Signalduino Entwicklung
Begonnen von thoffma3, 05 Juli 2015, 23:01:00
hjgode
#465
Hallo
kann es sein das SignalDuino den FHEM crasht?
Wollte gerade auf meinen Server zugreifen, bekam aber nur server not found. Kurz /etc/opt/init.d/fhem status geckeckt: fhem not running.
Fhem gestartet und dann aber im log gesucht, wann der Server beendet war. Da habe ich dann die Zeile
2015.10.23 13:40:04 4: Found matched Protocol id 7 -> weatherID7
2015.10.23 13:40:04 5: Starting demodulation at Position 2
2015.10.23 13:40:04 5: converted Data to (P7#59301ADE80)
2015.10.23 13:40:04 5: sduino dispatch P7#59301ADE80
2015.10.23 13:40:04 4: SIGNALduino_unknown incomming msg: P7#59301ADE80
2015.10.23 13:40:04 4: SIGNALduino_unknown rawData: 59301ADE80
2015.10.23 13:40:04 4: SIGNALduino_unknown Protocol: 7
2015.10.23 13:40:04 4: SIGNALduino_unknown converted to bits: 0101100100110000000110101101111010000000
[b]Undefined subroutine &main::SIGNALduino_SIGNALduino_bin2dec called at ./FHEM/90_SIGNALduino_un.pm line 101.[/b]
2015.10.23 18:55:31 1: Including fhem.cfg
keys on reference is experimental at ./FHEM/00_SIGNALduino.pm line 1342, <$fh> line 20.
keys on reference is experimental at ./FHEM/00_SIGNALduino.pm line 1521, <$fh> line 20.
2015.10.23 18:55:31 1: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0@57600
gefunden.
In 90_SignalDuino_un.pm wird mehrfach ...bin2dec aufgerufen:
hgode@aoa150:~/Documents/perl/dev-rawIn.git2/FHEM$ grep 'bin2dec' *.pm
90_SIGNALduino_un.pm: my $channel = SIGNALduino_SIGNALduino_bin2dec(substr($bitData,9,3));
90_SIGNALduino_un.pm: my $temp = SIGNALduino_SIGNALduino_bin2dec(substr($bitData,16,8));
90_SIGNALduino_un.pm: my $hum = SIGNALduino_SIGNALduino_bin2dec(substr($bitData,29,7));
90_SIGNALduino_un.pm: $channel = SIGNALduino_SIGNALduino_bin2dec(substr($bitData,9,3))+1;
90_SIGNALduino_un.pm: $hum = SIGNALduino_SIGNALduino_bin2dec(substr($bitData,28,8));
90_SIGNALduino_un.pm: my $type = SIGNALduino_SIGNALduino_bin2dec(substr($bitData,0,4));
90_SIGNALduino_un.pm: my $temp = SIGNALduino_SIGNALduino_bin2dec(substr($bitData,25,11));
90_SIGNALduino_un.pm: my $hum = SIGNALduino_SIGNALduino_bin2dec(substr($bitData,17,7));
90_SIGNALduino_un.pm: my $channel = SIGNALduino_bin2dec(substr($bitData,9,3))+1;
90_SIGNALduino_un.pm: my $type = SIGNALduino_bin2dec(substr($bitData,0,4));
90_SIGNALduino_un.pm:SIGNALduino_bin2dec($)
Ich denke die Zeilen mit 'SIGNALduino_SIGNALduino_bin2dec' sind falsch. Diese Ausgabe ist von dev-RawIn.
Habe extra nochmal update check und update all gemacht. Es wurden beim ersten Mal einige Updates bei check angezeigt, aktualisiert wird aber nix.
Auf dem Server behauptet grep dass 90_SIGNALduino_un.pm eine binäre Datei sei.
~Josef
EDIT: Hab mal im git dev-RawIn in der 90_SIGNALduino.pm die SIGNALduino_SIGNALduino_bin2dec druch SIGNALduino_bin2dec ersetzt. Hoffe das ist OK.
Debian SID mit aktuellem FHEM, nanoCUL 866, JeeLink EC3000, fhemduino, SIGNALduino,
3 x TFA TH Sensor, 1 x TFA TH Arduino Sender, 3 x EC3000, 4 x Elro Schaltsteckdosen, ESA2000
offline: Wibo Funkthermostat, 2 x ELV Funkthermostat FHT80, 2 FS20 ST4 Funksteckdose
Sidey
Hi Josef,
Sieht nach einem Fehler aus.
Das fängt ja gut an....
Danke und Grüße
Sidey
Signalduino, Homematic, Raspberry Pi, Mysensors, MQTT, Alexa, Docker, AlexaFhem,zigbee2mqtt
Maintainer von: SIGNALduino, fhem-docker, alexa-fhem-docker, fhempy-docker
balki
Guten abend zusammen
Hab da ein kleines Problem  habe  heute mal den nano mit Sinaliduino geflasht ..
Seitdem steht laufend  im Log  ERROR: Cannot autoload SIGNALduino_un
Hat das was zu sagen ??
Markus
Cubietruck
2*Raspi  Rev B
Cubietruck,
Max Thermostate , 6*Fensterkontakt ,Wandthermostat
2*Jeelink , Cul 433 , 2*Cul 868 , Fhemduino,nanoCUL
Sidey
Hallo Markus,
kannst Du mal ins Log schauen, es müsste dort auch vermerkt sein, weshalb der autoload nicht klappt.
Grüße Sidey
balki
#469
Hallo Sidey
ein verbose 4 liefert mir  das
2015.10.23 23:16:23 4: SIGNALduino/msg READ: MS;P0=-1103;P1=305;P2=1006;P3=-410;P4=-11264;D=14102310101010101010231010101010101010102310231023;CP=1;SP=4;O;
2015.10.23 23:16:23 4: Found matched Protocol id 20 -> livolo
2015.10.23 23:16:23 4: SIGNALduino/msg READ: MU;P0=257;P1=-1102;P2=1006;P3=-351;P4=-32001;P5=-148;D=0123010101010101012301010101010101010123012301230405030;CP=0;
2015.10.23 23:16:23 4: Found matched Protocol id 9 -> CTW 600
2015.10.23 23:16:23 4: Found matched Protocol id 8 -> TX3 Protocol
2015.10.23 23:16:23 4: Found matched Protocol id 21 -> einhell garagedoor
2015.10.23 23:16:26 4: SIGNALduino/msg READ: MS;P0=467;P1=-3934;P2=-1971;P3=-9175;D=030202020101010102010201020202020201020201020102020201020201010101;CP=0;SP=3;O;
2015.10.23 23:16:26 4: Found matched Protocol id 0 -> weather1
2015.10.23 23:16:26 4: SIGNALduino/msg READ: MS;P0=-1972;P1=467;P2=-3924;P3=-9116;D=131010101212121210121012101010101012101012101210101012101012121212;CP=1;SP=3;
2015.10.23 23:16:26 4: Dropped (s1EA0944F00) due to short time or equal msg
2015.10.23 23:16:48 4: SIGNALduino/msg READ: MS;P0=507;P1=-1937;P2=-3888;P3=-9203;D=03010201020102010101010101020102010101010102010101010101020102010101020201;CP=0;SP=3;O;
2015.10.23 23:16:48 4: Found matched Protocol id 0 -> weather1
2015.10.23 23:16:48 4: SIGNALduino/msg READ: MS;P0=-1937;P1=502;P2=-3893;P3=-9189;D=13101210121012101010101010121012101010101012101010101010121012101010121210;CP=1;SP=3;O;
Momentan ist der Autoload fehler weg  aber der kommt  gleich bestimmt wieder
muss nen moment warten
015.10.24 11:04:15 4: SIGNALduino/msg READ: MU;P0=-2908;P1=-592;P2=495;P3=-4524;P4=-1929;D=0123242424242423232424242424242324242424232423242321;CP=2;
2015.10.24 11:04:15 4: Found matched Protocol id 16 -> Dooya shutter
2015.10.24 11:04:15 5: Starting demodulation at Position 1
2015.10.24 11:04:15 4: Found matched Protocol id 8 -> TX3 Protocol
2015.10.24 11:04:15 5: Starting demodulation at Position 50
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: /MS;P
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P/0=-1978;P1=-
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=-1978;P1=-/3927;P3=466;
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=-1978;P1=-3927;P3=466;/P5=-9163;D=3
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=-1978;P1=-3927;P3=466;P5=-9163;D=3/53030
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=-1978;P1=-3927;P3=466;P5=-9163;D=353030/303131313130
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=-1978;P1=-3927;P3=466;P5=-9163;D=353030303131313130/313031303030
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=-1978;P1=-3927;P3=466;P5=-9163;D=353030303131313130313031303030/303031
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=-1978;P1=-3927;P3=466;P5=-9163;D=353030303131313130313031303030303031/303031303031
