HomeMatic Funk-Statusanzeige - HM-Dis-WM55
Begonnen von Roaster, 14 November 2014, 20:33:48
strauch
Mhhh ich hab jetzt einen rssi von ca. 60. Ich werde heute Abend wenn meine Tochter im Bett ist den hmlan mal an die lxccu klemmen und mal testen....
_HM_Dis_WM55_33B83E protEvent:CMDs_done_Errors:1
2014.12.14 15:30:39.778 3: CUL_HM set CUL_HM_HM_Dis_WM55_33B83E clear rssi
2014.12.14 15:31:42.359 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:Info_Cleared
2014.12.14 15:31:42.359 3: CUL_HM set CUL_HM_HM_Dis_WM55_33B83E clear msgEvents
2014.12.14 15:31:51.818 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:1
2014.12.14 15:31:51.821 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:2
2014.12.14 15:31:51.823 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:3
2014.12.14 15:31:51.825 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:4
2014.12.14 15:31:51.827 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:5
2014.12.14 15:31:51.829 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:6
2014.12.14 15:31:51.831 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:7
2014.12.14 15:31:51.833 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:8
2014.12.14 15:31:51.835 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:9
2014.12.14 15:31:51.837 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:10
2014.12.14 15:31:51.839 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:11
2014.12.14 15:31:51.841 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:12
2014.12.14 15:31:51.843 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:13
2014.12.14 15:31:51.845 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:14
2014.12.14 15:31:51.847 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:15
2014.12.14 15:31:51.849 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:16
2014.12.14 15:31:51.851 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:17
2014.12.14 15:31:51.853 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:18
2014.12.14 15:31:51.856 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:19
2014.12.14 15:31:51.858 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:20
2014.12.14 15:31:51.860 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:21
2014.12.14 15:31:51.860 3: CUL_HM set CUL_HM_HM_Dis_WM55_33B83E getConfig
2014.12.14 15:32:47.601 0: HMLAN_Parse: HMLAN1 R:E33B83E   stat:0000 t:4777E2C8 d:FF r:FFC1     m:07 A240 33B83E F11134 0203
2014.12.14 15:32:47.697 0: HMLAN_Send:  HMLAN1 S:+33B83E,02,01,1E
2014.12.14 15:32:47.698 0: HMLAN_Send:  HMLAN1 S:S49374A3C stat:  00 t:00000000 d:01 r:49374A3C m:C8 A001 F11134 33B83E 00040000000000
2014.12.14 15:32:47.698 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_processing... pending:20
2014.12.14 15:32:47.698 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E prep ACK for 02
2014.12.14 15:32:47.699 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_processing... pending:20
2014.12.14 15:32:47.699 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E sent ACK:2
2014.12.14 15:32:48.054 0: HMLAN_Parse: HMLAN1 R:R49374A3C stat:0001 t:4777E492 d:FF r:FFC2     m:08 8400 33B83E F11134 1000D34C45513133323333353112110000
2014.12.14 15:32:53.513 4: CUL_HM_Resend: CUL_HM_HM_Dis_WM55_33B83E nr 2
2014.12.14 15:32:53.520 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:21
