Erste Schritte, Erster Aktor
Begonnen von moonsorrox, 17 September 2013, 12:51:07
moonsorrox
nein klappt leider nicht, hier mal mein log
2013.09.19 15:36:06 0: Server shutdown
2013.09.19 15:36:09 1: Including fhem.cfg
2013.09.19 15:36:10 3: telnetPort: port 7072 opened
2013.09.19 15:36:10 3: WEB: port 8083 opened
2013.09.19 15:36:10 3: WEBphone: port 8084 opened
2013.09.19 15:36:10 3: WEBtablet: port 8085 opened
2013.09.19 15:36:11 1: Including ./FHEM/LanInterface.cfg
2013.09.19 15:36:11 2: HMLAN_Parse: HMLanHaus new condition disconnected
2013.09.19 15:36:11 3: Opening HMLanHaus device 10.0.0.51:1000
2013.09.19 15:36:11 3: HMLanHaus device opened
2013.09.19 15:36:11 2: HMLAN_Parse: HMLanHaus new condition init
2013.09.19 15:36:11 1: Including ./FHEM/RollladenWZ.cfg
2013.09.19 15:36:12 1: define: please define a device with hmId:1F3F4A first
2013.09.19 15:36:12 3: Please define WZ_Rollladen_AUF first
2013.09.19 15:36:12 3: Please define WZ_Rollladen_ZU first
2013.09.19 15:36:12 1: configfile: please define a device with hmId:1F3F4A first
2013.09.19 15:36:12 1: Including ./log/fhem.save
2013.09.19 15:36:12 1: usb create starting
2013.09.19 15:36:14 3: Opening CUL device /dev/ttyAMA0
2013.09.19 15:36:14 3: Setting CUL baudrate to 38400
2013.09.19 15:36:14 3: CUL device opened
2013.09.19 15:36:14 1: usb create end
2013.09.19 15:36:14 2: SecurityCheck:  WEB has no basicAuth attribute. telnetPort has no password/globalpassword attribute.  Restart fhem for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2013.09.19 15:36:14 0: Server started with 17 defined entities (version $Id: fhem.pl 3872 2013-09-07 11:58:33Z rudolfkoenig $, os linux, user fhem, pid 3200)
2013.09.19 15:38:00 3: at_WZ_Rollladen_AUF: Please define WZ_Rollladen_AUF first
Puschel74
post noch mal den Inhalt deienr Rollladen.cfg und den relevanten Teil deiner fhem.cfg bitte.
Edith: Die include-Zeile gehört weiter runter in der fhem.cfg - nach dem autocreate-Eintrag in der fhem.cfg habe ich meine include-Zeilen.
moonsorrox
unterer Teil von fhem.cfg
#define FHZ FHZ /dev/USB0
#define CUL CUL /dev/ttyACM0@9600 1234
#attr CUL rfmode HomeMatic
#define EUL TCM 310 /dev/ttyACM0@57600
#define BscBor TCM 120 /dev/ttyUSB0@9600
#define BscSmartConnect TCM 310 /dev/ttyUSB0@57600
# -------- Wetterdaten erfassen ---------
define MeinWetter Weather 15002831 600 de
attr MeinWetter icon weather_cloudy
attr MeinWetter room Wettervorhersage
# -- Logfile alle Wetter Daten --
define FileLog_MeinWetter FileLog ./log/meinwetter-%Y-%m.log MeinWetter
attr FileLog_MeinWetter logtype text
attr FileLog_MeinWetter room Wettervorhersage
# attr MeinWetter localicons 1
# -- Wetter Icons hinzufügen --
define weblink_meinwetter weblink htmlCode {WeatherAsHtml("MeinWetter")}
attr weblink_meinwetter room Wettervorhersage
# -------- Aufruf der einzelnen Dateien ---------
include ./FHEM/LanInterface.cfg
include ./FHEM/RollladenWZ.cfg
# include ./FHEM/BeleuchtungEingang.cfg
RollladenWZ.cfg
## Wohnzimmer / Rollläden
## Zweck.........: Homematic Komponenten für Rollläden im Wohnzimmer
## Standort......: in der Verteilung
## Typ...........: HM-LC-SW2-FM Schaltaktor 2-fach UP
## Installation..: 17.09.2013
## Besonderheiten:
## Aktor für die Nebenstellen-Eingänge der Busch-Jalousiecontrol
### Kontakt_01 Rollladen_AUF
define WZ_Rollladen_AUF CUL_HM 1F3F4A01
attr WZ_Rollladen_AUF eventMap on:Auf off:off
attr WZ_Rollladen_AUF model HM-LC-SW2-FM
attr WZ_Rollladen_AUF peerIDs
attr WZ_Rollladen_AUF room Wohnzimmer