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=-1978;P1=-3927;P3=466;P5=-9163;D=353030303131313130313031303030303031303031303031/31313131303
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=-1978;P1=-3927;P3=466;P5=-9163;D=35303030313131313031303130303030303130303130303131313131303/030303
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=-1978;P1=-3927;P3=466;P5=-9163;D=35303030313131313031303130303030303130303130303131313131303030303/1;CP=3;SP=5;
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=-1978;P1=-3927;P3=466;P5=-9163;D=353030303131313130313031303030303031303031303031313131313030303031;CP=3;SP=5;/O;
2015.10.24 11:04:17 4: SIGNALduino/msg READ: MS;P0=-1978;P1=-3927;P3=466;P5=-9163;D=353030303131313130313031303030303031303031303031313131313030303031;CP=3;SP=5;O;
2015.10.24 11:04:17 4: Found matched Protocol id 0 -> weather1
2015.10.24 11:04:17 5: Starting demodulation at Position 2
2015.10.24 11:04:17 5: converted Data to (s1EA093E100)
2015.10.24 11:04:17 5: sduino dispatch s1EA093E100
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS/;P0=464;P1=-
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=464;P1=-/3931;P2=-197
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=464;P1=-3931;P2=-197/2;P3=
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=464;P1=-3931;P2=-1972;P3=/-9116;D=0302
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=464;P1=-3931;P2=-1972;P3=-9116;D=0302/020201010101
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=464;P1=-3931;P2=-1972;P3=-9116;D=0302020201010101/020102
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=464;P1=-3931;P2=-1972;P3=-9116;D=0302020201010101020102/010202020202
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=464;P1=-3931;P2=-1972;P3=-9116;D=0302020201010101020102010202020202/01020201020
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=464;P1=-3931;P2=-1972;P3=-9116;D=030202020101010102010201020202020201020201020/201010
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=464;P1=-3931;P2=-1972;P3=-9116;D=030202020101010102010201020202020201020201020201010/101010202020
2015.10.24 11:04:17 5: SIGNALduino/RAW READ: MS;P0=464;P1=-3931;P2=-1972;P3=-9116;D=030202020101010102010201020202020201020201020201010101010202020/201;CP=0;SP=3;
2015.10.24 11:04:17 4: SIGNALduino/msg READ: MS;P0=464;P1=-3931;P2=-1972;P3=-9116;D=030202020101010102010201020202020201020201020201010101010202020201;CP=0;SP=3;
2015.10.24 11:04:17 4: Dropped (s1EA093E100) due to short time or equal msg
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: /MS;P2=5
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=5/07;P3=-1935;
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=507;P3=-1935;/P4=-3891;P5=
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=507;P3=-1935;P4=-3891;P5=/-9203;D=2523
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=507;P3=-1935;P4=-3891;P5=-9203;D=2523/242324
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=507;P3=-1935;P4=-3891;P5=-9203;D=2523242324/23242323232
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=507;P3=-1935;P4=-3891;P5=-9203;D=252324232423242323232/323232423242
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=507;P3=-1935;P4=-3891;P5=-9203;D=252324232423242323232323232423242/323232
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=507;P3=-1935;P4=-3891;P5=-9203;D=252324232423242323232323232423242323232/323242323242
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=507;P3=-1935;P4=-3891;P5=-9203;D=252324232423242323232323232423242323232323242323242/324242323242
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=507;P3=-1935;P4=-3891;P5=-9203;D=252324232423242323232323232423242323232323242323242324242323242/32323242423;
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=507;P3=-1935;P4=-3891;P5=-9203;D=25232423242324232323232323242324232323232324232324232424232324232323242423;/CP=2;
2015.10.24 11:04:22 5: SIGNALduino/RAW READ: MS;P2=507;P3=-1935;P4=-3891;P5=-9203;D=25232423242324232323232323242324232323232324232324232424232324232323242423;CP=2;/SP=5;O;
Ist ja interessant was so alles gefunden wird  :-)  Habe  leider kein Einhell garagentor .  aber kann es sein das sich im letzten abschnitt meine Wetterstation   WS  1000  oder so  meldet ?
Gruss Markus
Cubietruck
2*Raspi  Rev B
Cubietruck,
hjgode
Hallo
mal was anderes: Hier steht noch im Raum den SIGNALDuino über Netzwerk zu betreiben. Ich habe da vielleicht einen Hinweis auf eine simple Lösung mit zwei ESP8266 (WiFi) als Wirelss-Serial-Bridge mit der ESP firmware esp-link von JeeLabs: https://github.com/jeelabs/esp-link
Die Lösung würde, soweit ich das überblicke, keine Änderung am Code des SIGNALDuino oder in FHEM erfordern. Am SIGNALDuino Nano würde die Ein-Ausgabe weiterhin seriell erfolgen. Das gleiche gilt für die Anbeindung eines ESP8266 am FHEM Server,
FHEM Server <=> serial<->ESP8266< ~ ~ Wireless ~ ~ >ESP8266<->serial<=>SignalDuino Nano
Die JeeLabs esp-link Software erlaubt sogar das Flashen des Nano über WiFi (und reflash des ESP8266)...
Leider habe ich derzeit andere Baustellen, aber zumindest konnte ich esp-link nach Anleitung kompilieren. Das war mir bei einer anderen Serial-ESP8266 Lösung (ESP8266-transparent-bridge) leider nicht möglich.
Hardware-technisch kann man den ESP8266 nicht direkt seriell an den PC anschliessen, dazu braicht es noch einen Pegel-Wandler, das Ding arbeitet zum einen mit Digital RX/TX und zum anderen mit 3,3V. Am Signalduino Nano wäre nur ein Widerstandsnetzwerk für Nano-TX nach ESP8266-RX nötig, um dafür zu soregn, dass der ESP8266 3,3V komaptible TTL Level bekommt (und nicht etwa 3,7V für High).
Josef
Sidey
Hi Balki,
solange die Nachricht nicht an ein anderes Modul weitergegeben wurde (z.B. Einhell) wurde das Signal auch nicht empfangen.
Die Logmeldung found matches protocol besagt nur, dass gewisse Kriterien zutreffen.
Zur WS 1000 kann ich jetzt nichts sagen. Hast Du dazu etwas mehr Informationen?
Wurde denn ein Gerät vom TYP TCM_97001 angelegt?
Grüße Sidey
Sidey
Huhu,
Zitat von: hjgode am 24 Oktober 2015, 19:59:26
Hallo
Den Ansatz mit dem ESP8266 finde ich auch am besten.
1. Man benötigt kein LAN Kabel
2. Übergibt man alles Seriell an den ESP8266.
Man kann meiner Meinung nach auf den 2. ESP8266 verzichten und FHEM direkt die IP-Adresse des SIGNALduino+ESP8266 adressieren.
Dann geht zwar ota flash nicht, sobald ich die Firmware mal endlich fertig habe, sollte das auch kaum mehr notwendig sein.
Die paar AT Befehle zum Initialisieren der Verbindung kann man in den SIGNALduino leicht einbauen.
Ich habe aber keinen ESP8266 um es mal zu probieren :(
Grüße Sidey
balki
#473
Hallo Sidey
Sorry mir ist der  Arduino abgeraucht  kommt Montag , Dienstag erst  neu  ..