2014.12.14 15:34:48.667 0: HMLAN_Parse: HMLAN1 R:E33B83E   stat:0000 t:4779BBBE d:FF r:FFC1     m:09 A240 33B83E F11134 0204
2014.12.14 15:34:48.762 0: HMLAN_Send:  HMLAN1 S:S49392326 stat:  00 t:00000000 d:01 r:49392326 m:C9 A001 F11134 33B83E 00040000000000
2014.12.14 15:34:48.762 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_processing... pending:20
2014.12.14 15:34:48.762 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E prep ACK for 02
2014.12.14 15:34:48.763 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_processing... pending:20
2014.12.14 15:34:48.763 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E sent ACK:2
2014.12.14 15:34:49.121 0: HMLAN_Parse: HMLAN1 R:R49392326 stat:0001 t:4779BD8A d:FF r:FFC2     m:0A 8400 33B83E F11134 1000D34C45513133323333353112110000
2014.12.14 15:34:53.682 4: CUL_HM_Resend: CUL_HM_HM_Dis_WM55_33B83E nr 3
2014.12.14 15:34:53.685 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:21
2014.12.14 15:35:34.312 0: HMLAN_Parse: HMLAN1 R:E33B83E   stat:0000 t:477A6E10 d:FF r:FFC4     m:0B A240 33B83E F11134 0205
2014.12.14 15:35:34.406 0: HMLAN_Send:  HMLAN1 S:S4939D573 stat:  00 t:00000000 d:01 r:4939D573 m:CA A001 F11134 33B83E 00040000000000
2014.12.14 15:35:34.407 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_processing... pending:20
2014.12.14 15:35:34.407 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E prep ACK for 02
2014.12.14 15:35:34.408 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_processing... pending:20
2014.12.14 15:35:34.408 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E sent ACK:2
2014.12.14 15:35:34.766 0: HMLAN_Parse: HMLAN1 R:R4939D573 stat:0001 t:477A6FDB d:FF r:FFC2     m:0C 8400 33B83E F11134 1000D34C45513133323333353112110000
2014.12.14 15:35:39.283 4: CUL_HM_Resend: CUL_HM_HM_Dis_WM55_33B83E nr 4
2014.12.14 15:35:39.285 5: CUL_HM CUL_HM_HM_Dis_WM55_33B83E protEvent:CMDs_pending pending:21
Gesendet von meinem Smartphone
FHEM 5.6 VMware mit Debian. 1 CUL für FS20 und HMLAN für Homematic, HM-CC-RT-DN, HM-LC_Sw1PBU-FM, HM-LC-Bl1PBU-FM,  HM-SEC-SC, HM-SEC-SC-2, HM-LC-Sw1-Pl2, HM-Sec-RHS, ASH2200, FHT80B, S20KSE, Sonos, XBMC, FB_Callmonitor, SMLUSB, Arduino Firmata, uvm.
martinp876
Was druckst du denn so . Immer config und eine taste ?
Druecke bitte entweder oder. Beides ist m.e. nicht notwendig, um das senden von fhem zu starten
strauch
Nein immer eine Taste....
strauch
#48
Also wenn ich es an die LXCCU verbinde dann bekomme ich Text hin. Soll ich da mal was mitschneiden (mit nem CUL)? Müssen dann beide die gleiche HMID haben? Oder muss ich mich irgendwie in den Netzwerktraffic reinhängen?
Die 10 Kanäle dienen der Textbevorratung siehe Screenshot. Die ich dann in einem Programm auswählen kann für einen der 6 Zeilen.
strauch
#49
Vielleicht kann jemand anders auch mal ein getconfig mitloggen, ob das genauso Schwierigkeiten macht wie bei mir. Was mir gestern Abend noch aufgefallen ist, ich hab mit der vccu gepaired, das ging auch bei meinem HM-MOD-RE-8 nicht gut. Dann hab ich den noch mal direkt mit HMLAN gepaired und es ging. Aber beim HM-Dis-WM55 hat das nicht geholfen (war ja auch schon korrekt gepaired).
jens-hoppel
@Strauch,
ich soll ein getconfig machen und diesen Teil aus der Logdatei auschneiden und hier posten, Richtig ?
