49_SSCam: Fragen, Hinweise, Neuigkeiten und mehr rund um dieses Modul
Begonnen von DS_Starter, 14 Dezember 2015, 16:19:08
juemuc
Und hier das Logfile
2021.07.01 10:26:38 4: E1Zoom - ####################################################
2021.07.01 10:26:38 4: E1Zoom - ###    start cam operation Getcapabilities
2021.07.01 10:26:38 3: E1Zoom - no session ID found - get new one
2021.07.01 10:26:38 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:26:38 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:26:38 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:26:38 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:26:38 3: E1Zoom - Polling now: 10:26:38 , next Polling: 10:31:38
2021.07.01 10:26:38 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
  'success' => bless( do{\(my $o = 0)}, 'JSON::PP::Boolean' )
2021.07.01 10:26:38 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:26:38 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 10:26:39 4: E1Zoom - ####################################################
2021.07.01 10:26:39 4: E1Zoom - ###    start cam operation getsvsinfo
2021.07.01 10:26:39 3: E1Zoom - no session ID found - get new one
2021.07.01 10:26:39 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:26:39 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:26:39 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:26:39 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:26:39 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 10:26:39 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:26:39 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 10:26:39 4: E1Zoom - ###    start cam operation getstreamformat
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:26:39 4: E1Zoom - ###    start cam operation getsnapgallery
2021.07.01 10:26:39 4: E1Zoom - Call getsnapinfo with params: Image numbers => 1, Image size => 1, Keyword => E1-Zoom
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:26:40 4: E1Zoom - ####################################################
2021.07.01 10:26:40 4: E1Zoom - ###    start cam operation geteventlist
2021.07.01 10:26:40 3: E1Zoom - no session ID found - get new one
2021.07.01 10:26:40 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:26:40 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:26:40 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:26:40 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:26:40 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 10:26:40 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:26:40 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 10:26:42 4: E1Zoom - ####################################################
2021.07.01 10:26:42 4: E1Zoom - ###    start cam operation getmotionenum
2021.07.01 10:26:42 3: E1Zoom - no session ID found - get new one
2021.07.01 10:26:42 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:26:42 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:26:42 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:26:42 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:26:42 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 10:26:42 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:26:42 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 10:26:44 4: E1Zoom - ####################################################
2021.07.01 10:26:44 4: E1Zoom - ###    start cam operation Getcaminfo
2021.07.01 10:26:44 3: E1Zoom - no session ID found - get new one
2021.07.01 10:26:44 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:26:44 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:26:44 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:26:44 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:26:44 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 10:26:44 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:26:44 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 10:26:46 4: E1Zoom - ####################################################
2021.07.01 10:26:46 4: E1Zoom - ###    start cam operation getStmUrlPath
2021.07.01 10:26:46 3: E1Zoom - no session ID found - get new one
2021.07.01 10:26:46 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:26:46 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:26:46 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:26:46 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:26:46 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 10:26:46 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
Jürgen
3x Sonos Play 1, 1x Sonos Arc + Sub, 1 Sonos-One, 1x Sonos Playbar
FB6690 + FB7490 mit 4x Dect 200 und 3 Dect-ULE-Thermostate,  raspberry3B+, HM Funkmodul HM-MOD-RPI-PCB, HM Klingelsensor HM-Sen-DB-PCB, HM (IP) Fensterkontakte und  Amazon Echo Dot,  piVCCU, pi OS (bookworm).
juemuc
Hallo Heiko,
das Attribut "simu_SVSversion" hilft leider nicht :-(
Wenn Du weitere Infos benötigst, bitte melden. Ich bin dann hier der "BETA-Tester"  ;D
Jürgen
DS_Starter
Hi, das Protokoll gibt noch zu wenig Infos. Lass mal verbose 5 an und dann get scanVirgin.
Ich will die API Infos mit sehen.
juemuc
Und hier das neue Log.
2021.07.01 10:43:47 4: E1Zoom - ####################################################
2021.07.01 10:43:47 4: E1Zoom - ###    start cam operation Getcapabilities
2021.07.01 10:43:47 3: E1Zoom - no session ID found - get new one
2021.07.01 10:43:47 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:43:47 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:43:47 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:43:47 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:43:47 3: E1Zoom - Polling now: 10:43:47 , next Polling: 10:48:47
2021.07.01 10:43:47 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 10:43:47 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:43:47 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 10:43:48 4: E1Zoom - ####################################################
2021.07.01 10:43:48 4: E1Zoom - ###    start cam operation getsvsinfo
2021.07.01 10:43:48 3: E1Zoom - no session ID found - get new one
2021.07.01 10:43:48 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:43:48 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:43:48 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:43:48 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:43:48 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 10:43:48 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:43:48 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 10:43:49 4: E1Zoom - ####################################################