Aber ich denke  das  es  dieses device ist  ..
CODE
Unknown
CUL_1_MSGCNT
39
CUL_1_RAWMSG
s1EA09696F7
CUL_1_TIME
2015-10-24 23:39:58
DEF
Unknown
LASTInputDev
CUL_1
MSGCNT
39
NAME
CUL_TCM97001_Unknown
NR
204
RSSI
-78.5
STATE
Code: 1EA09696
TYPE
CUL_TCM97001
lastH
0
lastT
1445722798
Readings
state
Code: 1EA09696
2015-10-24 23:39:58
Hoffe du kannst damit was anfangen ( ist vom FHEMDuino) Upps  kommt vom 433er Cul  ..  sorry
Gruss Markus
Cubietruck
2*Raspi  Rev B
Cubietruck,
Kuzl
#474
Bezüglich ESP8266:
Hier ist im Prinzip das gleiche nur mit einem CUL. http://forum.fhem.de/index.php/topic,42998.0/topicseen.html An den dort verwendeten Sketch hatte ich gedacht.
Der sollte dann eigentlich so funktionieren, wie gedacht. Warum das bei Josef nicht fehlerfrei kompiliert hat, kann ich leider nicht sagen. Allerdings sollte es reichen, die beiden Bin-Files einfach zu flashen, ohne irgendwas kompilieren zu müssen.
hjgode
Hallo Kuzl
der Code unter https://github.com/beckdac/ESP8266-transparent-bridge ließ sich auf meinem System nicht überreden. Das sind wahrscheinlich zu viele Abhängigkeiten mit externen Libs etc. vorhanden die nicht klar dokumentiert sind.
Der Code unter https://github.com/jeelabs/esp-link hat natürlich auch Abhängigkeiten, diese sind aber klar definiert. Den Code der Version 1.0.4 habe ich nun auf einem ESP-01 laufen.
Die serielle Bridge funktioniert auch (also zur Zeit USB-Serial<=>Telnet). Vielleicht komme ich die nächsten Tage dazu einen SignalDuino dranzuhängen. Sollte kein Problem sein: 5V an den Nano und einen LM117, TX an RX und Rx an TX und gut is.
Der ESP-01 hat 'nur' zwei freie GPIO (GPIO0 und GPIO2). Daran hängen für den Code aber zwei LEDs, die der ESP-01 eh schon hat (für Power und Aktivität). Vielleicht kann man statt GPIO12 und GPIO13 die Anschlüsse GPIO0 und GPIO2 nutzen. Ist so aber zur Zeit unter esp-link nicht vorgesehen. Wenn nicht, würde die Flash Arduino over-the-air Option wegfallen.
Zur Anbindung eines Nano über WiFi muss man nur ein ESP-01 (oder besser) haben, die esp-link Software und dann sollte das gehen. Bietet zwar keine +++AT Befehle, läßt sich dafür aber über Web managen.
bis dann
~josef
Kuzl
Hallo Josef,
du musst für die transparent-bridge gar nichts kompilieren. Einfach die beiden *.bin Files unter /firmware auf den ESP flashen (mit dem ESPFlashTool).
Aber wenn ich das richtig sehe, hat der esp-link genau die gleiche funktionalität oder? Bei der Bridge ist es so, dass man über Telnet die AT Befehle eingeben kann um z.b. den Accesspoint einzustellen.
Ich bin gespannt, was bei dir rauskommt :) ich hoffe meine kommen jetzt dann mal aus China an.
Kuzl
Sidey
Hi zusammen,
das umschalten ob ein ESP dran hängt, könnte man tatsächlich über einen Jumper realisieren. Daran hatte ich noch nicht gedacht.. gute Idee.
Jetzt aber mal zum Thema Version 3.2. Die Entwicklung kann so langsam beginnen finde ich.
Ich habe heute mal dafür einen neuen Entwicklungszweig erstellt. Was in 3.2 alles enthalten sein wird, weiss ich noch nicht. Es muss kein wahnsinnig großes Update sein, aber hier mal ein paar Ideen:
Module:
- Verbesserte Whitelist, Ralf hat da schon was vorgearbeitet
- ggf. dynamische Match und Clientlist (bin mir noch nicht sicher)
- Aufnahme neue Protokolle, OSV3 und noch zwei andere.
- eventuell Etablieren eines generischen devices für alles, was nicht spezifisch implementiert wurde.
- Verbessertes Handling, wenn auf eine get Nachricht auch eine "normale" Datenübermittlung erfolgt.
Firmware:
- Codereduzierung durch Umstellen von der spezifischen Sendefunktionen zur raw_send Funktion.
- Migration von Speicherallokierung heap -> Stack
- Ein paar Speicheroptimierungen
- Vergleich mehrerer MS Meldungen und Weitergabe wenn zwei oder mehr gleiche empfangen wurden.
Was fällt euch denn noch so für Version 3.2 ein?
Grüße Sidey
Sidey
#478
Zitat von: carlos am 22 Oktober 2015, 09:31:49
Ich habe dir mal einen kompletten log Mitschnitt geschickt.
Ich habe da zuvor ein update gemacht und auf 3.1.8 geflashed.
Wenn ich mich recht erinnere habe ich in der Zeit nur die LEDs ein paar mal ein und ausgeschaltet.
Hallo Carlos,
ich habe die Demodulation eingebaut.
Wenn Du die Taste an der FB drückst, sollten folgende Einträge in deinem Log (mind. verbose 4) erscheinen, aus denen Du entnehmen kannst, wie die Bits umgerechnet wurden.
2015.10.27 00:01:11 4: SIGNALduino_unknown converted to bits: 010001011010000001101011
2015.10.27 00:01:11 4: SIGNALduino_unknown Protocol: 25
2015.10.27 00:01:11 4: SIGNALduino_unknown rawData: 45A06B
2015.10.27 00:01:11 4: SIGNALduino_unknown incomming msg: u25#45A06B
2015.10.27 00:01:11 5: devSduino dispatch u25#45A06B
2015.10.27 00:01:11 5: converted Data to (u25#45A06B)
2015.10.27 00:01:11 5: Found wrong signal, aborting demodulation
2015.10.27 00:01:11 5: Starting demodulation at Position 3
2015.10.27 00:01:11 4: Found matched Protocol id 25 -> les led remote
2015.10.27 00:01:11 4: SIGNALduino/msg READ: MS;P0=-376;P1=697;P2=-726;P3=322;P4=-13188;P5=-15982;D=3530123010101230123230123010101010101232301230123234301230101012301232301230101010101012323012301232;CP=3;SP=5;O;
Drücke ein paar mal  eine der Tasten und vergleiche, ob die Bits immer gleich erkannt werden.
Anschließend kannst Du das mit der anderen Taste wiederholen.
Wenn die gleiche Taste immer gleich demoduliert wird, kannst Du dann erkennen, welche bits die Taste definieren.
Das kannst Du gerne noch mal posten.
Achso, Du musst vorher auf die aktuelle Entwicklungs Version updaten:
update all https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/dev-r32/controls_signalduino.txt
Grüße Sidey
carlos
Hallo Sidey,
Vielen Dank für deine Arbeit.
Ich habe mal das update gemacht inclusive firmware flash.