attr WZ_Rollladen_AUF serialNr KEQ0024598
attr WZ_Rollladen_AUF subType switch
attr WZ_Rollladen_AUF webCmd Auf:off:statusRequest
### Kontakt_02 Rollladen_ZU
define WZ_Rollladen_ZU CUL_HM 1F3F4A02
attr WZ_Rollladen_ZU eventMap on:Zu off:off
attr WZ_Rollladen_ZU model HM-LC-SW2-FM
attr WZ_Rollladen_ZU room Wohnzimmer
attr WZ_Rollladen_ZU subType switch
attr WZ_Rollladen_ZU webCmd Zu:off:statusRequest
## Rollladen soll fix um 08:00h jeden Tag hochfahren
define at_WZ_Rollladen_AUF at *15:38 set WZ_Rollladen_AUF Auf
define at_WZ_Rollladen_AUF_Aus at *15:38:40 set WZ_Rollladen_AUF off
## Rollladen soll variabel je nach Sonnenuntergang, aber
## nicht vor 17:00h und nicht nach 21:00h jeden Tag runterfahren
define at_WZ_Rollladen_ZU at *{sunset(0,"17:00:40","21:00:40")} set WZ_Rollladen_ZU Zu;;define at_WZ_Rollladen_ZU_Aus at +00:00:40 set WZ_Rollladen_ZU off
# define WZ_Rollladen_ZU at *{sunset(0,"17:00","21:00")} set WZ_Rollladen off
# define at_WZ_Rollladen_ZU_Aus at *18:15:40 set WZ_Rollladen zu
# attr WZ_Rollladen_ZU room Wohnzimmer
## Log File Rollladen_AUF
## Log File Rollladen_ZU
define FileLog_WZ_Rollladen_AUF FileLog ./log/WZ_Rollladen_AUF-%Y.log WZ_Rollladen_AUF
attr FileLog_WZ_Rollladen_AUF logtype text
attr FileLog_WZ_Rollladen_AUF room Wohnzimmer
define FileLog_WZ_Rollladen_ZU FileLog ./log/WZ_Rollladen_ZU-%Y.log WZ_Rollladen_ZU
attr FileLog_WZ_Rollladen_ZU logtype text
attr FileLog_WZ_Rollladen_ZU room Wohnzimmer
moonsorrox
aus dem, Wiki habe ic gerade mal ein Besipiel mit dem gleichen Aktor angeschaut wie das definiert wurde, nur das eben ein Taster eingesetzt wurde was ich ja nicht habe.
Evtl. kann man hier etwas ableiten
## Aktor für die Lampen auf der Schrankseite des Wohnzimmers
##  dies ist ein gemeinsamer Aktor mit WZ_Lampe_Couch
define WZ_Lampe_Schrank CUL_HM xxxxxx
attr WZ_Lampe_Schrank devInfo 020100
attr WZ_Lampe_Schrank firmware 1.9
attr WZ_Lampe_Schrank hmClass receiver
attr WZ_Lampe_Schrank model HM-LC-SW2-FM
attr WZ_Lampe_Schrank room Wohnzimmer
attr WZ_Lampe_Schrank serialNr xxxxxxxxxx
attr WZ_Lampe_Schrank subType switch
## Aktor für die Lampen auf der Couchseite des Wohnzimmers
##  dies ist ein gemeinsamer Aktor mit WZ_Lampe_Schrank
define WZ_Lampe_Couch CUL_HM xxxxxx
attr WZ_Lampe_Couch devInfo 020100
attr WZ_Lampe_Couch firmware 1.9
attr WZ_Lampe_Couch hmClass receiver
attr WZ_Lampe_Couch model HM-LC-SW2-FM
attr WZ_Lampe_Couch room Wohnzimmer
attr WZ_Lampe_Couch serialNr xxxxxxxxxxx
attr WZ_Lampe_Couch subType switch
define WZ_Taster_On_Links notify WZ_Taster:Btn1.on.* set WZ_Lampe_Schrank toggle
attr WZ_Taster_On_Links room Wohnzimmer
define WZ_Taster_Off_Links notify WZ_Taster:Btn1.off.* set WZ_Lampe_Schrank toggle
attr WZ_Taster_Off_Links room Wohnzimmer
## Doppeltaster im Wohnzimmer beim Flur
## Dieser Taster schaltet die Lampen im Wohnzimmer bei dem Schrank
## und bei der Couch
define WZ_Taster CUL_HM xxxxxx
attr WZ_Taster devInfo 040000
attr WZ_Taster firmware 1.2
attr WZ_Taster hmClass sender
attr WZ_Taster model HM-PB-4-WM
attr WZ_Taster room Wohnzimmer
attr WZ_Taster serialNr xxxxxxxxxxx
attr WZ_Taster subType remote
define WZ_Taster_On_Rechts notify WZ_Taster:Btn2.on.* set WZ_Lampe_Couch toggle
attr WZ_Taster_On_Rechts room Wohnzimmer
define WZ_Taster_Off_Rechts notify WZ_Taster:Btn2.off.* set WZ_Lampe_Couch toggle
attr WZ_Taster_Off_Rechts room Wohnzimmer
Puschel74
die attr gehören natürlich auch angepasst ;-)
attr at_WZ_Rollladen_AUF room Wohnzimmer
selbiges bei den anderen auch kontrollieren bitte.