2021.07.01 10:43:49 4: E1Zoom - ###    start cam operation getstreamformat
2021.07.01 10:43:49 3: E1Zoom - no session ID found - get new one
2021.07.01 10:43:49 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:43:49 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:43:49 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:43:49 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:43:49 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 10:43:49 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:43:49 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 10:43:49 4: E1Zoom - ###    start cam operation getsnapgallery
2021.07.01 10:43:49 4: E1Zoom - Call getsnapinfo with params: Image numbers => 1, Image size => 1, Keyword => E1-Zoom
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:43:49 4: E1Zoom - ###    start cam operation geteventlist
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:43:51 4: E1Zoom - ####################################################
2021.07.01 10:43:51 4: E1Zoom - ###    start cam operation getmotionenum
2021.07.01 10:43:51 3: E1Zoom - no session ID found - get new one
2021.07.01 10:43:51 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:43:51 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:43:51 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:43:51 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:43:51 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 10:43:51 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:43:51 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 10:43:53 4: E1Zoom - ####################################################
2021.07.01 10:43:53 4: E1Zoom - ###    start cam operation Getcaminfo
2021.07.01 10:43:53 3: E1Zoom - no session ID found - get new one
2021.07.01 10:43:53 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:43:53 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:43:53 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:43:53 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:43:53 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 10:43:53 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:43:53 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 10:43:55 4: E1Zoom - ####################################################
2021.07.01 10:43:55 4: E1Zoom - ###    start cam operation getStmUrlPath
2021.07.01 10:43:55 3: E1Zoom - no session ID found - get new one
2021.07.01 10:43:55 4: E1Zoom - --- Begin Function login ---
2021.07.01 10:43:55 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:43:55 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 10:43:55 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 10:43:55 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 10:43:55 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 10:43:55 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 10:44:01 4: E1Zoom - --- Start Synology logout ---
2021.07.01 10:44:01 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 10:44:01 2: E1Zoom - User "reolink" has no valid session, logout is cancelled
2021.07.01 10:44:01 4: E1Zoom - ####################################################
2021.07.01 10:44:01 4: E1Zoom - ###    start cam operation Getcapabilities
2021.07.01 10:44:01 4: E1Zoom - --- Start getApiSites ---
2021.07.01 10:44:01 5: E1Zoom - HTTP-Call will be done with httptimeout-Value: 20 s
2021.07.01 10:44:01 4: E1Zoom - API imported:
  'AUDIOSTM' => {
                  'NAME' => 'SYNO.SurveillanceStation.AudioStream'
  'AUTH' => {
              'NAME' => 'SYNO.API.Auth'
  'CAM' => {
             'NAME' => 'SYNO.SurveillanceStation.Camera'
  'CAMEVENT' => {
                  'NAME' => 'SYNO.SurveillanceStation.Camera.Event'
  'EVENT' => {
               'NAME' => 'SYNO.SurveillanceStation.Event'
  'EXTEVT' => {
                'NAME' => 'SYNO.SurveillanceStation.ExternalEvent'
  'EXTREC' => {
                'NAME' => 'SYNO.SurveillanceStation.ExternalRecording'
  'HMODE' => {
               'NAME' => 'SYNO.SurveillanceStation.HomeMode'
  'INFO' => {
              'NAME' => 'SYNO.API.Info',
              'PATH' => 'query.cgi',
              'VER' => 1
  'LOG' => {
             'NAME' => 'SYNO.SurveillanceStation.Log'
  'PRESET' => {
                'NAME' => 'SYNO.SurveillanceStation.PTZ.Preset'
  'PTZ' => {
             'NAME' => 'SYNO.SurveillanceStation.PTZ'
  'REC' => {
             'NAME' => 'SYNO.SurveillanceStation.Recording'
  'SNAPSHOT' => {
                  'NAME' => 'SYNO.SurveillanceStation.SnapShot'
  'STM' => {
             'NAME' => 'SYNO.SurveillanceStation.Stream'
  'SVSINFO' => {
                 'NAME' => 'SYNO.SurveillanceStation.Info'
  'VIDEOSTM' => {
                  'NAME' => 'SYNO.SurveillanceStation.VideoStreaming'
  'VIDEOSTMS' => {
                   'NAME' => 'SYNO.SurveillanceStation.VideoStream'
2021.07.01 10:44:01 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/query.cgi?api=SYNO.API.Info&method=Query&version=1&query=SYNO.SurveillanceStation.Camera,SYNO.SurveillanceStation.Info,SYNO.SurveillanceStation.Recording,SYNO.SurveillanceStation.PTZ.Preset,SYNO.SurveillanceStation.HomeMode,SYNO.SurveillanceStation.VideoStreaming,SYNO.API.Auth,SYNO.SurveillanceStation.Log,SYNO.SurveillanceStation.PTZ,SYNO.SurveillanceStation.Event,SYNO.SurveillanceStation.SnapShot,SYNO.API.Info,SYNO.SurveillanceStation.Stream,SYNO.SurveillanceStation.ExternalEvent,SYNO.SurveillanceStation.ExternalRecording,SYNO.SurveillanceStation.AudioStream,SYNO.SurveillanceStation.VideoStream,SYNO.SurveillanceStation.Camera.Event
2021.07.01 10:44:01 3: E1Zoom - Polling now: 10:44:01 , next Polling: 10:49:01
2021.07.01 10:44:01 5: E1Zoom - JSON returned: {
  'data' => {
              'SYNO.API.Auth' => {
                                   'maxVersion' => 7,
                                   'minVersion' => 1,
                                   'path' => 'entry.cgi'
              'SYNO.API.Info' => {
                                   'maxVersion' => 1,
                                   'minVersion' => 1,
                                   'path' => 'entry.cgi',
                                   'requestFormat' => 'JSON'
              'SYNO.SurveillanceStation.AudioStream' => {
                                                          'maxVersion' => 2,
                                                          'minVersion' => 1,
                                                          'path' => 'SurveillanceStation/audioStreaming.cgi'
              'SYNO.SurveillanceStation.Camera' => {