Folgendes log:
2015.10.28 07:02:04 5: Signalduino: command for gets: V
2015.10.28 07:02:04 5: SW: V
2015.10.28 07:02:04 5: SIGNALduino/RAW (ReadAnswer): V 3.1.8-HF1 SIGNALduino - compiled at Oct 26 2015
2015.10.28 07:02:04 5: SIGNALduino/RAW (ReadAnswer): 11:10:38
2015.10.28 07:02:04 5: Signalduino: received message for gets: V 3.1.8-HF1 SIGNALduino - compiled at Oct 26 2015 11:10:38
2015.10.28 07:02:33 5: SIGNALduino/RAW READ: /MU;P0=-42
2015.10.28 07:02:33 5: SIGNALduino/RAW READ: MU;P0=-42/0;P2=241;P3=596;P4
2015.10.28 07:02:33 5: SIGNALduino/RAW READ: MU;P0=-420;P2=241;P3=596;P4/=-705;P5=39
2015.10.28 07:02:33 5: SIGNALduino/RAW READ: MU;P0=-420;P2=241;P3=596;P4=-705;P5=39/2;D=00203420303034
2015.10.28 07:02:33 5: SIGNALduino/RAW READ: MU;P0=-420;P2=241;P3=596;P4=-705;P5=392;D=00203420303034/203424
2015.10.28 07:02:33 5: SIGNALduino/RAW READ: MU;P0=-420;P2=241;P3=596;P4=-705;P5=392;D=00203420303034203424/203420303030303034
2015.10.28 07:02:33 5: SIGNALduino/RAW READ: MU;P0=-420;P2=241;P3=596;P4=-705;P5=392;D=00203420303034203424203420303030303034/24203034245
2015.10.28 07:02:33 5: SIGNALduino/RAW READ: MU;P0=-420;P2=241;P3=596;P4=-705;P5=392;D=0020342030303420342420342030303030303424203034245/0;CP=2;
2015.10.28 07:02:33 4: SIGNALduino/msg READ: MU;P0=-420;P2=241;P3=596;P4=-705;P5=392;D=00203420303034203424203420303030303034242030342450;CP=2;
2015.10.28 07:02:33 4: Found matched Protocol id 8 -> TX3 Protocol
2015.10.28 07:02:33 5: Starting demodulation at Position -1
2015.10.28 07:02:33 4: Found matched Protocol id 16 -> Dooya shutter
2015.10.28 07:02:33 5: Starting demodulation at Position 5
2015.10.28 07:02:33 5: restarting demodulation at Position 11+2
2015.10.28 07:02:33 5: restarting demodulation at Position 15+2
2015.10.28 07:02:33 5: restarting demodulation at Position 21+2
2015.10.28 07:02:33 5: restarting demodulation at Position 35+2
2015.10.28 07:02:33 5: restarting demodulation at Position 43+2
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: /MS;
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;/P0=298;P1=-13079;P2=-380
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=298;P1=-13079;P2=-380/;P3=652;P4=-
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=298;P1=-13079;P2=-380;P3=652;P4=-/722;P5=-15856;D=0
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=298;P1=-13079;P2=-380;P3=652;P4=-722;P5=-15856;D=0/502340232323402340
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=298;P1=-13079;P2=-380;P3=652;P4=-722;P5=-15856;D=0502340232323402340/402340232323232323404023
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=298;P1=-13079;P2=-380;P3=652;P4=-722;P5=-15856;D=0502340232323402340402340232323232323404023/23402
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=298;P1=-13079;P2=-380;P3=652;P4=-722;P5=-15856;D=050234023232340234040234023232323232340402323402/340102340232323402
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=298;P1=-13079;P2=-380;P3=652;P4=-722;P5=-15856;D=050234023232340234040234023232323232340402323402340102340232323402/340402340232323232
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=298;P1=-13079;P2=-380;P3=652;P4=-722;P5=-15856;D=050234023232340234040234023232323232340402323402340102340232323402340402340232323232/3234040232340234;
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=298;P1=-13079;P2=-380;P3=652;P4=-722;P5=-15856;D=0502340232323402340402340232323232323404023234023401023402323234023404023402323232323234040232340234;/CP=0;SP=5;O;
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=298;P1=-13079;P2=-380;P3=652;P4=-722;P5=-15856;D=0502340232323402340402340232323232323404023234023401023402323234023404023402323232323234040232340234;CP=0;SP=5;O;/
2015.10.28 07:02:34 4: SIGNALduino/msg READ: MS;P0=298;P1=-13079;P2=-380;P3=652;P4=-722;P5=-15856;D=0502340232323402340402340232323232323404023234023401023402323234023404023402323232323234040232340234;CP=0;SP=5;O;
2015.10.28 07:02:34 4: Found matched Protocol id 20 -> livolo
2015.10.28 07:02:34 5: Starting demodulation at Position 20
2015.10.28 07:02:34 5: Found wrong signal, aborting demodulation
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: /MS;P0
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0/=-715;P1=308
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308/;P2=-3
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-3/65;P3=665;P4=-158
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-158/45;P5=
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=/-13058;D=151
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=151/230123
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=151230123/232301
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=151230123232301/23010123012323232
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=15123012323230123010123012323232/323230101232
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=15123012323230123010123012323232323230101232/301230
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=15123012323230123010123012323232323230101232301230/141230
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=15123012323230123010123012323232323230101232301230141230/123232301230101230
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=15123012323230123010123012323232323230101232301230141230123232301230101230/12323
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=1512301232323012301012301232323232323010123230123014123012323230123010123012323/232323230101
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=1512301232323012301012301232323232323010123230123014123012323230123010123012323232323230101/232301230;CP=1;SP=
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=1512301232323012301012301232323232323010123230123014123012323230123010123012323232323230101232301230;CP=1;SP=/5;O;
2015.10.28 07:02:34 4: SIGNALduino/msg READ: MS;P0=-715;P1=308;P2=-365;P3=665;P4=-15845;P5=-13058;D=1512301232323012301012301232323232323010123230123014123012323230123010123012323232323230101232301230;CP=1;SP=5;O;
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;/P0=662;P1=-3
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-3/68;P2=
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=/-713;P3=313;P4=-1
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-1/3069;P
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P/5=-158
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-158/54;D=3531023101010
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-15854;D=3531023101010/23102323102
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-15854;D=353102310101023102323102/310101
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-15854;D=353102310101023102323102310101/010101
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-15854;D=353102310101023102323102310101010101/023231010231023431
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-15854;D=353102310101023102323102310101010101023231010231023431/023101
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-15854;D=353102310101023102323102310101010101023231010231023431023101/010231023231
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-15854;D=353102310101023102323102310101010101023231010231023431023101010231023231/02310101010101023
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-15854;D=35310231010102310232310231010101010102323101023102343102310101023102323102310101010101023/231010
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-15854;D=35310231010102310232310231010101010102323101023102343102310101023102323102310101010101023231010/23102;
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-15854;D=3531023101010231023231023101010101010232310102310234310231010102310232310231010101010102323101023102;/CP=3;SP=5;O;
2015.10.28 07:02:34 4: SIGNALduino/msg READ: MS;P0=662;P1=-368;P2=-713;P3=313;P4=-13069;P5=-15854;D=3531023101010231023231023101010101010232310102310234310231010102310232310231010101010102323101023102;CP=3;SP=5;O;
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: /MS;P0=-
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-/720;P1
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1/=303;P2=-369
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369/;P3=664;P4=-
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-/15862;P5=-1
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-1/3082;D
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D/=15123
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=15123/012323230123010123
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=15123012323230123010123/012323232323
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=15123012323230123010123012323232323/23010
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=1512301232323012301012301232323232323010/123230
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=1512301232323012301012301232323232323010123230/123014123012323230
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=1512301232323012301012301232323232323010123230123014123012323230/123010
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=1512301232323012301012301232323232323010123230123014123012323230123010/123012323232
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=1512301232323012301012301232323232323010123230123014123012323230123010123012323232/32323010123230123
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=151230123232301230101230123232323232301012323012301412301232323012301012301232323232323010123230123/0;CP=1
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=1512301232323012301012301232323232323010123230123014123012323230123010123012323232323230101232301230;CP=1/;SP=5;
2015.10.28 07:02:34 5: SIGNALduino/RAW READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=1512301232323012301012301232323232323010123230123014123012323230123010123012323232323230101232301230;CP=1;SP=5;/
2015.10.28 07:02:34 4: SIGNALduino/msg READ: MS;P0=-720;P1=303;P2=-369;P3=664;P4=-15862;P5=-13082;D=1512301232323012301012301232323232323010123230123014123012323230123010123012323232323230101232301230;CP=1;SP=5;
