HM-CC-TC MISSING-ACK bei Einstellen desired-temp
Begonnen von Guest, 29 Oktober 2012, 18:30:27
Guest
Hallo Martin,
ich habe mal mein CUL in den Homematic Modus versetzt und mein HMLAN in der
Config auskommentiert.
Mit dem CUL funktioniert alles einwandfrei. (ich habe sonst nichts
verändert und auch nichts neu gepairt)
Anbei die Logs davon.
Vielleicht gibt das noch Mal Erkenntnisse.
Viele Grüße,
Merhan
2012.11.13 22:06:35.455 1: Including /opt/share/fhem-5.3/fhem.cfg
2012.11.13 22:06:35.457 5: Cmd: >attr global autoload_undefined_devices 1<
2012.11.13 22:06:35.459 5: Cmd: >attr global backupdir /opt/backup/fhem<
2012.11.13 22:06:35.460 5: Cmd: >attr global logfile /opt/var/log/fhem2/fhem-%Y-%m.log<
2012.11.13 22:06:35.476 5: Cmd: >attr global modpath /opt/share/fhem-5.3<
2012.11.13 22:06:35.505 5: Loading /opt/share/fhem-5.3/FHEM/99_SUNRISE_EL.pm
2012.11.13 22:06:35.651 5: Loading /opt/share/fhem-5.3/FHEM/99_Utils.pm
2012.11.13 22:06:35.716 5: Loading /opt/share/fhem-5.3/FHEM/99_XmlList.pm
2012.11.13 22:06:35.757 5: Cmd: >attr global motd SecurityCheck:\
WEB,WEBphone,WEBtablet has no basicAuth attribute.\
telnetPort has no password/globalpassword attribute.\
Running with root privileges.\
Restart fhem for a new check if the problem is fixed,\
or set the global attribute motd to none to supress this message.\
2012.11.13 22:06:35.758 5: Cmd: >attr global mseclog 1<
2012.11.13 22:06:35.759 5: Cmd: >attr global statefile /opt/var/log/fhem2/fhem.save<
2012.11.13 22:06:35.760 5: Cmd: >attr global userattr fm_fav fm_groups fm_name fm_order fm_type fm_view icon room_map structexclude webCmd<
2012.11.13 22:06:35.761 5: Cmd: >attr global verbose 5<
2012.11.13 22:06:35.763 5: Cmd: >define telnetPort telnet 7072 global<
2012.11.13 22:06:35.763 5: Loading /opt/share/fhem-5.3/FHEM/98_telnet.pm
2012.11.13 22:06:35.807 3: telnetPort: port 7072 opened
2012.11.13 22:06:35.808 5: Triggering global (1 changes)
2012.11.13 22:06:35.809 5: Cmd: >define WEB FHEMWEB 8083 global<
2012.11.13 22:06:35.810 5: Loading /opt/share/fhem-5.3/FHEM/01_FHEMWEB.pm
2012.11.13 22:06:36.021 4: FHEMWEB directories:
2012.11.13 22:06:36.022 4:   web server root: /opt/share/fhem-5.3/www
2012.11.13 22:06:36.022 4:   icon directory: /opt/share/fhem-5.3/www/images
2012.11.13 22:06:36.022 4:     Notice: if style-specific subdirectories /opt/share/fhem-5.3/www/images/default etc. exist, icons are only read from there and not from /opt/share/fhem-5.3/www/images!
2012.11.13 22:06:36.023 4:   doc directory: /opt/share/fhem-5.3/docs
2012.11.13 22:06:36.023 4:   css directory: /opt/share/fhem-5.3/www/pgm2
2012.11.13 22:06:36.023 4:   gplot directory: /opt/share/fhem-5.3/www/gplot
2012.11.13 22:06:36.024 4:   javascript directory: /opt/share/fhem-5.3/www/pgm2
2012.11.13 22:06:36.068 5: WEB Icon dictionary for /opt/share/fhem-5.3/www/images follows...