moonsorrox
OK werde gleich berichten.. muss da auch beim logfile rein?
Was mir auch bisher auffällt es gibt im Webinterface keine Schalter mehr
moonsorrox
geht leider nicht...
2013.09.19 16:06:20 0: Server shutdown
2013.09.19 16:06:24 1: Including fhem.cfg
2013.09.19 16:06:24 3: telnetPort: port 7072 opened
2013.09.19 16:06:25 3: WEB: port 8083 opened
2013.09.19 16:06:25 3: WEBphone: port 8084 opened
2013.09.19 16:06:25 3: WEBtablet: port 8085 opened
2013.09.19 16:06:26 1: Including ./FHEM/LanInterface.cfg
2013.09.19 16:06:26 2: HMLAN_Parse: HMLanHaus new condition disconnected
2013.09.19 16:06:26 3: Opening HMLanHaus device 10.0.0.51:1000
2013.09.19 16:06:26 3: HMLanHaus device opened
2013.09.19 16:06:26 2: HMLAN_Parse: HMLanHaus new condition init
2013.09.19 16:06:26 1: Including ./FHEM/RollladenWZ.cfg
2013.09.19 16:06:27 1: define: please define a device with hmId:1F3F4A first
2013.09.19 16:06:27 3: Please define WZ_Rollladen_AUF first
2013.09.19 16:06:27 3: Please define WZ_Rollladen_ZU first
2013.09.19 16:06:27 1: configfile: please define a device with hmId:1F3F4A first
2013.09.19 16:06:27 1: Including ./log/fhem.save
2013.09.19 16:06:27 1: usb create starting
2013.09.19 16:06:29 3: Opening CUL device /dev/ttyAMA0
2013.09.19 16:06:29 3: Setting CUL baudrate to 38400
2013.09.19 16:06:29 3: CUL device opened
2013.09.19 16:06:29 1: usb create end
2013.09.19 16:06:29 2: SecurityCheck:  WEB has no basicAuth attribute. telnetPort has no password/globalpassword attribute.  Restart fhem for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2013.09.19 16:06:29 0: Server started with 17 defined entities (version $Id: fhem.pl 3872 2013-09-07 11:58:33Z rudolfkoenig $, os linux, user fhem, pid 3212)
2013.09.19 16:08:00 3: at_WZ_Rollladen_AUF: Please define WZ_Rollladen_AUF first
hier der Code wie er jetzt aussieht
define at_WZ_Rollladen_AUF at *16:08 set WZ_Rollladen_AUF Auf
define at_WZ_Rollladen_AUF_Aus at *16:08:40 set WZ_Rollladen_AUF off
# define at_WZ_Rollladen_ZU at *{sunset(0,"17:00","21:00")} set WZ_Rollladen off
attr at_WZ_Rollladen_ZU room Wohnzimmer
# define at_WZ_Rollladen_ZU_Aus at *18:15:40 set WZ_Rollladen off
# attr at_WZ_Rollladen_ZU room Wohnzimmer
Puschel74
evtl. muss hier ja
Zitatdefine WZ_Rollladen_ZU CUL_HM 1F3F4A02
sowas rein
define WZ_Rollladen_ZU CUL_HM 1F3F4A 02
aber das kann ich dir nicht sagen.
Am besten mal im Wiki unter Homematic nach dem 2-Kanal suchen und schauen wie er dort eingebunden wird.
