab schon mal die Situation, dass nach einem Trennen der FB vom Stromnetz (mindestens 5 Minuten) ein solcher Fehler verschwunden ist. Ansonsten bin ich echt ratlos.
Grüße Jörg
Jörg Wiemann
