HMUARTLGW: Modul für HomeMatic UART-Modul (RPi) und HomeMatic LAN Gateway
Begonnen von mgernoth, 11 Juni 2016, 20:10:46
Rampler
Mit der Version vom 14.06 23:47:
2016.06.14 23:54:05 1: PERL WARNING: substr outside of string at ./FHEM/00_HMUARTLGW.pm line 559.
2016.06.14 23:54:05 1: PERL WARNING: Use of uninitialized value $a in hex at ./FHEM/00_HMUARTLGW.pm line 560.
2016.06.14 23:54:05 3: CUL_HM set Alarm_sir_ext statusRequest
2016.06.14 23:55:02 3: CUL_HM set FL.ZG.licht off
2016.06.14 23:55:12 3: CUL_HM set WF.keymatic lock
2016.06.15 00:03:54 1: PERL WARNING: substr outside of string at ./FHEM/00_HMUARTLGW.pm line 544.
2016.06.15 00:03:54 1: PERL WARNING: Use of uninitialized value $a in hex at ./FHEM/00_HMUARTLGW.pm line 545.
2016.06.15 00:04:34 3: CUL_HM set FL.OG.licht on-for-timer 600
2016.06.15 00:04:34 3: CUL_HM set FL.ZG.licht on-for-timer 600
2016.06.15 00:04:34 3: CUL_HM set FL.EG.licht on-for-timer 600
2016.06.15 00:04:34 3: CUL_HM set KU.licht on-for-timer 600
2016.06.15 00:04:34 3: CUL_HM set KU.spuele on-for-timer 600
2016.06.15 00:04:34 3: CUL_HM set HW.licht on-for-timer 600
2016.06.15 00:04:34 3: CUL_HM set WF.licht on-for-timer 600
2016.06.15 00:04:34 3: CUL_HM set FL.UG.licht on-for-timer 600
2016.06.15 00:04:35 3: CUL_HM set FL.UG.strahler on-for-timer 600
2016.06.15 00:04:35 3: CUL_HM set WC.licht on-for-timer 600
2016.06.15 00:04:35 3: CUL_HM set GA.licht on-for-timer 600
2016.06.15 00:04:35 1: sendEmail RCP: Klaus.Voigt@Online.de
2016.06.15 00:04:35 1: sendEmail Subject: FHEM Alarmanlage ausgeloest
2016.06.15 00:04:35 1: sendEmail Text: Ausloeser: HW.tk
2016.06.15 00:04:36 1: sendEmail returned: Jun 15 00:04:36 raspberry sendEmail[3755]: Email was sent successfully!
2016.06.15 00:04:36 1: Perfmon: possible freeze starting at 00:04:35, delay is 1.481
2016.06.15 00:04:36 1: PERL WARNING: Use of uninitialized value in numeric gt (>) at ./FHEM/00_HMUARTLGW.pm line 1314.
2016.06.15 00:04:37 3: CUL_HM set Alarm_sir_int statusRequest
2016.06.15 00:04:38 3: CUL_HM set BD.licht statusRequest
2016.06.15 00:04:39 1: PERL WARNING: Use of uninitialized value in substr at ./FHEM/00_HMUARTLGW.pm line 544.
.... hat sich mi der aktuellen Version erledigt ...
DANKE
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Trixie), ZWAVE, HM-Classic, und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
Rampler
Brauchst Du mehr Infomationen ?
2016.06.15 15:06:34 3: CUL_HM set WF.keymatic lock
2016.06.15 15:06:34 3: CUL_HM set GA.keymatic lock
2016.06.15 15:07:03 3: CUL_HM set FL.OG.licht on-for-timer 600
2016.06.15 15:07:03 3: CUL_HM set FL.ZG.licht on-for-timer 600
2016.06.15 15:07:03 3: CUL_HM set FL.EG.licht on-for-timer 600
2016.06.15 15:07:03 3: CUL_HM set KU.licht on-for-timer 600
2016.06.15 15:07:03 3: CUL_HM set KU.spuele on-for-timer 600
2016.06.15 15:07:03 3: CUL_HM set HW.licht on-for-timer 600
2016.06.15 15:07:03 3: CUL_HM set WF.licht on-for-timer 600
2016.06.15 15:07:03 3: CUL_HM set FL.UG.licht on-for-timer 600
2016.06.15 15:07:03 3: CUL_HM set FL.UG.strahler on-for-timer 600
2016.06.15 15:07:03 3: CUL_HM set WC.licht on-for-timer 600
2016.06.15 15:07:03 3: CUL_HM set GA.licht on-for-timer 600
2016.06.15 15:07:03 1: sendEmail RCP: Klaus.xxxxxxxxxxxxxxxx
2016.06.15 15:07:03 1: sendEmail Subject: FHEM Alarmanlage ausgeloest
2016.06.15 15:07:03 1: sendEmail Text: Ausloeser: FL.UG.tk.ke
2016.06.15 15:07:05 1: sendEmail returned: Jun 15 15:07:05 raspberry sendEmail[5630]: Email was sent successfully!
2016.06.15 15:07:05 1: Perfmon: possible freeze starting at 15:07:04, delay is 1.139
2016.06.15 15:07:05 1: HMUARTLGW HMUART did not respond, reopening
2016.06.15 15:07:05 1: HMUARTLGW HMUART Reopen
2016.06.15 15:07:05 3: Setting HMUART serial parameters to 115200,8,N,1
2016.06.15 15:07:05 1: /dev/ttyAMA0 reappeared (HMUART)
2016.06.15 15:07:06 3: CUL_HM set FL.OG.rm statusRequest
2016.06.15 15:07:06 3: HMUARTLGW HMUART currently running Co_CPU_App
2016.06.15 15:07:07 3: CUL_HM set FL.UG.rm statusRequest
2016.06.15 15:07:08 3: CUL_HM set GA.taster statusRequest
2016.06.15 15:07:08 1: HMUARTLGW HMUART Ack with invalid counter received, dropping. We: 59, device: 58
2016.06.15 15:07:09 3: CUL_HM set HZ.zs statusRequest
2016.06.15 15:07:10 1: HMUARTLGW HMUART Ack with invalid counter received, dropping. We: 63, device: 62
2016.06.15 15:07:10 3: CUL_HM set KG.rm statusRequest
2016.06.15 15:07:10 1: HMUARTLGW HMUART Ack with invalid counter received, dropping. We: 65, device: 64
2016.06.15 15:07:11 1: HMUARTLGW HMUART Ack with invalid counter received, dropping. We: 68, device: 66
2016.06.15 15:07:11 3: CUL_HM set KK.rm statusRequest
2016.06.15 15:07:11 1: HMUARTLGW HMUART Ack with invalid counter received, dropping. We: 70, device: 69
2016.06.15 15:07:12 1: HMUARTLGW HMUART Ack with invalid counter received, dropping. We: 73, device: 71
2016.06.15 15:07:31 3: CUL_HM set FL.OG.licht off
2016.06.15 15:07:31 3: CUL_HM set FL.ZG.licht off
2016.06.15 15:07:31 3: CUL_HM set FL.EG.licht off
2016.06.15 15:07:31 3: CUL_HM set KU.licht off
2016.06.15 15:07:31 3: CUL_HM set KU.spuele off
