[gelöst] Fritzbox Problem
Begonnen von matze1999, 19 Januar 2024, 18:57:05
matze1999
heute hatte ich plötzlich folgende Fehlermeldungen im Log
2024.01.19 07:28:12 1: PERL WARNING: Use of uninitialized value $avmModel in pattern match (m//) at ./FHEM/72_FRITZBOX.pm line 8717.
2024.01.19 07:28:12 1: stacktrace:
2024.01.19 07:28:12 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8717)
2024.01.19 07:28:12 1:     main::FRITZBOX_open_Web_Connection  called by ./FHEM/72_FRITZBOX.pm (8753)
2024.01.19 07:28:12 1:     main::FRITZBOX_call_Lua_Query       called by ./FHEM/72_FRITZBOX.pm (2825)
2024.01.19 07:28:12 1:     main::FRITZBOX_Readout_Run_Web      called by FHEM/Blocking.pm (194)
2024.01.19 07:28:12 1:     main::BlockingStart                 called by FHEM/Blocking.pm (107)
2024.01.19 07:28:12 1:     main::BlockingCall                  called by ./FHEM/72_FRITZBOX.pm (2655)
2024.01.19 07:28:12 1:     main::FRITZBOX_Readout_Start        called by fhem.pl (3508)
2024.01.19 07:28:12 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.01.19 07:28:13 2: [FritzRepeater1 | 0000 | 128.07.15 | open_Web_Connection.8734] - SIGNIFICANT:Web connection could not be established. Please check your credentials (password, user).
2024.01.19 07:28:13 2: [FritzRepeater1 | 0000 | 128.07.15 | Readout_Response.4747] - SIGNIFICANT:Web connection could not be established
2024.01.19 07:28:13 2: [FritzRepeater4 | 0000 | 169.07.57 | open_Web_Connection.8734] - SIGNIFICANT:Web connection could not be established. Please check your credentials (password, user).
2024.01.19 07:28:13 2: [FritzRepeater4 | 0000 | 169.07.57 | Readout_Response.4747] - SIGNIFICANT:Web connection could not be established
2024.01.19 07:28:14 2: [FritzRepeater | 0000 | 263.07.57 | open_Web_Connection.8734] - SIGNIFICANT:Web connection could not be established. Please check your credentials (password, user).
2024.01.19 07:28:14 2: [FritzRepeater | 0000 | 263.07.57 | Readout_Response.4747] - SIGNIFICANT:Web connection could not be established
2024.01.19 07:33:12 2: [FritzRepeater | 0000 | 263.07.57 | Readout_Start.2598] - SIGNIFICANT:stopped while to many authentication errors
2024.01.19 07:33:12 2: [FritzRepeater4 | 0000 | 169.07.57 | Readout_Start.2598] - SIGNIFICANT:stopped while to many authentication errors
2024.01.19 07:33:12 2: [FritzRepeater1 | 0000 | 128.07.15 | Readout_Start.2598] - SIGNIFICANT:stopped while to many authentication errors
Bei den drei Repeatern war der admin abgeschaltet und ein username angelegt, seit Jahren.
Nachdem ich wieder auf die Anmeldung nur mit Kennwort zurück bin, ist der Fehler weg. Nur der FRITZ!WLAN Repeater 450E zeigt jetzt im Status jetzt
undefined situation.
Alles nach dem letzten update:
72_FRITZBOX.pm             28384 2024-01-15 06:50:49Z jowiemann
Was ist hier los?
matze1999
JoWiemann
Hallo matze,
ich hatte ja hier geschrieben: https://forum.fhem.de/index.php?topic=136517.0, dass ich einiges im Modul umgestellt habe um es wartbarer zu machen. Nachdem sich keiner gemeldet hatte, bin ich davon ausgegangen, dass soweit alles ok ist. Nun ja, so ist das.
Deine Beschreibung hilft auf jeden Fall weiter. Dein Problem mit dem Repeater FRITZ!WLAN Repeater 450E ist auch schon hier adressiert:https://forum.fhem.de/index.php?topic=136718.0. Ich bräuchte hier ein List des Device mit der letzten funktionierenden Version des FRITZOX Moduls.
Grüße und Danke
Jörg
PS: Bitte verschieb den Post in das richtige Board. Also FritzBox. Danke Dir.
Jörg Wiemann
JoWiemann
Hallo Matze,
anbei eine neue Version. Bitte prüfe einmal, ob das Problem mit User/Passwort bei den Repeatern damit behoben ist.
Beim FRITZ!WLAN Repeater 450E bin ich noch am suchen.
Grüße Jörg
Jörg Wiemann
matze1999
für den 450E:
2024.01.19 19:48:19 1: PERL WARNING: Use of uninitialized value $avmModel in pattern match (m//) at ./FHEM/72_FRITZBOX.pm line 8718.