FHEM auf 1.Rasberry PI, 2xCUL CC1101, HMLAN, USV 400
2.Rasberry PI als Wetterserver
HM, FS20, FHT, HMS, WS1080 Komponenten für diverse Schalt- und Überwachungsaufgaben
strauch
Genau aber vorher das Log erweitern nach dieser Anleitung:
http://www.fhemwiki.de/wiki/Homematic_Nachrichten_sniffen
Als LogID dann die ID von deinem HM-Dis-WM55 (statt all,sys) bei mir die ID 33B83E
jens-hoppel
Dauert noch, habe diese Fehlermeldung:
2014.12.15 16:56:15.055 0: Server started with 23 defined entities (version $Id: fhem.pl 7124 2014-12-05 07:10:20Z rudolfkoenig $, os linux, user boxusr99, pid 2603)
2014.12.15 16:56:15.067 1: HMLAN_Parse: HMLAN1 new condition ok
2014.12.15 17:00:51.066 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/10_CUL_HM.pm line 6975.
jens-hoppel
er meckert bei mir immer über die 10_CUL_HM.pm line 6975. Kannst du im Protokoll sehen,
Vielleiccht weiß jemand was das bedeutet.
Hier das Log:
2014.12.15 17:17:24.449 0: Server shutdown
2014.12.15 17:17:28.866 1: Including fhem.cfg
2014.12.15 17:17:31.294 1: HMLAN_Parse: HMLAN1 new condition disconnected
2014.12.15 17:17:31.348 1: HMLAN_Parse: HMLAN1 new condition init
2014.12.15 17:17:34.609 1: Including ./log/fhem.save
2014.12.15 17:17:34.739 0: Server started with 23 defined entities (version $Id: fhem.pl 7124 2014-12-05 07:10:20Z rudolfkoenig $, os linux, user boxusr99, pid 2611)
2014.12.15 17:17:34.750 1: HMLAN_Parse: HMLAN1 new condition ok
2014.12.15 17:20:48.227 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/10_CUL_HM.pm line 6975.
2014.12.15 17:21:39.114 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:0031E48C d:FF r:FFCF     m:35 A240 33B72E 29A0B0 011C
2014.12.15 17:21:39.247 0: HMLAN_Send:  HMLAN1 S:+33B72E,02,01,1E
2014.12.15 17:21:39.249 0: HMLAN_Send:  HMLAN1 S:S4EC15077 stat:  00 t:00000000 d:01 r:4EC15077 m:01 A001 29A0B0 33B72E 00040000000000
2014.12.15 17:21:39.568 0: HMLAN_Parse: HMLAN1 R:R4EC15077 stat:0001 t:0031E657 d:FF r:FFCD     m:36 8400 33B72E 29A0B0 1000D34C45513133323336323312110000
2014.12.15 17:22:43.582 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:0032E06C d:FF r:FFD0     m:37 A240 33B72E 29A0B0 011D
2014.12.15 17:22:43.676 0: HMLAN_Send:  HMLAN1 S:S4EC24BD4 stat:  00 t:00000000 d:01 r:4EC24BD4 m:02 A001 29A0B0 33B72E 00040000000000
2014.12.15 17:22:44.037 0: HMLAN_Parse: HMLAN1 R:R4EC24BD4 stat:0001 t:0032E237 d:FF r:FFCF     m:38 8400 33B72E 29A0B0 1000D34C45513133323336323312110000
2014.12.15 17:23:11.766 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:00334E88 d:FF r:FFD1     m:39 A240 33B72E 29A0B0 011E
2014.12.15 17:23:11.858 0: HMLAN_Send:  HMLAN1 S:S4EC2B9EC stat:  00 t:00000000 d:01 r:4EC2B9EC m:03 A001 29A0B0 33B72E 00040000000000
2014.12.15 17:23:12.220 0: HMLAN_Parse: HMLAN1 R:R4EC2B9EC stat:0001 t:00335053 d:FF r:FFD2     m:3A 8400 33B72E 29A0B0 1000D34C45513133323336323312110000