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: /MS;P0=-728;P1=294;P2=-378;P3=651;P4=-15832;P5=-13064;D=1512301232323012301012301232323232323010123012301014123012323230123010123012323232323230101230123010;CP=1;SP=5;O;
MS;P0=312;P1=-371;P2=660;P3=-711;P4=-15839;P5=-13056;D=0501230121212301230301230121
2015.10.28 07:02:45 4: SIGNALduino/msg READ: MS;P0=-728;P1=294;P2=-378;P3=651;P4=-15832;P5=-13064;D=1512301232323012301012301232323232323010123012301014123012323230123010123012323232323230101230123010;CP=1;SP=5;O;
2015.10.28 07:02:45 4: Found matched Protocol id 20 -> livolo
2015.10.28 07:02:45 5: Starting demodulation at Position 20
2015.10.28 07:02:45 5: Found wrong signal, aborting demodulation
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=312;P1=-371;P2=660;P3=-711;P4=-15839;P5=-13056;D=0501230121212301230301230121/212121212303012301230304012301212123012303012301212121212123030123012303;CP=0;SP=5;O;
MS;P0=-364;P1=665;P2=-716;P3=309;P4=-13070;P5=-15856;D=3530123010101230123230123010101010101232301230123234301230101012301232301230101010101012323012301232;CP=3;SP=5;O
2015.10.28 07:02:45 4: SIGNALduino/msg READ: MS;P0=312;P1=-371;P2=660;P3=-711;P4=-15839;P5=-13056;D=0501230121212301230301230121212121212303012301230304012301212123012303012301212121212123030123012303;CP=0;SP=5;O;
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-364;P1=665;P2=-716;P3=309;P4=-13070;P5=-15856;D=3530123010101230123230123010101010101232301230123234301230101012301232301230101010101012323012301232;CP=3;SP=5;O/;
MS;P0=663;P1=-714;P2=308;P3=-369;P5=-13076;D=2523012303030123012123012303030303030121230123012121;CP=2;SP=5;
MU;P0=-787;P1=-446;P2=234;P3=559;P4=-612;D=01213421313130213020213021313131313130202133;CP=2;
MS;P0=-726;P1=296;P2=-381;P3=649;P4=-15844;P
2015.10.28 07:02:45 4: SIGNALduino/msg READ: MS;P0=-364;P1=665;P2=-716;P3=309;P4=-13070;P5=-15856;D=3530123010101230123230123010101010101232301230123234301230101012301232301230101010101012323012301232;CP=3;SP=5;O;
2015.10.28 07:02:45 4: SIGNALduino/msg READ: MS;P0=663;P1=-714;P2=308;P3=-369;P5=-13076;D=2523012303030123012123012303030303030121230123012121;CP=2;SP=5;
2015.10.28 07:02:45 4: SIGNALduino/msg READ: MU;P0=-787;P1=-446;P2=234;P3=559;P4=-612;D=01213421313130213020213021313131313130202133;CP=2;
2015.10.28 07:02:45 4: Found matched Protocol id 8 -> TX3 Protocol
2015.10.28 07:02:45 5: Starting demodulation at Position 12
2015.10.28 07:02:45 5: restarting demodulation at Position 14+2
2015.10.28 07:02:45 5: restarting demodulation at Position 20+2
2015.10.28 07:02:45 5: restarting demodulation at Position 34+2
2015.10.28 07:02:45 4: Found matched Protocol id 16 -> Dooya shutter
2015.10.28 07:02:45 5: Starting demodulation at Position 13
2015.10.28 07:02:45 5: restarting demodulation at Position 15+2
2015.10.28 07:02:45 5: restarting demodulation at Position 21+2
2015.10.28 07:02:45 5: restarting demodulation at Position 35+2
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-726;P1=296;P2=-381;P3=649;P4=-15844;P/5=-13078;D=1512301232323012301012301232323232323010123012301014123012323230123010123012323232323230101230123010;CP=1;SP=5;O;
2015.10.28 07:02:45 4: SIGNALduino/msg READ: MS;P0=-726;P1=296;P2=-381;P3=649;P4=-15844;P5=-13078;D=1512301232323012301012301232323232323010123012301014123012323230123010123012323232323230101230123010;CP=1;SP=5;O;
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: /MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=/050123012121230123030123
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=050123012121230123030123/01212121212
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=05012301212123012303012301212121212/123030123012303040
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=05012301212123012303012301212121212123030123012303040/123012
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=05012301212123012303012301212121212123030123012303040123012/121230
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=05012301212123012303012301212121212123030123012303040123012121230/123030123012121212
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=05012301212123012303012301212121212123030123012303040123012121230123030123012121212/12123
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=0501230121212301230301230121212121212303012301230304012301212123012303012301212121212123/030123012303
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=0501230121212301230301230121212121212303012301230304012301212123012303012301212121212123030123012303/;CP=0;
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=0501230121212301230301230121212121212303012301230304012301212123012303012301212121212123030123012303;CP=0;/SP=5;O;
2015.10.28 07:02:45 4: SIGNALduino/msg READ: MS;P0=304;P1=-371;P2=657;P3=-717;P4=-15855;P5=-13068;D=0501230121212301230301230121212121212303012301230304012301212123012303012301212121212123030123012303;CP=0;SP=5;O;
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=/-367;P
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P/1=667;P2=-71
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-71/8;P3=
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=/306;P4
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4/=-13077;P5=-
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-/15870;D=3530
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=3530/123010101230
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=3530123010101230/12323
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=353012301010123012323/012301010101
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=353012301010123012323012301010101/010123
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=353012301010123012323012301010101010123/230123
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=353012301010123012323012301010101010123230123/012323430123
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=353012301010123012323012301010101010123230123012323430123/010101
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=353012301010123012323012301010101010123230123012323430123010101/230123
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=353012301010123012323012301010101010123230123012323430123010101230123/23012301010
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=35301230101012301232301230101010101012323012301232343012301010123012323012301010/101010123230123012
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=35301230101012301232301230101010101012323012301232343012301010123012323012301010101010123230123012/32;CP=
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=3530123010101230123230123010101010101232301230123234301230101012301232301230101010101012323012301232;CP=/3;SP=5
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=3530123010101230123230123010101010101232301230123234301230101012301232301230101010101012323012301232;CP=3;SP=5/;O;
2015.10.28 07:02:45 4: SIGNALduino/msg READ: MS;P0=-367;P1=667;P2=-718;P3=306;P4=-13077;P5=-15870;D=3530123010101230123230123010101010101232301230123234301230101012301232301230101010101012323012301232;CP=3;SP=5;O;
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: /MS;P0=662;P1
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1/=-723;
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1=-723;/P2=300
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1=-723;P2=300/;P3=-372;P5
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1=-723;P2=300;P3=-372;P5/=-1308
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1=-723;P2=300;P3=-372;P5=-1308/8;D=25230123030301
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1=-723;P2=300;P3=-372;P5=-13088;D=25230123030301/230121
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1=-723;P2=300;P3=-372;P5=-13088;D=25230123030301230121/23012303030
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1=-723;P2=300;P3=-372;P5=-13088;D=2523012303030123012123012303030/303030
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1=-723;P2=300;P3=-372;P5=-13088;D=2523012303030123012123012303030303030/121230
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1=-723;P2=300;P3=-372;P5=-13088;D=2523012303030123012123012303030303030121230/123012121;CP
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1=-723;P2=300;P3=-372;P5=-13088;D=2523012303030123012123012303030303030121230123012121;CP/=2;SP=
2015.10.28 07:02:45 5: SIGNALduino/RAW READ: MS;P0=662;P1=-723;P2=300;P3=-372;P5=-13088;D=2523012303030123012123012303030303030121230123012121;CP=2;SP=/5;
2015.10.28 07:02:45 4: SIGNALduino/msg READ: MS;P0=662;P1=-723;P2=300;P3=-372;P5=-13088;D=2523012303030123012123012303030303030121230123012121;CP=2;SP=5;
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: /MU;P0=581
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MU;P0=581/;P1=764;P2=-
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MU;P0=581;P1=764;P2=-/797;P3=247;P4=-49
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MU;P0=581;P1=764;P2=-797;P3=247;P4=-49/3;D=01234040402340
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MU;P0=581;P1=764;P2=-797;P3=247;P4=-493;D=01234040402340/232340
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MU;P0=581;P1=764;P2=-797;P3=247;P4=-493;D=01234040402340232340/234040404040402323
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MU;P0=581;P1=764;P2=-797;P3=247;P4=-493;D=01234040402340232340234040404040402323/404023432;CP=3;
2015.10.28 07:02:49 4: SIGNALduino/msg READ: MU;P0=581;P1=764;P2=-797;P3=247;P4=-493;D=01234040402340232340234040404040402323404023432;CP=3;
2015.10.28 07:02:49 4: Found matched Protocol id 8 -> TX3 Protocol
2015.10.28 07:02:49 5: Starting demodulation at Position 1
2015.10.28 07:02:49 4: Found matched Protocol id 16 -> Dooya shutter
2015.10.28 07:02:49 5: Starting demodulation at Position 2
2015.10.28 07:02:49 5: restarting demodulation at Position 8+2