2024.01.19 19:48:19 1: stacktrace:
2024.01.19 19:48:19 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8718)
2024.01.19 19:48:19 1:     main::FRITZBOX_open_Web_Connection  called by ./FHEM/72_FRITZBOX.pm (8753)
2024.01.19 19:48:19 1:     main::FRITZBOX_call_Lua_Query       called by ./FHEM/72_FRITZBOX.pm (2825)
2024.01.19 19:48:19 1:     main::FRITZBOX_Readout_Run_Web      called by FHEM/Blocking.pm (194)
2024.01.19 19:48:19 1:     main::BlockingStart                 called by FHEM/Blocking.pm (107)
2024.01.19 19:48:19 1:     main::BlockingCall                  called by ./FHEM/72_FRITZBOX.pm (2655)
2024.01.19 19:48:19 1:     main::FRITZBOX_Readout_Start        called by ./FHEM/72_FRITZBOX.pm (2066)
2024.01.19 19:48:19 1:     main::FRITZBOX_Set                  called by fhem.pl (3980)
2024.01.19 19:48:19 1:     main::CallFn                        called by fhem.pl (1970)
2024.01.19 19:48:19 1:     main::DoSet                         called by fhem.pl (2002)
2024.01.19 19:48:19 1:     main::CommandSet                    called by fhem.pl (1282)
2024.01.19 19:48:19 1:     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2861)
2024.01.19 19:48:19 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (1025)
2024.01.19 19:48:19 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (609)
2024.01.19 19:48:19 1:     main::FW_Read                       called by fhem.pl (3985)
2024.01.19 19:48:19 1:     main::CallFn                        called by fhem.pl (786)
2024.01.19 19:48:19 2: [FritzRepeaterDD | 0000 | 174.07.57 | open_Web_Connection.8719] - SIGNIFICANT:No boxUser set. Please define it (once) with 'attr FritzRepeaterDD boxUser YourBoxUser'
2024.01.19 19:48:19 2: [FritzRepeaterDD | 0000 | 174.07.57 | Readout_Response.4747] - SIGNIFICANT:No attr boxUser set
BoxUser ist gesetzt:
defmod FritzRepeaterDD FRITZBOX 192.168.1.5
attr FritzRepeaterDD boxUser username
attr FritzRepeaterDD verbose 2
matze1999
matze1999
mit der Version bei allen Repeatern (auch die immer schon keinen usernamen hatten) das gleiche.
2400, 3000, 600
matze1999
JoWiemann
Zitat von: matze1999 am 19 Januar 2024, 19:55:05mit der Version bei allen Repeatern (auch die immer schon keinen usernamen hatten) das gleiche.
2400, 3000, 600
matze1999
Sorry, hatte noch etwas übersehen.
Grüße Jörg
Jörg Wiemann
matze1999
Repeater 3000, 2400, 600 funktionieren wieder, auch mit usernamen (nicht admin) und passwort, nur der 450E macht noch Probleme:
2024.01.19 20:48:49 1: PERL WARNING: Use of uninitialized value $user in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 8724.
2024.01.19 20:48:49 1: stacktrace:
2024.01.19 20:48:49 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8724)
2024.01.19 20:48:49 1:     main::FRITZBOX_open_Web_Connection  called by ./FHEM/72_FRITZBOX.pm (8753)
2024.01.19 20:48:49 1:     main::FRITZBOX_call_Lua_Query       called by ./FHEM/72_FRITZBOX.pm (2825)
2024.01.19 20:48:49 1:     main::FRITZBOX_Readout_Run_Web      called by FHEM/Blocking.pm (194)
2024.01.19 20:48:49 1:     main::BlockingStart                 called by FHEM/Blocking.pm (107)
2024.01.19 20:48:49 1:     main::BlockingCall                  called by ./FHEM/72_FRITZBOX.pm (2655)
2024.01.19 20:48:49 1:     main::FRITZBOX_Readout_Start        called by fhem.pl (3508)
2024.01.19 20:48:49 1:     main::HandleTimeout                 called by fhem.pl (707)
2024.01.19 20:48:49 2: [FritzRepeater3 | 450 | 128.07.15 | Readout_Response.4762] - SIGNIFICANT:undefined situation
2024.01.19 20:48:50 2: [FritzRepeater | 450 | 128.07.15 | Readout_Response.4762] - SIGNIFICANT:undefined situation
matze1999
matze1999
Korrektur:
2400
boxUser ungleich admin, geht, aber
ich hab jetzt wieder auf admin umgestellt, und attr boxUser ist geblieben (nicht admin) trotzdem wird der repeater ohne Fehlermeldung ausgelesen.
matze
matze1999
Jetzt noch Fritzboxen; 7490, 7590, 7580 und 6850 LTE, teils mit admin, teils mit anderem Usernamen
keine Probleme, bei keiner der Versionen 72_FRITZBOX.pm
matze1999
JoWiemann
Zitat von: matze1999 am 19 Januar 2024, 20:56:40ich hab jetzt wieder auf admin umgestellt, und attr boxUser ist geblieben (nicht admin) trotzdem wird der repeater ohne Fehlermeldung ausgelesen.
Hallo Matze,
ich habe das bei den Repeatern noch nicht ausprobiert. Bei Admin wird doch kein User benötigt!? Wenn das Passwort stimmt, dann wird bei der Anmeldung der Benutzer wohl einfach ignoriert.
Ich habe in der angehängte Version das Log bei "undefined situation" erweitert.
Ich hoffe da kommen dann mehr Infos beim 450E.
Grüße Jörg
Jörg Wiemann
matze1999
jetzt das im log:
2024.01.20 09:34:26 2: [FritzRepeater | 450 | 128.07.15 | Readout_Response.4762] - SIGNIFICANT:undefined situation
$VAR1 = {};
matze1999
JoWiemann
Zitat von: matze1999 am 20 Januar 2024, 09:35:54Hallo,
jetzt das im log:
$VAR1 = {};
matze1999
Hallo matze,
da kommt vom 450E gar nichts bei einer Anfrage zurück. Ich muss mal überlegen, wie ich damit umgehe.
Grüße Jörg
Jörg Wiemann
JoWiemann
Hallo Matze,
ich habe doch noch etwas gefunden. Bitte einmal probieren. Danke Dir
Grüße Jörg
Jörg Wiemann
Nobbynews
#13
Hallo Jörg,
funktioniert!
Danke.
Norbert
matze1999
alles bestens, Danke!
matze1999