2016.06.15 15:07:31 3: CUL_HM set HW.licht off
2016.06.15 15:07:31 3: CUL_HM set WF.licht off
2016.06.15 15:07:31 3: CUL_HM set FL.UG.licht off
2016.06.15 15:07:31 3: CUL_HM set FL.UG.strahler off
2016.06.15 15:07:31 3: CUL_HM set WC.licht off
2016.06.15 15:07:31 3: CUL_HM set GA.licht off
2016.06.15 15:07:32 3: CUL_HM set Rauchmelder alarmOff
2016.06.15 15:07:35 3: CUL_HM set GA.keymatic unlock
Das passende EventLog dazu:
2016-06-15 15:05:32 dummy Alarm_status wait
2016-06-15 15:05:32 CUL_HM FL.EG.gong.mp3 set_playTone 05
2016-06-15 15:05:32 at Alarm_set_armedext_delay Next: 15:06:32
2016-06-15 15:05:32 Global global DEFINED Alarm_set_armedext_delay
2016-06-15 15:05:32 dummy Alarm_set_armedext on
2016-06-15 15:05:32 CUL_HM Alarm_switch_btn1 trigger: Short_123
2016-06-15 15:05:33 CUL_HM FL.EG.anzeige.led01 color: orange
2016-06-15 15:05:34 CUL_HM FL.EG.gong.mp3 on
2016-06-15 15:05:34 CUL_HM HW.bm motion: off
2016-06-15 15:05:41 CUL_HM FL.EG.gong.mp3 off
2016-06-15 15:06:29 CUL_HM KU.bm motion: on (to KU.licht)
2016-06-15 15:06:31 CUL_HM FL.UG.bm motion: on (to FL.UG.licht)
2016-06-15 15:06:32 dummy Alarm_status armedext
2016-06-15 15:06:32 CUL_HM FL.EG.gong.mp3 set_playTone 08
2016-06-15 15:06:32 Global global DELETED Alarm_set_armedext_delay
2016-06-15 15:06:32 CUL_HM FL.EG.anzeige.led01 color: green
2016-06-15 15:06:33 CUL_HM FL.EG.gong.mp3 on
2016-06-15 15:06:34 CUL_HM GA.keymatic set_lock
2016-06-15 15:06:34 CUL_HM FL.EG.gong.led set_led greenL 255
2016-06-15 15:06:35 CUL_HM GA.keymatic unlocked (uncertain)
2016-06-15 15:06:40 CUL_HM GA.keymatic locked
2016-06-15 15:06:40 CUL_HM FL.EG.gong.mp3 off
2016-06-15 15:06:42 CUL_HM FL.EG.anzeige.led12 color: green
2016-06-15 15:06:44 CUL_HM FL.EG.gong.led on
2016-06-15 15:06:56 CUL_HM KU.bm motion: on (to vccu)
2016-06-15 15:07:03 dummy Alarm_status trigger_FL.UG.tk.ke
2016-06-15 15:07:03 structure Alarm_licht_all on-for-timer 600
2016-06-15 15:07:03 CUL_HM FL.OG.licht set_on-for-timer 600
2016-06-15 15:07:03 CUL_HM FL.ZG.licht set_on-for-timer 600
2016-06-15 15:07:03 CUL_HM FL.EG.licht set_on-for-timer 600
2016-06-15 15:07:03 CUL_HM KU.licht set_on-for-timer 600
2016-06-15 15:07:03 CUL_HM KU.spuele set_on-for-timer 600
2016-06-15 15:07:03 CUL_HM HW.licht set_on-for-timer 600
2016-06-15 15:07:03 CUL_HM WF.licht set_on-for-timer 600
2016-06-15 15:07:03 CUL_HM FL.UG.licht set_on-for-timer 600
2016-06-15 15:07:03 CUL_HM FL.UG.strahler set_on-for-timer 600
2016-06-15 15:07:03 CUL_HM WC.licht set_on-for-timer 600
2016-06-15 15:07:03 CUL_HM GA.licht set_on-for-timer 600
2016-06-15 15:07:03 CUL_HM FL.EG.gong.mp3 set_playTone 12
2016-06-15 15:07:03 at Alarm_sir_delayed Next: 15:07:33
2016-06-15 15:07:03 Global global DEFINED Alarm_sir_delayed
2016-06-15 15:07:05 CUL_HM FL.UG.tk.ke open
2016-06-15 15:07:05 CUL_HM FL.UG.bm motion: off
2016-06-15 15:07:05 structure HMIO_STATE all_ok
2016-06-15 15:07:05 HMUARTLGW HMUART CONNECTED
2016-06-15 15:07:05 CUL_HM FL.UG.bm motion: on (to FL.UG.licht)
2016-06-15 15:07:05 structure Alarm_licht_all undefined
2016-06-15 15:07:05 CUL_HM FL.UG.licht NACK
2016-06-15 15:07:05 structure Alarm_licht_all on
2016-06-15 15:07:05 CUL_HM FL.UG.licht on
2016-06-15 15:07:05 structure Alarm_licht_all off
2016-06-15 15:07:05 CUL_HM FL.UG.licht off
2016-06-15 15:07:05 CUL_HM FL.UG.strahler on
2016-06-15 15:07:05 CUL_HM GA.licht on
2016-06-15 15:07:06 CUL_HM Rauchmelder off
2016-06-15 15:07:07 structure HMIO_STATE all_ok
2016-06-15 15:07:07 HMUARTLGW HMUART D-HMIdAssigned: 29A083
2016-06-15 15:07:07 HMUARTLGW HMUART D-HMIdOriginal: 45F973
2016-06-15 15:07:07 HMUARTLGW HMUART D-firmware: 1.4.1
2016-06-15 15:07:07 HMUARTLGW HMUART D-serialNr: MEQ1889725
2016-06-15 15:07:07 CUL_HM FL.EG.gong.led set_off
2016-06-15 15:07:07 CUL_HM FL.UG.tk.ke closed
2016-06-15 15:07:07 CUL_HM Rauchmelder off
2016-06-15 15:07:12 CUL_HM FL.EG.anzeige.led14 color: red
2016-06-15 15:07:13 CUL_HM FL.ZG.licht on
2016-06-15 15:07:13 CUL_HM FL.OG.licht on
2016-06-15 15:07:14 CUL_HM WF.licht on
2016-06-15 15:07:14 CUL_HM WC.licht on
2016-06-15 15:07:15 CUL_HM KG.rm unreachable
2016-06-15 15:07:15 CUL_HM HW.licht on
2016-06-15 15:07:16 CUL_HM KK.rm unreachable
2016-06-15 15:07:16 CUL_HM FL.EG.gong.mp3 on
2016-06-15 15:07:16 CUL_HM FL.EG.licht on
2016-06-15 15:07:17 CUL_HM KU.licht on
2016-06-15 15:07:18 CUL_HM KU.spuele on
2016-06-15 15:07:19 CUL_HM KK.rm battery: ok
2016-06-15 15:07:19 CUL_HM KK.rm level: 1
2016-06-15 15:07:19 CUL_HM KK.rm off
2016-06-15 15:07:19 CUL_HM Rauchmelder unreachable
2016-06-15 15:07:20 CUL_HM KG.rm ResndFail
2016-06-15 15:07:20 CUL_HM KG.rm MISSING ACK
2016-06-15 15:07:20 CUL_HM FL.EG.anzeige.led01 color: red
2016-06-15 15:07:23 CUL_HM FL.EG.gong.mp3 on
2016-06-15 15:07:24 CUL_HM FL.EG.gong.mp3 on
2016-06-15 15:07:28 CUL_HM FL.EG.gong.led off
2016-06-15 15:07:29 CUL_HM FL.EG.anzeige.led09 color: red
2016-06-15 15:07:30 CUL_HM KU.bm motion: on (to KU.licht)
2016-06-15 15:07:31 Global global DELETED Alarm_sir_delayed
2016-06-15 15:07:31 structure Alarm_licht_all off
2016-06-15 15:07:31 CUL_HM FL.OG.licht set_off
2016-06-15 15:07:31 CUL_HM FL.ZG.licht set_off