Sonst die beiden Kanäle einfach per autocreate einbinden lassen und dann in die Rollladen.cfg verschieben.
moonsorrox
ich habe die gestern nochmal erstellen lassen mit autocreate und dann versucht umzusetzen..
Deshalb habe ich mir das Beispiel von meinem Aktor genommen und versuche damit etwas zu realisieren nur eben ohne Taster, leider gibt es solch ein Bsp. nicht im Wiki wo die Rollläden so geschaltet werden nur mit dem anderen HM-LC-BI1-FM
Puschel74
ich meinte auch das.
Hier wird erklärt wie ein LC-SW2 an FHEM angelernt wird.
So wie es aussieht stimmt mit deiner Adressvergabe irgendwas nicht.
FHEM meckert an das ein Device mit dieser ID definiert werden soll.
Die nachfolgenden Fehler sind nur Folgefehler da die ganzen Attribute nicht passen da es kein define gibt.
moonsorrox
ich habe nun die Rollladen.cfg komplett geleert und den Aktor nochmals angelernt.
Sieht nun folgendermaßen aus
define CUL_HM_HM_LC_SW2_FM_1F3F4A CUL_HM 1F3F4A
attr CUL_HM_HM_LC_SW2_FM_1F3F4A .devInfo 020200
attr CUL_HM_HM_LC_SW2_FM_1F3F4A .stc 10
attr CUL_HM_HM_LC_SW2_FM_1F3F4A firmware 1.9
attr CUL_HM_HM_LC_SW2_FM_1F3F4A model HM-LC-SW2-FM
attr CUL_HM_HM_LC_SW2_FM_1F3F4A room CUL_HM
attr CUL_HM_HM_LC_SW2_FM_1F3F4A serialNr KEQ0024598
attr CUL_HM_HM_LC_SW2_FM_1F3F4A subType switch
define FileLog_CUL_HM_HM_LC_SW2_FM_1F3F4A FileLog ./log/CUL_HM_HM_LC_SW2_FM_1F3F4A-%Y.log CUL_HM_HM_LC_SW2_FM_1F3F4A
attr FileLog_CUL_HM_HM_LC_SW2_FM_1F3F4A logtype text
attr FileLog_CUL_HM_HM_LC_SW2_FM_1F3F4A room CUL_HM
define CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_01 CUL_HM 1F3F4A01
attr CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_01 model HM-LC-SW2-FM
attr CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_01 peerIDs
attr CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_01 room CUL_HM
define FileLog_CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_01 FileLog ./log/CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_01-%Y.log CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_01
attr FileLog_CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_01 logtype text
attr FileLog_CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_01 room CUL_HM
define CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_02 CUL_HM 1F3F4A02
attr CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_02 model HM-LC-SW2-FM
attr CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_02 room CUL_HM
define FileLog_CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_02 FileLog ./log/CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_02-%Y.log CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_02
attr FileLog_CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_02 logtype text
attr FileLog_CUL_HM_HM_LC_SW2_FM_1F3F4A_Sw_02 room CUL_HM
Puschel74
und diese beiden
kannst du nun in
Zitatdefine WZ_Rollladen_AUF CUL_HM 1F3F4A01
attr WZ_Rollladen_AUF eventMap on:Auf off:Stop
attr WZ_Rollladen_AUF room CUL_HM
attr WZ_Rollladen_AUF webCmd Auf:Stop
attr FileLog_WZ_Rollladen_AUF room CUL_HM
attr WZ_Rollladen_ZU eventMap on:Zu off:Stop
attr WZ_Rollladen_ZU room CUL_HM
attr WZ_Rollladen_ZU webCmd Zu:Stop
attr FileLog_WZ_Rollladen_ZU room CUL_HM
umarbeiten dann sollte sowas dabei raus kommen.
moonsorrox
OK ich habe erst einmal dieses gemacht.. und ich kann die Rollläden jetzt darüber auch fahren und es funktioniert
Die Umbenennung kann ich direkt in der Datei machen, oder
Puschel74
ZitatDie Umbenennung kann ich direkt in der Datei machen, oder
Ja, aber du musst drauf achten wirklich jede Zeile zu kontrollieren.
Auch die FileLog-Einträge gehören dazu.
Am einfachsten geht das mit Notepad++
Aus der fhem.cfg kopieren, in Notepad++ einfügen, Suchen/Ersetzen und fertig.
Zurück kopieren - fhem.cfg save und passt.
moonsorrox
jo ich habe jetzt die Änderungen gemacht und es geht ich kann über die Weboberfläche und mein iPad die Rollläden steuern.
Ich arbeite nur mit Notepad++