2012.11.13 22:06:36.069 5: WEB ._FS20.off => default/._FS20.off.png
2012.11.13 22:06:36.069 5: WEB ._FS20.on => default/._FS20.on.png
2012.11.13 22:06:36.070 5: WEB ._HOME_Status.0 => default/._HOME_Status.0.png
2012.11.13 22:06:36.070 5: WEB ._HOME_Status.1 => default/._HOME_Status.1.png
2012.11.13 22:06:36.072 5: WEB ._HOME_Status.3 => default/._HOME_Status.3.png
2012.11.13 22:06:36.072 5: WEB ._HOME_Status.4 => default/._HOME_Status.4.png
2012.11.13 22:06:36.072 5: WEB ._Heizung_Hauptschalter.off => default/._Heizung_Hauptschalter.off.png
2012.11.13 22:06:36.073 5: WEB ._Heizung_Hauptschalter.off-for-timer => default/._Heizung_Hauptschalter.off-for-timer.png
2012.11.13 22:06:36.073 5: WEB ._Heizung_Hauptschalter.on => default/._Heizung_Hauptschalter.on.png
2012.11.13 22:06:36.073 5: WEB ._Next => default/._Next.png
2012.11.13 22:06:36.074 5: WEB ._Prev => default/._Prev.png
2012.11.13 22:06:36.074 5: WEB ._Restart => default/._Restart.png
2012.11.13 22:06:36.074 5: WEB ._Shutdown => default/._Shutdown.png
2012.11.13 22:06:36.074 5: WEB ._StandBy => default/._StandBy.png
2012.11.13 22:06:36.075 5: WEB ._Update => default/._Update.png
2012.11.13 22:06:36.075 5: WEB ._WLAN_Status.0 => default/._WLAN_Status.0.png
2012.11.13 22:06:36.075 5: WEB ._WLAN_Status.1 => default/._WLAN_Status.1.png
2012.11.13 22:06:36.076 5: WEB ._Zoom-in => default/._Zoom-in.png
2012.11.13 22:06:36.076 5: WEB ._Zoom-out => default/._Zoom-out.png
2012.11.13 22:06:36.076 5: WEB ._back => default/._back.png
2012.11.13 22:06:36.076 5: WEB ._black_FS20.off => default/._black_FS20.off.png
2012.11.13 22:06:36.077 5: WEB ._black_FS20.on => default/._black_FS20.on.png
2012.11.13 22:06:36.077 5: WEB ._black_Steckdose.off => default/._black_Steckdose.off.png
2012.11.13 22:06:36.077 5: WEB ._black_Steckdose.on => default/._black_Steckdose.on.png
2012.11.13 22:06:36.078 5: WEB ._black_down => default/._black_down.png
2012.11.13 22:06:36.078 5: WEB ._black_up => default/._black_up.png
2012.11.13 22:06:36.078 5: WEB ._dim06% => default/._dim06%.png
2012.11.13 22:06:36.078 5: WEB ._dim100% => default/._dim100%.png
2012.11.13 22:06:36.079 5: WEB ._dim12% => default/._dim12%.png
2012.11.13 22:06:36.079 5: WEB ._dim18% => default/._dim18%.png
2012.11.13 22:06:36.079 5: WEB ._dim25% => default/._dim25%.png
2012.11.13 22:06:36.079 5: WEB ._dim31% => default/._dim31%.png
2012.11.13 22:06:36.080 5: WEB ._dim37% => default/._dim37%.png
2012.11.13 22:06:36.080 5: WEB ._dim43% => default/._dim43%.png
2012.11.13 22:06:36.080 5: WEB ._dim50% => default/._dim50%.png
2012.11.13 22:06:36.081 5: WEB ._dim56% => default/._dim56%.png