2014.12.15 17:24:12.729 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:00343CB5 d:FF r:FFD2     m:3B A240 33B72E 29A0B0 011F
2014.12.15 17:24:12.821 0: HMLAN_Send:  HMLAN1 S:S4EC3A80E stat:  00 t:00000000 d:01 r:4EC3A80E m:04 A001 29A0B0 33B72E 00040000000000
2014.12.15 17:24:13.183 0: HMLAN_Parse: HMLAN1 R:R4EC3A80E stat:0001 t:00343E80 d:FF r:FFD2     m:3C 8400 33B72E 29A0B0 1000D34C45513133323336323312110000
2014.12.15 17:24:59.009 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:0034F185 d:FF r:FFD2     m:3D A240 33B72E 29A0B0 0120
2014.12.15 17:25:04.848 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:00350855 d:FF r:FFD3     m:00 A610 33B72E 29A0B0 06000000
2014.12.15 17:25:07.004 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:003510C1 d:FF r:FFD2     m:01 A240 33B72E 29A0B0 0101
2014.12.15 17:25:07.096 0: HMLAN_Send:  HMLAN1 S:S4EC47C2D stat:  00 t:00000000 d:01 r:4EC47C2D m:05 A001 29A0B0 33B72E 00040000000000
2014.12.15 17:25:07.970 0: HMLAN_Parse: HMLAN1 R:R4EC47C2D stat:0008 t:00000000 d:FF r:7FFF     m:05 A001 29A0B0 33B72E 00040000000000
2014.12.15 17:25:07.974 0: HMLAN_Parse: HMLAN1 no ACK from 33B72E
lg Jens
jens-hoppel
Hier noch ein Mitschnitt von einem anschließenden Pairing:
2014.12.15 17:33:49.744 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:003D0B0A d:FF r:FFCF     m:02 8400 33B72E 29A0B0 1000D34C45513133323336323312110000
2014.12.15 17:33:49.835 0: HMLAN_Send:  HMLAN1 S:S4ECC7633 stat:  00 t:00000000 d:01 r:4ECC7633 m:06 A001 29A0B0 33B72E 00050000000000
2014.12.15 17:33:50.219 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0100 t:003D0CD6 d:FF r:FFD0     m:06 A002 33B72E 29A0B0 04091EFBFB091E00
2014.12.15 17:33:50.453 0: HMLAN_Parse: HMLAN1 R:R4ECC7633 stat:0021 t:003D0CDB d:00 r:FFD0     m:06 8002 33B72E 29A0B0 00D4BE2AA6
2014.12.15 17:33:50.472 0: HMLAN_Send:  HMLAN1 S:S4ECC78CF stat:  00 t:00000000 d:01 r:4ECC78CF m:07 A001 29A0B0 33B72E 000802010A290BA00CB0
2014.12.15 17:33:50.879 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0100 t:003D0F6A d:FF r:FFCF     m:07 A002 33B72E 29A0B0 04DD9A5F78DD9A00
2014.12.15 17:33:51.125 0: HMLAN_Parse: HMLAN1 R:R4ECC78CF stat:0021 t:003D0F6F d:00 r:FFCF     m:07 8002 33B72E 29A0B0 0037E22638
2014.12.15 17:33:51.142 0: HMLAN_Send:  HMLAN1 S:S4ECC7B6E stat:  00 t:00000000 d:01 r:4ECC7B6E m:08 A001 29A0B0 33B72E 0006
2014.12.15 17:33:51.549 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0100 t:003D1208 d:FF r:FFCB     m:08 A002 33B72E 29A0B0 049E1FBDFC9E1F00
2014.12.15 17:33:51.824 0: HMLAN_Parse: HMLAN1 R:R4ECC7B6E stat:0021 t:003D120D d:00 r:FFCC     m:08 8002 33B72E 29A0B0 00183877AC
2014.12.15 17:33:51.842 0: HMLAN_Send:  HMLAN1 S:S4ECC7E2A stat:  00 t:00000000 d:01 r:4ECC7E2A m:09 A001 29A0B0 33B72E 00040000000000