2016-06-15 15:07:31 CUL_HM FL.EG.licht set_off
2016-06-15 15:07:31 CUL_HM KU.licht set_off
2016-06-15 15:07:31 CUL_HM KU.spuele set_off
2016-06-15 15:07:31 CUL_HM HW.licht set_off
2016-06-15 15:07:31 CUL_HM WF.licht set_off
2016-06-15 15:07:31 CUL_HM FL.UG.licht set_off
2016-06-15 15:07:31 CUL_HM FL.UG.strahler set_off
2016-06-15 15:07:31 CUL_HM WC.licht set_off
2016-06-15 15:07:31 CUL_HM GA.licht set_off
2016-06-15 15:07:32 CUL_HM RM.td CMDs_pending
2016-06-15 15:07:32 dummy Alarm_status disarmed
2016-06-15 15:07:32 dummy Alarm_set_armedext off
2016-06-15 15:07:32 CUL_HM Alarm_switch_btn1 trigger: Long_124
2016-06-15 15:07:32 CUL_HM KG.rm smoke_detect: none
2016-06-15 15:07:32 CUL_HM KG.rm off
2016-06-15 15:07:32 CUL_HM KK.rm smoke_detect: none
2016-06-15 15:07:32 CUL_HM KK.rm off
2016-06-15 15:07:32 CUL_HM KU.rm smoke_detect: none
2016-06-15 15:07:32 CUL_HM KU.rm off
2016-06-15 15:07:32 CUL_HM Rauchmelder eventNo: 0C
2016-06-15 15:07:32 CUL_HM Rauchmelder level: 1
2016-06-15 15:07:32 CUL_HM Rauchmelder smoke_detect: none
2016-06-15 15:07:32 CUL_HM Rauchmelder off
2016-06-15 15:07:32 CUL_HM SZ.rm smoke_detect: none
2016-06-15 15:07:32 CUL_HM SZ.rm off
2016-06-15 15:07:32 CUL_HM FL.EG.anzeige.led14 color: green
2016-06-15 15:07:32 CUL_HM FL.UG.licht off
2016-06-15 15:07:32 CUL_HM FL.UG.strahler off
2016-06-15 15:07:32 CUL_HM FL.OG.licht off
2016-06-15 15:07:32 CUL_HM Rauchmelder trigger_cnt: 12
2016-06-15 15:07:32 CUL_HM RM.td CMDs_done
2016-06-15 15:07:33 CUL_HM FL.ZG.licht off
2016-06-15 15:07:33 CUL_HM Rauchmelder trigger_cnt: 12
2016-06-15 15:07:33 CUL_HM FL.EG.gong.mp3 set_playTone 7
2016-06-15 15:07:33 CUL_HM GA.licht off
2016-06-15 15:07:34 CUL_HM FL.EG.licht off
2016-06-15 15:07:35 CUL_HM GA.keymatic set_unlock
2016-06-15 15:07:35 CUL_HM KU.licht off
2016-06-15 15:07:35 CUL_HM KU.spuele off
2016-06-15 15:07:35 CUL_HM GA.keymatic locked (uncertain)
2016-06-15 15:07:37 CUL_HM FL.UG.bm motion: off
2016-06-15 15:07:37 CUL_HM WF.licht off
2016-06-15 15:07:38 CUL_HM WC.licht off
2016-06-15 15:07:39 CUL_HM FL.EG.gong.mp3 on
2016-06-15 15:07:40 CUL_HM GA.keymatic unlocked
2016-06-15 15:07:46 CUL_HM HW.licht ResndFail
2016-06-15 15:07:46 CUL_HM HW.licht MISSING ACK
2016-06-15 15:07:48 CUL_HM FL.EG.gong.mp3 off
2016-06-15 15:07:48 CUL_HM HW.licht off
2016-06-15 15:07:52 CUL_HM HW.bm motion: on (to HW.licht)
2016-06-15 15:07:53 CUL_HM FL.EG.gong.mp3 off
2016-06-15 15:07:54 CUL_HM FL.EG.anzeige.led01 color: off
2016-06-15 15:07:55 CUL_HM HW.tk open
2016-06-15 15:07:58 CUL_HM FL.EG.anzeige.led09 color: off
2016-06-15 15:08:00 CUL_HM FL.EG.anzeige.led12 color: orange
2016-06-15 15:08:00 CUL_HM FL.EG.anzeige.led07 color: red
2016-06-15 15:08:00 CUL_HM HW.tk closed
2016-06-15 15:08:03 CUL_HM FL.EG.anzeige.led07 color: orange
2016-06-15 15:08:09 CUL_HM HW.bm motion: off
2016-06-15 15:08:32 CUL_HM KU.bm motion: on (to KU.licht)
Beim manuellen setzen der structure "Alarm_licht_all" funktioniert es tadellos..
Kann auch gerne nochmal mit Verbose 5 aufzeichnen..
Rampler
Mit der aktuellen Version funktioniert meine keymatic nicht mehr..
Nach Umstellung auf IOGrp vccu:alterAdapter funktioniert es wieder...
2016.06.15 15:23:07 3: CUL_HM set WF.keymatic unlock
2016.06.15 15:23:07 5: HMUARTLGW HMUART send: 01 02 00 00 01 msg: 0D B0 11 29A083 261118 800101FF
2016.06.15 15:23:07 5: HMUARTLGW HMUART send: (24): fd00130116020000010db01129a083261118800101ff8d91
2016.06.15 15:23:07 5: SW: fd00130116020000010db01129a083261118800101ff8d91
2016.06.15 15:23:08 5: HMUARTLGW HMUART read raw (8): fd001701c9050001
2016.06.15 15:23:08 5: HMUARTLGW HMUART read raw (20): 330da00226111829a08304463f34bfaee4029d5c
2016.06.15 15:23:08 5: HMUARTLGW HMUART read (27): fd001701c9050001330da00226111829a08304463f34bfaee4029d5c crc OK
2016.06.15 15:23:08 5: HMUARTLGW HMUART recv: 01 05 00 01 33 msg: 0D A0 02 261118 29A083 04463F34BFAEE402
2016.06.15 15:23:08 5: HMUARTLGW HMUART Dispatch: A110DA00226111829A08304463F34BFAEE402::-51:HMUART
2016.06.15 15:23:08 5: HMUART dispatch A110DA00226111829A08304463F34BFAEE402::-51:HMUART
2016.06.15 15:23:08 5: HMUARTLGW HMUART: Skip ACK
2016.06.15 15:23:09 5: HMUARTLGW HMUART read raw (8): fd0004001505c61c
2016.06.15 15:23:09 5: HMUARTLGW HMUART read raw (1): a8
2016.06.15 15:23:09 5: HMUARTLGW HMUART read (8): fd0004001505c61ca8 crc OK
2016.06.15 15:23:09 5: HMUARTLGW HMUART recv: 00 05C6, state 100
2016.06.15 15:23:09 5: HMUARTLGW HMUART read raw (8): fd001701ca050001
2016.06.15 15:23:09 5: HMUARTLGW HMUART read raw (20): 330da00226111829a083049265c999ab5a0293e0
2016.06.15 15:23:09 5: HMUARTLGW HMUART read (27): fd001701ca050001330da00226111829a083049265c999ab5a0293e0 crc OK
2016.06.15 15:23:09 5: HMUARTLGW HMUART recv: 01 05 00 01 33 msg: 0D A0 02 261118 29A083 049265C999AB5A02
2016.06.15 15:23:09 5: HMUARTLGW HMUART Dispatch: A110DA00226111829A083049265C999AB5A02::-51:HMUART
2016.06.15 15:23:09 5: HMUART dispatch A110DA00226111829A083049265C999AB5A02::-51:HMUART
2016.06.15 15:23:09 5: HMUARTLGW HMUART: Skip ACK
mgernoth
Bitte das Attribut logIDs am HMUART auf "sys,all" setzen, nicht mit Verbose 5 aufzeichnen.