                                                     'maxVersion' => 9,
                                                     'minVersion' => 1,
              'SYNO.SurveillanceStation.Camera.Event' => {
                                                           'maxVersion' => 1,
                                                           'minVersion' => 1,
              'SYNO.SurveillanceStation.Event' => {
                                                    'maxVersion' => 5,
                                                    'minVersion' => 1,
              'SYNO.SurveillanceStation.ExternalEvent' => {
                                                            'maxVersion' => 1,
                                                            'minVersion' => 1,
              'SYNO.SurveillanceStation.ExternalRecording' => {
        'maxVersion' => 3,
        'minVersion' => 1,
              'SYNO.SurveillanceStation.HomeMode' => {
                                                       'maxVersion' => 1,
                                                       'minVersion' => 1,
              'SYNO.SurveillanceStation.Info' => {
                                                   'maxVersion' => 8,
                                                   'minVersion' => 1,
              'SYNO.SurveillanceStation.Log' => {
                                                  'maxVersion' => 3,
                                                  'minVersion' => 1,
              'SYNO.SurveillanceStation.PTZ' => {
                                                  'maxVersion' => 6,
                                                  'minVersion' => 1,
              'SYNO.SurveillanceStation.PTZ.Preset' => {
                                                         'maxVersion' => 1,
                                                         'minVersion' => 1,
              'SYNO.SurveillanceStation.Recording' => {
                                                        'maxVersion' => 6,
                                                        'minVersion' => 1,
              'SYNO.SurveillanceStation.SnapShot' => {
                                                       'maxVersion' => 1,
                                                       'minVersion' => 1,
              'SYNO.SurveillanceStation.Stream' => {
                                                     'maxVersion' => 1,
                                                     'minVersion' => 1,
              'SYNO.SurveillanceStation.VideoStream' => {
                                                          'maxVersion' => 1,
                                                          'minVersion' => 1,
                                                          'path' => 'SurveillanceStation/videoStreaming.cgi'
              'SYNO.SurveillanceStation.VideoStreaming' => {
                                                             'maxVersion' => 1,
                                                             'minVersion' => 1,
  'success' => bless( do{\(my $o = 1)}, 'JSON::PP::Boolean' )
2021.07.01 10:44:01 4: E1Zoom - installed SVS version is: 8297296
2021.07.01 10:44:01 4: E1Zoom - ------- Begin of adaption section -------
2021.07.01 10:44:01 4: E1Zoom - ------- End of adaption section -------
2021.07.01 10:44:01 4: E1Zoom - ------- Begin of simulation section -------
2021.07.01 10:44:01 4: E1Zoom - SVS version 820xxxx-simu will be simulated
2021.07.01 10:44:01 4: E1Zoom - Version of SYNO.SurveillanceStation.VideoStream adapted to: 0
2021.07.01 10:44:01 4: E1Zoom - Version of SYNO.SurveillanceStation.AudioStream adapted to: 0
2021.07.01 10:44:01 4: E1Zoom - ------- End of simulation section -------
2021.07.01 10:44:01 4: E1Zoom - API completed after retrieval and adaption:
  'AUDIOSTM' => {
                  'MOD' => 'yes',
                  'NAME' => 'SYNO.SurveillanceStation.AudioStream',
                  'PATH' => 'SurveillanceStation/audioStreaming.cgi',
                  'VER' => '0'
  'AUTH' => {
              'MOD' => 'no',
              'NAME' => 'SYNO.API.Auth',
              'PATH' => 'entry.cgi',
              'VER' => 7
  'CAM' => {
             'MOD' => 'no',
             'NAME' => 'SYNO.SurveillanceStation.Camera',
             'VER' => 9
  'CAMEVENT' => {
                  'MOD' => 'no',
                  'NAME' => 'SYNO.SurveillanceStation.Camera.Event',
                  'VER' => 1
  'EVENT' => {
               'MOD' => 'no',
               'NAME' => 'SYNO.SurveillanceStation.Event',
               'VER' => 5
  'EXTEVT' => {
                'MOD' => 'no',
                'NAME' => 'SYNO.SurveillanceStation.ExternalEvent',
                'VER' => 1
  'EXTREC' => {
                'MOD' => 'no',
                'NAME' => 'SYNO.SurveillanceStation.ExternalRecording',
                'VER' => 3
  'HMODE' => {
               'MOD' => 'no',
               'NAME' => 'SYNO.SurveillanceStation.HomeMode',
               'VER' => 1
  'INFO' => {
              'MOD' => 'no',
              'VER' => 1
  'LOG' => {
             'MOD' => 'no',
             'NAME' => 'SYNO.SurveillanceStation.Log',
             'VER' => 3
  'PARSET' => 1,
  'PRESET' => {
                'MOD' => 'no',
                'NAME' => 'SYNO.SurveillanceStation.PTZ.Preset',
                'VER' => 1
  'PTZ' => {
             'MOD' => 'no',
             'NAME' => 'SYNO.SurveillanceStation.PTZ',
             'VER' => 6
  'REC' => {
             'MOD' => 'no',
             'NAME' => 'SYNO.SurveillanceStation.Recording',
             'VER' => 6
  'SNAPSHOT' => {
                  'MOD' => 'no',
                  'NAME' => 'SYNO.SurveillanceStation.SnapShot',
                  'VER' => 1
  'STM' => {
             'MOD' => 'no',
             'NAME' => 'SYNO.SurveillanceStation.Stream',
             'VER' => 1
  'SVSINFO' => {
                 'MOD' => 'no',
                 'NAME' => 'SYNO.SurveillanceStation.Info',
                 'VER' => 8
  'VIDEOSTM' => {
                  'MOD' => 'no',
                  'NAME' => 'SYNO.SurveillanceStation.VideoStreaming',
                  'VER' => 1
  'VIDEOSTMS' => {
                   'MOD' => 'yes',
                   'NAME' => 'SYNO.SurveillanceStation.VideoStream',
                   'PATH' => 'SurveillanceStation/videoStreaming.cgi',
                   'VER' => '0'
2021.07.01 10:44:01 3: E1Zoom - no session ID found - get new one
2021.07.01 10:44:01 4: E1Zoom - --- Begin Function login ---
DS_Starter
Danke Jürgen, werde mich heute Abend mal damit beschäftigen und melde mich wieder.