2014.12.15 17:33:52.260 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:003D14DC d:FF r:FFCC     m:09 A010 33B72E 29A0B0 02020107010A290BA00CB00E0A18000000
2014.12.15 17:33:52.366 0: HMLAN_Parse: HMLAN1 R:R4ECC7E2A stat:0001 t:003D14E1 d:FF r:FFCC     m:09 A010 33B72E 29A0B0 02020107010A290BA00CB00E0A18000000
2014.12.15 17:33:52.380 0: HMLAN_Send:  HMLAN1 S:+33B72E,02,01,1E
2014.12.15 17:33:52.382 0: HMLAN_Send:  HMLAN1 S:S4ECC8044 stat:  00 t:00000000 d:01 r:4ECC8044 m:0A A001 29A0B0 33B72E 01040000000001
2014.12.15 17:33:52.783 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:003D16E8 d:FF r:FFCD     m:0A A010 33B72E 29A0B0 02080036743765387339743A003B6C3C6F
2014.12.15 17:33:52.890 0: HMLAN_Parse: HMLAN1 R:R4ECC8044 stat:0001 t:003D16ED d:FF r:FFCD     m:0A A010 33B72E 29A0B0 02080036743765387339743A003B6C3C6F
2014.12.15 17:33:53.035 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:003D17E6 d:FF r:FFCD     m:0A A010 33B72E 29A0B0 023D633E6B3F2040314100460047654878
2014.12.15 17:33:53.284 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:003D18DF d:FF r:FFCD     m:0A A010 33B72E 29A0B0 0249744A624B6C4C6F4D634E6B4F205032
2014.12.15 17:33:53.523 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:003D19CE d:FF r:FFCC     m:0A A010 33B72E 29A0B0 0251000000
2014.12.15 17:33:53.614 0: HMLAN_Send:  HMLAN1 S:S4ECC84D7 stat:  00 t:00000000 d:01 r:4ECC84D7 m:0B A001 29A0B0 33B72E 0103
2014.12.15 17:33:54.043 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:003D1BD4 d:FF r:FFCC     m:0B A010 33B72E 29A0B0 012C000000
2014.12.15 17:33:54.159 0: HMLAN_Parse: HMLAN1 R:R4ECC84D7 stat:0001 t:003D1BD9 d:FF r:FFCC     m:0B A010 33B72E 29A0B0 012C000000
2014.12.15 17:34:00.601 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:003D3575 d:FF r:FFD2     m:03 8400 33B72E 29A0B0 1000D34C45513133323336323312110000
2014.12.15 17:34:00.692 0: HMLAN_Send:  HMLAN1 S:S4ECCA074 stat:  00 t:00000000 d:01 r:4ECCA074 m:0C A001 29A0B0 33B72E 0103
2014.12.15 17:34:01.059 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:003D373D d:FF r:FFCC     m:0C A010 33B72E 29A0B0 01FA000000
2014.12.15 17:34:01.175 0: HMLAN_Parse: HMLAN1 R:R4ECCA074 stat:0001 t:003D3742 d:FF r:FFCC     m:0C A010 33B72E 29A0B0 01FA000000
2014.12.15 17:34:05.548 0: HMLAN_Parse: HMLAN1 R:E33B72E   stat:0000 t:003D48C9 d:FF r:FFD2     m:04 8400 33B72E 29A0B0 1000D34C45513133323336323312110000
strauch
Du logst sys im hmlan oder? stell das mal auf E33B72E das scheint ja dein Display zu sein und mach ein getconfig
jens-hoppel
Hier die Einstellung in der fhem.cfg
attr global userattr devStateIcon devStateStyle fm_fav fm_groups fm_name fm_order fm_type fm_view icon sortby webCmd widgetOverride
attr global logfile ./log/fhem-%Y-%m.log
attr global modpath .