Und ganz wichtig: Auch immer Kontext _vor_ dem Problem mitschicken! (Wenn möglich ein reopen des Geräts und die ganzen Nachrichten ab dem Open bis zum Fehler).
  Michae
Rampler
hat eigentlich irgend jemand Martin angesprochen, damit er die Änderungen in die 10_CUL_HM.pm aufnimmt, bzw. gab es da schon ein Feedback ?
Wie sieht es denn mit der 00_HMUARTLGW.pm aus, wird diese auch in das FHEM Repository aufgenommen ?
mfg
Klaus
betateilchen
Diese Frage hat doch Michael schon hier im Thread beantwortet.
Und was martin angeht, der macht das Ganze auch nur nebenbei und er wird sich das sicher anschauen, wenn er die entsprechende Zeit & Ruhe hat, sich des Themas anzunehmen.
betateilchen
An alle, die ihre 10_CUL_HM.pm gemäß der Anleitung hier im Thread gepatched haben, der Hinweis, dass morgen per update eine neue Version dieser Moduldatei kommt, in der (bisher) die notwendigen Änderungen für hmuart noch nicht enthalten sind.
Also bitte Vorsicht beim morgigen Update.
Rampler
Habe den UART jetzt seit ein paar Tagen zusammen mit zwei HMLAN Adaptern am laufen, und bis jetzt keine Fehlfunktion feststellen können.  :)
Allerdings finde ich im Log immer mal wieder solche Meldungen:
ZitatHMUARTLGW HMUART Ack with invalid counter received, dropping. We: 119, device: 118
Wobei die device immer wieder eine andere ist. Kann mir nicht erklären woher dies kommt. Evtl. durch die zusätzlichen HMLAN Adapter ?
mfg
Klaus
betateilchen
Installiere einfach mal die aktuelle Modulversion, dann sollte die Meldung verschwinden.
Rampler
Leider Nein, habe die aktuelle Version vom github..
mgernoth
Ich brauche da mehr Logs. Zumindest die Nachrichten um die Meldung herum, ansonsten kann ich das nicht debuggen.
  Michael
Rampler
So, habe jetzt mal eine Meldung aufgezeichnet:
2016.06.19 00:06:44 0: HMUARTLGW HMUART recv: 00 04020B, state 98
2016.06.19 00:06:44 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 00:06:55 0: HMUARTLGW HMUART recv: 01 05 00 01 3D msg: B6 A4 41 2FDB9E 2DE4BB 01940850
2016.06.19 00:06:55 0: HMUARTLGW HMUART recv: 01 05 00 01 43 msg: B6 80 02 2DE4BB 2FDB9E 0101C84050
2016.06.19 00:06:57 0: HMUARTLGW HMUART recv: 01 05 01 01 41 msg: B7 A4 10 2DE4BB 29A083 0601C840
2016.06.19 00:06:59 0: HMUARTLGW HMUART send: 00 08
2016.06.19 00:06:59 0: HMUARTLGW HMUART recv: 00 04020B, state 98
2016.06.19 00:06:59 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 00:07:01 0: HMUARTLGW HMUART recv: 01 05 00 01 34 msg: 79 84 10 33BADB 29A083 06012100
2016.06.19 00:07:01 0: HMUARTLGW HMUART recv: 01 05 01 01 49 msg: 55 A6 41 30A96E 29A083 0161C8
2016.06.19 00:07:01 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 55 80 02 29A083 30A96E 0101C800
2016.06.19 00:07:02 3: CUL_HM set FL.OG.licht on-for-timer 600
2016.06.19 00:07:02 3: CUL_HM set FL.ZG.licht on-for-timer 600
2016.06.19 00:07:02 3: CUL_HM set FL.EG.licht on-for-timer 600
2016.06.19 00:07:02 3: CUL_HM set KU.licht on-for-timer 600
2016.06.19 00:07:02 3: CUL_HM set KU.spuele on-for-timer 600
2016.06.19 00:07:02 3: CUL_HM set HW.licht on-for-timer 600
2016.06.19 00:07:02 3: CUL_HM set WF.licht on-for-timer 600
2016.06.19 00:07:02 3: CUL_HM set FL.UG.licht on-for-timer 600
2016.06.19 00:07:02 3: CUL_HM set FL.UG.strahler on-for-timer 600
2016.06.19 00:07:02 3: CUL_HM set WC.licht on-for-timer 600
2016.06.19 00:07:02 3: CUL_HM set GA.licht on-for-timer 600
2016.06.19 00:07:02 1: sendEmail RCP: xxxxxxxxxxxxxxxxxx
2016.06.19 00:07:02 1: sendEmail Subject: FHEM Alarmanlage ausgeloest
2016.06.19 00:07:02 1: sendEmail Text: Ausloeser: FL.UG.tk.ke
2016.06.19 00:07:03 1: sendEmail returned: Jun 19 00:07:03 raspberry sendEmail[15529]: Email was sent successfully!
2016.06.19 00:07:03 1: Perfmon: possible freeze starting at 00:07:02, delay is 1.913
2016.06.19 00:07:03 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 70 A0 11 29A083 1B254C 800E01
2016.06.19 00:07:03 0: HMUARTLGW HMUART send: FD is readable! This might corrupt the received frame!