DS_Starter
Hallo Jürgen,
zieh dir mal die Version aus meinem contrib,  setze das Attr
SVSversion = 8.2.0-xxxx-simu
und starte FHEM neu.
Dann testen.
Grüße,
Heiko
juemuc
Hallo Heiko,
ich habe die Daten mit
"wget -qO ./FHEM/49_SSCam.pm https://svn.fhem.de/fhem/trunk/fhem/contrib/DS_Starter/49_SSCam.pm"
gelesen und fhem neu gestartet. Attribut ist gesetzt. Wie sehe ich denn, dass ich die richtige Version habe? Im Log sehe ich nichts. und es funktioniert nicht.
Zusätzlich habe ich noch diese Meldung gefunden.
2021.07.01 17:14:11 2: SVS_HomeMode - WARNING - The current/simulated SVS-version 8.2.9-7296 may be incompatible with SSCam version 9.9.0. For further information execute "get SVS_HomeMode versionNotes 4".
Jürgen
DS_Starter
Die Version siehst du im Internal
FVERSION    49_SSCam.pm:v9.10.0-s24484/2021-05-21
Wenn du mit verbose 4 neu startest siehst du im Log das:
2021.07.01 22:18:07.338 4: CamHE1 - ------- Begin of simulation section -------
2021.07.01 22:18:07.338 4: CamHE1 - SVS version 820xxxx-simu will be simulated
2021.07.01 22:18:07.339 4: CamHE1 - Version of SYNO.API.Auth adapted to: 6
2021.07.01 22:18:07.339 4: CamHE1 - Version of SYNO.SurveillanceStation.ExternalRecording adapted to: 3
2021.07.01 22:18:07.340 4: CamHE1 - Version of SYNO.SurveillanceStation.Camera adapted to: 9
2021.07.01 22:18:07.340 4: CamHE1 - Version of SYNO.SurveillanceStation.SnapShot adapted to: 1
2021.07.01 22:18:07.340 4: CamHE1 - Version of SYNO.SurveillanceStation.PTZ adapted to: 5
2021.07.01 22:18:07.341 4: CamHE1 - Version of SYNO.SurveillanceStation.PTZ.Preset adapted to: 1
2021.07.01 22:18:07.341 4: CamHE1 - Version of SYNO.SurveillanceStation.Camera.Event adapted to: 1
2021.07.01 22:18:07.342 4: CamHE1 - Version of SYNO.SurveillanceStation.Event adapted to: 5
2021.07.01 22:18:07.342 4: CamHE1 - Version of SYNO.SurveillanceStation.VideoStreaming adapted to: 1
2021.07.01 22:18:07.342 4: CamHE1 - Version of SYNO.SurveillanceStation.ExternalEvent adapted to: 1
2021.07.01 22:18:07.343 4: CamHE1 - Version of SYNO.SurveillanceStation.Stream adapted to: 1
2021.07.01 22:18:07.343 4: CamHE1 - Version of SYNO.SurveillanceStation.HomeMode adapted to: 1
2021.07.01 22:18:07.344 4: CamHE1 - Version of SYNO.SurveillanceStation.Log adapted to: 3
2021.07.01 22:18:07.344 4: CamHE1 - Version of SYNO.SurveillanceStation.AudioStream adapted to: 2
2021.07.01 22:18:07.345 4: CamHE1 - Version of SYNO.SurveillanceStation.VideoStream adapted to: 1
2021.07.01 22:18:07.345 4: CamHE1 - ------- End of simulation section -------
Download mit:
Sollte also stimmen.
juemuc
Hallo Heiko,
also die Version passt. Es scheint ein Problem mit der Anmeldung zu geben.
2021.07.01 22:24:18 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
Auf der Syno kann ich mich aber mit diesen Daten direkt anmelden.
Jürgen
DS_Starter
Ja, das wird das Hauptproblem sein. Was zeigt denn verbose 5 ?
EDIT: Wie steht das Attr session bei dir ?