attr global motd SecurityCheck:\
WEB,WEBphone,WEBtablet has no basicAuth attribute.\
telnetPort has no password/globalpassword attribute.\
Running with root privileges.\
Restart FHEM for a new check if the problem is fixed,\
or set the global attribute motd to none to supress this message.\
attr global sendStatistics onUpdate
attr global statefile ./log/fhem.save
attr global uniqueID ./FHEM/FhemUtils/uniqueID
#attr global verbose 3
attr global verbose 1
attr global mseclog 1
define WEBphone FHEMWEB 8084 global
attr WEBphone stylesheetPrefix smallscreen
attr WEBtablet stylesheetPrefix touchpad
# Fake FileLog entry, to access the fhem log from FHEMWEB
define Logfile FileLog ./log/fhem-%Y-%m.log fakelog
define autocreate autocreate
attr autocreate autosave 1
attr autocreate device_room %TYPE
attr autocreate filelog ./log/%NAME-%Y.log
attr autocreate weblink 1
attr autocreate weblink_room Plot
#define initialUsbCheck notify global:INITIALIZED usb create
define telnetPort telnet 7072 global
define HMLAN1 HMLAN 192.168.170.222:1000
attr HMLAN1 hmId 29A0B0
attr HMLAN1 hmLanQlen 1_min
attr HMLAN1 logIDs 33B72E
ist da was falsch ?
strauch
Jetzt fehlt evtl. noch beim device das attr verbose 5
jens-hoppel
#58
habe ich eingefügt, jetzt bekomme ich nur noch:
2014.12.15 20:32:52.470 0: Server started with 23 defined entities (version $Id: fhem.pl 7124 2014-12-05 07:10:20Z rudolfkoenig $, os linux, user boxusr99, pid 2726)
2014.12.15 20:32:52.481 1: HMLAN_Parse: HMLAN1 new condition ok
2014.12.15 20:33:30.036 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/10_CUL_HM.pm line 6975.
2014.12.15 20:33:30.180 1: Including fhem.cfg
2014.12.15 20:33:30.345 1: HMLAN_Parse: HMLAN1 new condition disconnected
2014.12.15 20:33:30.362 1: HMLAN_Parse: HMLAN1 new condition init
2014.12.15 20:33:30.740 1: Including ./log/fhem.save
2014.12.15 20:33:33.384 1: HMLAN_Parse: HMLAN1 new condition ok
2014.12.15 20:33:51.856 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:1
2014.12.15 20:33:51.869 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:2
2014.12.15 20:33:51.878 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:3
2014.12.15 20:33:51.887 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:4
2014.12.15 20:33:51.895 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:5
2014.12.15 20:33:51.902 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:6
2014.12.15 20:33:51.910 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:7
2014.12.15 20:33:51.918 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:8
2014.12.15 20:33:51.925 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:9
2014.12.15 20:33:51.933 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:10
2014.12.15 20:33:51.941 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:11
2014.12.15 20:33:51.949 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:12
2014.12.15 20:33:51.957 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:13
2014.12.15 20:33:51.970 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:14
2014.12.15 20:33:51.978 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:15
2014.12.15 20:33:51.986 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:16
2014.12.15 20:33:51.993 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:17
2014.12.15 20:33:52.001 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:18
2014.12.15 20:33:52.008 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:19
2014.12.15 20:33:52.016 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:20
2014.12.15 20:33:52.024 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_pending pending:21
2014.12.15 20:33:52.026 3: CUL_HM set CUL_HM_HM_Dis_WM55_33B72E getConfig
Nachtrag, der kam noch:
2014.12.15 20:39:22.383 5: CUL_HM CUL_HM_HM_Dis_WM55_33B72E protEvent:CMDs_done_Errors:1
jens-hoppel
#59
Wenn ich den HM-Dis-WM55 im HMLAN-Konfigurator anlerne, habe ich 17 Kanäle,
in FHEM sind es nur 10. Ist hier was noch nicht Richtig, oder verstehe ich das nicht ?
lg Jens