2016.06.19 00:07:03 0: HMUARTLGW HMUART recv: 01 0408, state 100
[b]2016.06.19 00:07:03 1: HMUARTLGW HMUART Ack with invalid counter received, dropping. We: 73, device: 72[/b]
2016.06.19 00:07:03 0: HMUARTLGW HMUART recv: 01 05 00 01 4D msg: B8 A0 11 29A083 2DE4BB 0201C80000BB82
2016.06.19 00:07:03 0: HMUARTLGW HMUART recv: 01 05 01 01 42 msg: B8 80 02 2DE4BB 29A083 0101C84037
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 05 01 01 2C msg: 30 84 10 287108 29A083 06012300
2016.06.19 00:07:04 0: HMUARTLGW HMUART send: 01 072DE4BB
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 04 03 01 32 msg: 70 80 02 1B254C 29A083 010E010034
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 04070101002A, state 90
2016.06.19 00:07:04 0: HMUARTLGW HMUART GetSet Ack: 07, state 90
2016.06.19 00:07:04 0: HMUARTLGW HMUART send: 01 072F1090
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 040701010029, state 90
2016.06.19 00:07:04 0: HMUARTLGW HMUART send: 01 08
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 040701092D9008FFFFFFFFFFFFFFFF0035C7E2FFFFFFFFFFFFFFFF002DCF27FFFFFFFFFFFFFFFF0041C72FFFFFFFFFFFFFFFFF002D9034FFFFFFFFFFFFFFFF00, state 93
2016.06.19 00:07:04 0: HMUARTLGW HMUART GetSet Ack: 07, state 93
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2D9008, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 35C7E2, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2DCF27, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 41C72F, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2D9034, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 040702092DE136FFFFFFFFFFFFFFFF002DE13AFFFFFFFFFFFFFFFF002F038AFFFFFFFFFFFFFFFF0026110DFFFFFFFFFFFFFFFF00261118FFFFFFFFFFFFFFFF00, state 93
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2DE136, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2DE13A, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2F038A, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 26110D, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 261118, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 04070309287108FFFFFFFFFFFFFFFF0030A8DBFFFFFFFFFFFFFFFF00322BFAFFFFFFFFFFFFFFFF01344397FFFFFFFFFFFFFFFF012A5517FFFFFFFFFFFFFFFF00, state 93
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 287108, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 30A8DB, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 322BFA, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 344397, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2A5517, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 040704092F0F99FFFFFFFFFFFFFFFF002F0FA1FFFFFFFFFFFFFFFF0030B463FFFFFFFFFFFFFFFF002F046FFFFFFFFFFFFFFFFF002DAA03FFFFFFFFFFFFFFFF00, state 93
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2F0F99, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2F0FA1, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 30B463, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2F046F, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2DAA03, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 040705092DAA09FFFFFFFFFFFFFFFF001B254CFFFFFFFFFFFFFFFF0032570EFFFFFFFFFFFFFFFF00383A9FFFFFFFFFFFFFFFFF002F0FE2FFFFFFFFFFFFFFFF00, state 93
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2DAA09, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 1B254C, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 32570E, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 383A9F, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2F0FE2, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 0407060930A96EFFFFFFFFFFFFFFFF0047A778FFFFFFFFFFFFFFFF012EF73FFFFFFFFFFFFFFFFF0035C94CFFFFFFFFFFFFFFFF002ED351FFFFFFFFFFFFFFFF00, state 93
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 30A96E, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 47A778, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2EF73F, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 35C94C, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2ED351, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 040707092F0292FFFFFFFFFFFFFFFF002A55C1FFFFFFFFFFFFFFFF002B1983FFFFFFFFFFFFFFFF0041D1CEFFFFFFFFFFFFFFFF0030A9CEFFFFFFFFFFFFFFFF00, state 93
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2F0292, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2A55C1, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2B1983, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 41D1CE, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 30A9CE, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 040708092C0833FFFFFFFFFFFFFFFF002EEC7CFFFFFFFFFFFFFFFF002F0303FFFFFFFFFFFFFFFF002E26B3FFFFFFFFFFFFFFFF002B493AFFFFFFFFFFFFFFFF00, state 93
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2C0833, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2EEC7C, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2F0303, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2E26B3, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2B493A, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 040709092C15FEFFFFFFFFFFFFFFFF00, state 93
2016.06.19 00:07:04 0: HMUARTLGW HMUART known peer: 2C15FE, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 00:07:04 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 06 A0 11 29A083 2E26B3 0201C80000BB82
2016.06.19 00:07:04 0: HMUARTLGW HMUART send: FD is readable! This might corrupt the received frame!
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 05 00 01 4E msg: 94 A0 11 29A083 287AFD 0201C80000BB82
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 05 00 01 51 msg: 94 80 02 287AFD 29A083 0101C84046
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 0406, state 100
2016.06.19 00:07:04 0: HMUARTLGW HMUART can't send due to CSMA/CA, trying again in a bit
2016.06.19 00:07:04 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 1B A0 11 29A083 2DCF27 0201C80000BB82
2016.06.19 00:07:04 0: HMUARTLGW HMUART recv: 01 04 03 01 3D msg: 06 80 02 2E26B3 29A083 0101C84043
2016.06.19 00:07:05 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 2A A0 11 29A083 2DAA03 0201C80000BB82
2016.06.19 00:07:05 0: HMUARTLGW HMUART recv: 01 04 03 01 36 msg: 1B 80 02 2DCF27 29A083 0101C8403C
2016.06.19 00:07:06 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: A7 A0 11 29A083 2F0F99 0201C80000BB82
2016.06.19 00:07:06 0: HMUARTLGW HMUART recv: 01 04 03 01 40 msg: 2A 80 02 2DAA03 29A083 0101C84048
2016.06.19 00:07:06 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 0C A0 11 29A083 2F038A 0201C80000BB82
2016.06.19 00:07:06 0: HMUARTLGW HMUART recv: 01 04 03 01 43 msg: A7 80 02 2F0F99 29A083 0101C8404B
2016.06.19 00:07:07 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 7A A0 11 29A083 2F0303 0201C80000BB82
2016.06.19 00:07:07 0: HMUARTLGW HMUART recv: 01 04 03 01 37 msg: 0C 80 02 2F038A 29A083 0101C8403E
2016.06.19 00:07:07 0: HMUARTLGW HMUART recv: 01 05 01 01 37 msg: 58 A6 10 2EEC7C 29A083 06010C00
2016.06.19 00:07:07 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 0B A0 11 29A083 2DAA09 0201C80000BB82
2016.06.19 00:07:07 0: HMUARTLGW HMUART recv: 01 04 03 01 3E msg: 7A 80 02 2F0303 29A083 0101C84059
2016.06.19 00:07:08 0: HMUARTLGW HMUART send: 00 08
2016.06.19 00:07:08 0: HMUARTLGW HMUART recv: 01 04 03 01 47 msg: 0B 80 02 2DAA09 29A083 0101C8404E
2016.06.19 00:07:08 0: HMUARTLGW HMUART recv: 00 04020D, state 98
2016.06.19 00:07:08 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 00:07:08 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 57 A0 11 29A083 2F046F 0201C80000BB82
2016.06.19 00:07:08 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 74 A0 11 29A083 322BFA 8002C8010C00000000000000000083CA
2016.06.19 00:07:08 0: HMUARTLGW HMUART recv: 01 04 03 01 3B msg: 57 80 02 2F046F 29A083 0101C84045
2016.06.19 00:07:09 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 0B A0 11 29A083 2DAA09 0201C80000BB82
2016.06.19 00:07:09 0: HMUARTLGW HMUART recv: 01 04 03 01 26 msg: 74 80 02 322BFA 29A083 0102C8402B
2016.06.19 00:07:09 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: A7 A0 11 29A083 2F0F99 0201C80000BB82
2016.06.19 00:07:09 0: HMUARTLGW HMUART recv: 01 04 03 01 47 msg: 0B 80 02 2DAA09 29A083 0101C8404F
2016.06.19 00:07:10 0: HMUARTLGW HMUART recv: 01 0404, state 100
2016.06.19 00:07:10 0: HMUARTLGW HMUART can't send due to unknown problem (no response?)