juemuc
Hallo Heiko,
session steht auf "SurveillanceStation"
Hier das Log:
2021.07.01 22:47:21 4: E1Zoom - --- Start Synology logout ---
2021.07.01 22:47:21 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 22:47:21 2: E1Zoom - User "reolink" has no valid session, logout is cancelled
2021.07.01 22:47:21 4: E1Zoom - ####################################################
2021.07.01 22:47:21 4: E1Zoom - ###    start cam operation Getcapabilities
2021.07.01 22:47:21 4: E1Zoom - --- Start getApiSites ---
2021.07.01 22:47:21 5: E1Zoom - HTTP-Call will be done with httptimeout-Value: 20 s
2021.07.01 22:47:21 4: E1Zoom - API imported:
  'AUDIOSTM' => {
  'AUTH' => {
  'CAM' => {
  'CAMEVENT' => {
  'EVENT' => {
  'EXTEVT' => {
  'EXTREC' => {
  'HMODE' => {
  'INFO' => {
              'VER' => 1
  'LOG' => {
  'PRESET' => {
  'PTZ' => {
  'REC' => {
  'SNAPSHOT' => {
  'STM' => {
  'SVSINFO' => {
  'VIDEOSTM' => {
  'VIDEOSTMS' => {
2021.07.01 22:47:21 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/query.cgi?api=SYNO.API.Info&method=Query&version=1&query=SYNO.SurveillanceStation.Info,SYNO.SurveillanceStation.Event,SYNO.SurveillanceStation.Log,SYNO.SurveillanceStation.SnapShot,SYNO.SurveillanceStation.VideoStreaming,SYNO.SurveillanceStation.PTZ,SYNO.SurveillanceStation.Stream,SYNO.SurveillanceStation.PTZ.Preset,SYNO.SurveillanceStation.Recording,SYNO.SurveillanceStation.AudioStream,SYNO.SurveillanceStation.Camera.Event,SYNO.SurveillanceStation.Camera,SYNO.SurveillanceStation.VideoStream,SYNO.API.Auth,SYNO.API.Info,SYNO.SurveillanceStation.ExternalRecording,SYNO.SurveillanceStation.ExternalEvent,SYNO.SurveillanceStation.HomeMode
2021.07.01 22:47:21 3: E1Zoom - Polling now: 22:47:21 , next Polling: 22:52:21
2021.07.01 22:47:21 5: E1Zoom - JSON returned: {
  'data' => {
                                   'maxVersion' => 7,
                                   'minVersion' => 1,
                                   'maxVersion' => 1,
                                   'minVersion' => 1,
                                                          'maxVersion' => 2,
                                                          'minVersion' => 1,
                                                     'maxVersion' => 9,
                                                     'minVersion' => 1,
                                                           'maxVersion' => 1,
                                                           'minVersion' => 1,
                                                    'maxVersion' => 5,
                                                    'minVersion' => 1,
                                                            'maxVersion' => 1,
                                                            'minVersion' => 1,
        'maxVersion' => 3,
        'minVersion' => 1,
                                                       'maxVersion' => 1,
                                                       'minVersion' => 1,
                                                   'maxVersion' => 8,
                                                   'minVersion' => 1,
                                                  'maxVersion' => 3,
                                                  'minVersion' => 1,
                                                  'maxVersion' => 6,
                                                  'minVersion' => 1,
                                                         'maxVersion' => 1,
                                                         'minVersion' => 1,
                                                        'maxVersion' => 6,
                                                        'minVersion' => 1,
                                                       'maxVersion' => 1,
                                                       'minVersion' => 1,
                                                     'maxVersion' => 1,
                                                     'minVersion' => 1,
                                                          'maxVersion' => 1,
                                                          'minVersion' => 1,
                                                             'maxVersion' => 1,
                                                             'minVersion' => 1,
2021.07.01 22:47:21 4: E1Zoom - installed SVS version is: 8297296
2021.07.01 22:47:21 4: E1Zoom - ------- Begin of adaption section -------
2021.07.01 22:47:21 4: E1Zoom - ------- End of adaption section -------
2021.07.01 22:47:21 4: E1Zoom - ------- Begin of simulation section -------
2021.07.01 22:47:21 4: E1Zoom - ------- End of simulation section -------
2021.07.01 22:47:21 4: E1Zoom - API completed after retrieval and adaption:
  'AUDIOSTM' => {
                  'MOD' => 'no',
                  'VER' => 2
  'AUTH' => {
              'MOD' => 'no',
              'VER' => 7
  'CAM' => {
             'MOD' => 'no',
             'VER' => 9
  'CAMEVENT' => {
                  'MOD' => 'no',
                  'VER' => 1
  'EVENT' => {
               'MOD' => 'no',
               'VER' => 5
  'EXTEVT' => {
                'MOD' => 'no',
                'VER' => 1
  'EXTREC' => {
                'MOD' => 'no',
                'VER' => 3
  'HMODE' => {
               'MOD' => 'no',
               'VER' => 1
  'INFO' => {
              'MOD' => 'no',
              'VER' => 1
  'LOG' => {
             'MOD' => 'no',
             'VER' => 3
  'PARSET' => 1,
  'PRESET' => {
                'MOD' => 'no',
                'VER' => 1
  'PTZ' => {
             'MOD' => 'no',
             'VER' => 6
  'REC' => {
             'MOD' => 'no',
             'VER' => 6
  'SNAPSHOT' => {
                  'MOD' => 'no',
                  'VER' => 1
  'STM' => {
             'MOD' => 'no',
             'VER' => 1
  'SVSINFO' => {
                 'MOD' => 'no',
                 'VER' => 8
  'VIDEOSTM' => {
                  'MOD' => 'no',
                  'VER' => 1
  'VIDEOSTMS' => {
                   'MOD' => 'no',
                   'VER' => 1
2021.07.01 22:47:21 3: E1Zoom - no session ID found - get new one
2021.07.01 22:47:21 4: E1Zoom - --- Begin Function login ---
2021.07.01 22:47:21 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 22:47:21 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 22:47:21 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 22:47:21 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 22:47:21 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 22:47:22 4: E1Zoom - ####################################################