2015.10.28 07:02:49 5: restarting demodulation at Position 12+2
2015.10.28 07:02:49 5: restarting demodulation at Position 18+2
2015.10.28 07:02:49 5: restarting demodulation at Position 32+2
2015.10.28 07:02:49 5: restarting demodulation at Position 40+2
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: /MS;P0=297
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297/;P1=-724;P2=-1308
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-1308/9;P3=-
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-/379;P4=649;P5=-158
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-158/68;D=0
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-15868;D=0/50341034343410341
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-15868;D=050341034343410341/010341034343434343
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-15868;D=050341034343410341010341034343434343/410103
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-15868;D=050341034343410341010341034343434343410103/434103410203410343
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-15868;D=050341034343410341010341034343434343410103434103410203410343/43410
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-15868;D=05034103434341034101034103434343434341010343410341020341034343410/341010341034343434
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-15868;D=05034103434341034101034103434343434341010343410341020341034343410341010341034343434/343410
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-15868;D=05034103434341034101034103434343434341010343410341020341034343410341010341034343434343410/10343410341;CP=0;S
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-15868;D=0503410343434103410103410343434343434101034341034102034103434341034101034103434343434341010343410341;CP=0;S/P=5;O
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-15868;D=0503410343434103410103410343434343434101034341034102034103434341034101034103434343434341010343410341;CP=0;SP=5;O/;
2015.10.28 07:02:49 4: SIGNALduino/msg READ: MS;P0=297;P1=-724;P2=-13089;P3=-379;P4=649;P5=-15868;D=0503410343434103410103410343434343434101034341034102034103434341034101034103434343434341010343410341;CP=0;SP=5;O;
2015.10.28 07:02:49 4: Found matched Protocol id 20 -> livolo
2015.10.28 07:02:49 5: Starting demodulation at Position 20
2015.10.28 07:02:49 5: Found wrong signal, aborting demodulation
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P/0=-715;P1=308;P2=-
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-/364;P3
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-364;P3/=666;P4=-15868;P5=
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-364;P3=666;P4=-15868;P5=/-13074;D=15
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-364;P3=666;P4=-15868;P5=-13074;D=15/123012323230
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-364;P3=666;P4=-15868;P5=-13074;D=15123012323230/123010123012323232
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-364;P3=666;P4=-15868;P5=-13074;D=15123012323230123010123012323232/323230
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-364;P3=666;P4=-15868;P5=-13074;D=15123012323230123010123012323232323230/10123230123014123
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-364;P3=666;P4=-15868;P5=-13074;D=1512301232323012301012301232323232323010123230123014123/012323230123010123
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-364;P3=666;P4=-15868;P5=-13074;D=1512301232323012301012301232323232323010123230123014123012323230123010123/012323
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-364;P3=666;P4=-15868;P5=-13074;D=1512301232323012301012301232323232323010123230123014123012323230123010123012323/23232323010123230
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-364;P3=666;P4=-15868;P5=-13074;D=151230123232301230101230123232323232301012323012301412301232323012301012301232323232323010123230/1230;C
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=-715;P1=308;P2=-364;P3=666;P4=-15868;P5=-13074;D=1512301232323012301012301232323232323010123230123014123012323230123010123012323232323230101232301230;C/P=1;SP=5;O;
2015.10.28 07:02:49 4: SIGNALduino/msg READ: MS;P0=-715;P1=308;P2=-364;P3=666;P4=-15868;P5=-13074;D=1512301232323012301012301232323232323010123230123014123012323230123010123012323232323230101232301230;CP=1;SP=5;O;
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS/;P0=665;P1=-362;P2
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2/=-712;
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;/P3=312;P4=-13084;
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;/P5=-15
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;P5=-15/872;D=353102310101
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;P5=-15872;D=353102310101/023102
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;P5=-15872;D=353102310101023102/323102310101010101
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;P5=-15872;D=353102310101023102323102310101010101/02323101023102343
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;P5=-15872;D=35310231010102310232310231010101010102323101023102343/102310
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;P5=-15872;D=35310231010102310232310231010101010102323101023102343102310/101023102323102310
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;P5=-15872;D=35310231010102310232310231010101010102323101023102343102310101023102323102310/101010
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;P5=-15872;D=35310231010102310232310231010101010102323101023102343102310101023102323102310101010/10102323101023102
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;P5=-15872;D=3531023101010231023231023101010101010232310102310234310231010102310232310231010101010102323101023102/;CP=3;SP=5;O
2015.10.28 07:02:49 5: SIGNALduino/RAW READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;P5=-15872;D=3531023101010231023231023101010101010232310102310234310231010102310232310231010101010102323101023102;CP=3;SP=5;O/;
2015.10.28 07:02:49 4: SIGNALduino/msg READ: MS;P0=665;P1=-362;P2=-712;P3=312;P4=-13084;P5=-15872;D=3531023101010231023231023101010101010232310102310234310231010102310232310231010101010102323101023102;CP=3;SP=5;O;
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: /M
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: M/S;P0=
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=/-348;P
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P/1=663;P2=-71
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-71/8;P3=3
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=3/27;P4=-15884;P5=-1
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-1/3088;D
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D/=3530123010
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=3530123010/101230
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=3530123010101230/123230
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=3530123010101230123230/123010101010
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=3530123010101230123230123010101010/101232
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=3530123010101230123230123010101010101232/301012
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=3530123010101230123230123010101010101232301012/30123430123010101
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=353012301010123012323012301010101010123230101230123430123010101/230123230123
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=353012301010123012323012301010101010123230101230123430123010101230123230123/010101
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=353012301010123012323012301010101010123230101230123430123010101230123230123010101/010101
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=353012301010123012323012301010101010123230101230123430123010101230123230123010101010101/232301012301
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=353012301010123012323012301010101010123230101230123430123010101230123230123010101010101232301012301/2;CP=3
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=3530123010101230123230123010101010101232301012301234301230101012301232301230101010101012323010123012;CP=3/;SP=5
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=3530123010101230123230123010101010101232301012301234301230101012301232301230101010101012323010123012;CP=3;SP=5/;O;
2015.10.28 07:02:50 4: SIGNALduino/msg READ: MS;P0=-348;P1=663;P2=-718;P3=327;P4=-15884;P5=-13088;D=3530123010101230123230123010101010101232301012301234301230101012301232301230101010101012323010123012;CP=3;SP=5;O;
2015.10.28 07:02:50 4: Found matched Protocol id 20 -> livolo
2015.10.28 07:02:50 5: Starting demodulation at Position 20
2015.10.28 07:02:50 5: Found wrong signal, aborting demodulation
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: /MS;
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;/P0=663
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663/;P1=-719;P2=
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663;P1=-719;P2=/304;P3
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663;P1=-719;P2=304;P3/=-368;P4=-1
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663;P1=-719;P2=304;P3=-368;P4=-1/3096;D
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663;P1=-719;P2=304;P3=-368;P4=-13096;D/=24230123030301230
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663;P1=-719;P2=304;P3=-368;P4=-13096;D=24230123030301230/121230
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663;P1=-719;P2=304;P3=-368;P4=-13096;D=24230123030301230121230/123030
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663;P1=-719;P2=304;P3=-368;P4=-13096;D=24230123030301230121230123030/30303030121
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663;P1=-719;P2=304;P3=-368;P4=-13096;D=2423012303030123012123012303030303030121/230301
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663;P1=-719;P2=304;P3=-368;P4=-13096;D=2423012303030123012123012303030303030121230301/230121;CP=2;