2016.06.19 00:07:10 0: HMUARTLGW HMUART recv: 01 05 01 01 44 msg: A7 80 02 2F0F99 29A083 0101C8404B
2016.06.19 00:07:11 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 71 A0 11 29A083 1B254C 800101
2016.06.19 00:07:11 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 2A A0 11 29A083 2DAA03 0201C80000BB82
2016.06.19 00:07:11 0: HMUARTLGW HMUART recv: 01 04 03 01 32 msg: 71 80 02 1B254C 29A083 0101010034
2016.06.19 00:07:12 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 57 A0 11 29A083 2F046F 0201C80000BB82
2016.06.19 00:07:12 0: HMUARTLGW HMUART recv: 01 04 03 01 40 msg: 2A 80 02 2DAA03 29A083 0101C84048
2016.06.19 00:07:12 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 0C A0 11 29A083 2F038A 0201C80000BB82
2016.06.19 00:07:12 0: HMUARTLGW HMUART recv: 01 04 03 01 3B msg: 57 80 02 2F046F 29A083 0101C84044
2016.06.19 00:07:13 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 7A A0 11 29A083 2F0303 0201C80000BB82
2016.06.19 00:07:13 0: HMUARTLGW HMUART recv: 01 04 03 01 37 msg: 0C 80 02 2F038A 29A083 0101C8403D
2016.06.19 00:07:13 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 58 80 02 29A083 2EEC7C 01010C00
2016.06.19 00:07:13 0: HMUARTLGW HMUART recv: 01 04 03 01 3E msg: 7A 80 02 2F0303 29A083 0101C84059
2016.06.19 00:07:14 0: HMUARTLGW HMUART send: 00 08
2016.06.19 00:07:14 0: HMUARTLGW HMUART recv: 00 04020F, state 98
2016.06.19 00:07:14 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 00:07:14 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 74 A0 11 29A083 322BFA 8002C8010C00000000000000000083CA
2016.06.19 00:07:14 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 71 A0 11 29A083 1B254C 800101
2016.06.19 00:07:14 0: HMUARTLGW HMUART recv: 01 04 03 01 26 msg: 74 80 02 322BFA 29A083 0102C8402B
2016.06.19 00:07:14 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 0B A0 11 29A083 2DAA09 0201C80000BB82
2016.06.19 00:07:14 0: HMUARTLGW HMUART recv: 01 04 03 01 32 msg: 71 80 02 1B254C 29A083 0101010034
2016.06.19 00:07:15 0: HMUARTLGW HMUART recv: 01 05 01 01 42 msg: 56 A6 41 30A96E 29A083 016200
2016.06.19 00:07:15 0: HMUARTLGW HMUART recv: 01 0404, state 100
2016.06.19 00:07:15 0: HMUARTLGW HMUART can't send due to unknown problem (no response?)
2016.06.19 00:07:15 0: HMUARTLGW HMUART recv: 01 05 01 01 48 msg: 0B 80 02 2DAA09 29A083 0101C8404F
2016.06.19 00:07:15 0: HMUARTLGW HMUART send: 00 08
2016.06.19 00:07:15 0: HMUARTLGW HMUART recv: 00 040210, state 98
bis dann
  Klaus
mgernoth
Super, Danke. :-)
Dann habe ich genau das jetzt auch gerade gefixed (war die einzige Möglichkeit, die ich mir vorstellen konnte).
Hier wird ein Kommando ohne Ack-Anforderung gesendet, darauf antwortet das Modul entweder gar nicht oder sehr schnell (deutlich weniger als 100ms). Deswegen wird ab jetzt 100ms auf eine evtl. Fehlermeldung des Moduls "gewartet" (Timer aufgesetzt).
Dein EMail-senden ist synchron und blockiert Fhem, weswegen die Antwort nicht zeitnah vom Modul abgeholt wird. Stattdessen werden zuerst (von fhem.pl) die Timer abgearbeitet und darin (in HMUARTLGW) festgestellt, dass keine Antwort kam und deshalb das Kommando wohl gesendet wurde.
So lange Blockaden sind keine gute Idee!
Das nächste Kommando wird abgeschickt.
Beim Senden wird festgestellt, dass noch Daten anliegen (das Modul zerschiesst in manchen Fällen Daten wenn gleichzeitig in beide Richtungen seriell kommuniziert wird, deswegen diese "might corrupt" Ausgabe).
Die empfangenen Daten "01 0408" sagen dann auch, dass das erste Sendekommando fehlgeschlagen ist (das aber nicht mehr aktuell ist, daher auch die Meldung bzg. invalid counter).
Ich habe das jetzt behoben, indem nochmal explizit geprüft wird ob Daten anliegen, wenn der Timeout zuschlägt. Diese werden dann noch verarbeitet.
  Michael
Rampler
ZitatIch habe das jetzt behoben, indem nochmal explizit geprüft wird ob Daten anliegen, wenn der Timeout zuschlägt. Diese werden dann noch verarbeitet.
Habe Deine Änderung gerade eingebaut, ich werde berichten...
ZitatDein EMail-senden ist synchron und blockiert Fhem, weswegen die Antwort nicht zeitnah vom Modul abgeholt wird. Stattdessen werden zuerst (von fhem.pl) die Timer abgearbeitet und darin (in HMUARTLGW) festgestellt, dass keine Antwort kam und deshalb das Kommando wohl gesendet wurde.
Sehe ich auch so, allerdings gibt es beim Email versenden keine andere Möglichkeit, leider..
Der Support hier im Forum war schon immer super, aber speziell für das das HMUARTLGW Modul wohl nicht mehr zu toppen..  :)
bis die Tage
   Klaus
Rampler
Guten Morgen,
habe jetzt das aktuelle Modul installiert und FHEM restartet..
2016.06.19 07:45:45 0: Featurelevel: 5.7
2016.06.19 07:45:45 0: Server started with 308 defined entities (fhem.pl:11611/2016-06-04 perl:5.014002 os:linux user:fhem pid:16477)
2016.06.19 07:45:45 1: Perfmon: possible freeze starting at 07:45:32, delay is 13.604
2016.06.19 07:45:45 0: HMUARTLGW HMUART send: 00 00
2016.06.19 07:45:45 0: HMUARTLGW HMUART recv: 00 0402436F5F4350555F417070, state 1
2016.06.19 07:45:45 3: HMUARTLGW HMUART currently running Co_CPU_App
2016.06.19 07:45:45 1: HMLAN_Parse: HMLAN1 new condition ok
2016.06.19 07:45:46 3: CUL_HM set AZ.rm statusRequest
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 05 00 01 55 msg: 02 B0 01 29A083 2A55C1 010E
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 0029A083
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 0401, state 4
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 01, state 4
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 01
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 0407010129A083, state 5
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 07, state 5
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 10
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: FD is readable! This might corrupt the received frame, so processing data now
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 0407010129A083, state 6
2016.06.19 07:45:46 1: HMUARTLGW HMUART Ack with invalid counter received, dropping. We: 4, device: 3, state: 6, msg: 1 0407010129A083
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 05 00 01 25 msg: 02 A0 10 2A55C1 29A083 0601010058
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 0407010145F973, state 6
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 07, state 6
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 00 0E5766318A04
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 00 0401, state 7
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 01, state 7
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 00 02
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 00 0402010003010401, state 8
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 02, state 8
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 00 0B
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 00 04024D455131383839373235, state 9
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 02, state 9
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 00 0A01
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 00 0401, state 10
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 01, state 10
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 00 0901
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 00 0401, state 11
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 01, state 11
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 03749D193DFF62CDD85B5C22873DAB6A4001
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 0401, state 12
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 01, state 12
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 0F0000000000000000000000000000000000
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 0401, state 13
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 01, state 13
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 0B0000000000000000000000000000000000