2021.07.01 22:47:22 4: E1Zoom - ###    start cam operation getsvsinfo
2021.07.01 22:47:22 3: E1Zoom - no session ID found - get new one
2021.07.01 22:47:22 4: E1Zoom - --- Begin Function login ---
2021.07.01 22:47:22 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 22:47:22 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 22:47:22 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 22:47:22 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 22:47:22 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 22:47:22 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 22:47:22 4: E1Zoom - ###    start cam operation getstreamformat
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 22:47:23 4: E1Zoom - ####################################################
2021.07.01 22:47:23 4: E1Zoom - ###    start cam operation getsnapgallery
2021.07.01 22:47:23 4: E1Zoom - Call getsnapinfo with params: Image numbers => 1, Image size => 1, Keyword => E1-Zoom
2021.07.01 22:47:23 3: E1Zoom - no session ID found - get new one
2021.07.01 22:47:23 4: E1Zoom - --- Begin Function login ---
2021.07.01 22:47:23 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 22:47:23 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 22:47:23 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 22:47:23 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 22:47:23 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 22:47:23 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 22:47:23 4: E1Zoom - ###    start cam operation geteventlist
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 22:47:25 4: E1Zoom - ####################################################
2021.07.01 22:47:25 4: E1Zoom - ###    start cam operation getmotionenum
2021.07.01 22:47:25 3: E1Zoom - no session ID found - get new one
2021.07.01 22:47:25 4: E1Zoom - --- Begin Function login ---
2021.07.01 22:47:25 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 22:47:25 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 22:47:25 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 22:47:25 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 22:47:25 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 22:47:25 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 22:47:25 2: SVS_HomeMode - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 22:47:26 2: SVS_HomeMode - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 22:47:27 4: E1Zoom - ####################################################
2021.07.01 22:47:27 4: E1Zoom - ###    start cam operation Getcaminfo
2021.07.01 22:47:27 3: E1Zoom - no session ID found - get new one
2021.07.01 22:47:27 4: E1Zoom - --- Begin Function login ---
2021.07.01 22:47:27 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 22:47:27 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 22:47:27 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 22:47:27 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 22:47:27 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 22:47:27 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
2021.07.01 22:47:29 4: E1Zoom - ####################################################
2021.07.01 22:47:29 4: E1Zoom - ###    start cam operation getStmUrlPath
2021.07.01 22:47:29 3: E1Zoom - no session ID found - get new one
2021.07.01 22:47:29 4: E1Zoom - --- Begin Function login ---
2021.07.01 22:47:29 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 22:47:29 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 22:47:29 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=7&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 22:47:29 5: E1Zoom - JSON decoded: {
  'error' => {
               'code' => 103
2021.07.01 22:47:29 3: E1Zoom - Login of User reolink unsuccessful. Code: 103 - Message not found for error code: 103 - try again
  'error' => {
               'code' => 103
  'error' => {
               'code' => 103
2021.07.01 22:47:29 2: E1Zoom - ERROR - Login or privilege of user reolink unsuccessful
Jürgen
DS_Starter
Sieht so aus als ob dein Attr
nicht gesetzt ist.
juemuc
Ich habe es noch einmal gesetzt. Das Attribut war weg. Es stand nur im Reading.
Hier das neue Log:
2021.07.01 23:03:48 4: E1Zoom - --- Start Synology logout ---
2021.07.01 23:03:48 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 23:03:48 5: E1Zoom - Call logout will be done with timeout value: 60 s
2021.07.01 23:03:48 3: E1Zoom - Polling now: 23:03:48 , next Polling: 23:08:48
2021.07.01 23:03:48 4: E1Zoom - URL-Call: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=6&method=Logout&session=SurveillanceStation&_sid=Aga87nNVdoxXryNUytfC1NJAd670xJyiRQrq9Vt4DuwbWPd3UYAqoVcrTsdooCTqtL-L8Ip8A_dEhA2NYWwFS8
2021.07.01 23:03:48 4: E1Zoom - JSON returned: {
2021.07.01 23:03:48 2: E1Zoom - Session of User "reolink" terminated - session ID "Aga87nNVdoxXryNUytfC1NJAd670xJyiRQrq9Vt4DuwbWPd3UYAqoVcrTsdooCTqtL-L8Ip8A_dEhA2NYWwFS8" deleted
2021.07.01 23:03:49 4: E1Zoom - ####################################################
2021.07.01 23:03:49 4: E1Zoom - ###    start cam operation Getcapabilities
2021.07.01 23:03:49 4: E1Zoom - --- Start getApiSites ---
2021.07.01 23:03:49 5: E1Zoom - HTTP-Call will be done with httptimeout-Value: 20 s
2021.07.01 23:03:49 4: E1Zoom - API imported:
  'AUDIOSTM' => {
  'AUTH' => {
  'CAM' => {
  'CAMEVENT' => {
  'EVENT' => {
  'EXTEVT' => {
  'EXTREC' => {
  'HMODE' => {
  'INFO' => {
              'VER' => 1
  'LOG' => {
  'PRESET' => {
  'PTZ' => {
  'REC' => {
  'SNAPSHOT' => {
  'STM' => {
  'SVSINFO' => {
  'VIDEOSTM' => {
  'VIDEOSTMS' => {
2021.07.01 23:03:49 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/query.cgi?api=SYNO.API.Info&method=Query&version=1&query=SYNO.SurveillanceStation.HomeMode,SYNO.SurveillanceStation.AudioStream,SYNO.SurveillanceStation.Camera.Event,SYNO.SurveillanceStation.PTZ.Preset,SYNO.SurveillanceStation.Stream,SYNO.SurveillanceStation.PTZ,SYNO.SurveillanceStation.Recording,SYNO.SurveillanceStation.ExternalRecording,SYNO.SurveillanceStation.ExternalEvent,SYNO.SurveillanceStation.Camera,SYNO.SurveillanceStation.VideoStream,SYNO.API.Auth,SYNO.API.Info,SYNO.SurveillanceStation.Log,SYNO.SurveillanceStation.VideoStreaming,SYNO.SurveillanceStation.SnapShot,SYNO.SurveillanceStation.Event,SYNO.SurveillanceStation.Info
2021.07.01 23:03:49 5: E1Zoom - JSON returned: {
  'data' => {
                                   'maxVersion' => 7,
                                   'minVersion' => 1,
                                   'maxVersion' => 1,
                                   'minVersion' => 1,