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663;P1=-719;P2=304;P3=-368;P4=-13096;D=2423012303030123012123012303030303030121230301230121;CP=2;/SP=4;
2015.10.28 07:02:50 5: SIGNALduino/RAW READ: MS;P0=663;P1=-719;P2=304;P3=-368;P4=-13096;D=2423012303030123012123012303030303030121230301230121;CP=2;SP=4;/
2015.10.28 07:02:50 4: SIGNALduino/msg READ: MS;P0=663;P1=-719;P2=304;P3=-368;P4=-13096;D=2423012303030123012123012303030303030121230301230121;CP=2;SP=4;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: /MS;P0
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0/=251;P1=590;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=251;P1=590;/P2=-7
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=251;P1=590;P2=-7/87;P4=-437;P5=-131
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=251;P1=590;P2=-787;P4=-437;P5=-131/12;D=0
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=251;P1=590;P2=-787;P4=-437;P5=-13112;D=0/504120414141
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=251;P1=590;P2=-787;P4=-437;P5=-13112;D=0504120414141/20412020412
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=251;P1=590;P2=-787;P4=-437;P5=-13112;D=050412041414120412020412/041414141414120204
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=251;P1=590;P2=-787;P4=-437;P5=-13112;D=050412041414120412020412041414141414120204/120412
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=251;P1=590;P2=-787;P4=-437;P5=-13112;D=050412041414120412020412041414141414120204120412/0202;CP=0;SP=5;
2015.10.28 07:02:55 4: SIGNALduino/msg READ: MS;P0=251;P1=590;P2=-787;P4=-437;P5=-13112;D=0504120414141204120204120414141414141202041204120202;CP=0;SP=5;
2015.10.28 07:02:55 4: Found matched Protocol id 20 -> livolo
2015.10.28 07:02:55 5: Starting demodulation at Position 20
2015.10.28 07:02:55 5: Found wrong signal, aborting demodulation
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS/;P0=29
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=29/4;P1=-
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-/381;P2=650;P
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P/3=-727
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727/;P4=-13076;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;/P5=-15842;D=
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=/050123012121230123
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=050123012121230123/03012301212121212
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=05012301212123012303012301212121212/123030
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=05012301212123012303012301212121212123030/123012303040
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=05012301212123012303012301212121212123030123012303040/123012
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=05012301212123012303012301212121212123030123012303040123012/121230
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=05012301212123012303012301212121212123030123012303040123012121230/123030123012
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=05012301212123012303012301212121212123030123012303040123012121230123030123012/121212
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=05012301212123012303012301212121212123030123012303040123012121230123030123012121212/12123
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=0501230121212301230301230121212121212303012301230304012301212123012303012301212121212123/030123012303
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=0501230121212301230301230121212121212303012301230304012301212123012303012301212121212123030123012303/;CP=0;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=0501230121212301230301230121212121212303012301230304012301212123012303012301212121212123030123012303;CP=0;/SP=5;O;
2015.10.28 07:02:55 4: SIGNALduino/msg READ: MS;P0=294;P1=-381;P2=650;P3=-727;P4=-13076;P5=-15842;D=0501230121212301230301230121212121212303012301230304012301212123012303012301212121212123030123012303;CP=0;SP=5;O;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: /MS;P0=-36
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-36/5;P1=6
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=6/63;P2=-714;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;/P3=308
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308/;P4=-1
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-1/3078;P5=-158
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-158/56;D=3
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=3/530123
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=3530123/010101230123
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=3530123010101230123/23012
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=353012301010123012323012/301010101010123230
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=353012301010123012323012301010101010123230/123012
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=353012301010123012323012301010101010123230123012/323430123010
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=353012301010123012323012301010101010123230123012323430123010/10123
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=35301230101012301232301230101010101012323012301232343012301010123/012323
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=35301230101012301232301230101010101012323012301232343012301010123012323/012301010101
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=35301230101012301232301230101010101012323012301232343012301010123012323012301010101/010123
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=35301230101012301232301230101010101012323012301232343012301010123012323012301010101010123/23012301232;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=3530123010101230123230123010101010101232301230123234301230101012301232301230101010101012323012301232;/CP=3;S
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=3530123010101230123230123010101010101232301230123234301230101012301232301230101010101012323012301232;CP=3;S/P=5;O;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=3530123010101230123230123010101010101232301230123234301230101012301232301230101010101012323012301232;CP=3;SP=5;O;/
2015.10.28 07:02:55 4: SIGNALduino/msg READ: MS;P0=-365;P1=663;P2=-714;P3=308;P4=-13078;P5=-15856;D=3530123010101230123230123010101010101232301230123234301230101012301232301230101010101012323012301232;CP=3;SP=5;O;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS/;P0=667;P1=-
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-/361;P2
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2/=-714;P3=309
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309/;P4=-1
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-1/5876;P
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P/5=-13080;D=
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=/353102
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=353102/310101
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=353102310101/023102323102
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=353102310101023102323102/310101010101023231
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=353102310101023102323102310101010101023231/02310
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=35310231010102310232310231010101010102323102310/232343
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=35310231010102310232310231010101010102323102310232343/102310101023
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=35310231010102310232310231010101010102323102310232343102310101023/102323
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=35310231010102310232310231010101010102323102310232343102310101023102323/102310
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=35310231010102310232310231010101010102323102310232343102310101023102323102310/101010101023
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=35310231010102310232310231010101010102323102310232343102310101023102323102310101010101023/23102
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=3531023101010231023231023101010101010232310231023234310231010102310232310231010101010102323102/310232;CP=3;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=3531023101010231023231023101010101010232310231023234310231010102310232310231010101010102323102310232;CP=3;/SP=5;O
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=3531023101010231023231023101010101010232310231023234310231010102310232310231010101010102323102310232;CP=3;SP=5;O/;
2015.10.28 07:02:55 4: SIGNALduino/msg READ: MS;P0=667;P1=-361;P2=-714;P3=309;P4=-15876;P5=-13080;D=3531023101010231023231023101010101010232310231023234310231010102310232310231010101010102323102310232;CP=3;SP=5;O;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P/0=-727;P1=29
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=29/7;P2=-
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-/373;P3
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3/=659;P4=-130
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-130/86;P5=
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=/-1588
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-1588/4;D=15123012
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=15123012/323230
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=15123012323230/123010123012
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=15123012323230123010123012/323232
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=15123012323230123010123012323232/32323010123012301
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=1512301232323012301012301232323232323010123012301/014123
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=1512301232323012301012301232323232323010123012301014123/012323
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=1512301232323012301012301232323232323010123012301014123012323/230123010123
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=1512301232323012301012301232323232323010123012301014123012323230123010123/012323