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 0401, state 14
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 01, state 14
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 08
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 04070101261118FFFFFFFFFFFFFFFF01322BFAFFFFFFFFFFFFFFFF01344397FFFFFFFFFFFFFFFF011B254CFFFFFFFFFFFFFFFF0047A778FFFFFFFFFFFFFFFF01, state 15
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 07, state 15
2016.06.19 07:45:46 0: HMUARTLGW HMUART known peer: 261118, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:46 0: HMUARTLGW HMUART known peer: 322BFA, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:46 0: HMUARTLGW HMUART known peer: 344397, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:46 0: HMUARTLGW HMUART known peer: 1B254C, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 07:45:46 0: HMUARTLGW HMUART known peer: 47A778, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 07322BFA
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 040701010004, state 90
2016.06.19 07:45:46 0: HMUARTLGW HMUART GetSet Ack: 07, state 90
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 07344397
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 040701010003, state 90
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 0747A778
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 040701010002, state 90
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 07261118
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 040701010001, state 90
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 071B254C
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 040701010000, state 90
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 06322BFA000000
2016.06.19 07:45:46 0: HMUARTLGW HMUART recv: 01 040701010001FFFFFFFFFFFFFFFF, state 90
2016.06.19 07:45:46 0: HMUARTLGW HMUART send: 01 06344397000000
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 040701010002FFFFFFFFFFFFFFFF, state 90
2016.06.19 07:45:47 0: HMUARTLGW HMUART GetSet Ack: 07, state 90
2016.06.19 07:45:47 0: HMUARTLGW HMUART send: 01 0647A778000000
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 040701010003FFFFFFFFFFFFFFFF, state 90
2016.06.19 07:45:47 0: HMUARTLGW HMUART send: 01 06261118000000
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 040701010004FFFFFFFFFFFFFFFF, state 90
2016.06.19 07:45:47 0: HMUARTLGW HMUART send: 01 06322BFA010000
2016.06.19 07:45:47 0: HMUARTLGW HMUART send: 01 06344397010000
2016.06.19 07:45:47 0: HMUARTLGW HMUART send: 01 0647A778010000
2016.06.19 07:45:47 0: HMUARTLGW HMUART send: 01 06261118010000
2016.06.19 07:45:47 0: HMUARTLGW HMUART send: 01 08
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 04070101261118FFFFFFFFFFFFFFFF01322BFAFFFFFFFFFFFFFFFF01344397FFFFFFFFFFFFFFFF0147A778FFFFFFFFFFFFFFFF01, state 93
2016.06.19 07:45:47 0: HMUARTLGW HMUART GetSet Ack: 07, state 93
2016.06.19 07:45:47 0: HMUARTLGW HMUART known peer: 261118, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:47 0: HMUARTLGW HMUART known peer: 322BFA, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:47 0: HMUARTLGW HMUART known peer: 344397, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:47 0: HMUARTLGW HMUART known peer: 47A778, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:47 0: HMUARTLGW HMUART send: 01 03749D193DFF62CDD85B5C22873DAB6A4001
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 0401, state 12
2016.06.19 07:45:47 0: HMUARTLGW HMUART GetSet Ack: 01, state 12
2016.06.19 07:45:47 0: HMUARTLGW HMUART send: 01 0F0000000000000000000000000000000000
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 0401, state 13
2016.06.19 07:45:47 0: HMUARTLGW HMUART GetSet Ack: 01, state 13
2016.06.19 07:45:47 0: HMUARTLGW HMUART send: 01 0B0000000000000000000000000000000000
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 0401, state 14
2016.06.19 07:45:47 0: HMUARTLGW HMUART GetSet Ack: 01, state 14
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 05 00 01 54 msg: 02 B0 01 29A083 2A55C1 010E
2016.06.19 07:45:47 3: CUL_HM set Alarm_sir_ext statusRequest
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 05 00 01 25 msg: 02 A0 10 2A55C1 29A083 0601010058
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 05 00 01 54 msg: 02 80 02 29A083 2A55C1 00
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 05 00 01 54 msg: 02 B0 01 29A083 331747 010E
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 01 05 00 01 4A msg: 02 A4 10 331747 29A083 060100004B
2016.06.19 07:45:47 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:45:47 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:45:47 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:45:48 0: HMUARTLGW HMUART recv: 01 05 00 01 55 msg: 02 80 02 29A083 331747 00
2016.06.19 07:45:49 0: HMUARTLGW HMUART send: 01 061B254C000000
2016.06.19 07:45:49 0: HMUARTLGW HMUART recv: 01 040701010005FFFFFFFFFFFFFFFF, state 90
2016.06.19 07:45:49 0: HMUARTLGW HMUART GetSet Ack: 07, state 90
2016.06.19 07:45:49 0: HMUARTLGW HMUART send: 01 08
2016.06.19 07:45:49 0: HMUARTLGW HMUART recv: 01 04070101261118FFFFFFFFFFFFFFFF01322BFAFFFFFFFFFFFFFFFF01344397FFFFFFFFFFFFFFFF011B254CFFFFFFFFFFFFFFFF0047A778FFFFFFFFFFFFFFFF01, state 93
2016.06.19 07:45:49 0: HMUARTLGW HMUART GetSet Ack: 07, state 93
2016.06.19 07:45:49 0: HMUARTLGW HMUART known peer: 261118, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:49 0: HMUARTLGW HMUART known peer: 322BFA, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:49 0: HMUARTLGW HMUART known peer: 344397, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:49 0: HMUARTLGW HMUART known peer: 1B254C, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 07:45:49 0: HMUARTLGW HMUART known peer: 47A778, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:45:49 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 02 A0 11 29A083 1B254C 801003
2016.06.19 07:45:49 0: HMUARTLGW HMUART recv: 01 04 03 01 30 msg: 02 80 02 1B254C 29A083 0110030032
2016.06.19 07:46:02 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:46:02 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:46:02 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:46:17 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:46:17 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:46:17 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:46:20 0: HMUARTLGW HMUART recv: 01 05 00 01 3C msg: 0C 84 10 2FDB9E 29A083 06017200
2016.06.19 07:46:32 0: HMUARTLGW HMUART recv: 01 05 00 01 3E msg: 11 84 10 2EECCA 29A083 06019300
2016.06.19 07:46:32 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:46:32 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:46:32 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:46:47 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:46:47 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:46:47 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:47:01 0: HMUARTLGW HMUART recv: 01 05 00 01 34 msg: 16 86 70 2BBFE8 000000 007D5B
2016.06.19 07:47:02 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:47:02 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:47:02 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:47:17 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:47:17 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:47:17 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:47:31 0: HMUARTLGW HMUART recv: 01 05 00 01 24 msg: 6E 84 5E 27415A 000000 800000000000000008DFFE
2016.06.19 07:47:32 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:47:32 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:47:32 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:47:45 0: HMUARTLGW HMUART recv: 01 05 00 01 38 msg: B5 A6 10 2EEC7C 29A083 06016B00
2016.06.19 07:47:45 0: HMUARTLGW HMUART send: 01 062EEC7C000000
2016.06.19 07:47:45 0: HMUARTLGW HMUART recv: 01 040701010006FFFFFFFFFFFFFFFF, state 90