                                                          'maxVersion' => 2,
                                                          'minVersion' => 1,
                                                     'maxVersion' => 9,
                                                     'minVersion' => 1,
                                                           'maxVersion' => 1,
                                                           'minVersion' => 1,
                                                    'maxVersion' => 5,
                                                    'minVersion' => 1,
                                                            'maxVersion' => 1,
                                                            'minVersion' => 1,
        'maxVersion' => 3,
        'minVersion' => 1,
                                                       'maxVersion' => 1,
                                                       'minVersion' => 1,
                                                   'maxVersion' => 8,
                                                   'minVersion' => 1,
                                                  'maxVersion' => 3,
                                                  'minVersion' => 1,
                                                  'maxVersion' => 6,
                                                  'minVersion' => 1,
                                                         'maxVersion' => 1,
                                                         'minVersion' => 1,
                                                        'maxVersion' => 6,
                                                        'minVersion' => 1,
                                                       'maxVersion' => 1,
                                                       'minVersion' => 1,
                                                     'maxVersion' => 1,
                                                     'minVersion' => 1,
                                                          'maxVersion' => 1,
                                                          'minVersion' => 1,
                                                             'maxVersion' => 1,
                                                             'minVersion' => 1,
2021.07.01 23:03:49 4: E1Zoom - installed SVS version is: 8297296
2021.07.01 23:03:49 4: E1Zoom - ------- Begin of adaption section -------
2021.07.01 23:03:49 4: E1Zoom - ------- End of adaption section -------
2021.07.01 23:03:49 4: E1Zoom - ------- Begin of simulation section -------
2021.07.01 23:03:49 4: E1Zoom - SVS version 820xxxx-simu will be simulated
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.API.Auth adapted to: 6
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.ExternalRecording adapted to: 3
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.Camera adapted to: 9
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.SnapShot adapted to: 1
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.PTZ adapted to: 5
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.PTZ.Preset adapted to: 1
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.Camera.Event adapted to: 1
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.Event adapted to: 5
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.VideoStreaming adapted to: 1
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.ExternalEvent adapted to: 1
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.Stream adapted to: 1
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.HomeMode adapted to: 1
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.Log adapted to: 3
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.AudioStream adapted to: 2
2021.07.01 23:03:49 4: E1Zoom - Version of SYNO.SurveillanceStation.VideoStream adapted to: 1
2021.07.01 23:03:49 4: E1Zoom - ------- End of simulation section -------
2021.07.01 23:03:49 4: E1Zoom - API completed after retrieval and adaption:
  'AUDIOSTM' => {
                  'MOD' => 'yes',
                  'VER' => '2'
  'AUTH' => {
              'MOD' => 'yes',
              'VER' => '6'
  'CAM' => {
             'MOD' => 'yes',
             'VER' => '9'
  'CAMEVENT' => {
                  'MOD' => 'yes',
                  'VER' => '1'
  'EVENT' => {
               'MOD' => 'yes',
               'VER' => '5'
  'EXTEVT' => {
                'MOD' => 'yes',
                'VER' => '1'
  'EXTREC' => {
                'MOD' => 'yes',
                'VER' => '3'
  'HMODE' => {
               'MOD' => 'yes',
               'VER' => '1'
  'INFO' => {
              'MOD' => 'no',
              'VER' => 1
  'LOG' => {
             'MOD' => 'yes',
             'VER' => '3'
  'PARSET' => 1,
  'PRESET' => {
                'MOD' => 'yes',
                'VER' => '1'
  'PTZ' => {
             'MOD' => 'yes',
             'VER' => '5'
  'REC' => {
             'MOD' => 'no',
             'VER' => 6
  'SNAPSHOT' => {
                  'MOD' => 'yes',
                  'VER' => '1'
  'STM' => {
             'MOD' => 'yes',
             'VER' => '1'
  'SVSINFO' => {
                 'MOD' => 'no',
                 'VER' => 8
  'VIDEOSTM' => {
                  'MOD' => 'yes',
                  'VER' => '1'
  'VIDEOSTMS' => {
                   'MOD' => 'yes',
                   'VER' => '1'
2021.07.01 23:03:49 3: E1Zoom - no session ID found - get new one
2021.07.01 23:03:49 4: E1Zoom - --- Begin Function login ---
2021.07.01 23:03:49 4: E1Zoom - Credentials read from RAM: reolink ********
2021.07.01 23:03:49 4: E1Zoom - HTTP-Call login will be done with httptimeout-Value: 60 s
2021.07.01 23:03:49 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.API.Auth&version=6&method=Login&account=reolink&passwd=*****&session=SurveillanceStation&format="sid"
2021.07.01 23:03:49 5: E1Zoom - JSON decoded: {
  'data' => {
              'did' => 'xF34969upGVzOmwZ_UjxgZh6vkXxnT4ICEktP5rrrOBfxfwsd3aP8pHG_I5Xn9lxa7v87VIbUUOy4Icjga1R1A',
              'is_portal_port' => bless( do{\(my $o = 0)}, 'JSON::PP::Boolean' ),
              'sid' => 'JekXQrbxCQp8AUr4uIRuvdgPWiFfQJFzaN4X8R9wA1sq45AupdSu8wn2PQly8HiL1u-jXcFM_MFZbh1U3aYGvI'
2021.07.01 23:03:49 4: E1Zoom - Login of User reolink successful - SID: JekXQrbxCQp8AUr4uIRuvdgPWiFfQJFzaN4X8R9wA1sq45AupdSu8wn2PQly8HiL1u-jXcFM_MFZbh1U3aYGvI
2021.07.01 23:03:49 4: E1Zoom - --- Start getCamId ---
2021.07.01 23:03:49 4: E1Zoom - Call-Out now: https://DS415-JH:8701/webapi/entry.cgi?api=SYNO.SurveillanceStation.Camera&version=9&method="List"&basic=true&streamInfo=true&camStm=0&_sid="JekXQrbxCQp8AUr4uIRuvdgPWiFfQJFzaN4X8R9wA1sq45AupdSu8wn2PQly8HiL1u-jXcFM_MFZbh1U3aYGvI"