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=1512301232323012301012301232323232323010123012301014123012323230123010123012323/232323230101
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=1512301232323012301012301232323232323010123012301014123012323230123010123012323232323230101/23012
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=151230123232301230101230123232323232301012301230101412301232323012301012301232323232323010123012/301010
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=151230123232301230101230123232323232301012301230101412301232323012301012301232323232323010123012301010/;CP=1;SP=5;
2015.10.28 07:02:55 5: SIGNALduino/RAW READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=151230123232301230101230123232323232301012301230101412301232323012301012301232323232323010123012301010;CP=1;SP=5;/
2015.10.28 07:02:55 4: SIGNALduino/msg READ: MS;P0=-727;P1=297;P2=-373;P3=659;P4=-13086;P5=-15884;D=151230123232301230101230123232323232301012301230101412301232323012301012301232323232323010123012301010;CP=1;SP=5;
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: /
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: /MU;P0=-418;P1=283;P3=603
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MU;P0=-418;P1=283;P3=603/;P4=-722;D=0010103
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MU;P0=-418;P1=283;P3=603;P4=-722;D=0010103/41030303410341410341030
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MU;P0=-418;P1=283;P3=603;P4=-722;D=001010341030303410341410341030/303030303414103034
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MU;P0=-418;P1=283;P3=603;P4=-722;D=001010341030303410341410341030303030303414103034/1411;CP=1;
2015.10.28 07:02:59 4: SIGNALduino/msg READ: MU;P0=-418;P1=283;P3=603;P4=-722;D=0010103410303034103414103410303030303034141030341411;CP=1;
2015.10.28 07:02:59 4: Found matched Protocol id 8 -> TX3 Protocol
2015.10.28 07:02:59 5: Starting demodulation at Position 6
2015.10.28 07:02:59 5: restarting demodulation at Position 12+2
2015.10.28 07:02:59 5: restarting demodulation at Position 16+2
2015.10.28 07:02:59 5: restarting demodulation at Position 22+2
2015.10.28 07:02:59 5: restarting demodulation at Position 36+2
2015.10.28 07:02:59 5: restarting demodulation at Position 44+2
2015.10.28 07:02:59 4: Found matched Protocol id 16 -> Dooya shutter
2015.10.28 07:02:59 5: Starting demodulation at Position 7
2015.10.28 07:02:59 5: restarting demodulation at Position 13+2
2015.10.28 07:02:59 5: restarting demodulation at Position 17+2
2015.10.28 07:02:59 5: restarting demodulation at Position 23+2
2015.10.28 07:02:59 5: restarting demodulation at Position 37+2
2015.10.28 07:02:59 5: restarting demodulation at Position 45+2
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: /MS;P0=-730;P
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P/1=296;P2=-13088;P
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P/3=-382
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P3=-382/;P4=647;P5=-15876;
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P3=-382;P4=647;P5=-15876;/D=1513401343
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P3=-382;P4=647;P5=-15876;D=1513401343/434013401013
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P3=-382;P4=647;P5=-15876;D=1513401343434013401013/40134
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P3=-382;P4=647;P5=-15876;D=151340134343401340101340134/343434343401013434
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P3=-382;P4=647;P5=-15876;D=151340134343401340101340134343434343401013434/013401213401343434
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P3=-382;P4=647;P5=-15876;D=151340134343401340101340134343434343401013434013401213401343434/013401
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P3=-382;P4=647;P5=-15876;D=151340134343401340101340134343434343401013434013401213401343434013401/013401
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P3=-382;P4=647;P5=-15876;D=151340134343401340101340134343434343401013434013401213401343434013401013401/34343434343401013
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P3=-382;P4=647;P5=-15876;D=15134013434340134010134013434343434340101343401340121340134343401340101340134343434343401013/43401340;CP=1;SP=5
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-730;P1=296;P2=-13088;P3=-382;P4=647;P5=-15876;D=1513401343434013401013401343434343434010134340134012134013434340134010134013434343434340101343401340;CP=1;SP=5/;O;
2015.10.28 07:02:59 4: SIGNALduino/msg READ: MS;P0=-730;P1=296;P2=-13088;P3=-382;P4=647;P5=-15876;D=1513401343434013401013401343434343434010134340134012134013434340134010134013434343434340101343401340;CP=1;SP=5;O;
2015.10.28 07:02:59 4: Found matched Protocol id 20 -> livolo
2015.10.28 07:02:59 5: Starting demodulation at Position 20
2015.10.28 07:02:59 5: Found wrong signal, aborting demodulation
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS/;P0=302;P1=-721;P2
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2/=-369;
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;/P3=660;P4=-15873;
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;/P5=-13
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;P5=-13/080;D=050231023232
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;P5=-13080;D=050231023232/310231
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;P5=-13080;D=050231023232310231/01023102323232323
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;P5=-13080;D=05023102323231023101023102323232323/231010
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;P5=-13080;D=05023102323231023101023102323232323231010/232310231040231023
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;P5=-13080;D=05023102323231023101023102323232323231010232310231040231023/232310231010231023
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;P5=-13080;D=05023102323231023101023102323232323231010232310231040231023232310231010231023/23232
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;P5=-13080;D=0502310232323102310102310232323232323101023231023104023102323231023101023102323232/323231010232310231
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;P5=-13080;D=0502310232323102310102310232323232323101023231023104023102323231023101023102323232323231010232310231/;CP=0;
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;P5=-13080;D=0502310232323102310102310232323232323101023231023104023102323231023101023102323232323231010232310231;CP=0;/SP=5;O;
2015.10.28 07:02:59 4: SIGNALduino/msg READ: MS;P0=302;P1=-721;P2=-369;P3=660;P4=-15873;P5=-13080;D=0502310232323102310102310232323232323101023231023104023102323231023101023102323232323231010232310231;CP=0;SP=5;O;
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0/=-363;
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;/P1=667;P2=-711;P3=
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;P1=667;P2=-711;P3=/311;P4=-13087;P5=-
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;P1=667;P2=-711;P3=311;P4=-13087;P5=-/15884
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;P1=667;P2=-711;P3=311;P4=-13087;P5=-15884/;D=353012301
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;P1=667;P2=-711;P3=311;P4=-13087;P5=-15884;D=353012301/010123012323
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;P1=667;P2=-711;P3=311;P4=-13087;P5=-15884;D=353012301010123012323/012301010101010123
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;P1=667;P2=-711;P3=311;P4=-13087;P5=-15884;D=353012301010123012323012301010101010123/23010123012343012
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;P1=667;P2=-711;P3=311;P4=-13087;P5=-15884;D=35301230101012301232301230101010101012323010123012343012/301010
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;P1=667;P2=-711;P3=311;P4=-13087;P5=-15884;D=35301230101012301232301230101010101012323010123012343012301010/123012323012301010
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;P1=667;P2=-711;P3=311;P4=-13087;P5=-15884;D=35301230101012301232301230101010101012323010123012343012301010123012323012301010/101010
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;P1=667;P2=-711;P3=311;P4=-13087;P5=-15884;D=35301230101012301232301230101010101012323010123012343012301010123012323012301010101010/12323010123012;CP
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=-363;P1=667;P2=-711;P3=311;P4=-13087;P5=-15884;D=3530123010101230123230123010101010101232301012301234301230101012301232301230101010101012323010123012;CP/=3;SP=5;O;
2015.10.28 07:02:59 4: SIGNALduino/msg READ: MS;P0=-363;P1=667;P2=-711;P3=311;P4=-13087;P5=-15884;D=3530123010101230123230123010101010101232301012301234301230101012301232301230101010101012323010123012;CP=3;SP=5;O;
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P/0=662
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=662/;P1=-714;P2=304;P3
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=662;P1=-714;P2=304;P3/=-371;
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=662;P1=-714;P2=304;P3=-371;/P5=-13092;D=252301
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=662;P1=-714;P2=304;P3=-371;P5=-13092;D=252301/23030
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=662;P1=-714;P2=304;P3=-371;P5=-13092;D=25230123030/301230121230123030
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=662;P1=-714;P2=304;P3=-371;P5=-13092;D=25230123030301230121230123030/303030
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=662;P1=-714;P2=304;P3=-371;P5=-13092;D=25230123030301230121230123030303030/30121230301230121;CP=2;
2015.10.28 07:02:59 5: SIGNALduino/RAW READ: MS;P0=662;P1=-714;P2=304;P3=-371;P5=-13092;D=2523012303030123012123012303030303030121230301230121;CP=2;/SP=5;
2015.10.28 07:02:59 4: SIGNALduino/msg READ: MS;P0=662;P1=-714;P2=304;P3=-371;P5=-13092;D=2523012303030123012123012303030303030121230301230121;CP=2;SP=5;
Ich habe nur ein paar mal auf ein und aus gedrückt.
Carlos
FHEM svn auf Intel NUC mit proxmox, 3 Raspberry Pi, signalduino, nanoCUL,  toom Baumarkt Funksteckdosen, einige sonoffs, hue, shelly