2016.06.19 07:47:45 0: HMUARTLGW HMUART GetSet Ack: 07, state 90
2016.06.19 07:47:45 0: HMUARTLGW HMUART send: 01 08
2016.06.19 07:47:45 0: HMUARTLGW HMUART recv: 01 04070102261118FFFFFFFFFFFFFFFF01322BFAFFFFFFFFFFFFFFFF01344397FFFFFFFFFFFFFFFF011B254CFFFFFFFFFFFFFFFF0047A778FFFFFFFFFFFFFFFF01, state 93
2016.06.19 07:47:45 0: HMUARTLGW HMUART GetSet Ack: 07, state 93
2016.06.19 07:47:45 0: HMUARTLGW HMUART known peer: 261118, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:47:45 0: HMUARTLGW HMUART known peer: 322BFA, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:47:45 0: HMUARTLGW HMUART known peer: 344397, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:47:45 0: HMUARTLGW HMUART known peer: 1B254C, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 07:47:45 0: HMUARTLGW HMUART known peer: 47A778, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:47:45 0: HMUARTLGW HMUART recv: 01 040702022EEC7CFFFFFFFFFFFFFFFF00, state 93
2016.06.19 07:47:45 0: HMUARTLGW HMUART known peer: 2EEC7C, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 07:47:45 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: B5 80 02 29A083 2EEC7C 01016B00
2016.06.19 07:47:45 0: HMUARTLGW HMUART recv: 01 05 00 01 40 msg: B5 80 02 29A083 2EEC7C 00
2016.06.19 07:47:45 0: HMUARTLGW HMUART recv: 01 0406, state 101
2016.06.19 07:47:45 0: HMUARTLGW HMUART can't send due to CSMA/CA, trying again in a bit
2016.06.19 07:47:47 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:47:47 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:47:47 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:47:48 0: HMUARTLGW HMUART recv: 01 05 00 01 33 msg: A5 84 5E 24A2F6 000000 800000000000000008DCFE
2016.06.19 07:48:02 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:48:03 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:48:03 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:48:18 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:48:18 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:48:18 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:48:22 0: HMUARTLGW HMUART recv: 01 05 00 01 2D msg: 90 84 10 287108 29A083 06015100
2016.06.19 07:48:33 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:48:33 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:48:33 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:48:43 0: HMUARTLGW HMUART recv: 01 05 00 01 36 msg: 13 A4 41 25F392 2F0FE2 0127FE60
2016.06.19 07:48:43 0: HMUARTLGW HMUART recv: 01 05 00 01 3E msg: 13 80 02 2F0FE2 25F392 010100002C
2016.06.19 07:48:48 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:48:48 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:48:48 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:48:52 0: HMUARTLGW HMUART recv: 01 05 00 01 34 msg: 14 84 41 25F392 29A083 0127FE
2016.06.19 07:48:58 0: HMUARTLGW HMUART recv: 01 05 00 01 34 msg: FD 84 10 33BADB 29A083 0601A900
2016.06.19 07:49:03 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:49:03 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:49:03 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:49:05 0: HMUARTLGW HMUART recv: 01 05 00 01 51 msg: 38 84 10 2EF0D4 29A083 06010800
2016.06.19 07:49:05 0: HMUARTLGW HMUART recv: 01 05 00 01 37 msg: 6C 84 10 32570E 29A083 0601BE00
2016.06.19 07:49:18 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:49:18 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:49:18 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:49:29 0: HMUARTLGW HMUART recv: 01 05 00 01 35 msg: 17 86 70 2BBFE8 000000 007E5B
2016.06.19 07:49:33 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:49:33 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:49:33 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:49:43 0: HMUARTLGW HMUART recv: 01 05 00 01 35 msg: 15 A4 41 25F392 2F0FE2 0128FE64
2016.06.19 07:49:43 0: HMUARTLGW HMUART recv: 01 05 00 01 3F msg: 15 80 02 2F0FE2 25F392 010100002E
2016.06.19 07:49:48 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:49:48 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:49:48 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:49:58 0: HMUARTLGW HMUART recv: 01 05 00 01 33 msg: A6 84 5E 24A2F6 000000 800000000000000008DA01
2016.06.19 07:50:00 0: HMUARTLGW HMUART recv: 01 05 00 01 24 msg: 6F 84 5E 27415A 000000 800000000000000008D701
2016.06.19 07:50:03 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:50:03 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:50:03 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
2016.06.19 07:50:09 0: HMUARTLGW HMUART recv: 01 05 00 01 3A msg: 3F A6 41 2D9034 29A083 012FC8
2016.06.19 07:50:09 0: HMUARTLGW HMUART send: 01 062D9034000000
2016.06.19 07:50:09 0: HMUARTLGW HMUART recv: 01 040701010007FFFFFFFFFFFFFFFF, state 90
2016.06.19 07:50:09 0: HMUARTLGW HMUART GetSet Ack: 07, state 90
2016.06.19 07:50:09 0: HMUARTLGW HMUART send: 01 08
2016.06.19 07:50:09 0: HMUARTLGW HMUART send: FD is readable! This might corrupt the received frame, so processing data now
2016.06.19 07:50:09 0: HMUARTLGW HMUART recv: 01 040701010007FFFFFFFFFFFFFFFF, state 93
2016.06.19 07:50:09 1: HMUARTLGW HMUART Ack with invalid counter received, dropping. We: 61, device: 60, state: 93, msg: 1 040701010007FFFFFFFFFFFFFFFF
2016.06.19 07:50:09 0: HMUARTLGW HMUART recv: 01 05 00 01 40 msg: 3F 80 02 29A083 2D9034 00
2016.06.19 07:50:09 0: HMUARTLGW HMUART recv: 01 040701022D9034FFFFFFFFFFFFFFFF00261118FFFFFFFFFFFFFFFF01322BFAFFFFFFFFFFFFFFFF01344397FFFFFFFFFFFFFFFF011B254CFFFFFFFFFFFFFFFF00, state 93
2016.06.19 07:50:09 0: HMUARTLGW HMUART GetSet Ack: 07, state 93
2016.06.19 07:50:09 0: HMUARTLGW HMUART known peer: 2D9034, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 07:50:09 0: HMUARTLGW HMUART known peer: 261118, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:50:09 0: HMUARTLGW HMUART known peer: 322BFA, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:50:09 0: HMUARTLGW HMUART known peer: 344397, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:50:09 0: HMUARTLGW HMUART known peer: 1B254C, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 07:50:09 0: HMUARTLGW HMUART recv: 01 0407020247A778FFFFFFFFFFFFFFFF012EEC7CFFFFFFFFFFFFFFFF00, state 93
2016.06.19 07:50:09 0: HMUARTLGW HMUART known peer: 47A778, aesChannels: FFFFFFFFFFFFFFFF, flags: 1
2016.06.19 07:50:09 0: HMUARTLGW HMUART known peer: 2EEC7C, aesChannels: FFFFFFFFFFFFFFFF, flags: 0
2016.06.19 07:50:09 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 3F 80 02 29A083 2D9034 0101C800
2016.06.19 07:50:10 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 03 A0 11 29A083 1B254C 800601
2016.06.19 07:50:10 0: HMUARTLGW HMUART recv: 01 05 01 01 38 msg: 40 A6 41 2D9034 29A083 012FC8
2016.06.19 07:50:10 0: HMUARTLGW HMUART recv: 01 05 01 01 30 msg: 03 80 02 1B254C 29A083 0106010032
2016.06.19 07:50:11 0: HMUARTLGW HMUART recv: 01 0404, state 100
2016.06.19 07:50:11 0: HMUARTLGW HMUART can't send due to unknown problem (no response?)
2016.06.19 07:50:11 0: HMUARTLGW HMUART recv: 01 05 01 01 30 msg: 03 80 02 1B254C 29A083 0106010032
2016.06.19 07:50:12 0: HMUARTLGW HMUART recv: 01 05 01 01 39 msg: 42 A6 41 2D9034 29A083 012FC8
2016.06.19 07:50:12 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 40 80 02 29A083 2D9034 0101C800
2016.06.19 07:50:12 0: HMUARTLGW HMUART recv: 01 0408, state 101
2016.06.19 07:50:12 0: HMUARTLGW HMUART IO currently busy, trying again in a bit
2016.06.19 07:50:12 0: HMUARTLGW HMUART send: 01 02 00 00 00 msg: 42 80 02 29A083 2D9034 0101C800
2016.06.19 07:50:18 0: HMUARTLGW HMUART send: 00 08
2016.06.19 07:50:18 0: HMUARTLGW HMUART recv: 00 04020E, state 98
2016.06.19 07:50:18 0: HMUARTLGW HMUART GetSet Ack: 02, state 98
Zumindest beim Start kommen zwei "HMUARTLGW HMUART Ack with invalid counter received, dropping ..."
.. was aber zu verkraften ist ..
   Klaus