  'data' => {
              'cameras' => [
                               'DINum' => 0,
                               'DONum' => 0,
                               'analyticsType' => 0,
                               'appDetType' => 3,
                               'audioCodec' => 4,
                               'audioOut' => bless( do{\(my $o = 0)}, 'JSON::PP::Boolean' ),
                               'blEnableLiveBuffering' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'blG726LE' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'blPtzShowIcon' => bless( do{\(my $o = 1)}, 'JSON::PP::Boolean' ),
                               'blReceivePocZero' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'channel' => '1',
                               'deleted' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'deviceType' => 4,
                               'doorbellNum' => 0,
                               'dsId' => 0,
                               'enableLowProfile' => $VAR1->{'data'}{'cameras'}[0]{'blPtzShowIcon'},
                               'enablePtzControl' => $VAR1->{'data'}{'cameras'}[0]{'blPtzShowIcon'},
                               'enableRecordingKeepDays' => $VAR1->{'data'}{'cameras'}[0]{'blPtzShowIcon'},
                               'enableRecordingKeepSize' => $VAR1->{'data'}{'cameras'}[0]{'blPtzShowIcon'},
                               'enabled' => $VAR1->{'data'}{'cameras'}[0]{'blPtzShowIcon'},
                               'extDIDev' => 0,
                               'extDIPorts' => -1,
                               'firmware' => '',
                               'folder' => '/volume1/surveillance/C1Pro',
                               'fov' => '',
                               'hasCamParam' => $VAR1->{'data'}{'cameras'}[0]{'blPtzShowIcon'},
                               'hasEdgeStg' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'highProfileStreamNo' => 1,
                               'id' => 5,
                               'idOnRecServer' => 0,
                               'ip' => '192.168.70.45',
                               'isAudioDisableRec' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'isDisableRec' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'isEnableExtDI' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'isUnrecognized' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'ledCap' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'liveBufferingSec' => 1,
                               'liveViewSource' => 0,
                               'lowProfileStreamNo' => 1,
                               'mediumProfileStreamNo' => 1,
                               'mobileLiveViewSource' => 0,
                               'model' => 'C1 Pro',
                               'mountType' => 0,
                               'newName' => 'C1Pro',
                               'pairedSpeakerEnabled' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'pairedSpeakerId' => 0,
                               'port' => 80,
                               'postRecordTime' => 5,
                               'preRecordTime' => 5,
                               'presetNum' => 64,
                               'ptzCap' => 3,
                               'recShare' => 'surveillance',
                               'recShareMountType' => 0,
                               'recSharePath' => '/volume1/surveillance',
                               'recStatus' => 0,
                               'recStorageStatus' => 0,
                               'recVolume' => '/volume1',
                               'recordTime' => 60,
                               'recordingKeepDays' => 15,
                               'recordingKeepSize' => '500',
                               'relayPortList' => [],
                               'rotateOption' => 0,
                               'speedDryCap' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'status' => 15,
                               'statusFlags' => 0,
                               'stmFisheyeType' => 0,
                               'stream1' => {
                                              'bitrateCtrl' => 2,
                                              'constantBitrate' => '2048',
                                              'fps' => 30,
                                              'quality' => '',
                                              'resolution' => '2560x1440'
                               'tvStandard' => 1,
                               'uiStmNoList' => '1,1,1',
                               'updateTime' => 216855,
                               'vendor' => 'Reolink',
                               'videoCodec' => 3,
                               'videoMode' => '',
                               'volumeSpace' => '0',
                               'wiperCap' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'}
                               'DINum' => 0,
                               'DONum' => 0,
                               'appDetType' => 3,
                               'audioCodec' => 4,
                               'audioOut' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'blEnableLiveBuffering' => $VAR1->{'data'}{'cameras'}[0]{'blPtzShowIcon'},
                               'blPtzShowIcon' => $VAR1->{'data'}{'cameras'}[0]{'audioOut'},
                               'channel' => '1',
                               'deviceType' => 4,
                               'doorbellNum' => 0,
                               'dsId' => 0,
                               'extDIDev' => 0,
                               'extDIPorts' => -1,
                               'firmware' => 'v2.0.0.19_20050608',
                               'folder' => '/volume1/surveillance/E1-Zoom',
                               'fov' => '',
                               'id' => 9,
                               'ip' => 'e1-zoom',
                               'model' => 'E1 Zoom',
                               'mountType' => 0,
                               'newName' => 'E1-Zoom',
                               'port' => 80,
                               'presetNum' => 0,
                               'ptzCap' => 39,
                               'recStatus' => 0,
DS_Starter
juemuc
Die Frage ist, was Du unter "gut" verstehst  ;D
Es funktioniert zumindest noch nicht.
Availability Connect hist failed
Jürgen