2012.11.13 22:06:36.081 5: WEB ._dim62% => default/._dim62%.png
2012.11.13 22:06:36.081 5: WEB ._dim68% => default/._dim68%.png
2012.11.13 22:06:36.082 5: WEB ._dim75% => default/._dim75%.png
2012.11.13 22:06:36.082 5: WEB ._dim81% => default/._dim81%.png
2012.11.13 22:06:36.082 5: WEB ._dim87% => default/._dim87%.png
2012.11.13 22:06:36.082 5: WEB ._dim93% => default/._dim93%.png
2012.11.13 22:06:36.083 5: WEB ._dimdown => default/._dimdown.png
2012.11.13 22:06:36.083 5: WEB ._dimup => default/._dimup.png
2012.11.13 22:06:36.083 5: WEB ._favicon => default/._favicon.ico
2012.11.13 22:06:36.084 5: WEB ._fhemicon => default/._fhemicon.png
2012.11.13 22:06:36.084 5: WEB ._heizung.0 => default/._heizung.0.png
2012.11.13 22:06:36.084 5: WEB ._icoAUSSEN => default/._icoAUSSEN.png
2012.11.13 22:06:36.084 5: WEB ._icoAUSSENBEREICH => default/._icoAUSSENBEREICH.png
2012.11.13 22:06:36.085 5: WEB ._icoBELEUCHTUNG => default/._icoBELEUCHTUNG.png
2012.11.13 22:06:36.085 5: WEB ._icoBaum => default/._icoBaum.png
2012.11.13 22:06:36.085 5: WEB ._icoBlitz => default/._icoBlitz.png
2012.11.13 22:06:36.086 5: WEB ._icoEverything => default/._icoEverything.png
2012.11.13 22:06:36.086 5: WEB ._icoGraph => default/._icoGraph.png
2012.11.13 22:06:36.086 5: WEB ._icoHEIZUNG => default/._icoHEIZUNG.png
2012.11.13 22:06:36.086 5: WEB ._icoHISTORIE => default/._icoHISTORIE.png
2012.11.13 22:06:36.087 5: WEB ._icoHaus => default/._icoHaus.png
2012.11.13 22:06:36.087 5: WEB ._icoHeizungAn => default/._icoHeizungAn.png
2012.11.13 22:06:36.087 5: WEB ._icoHeizungReg => default/._icoHeizungReg.png
2012.11.13 22:06:36.087 5: WEB ._icoHouse => default/._icoHouse.png
2012.11.13 22:06:36.088 5: WEB ._icoKLIMA => default/._icoKLIMA.png
2012.11.13 22:06:36.088 5: WEB ._icoLicht => default/._icoLicht.png
2012.11.13 22:06:36.088 5: WEB ._icoLichtBaum => default/._icoLichtBaum.png
2012.11.13 22:06:36.089 5: WEB ._icoLichtHaus => default/._icoLichtHaus.png
2012.11.13 22:06:36.089 5: WEB ._icoLog => default/._icoLog.png
2012.11.13 22:06:36.089 5: WEB ._icoLuefter => default/._icoLuefter.png
2012.11.13 22:06:36.089 5: WEB ._icoMail => default/._icoMail.png
2012.11.13 22:06:36.090 5: WEB ._icoPfeil => default/._icoPfeil.png
2012.11.13 22:06:36.090 5: WEB ._icoPirAuto => default/._icoPirAuto.png
2012.11.13 22:06:36.092 5: WEB ._icoPirBaum => default/._icoPirBaum.png
2012.11.13 22:06:36.092 5: WEB ._icoSYSTEM => default/._icoSYSTEM.png
2012.11.13 22:06:36.092 5: WEB ._icoTemp => default/._icoTemp.png
2012.11.13 22:06:36.093 5: WEB ._icoTempBaum => default/._icoTempBaum.png
2012.11.13 22:06:36.093 5: WEB ._icoTempHausEG => default/._icoTempHausEG.png
2012.11.13 22:06:36.093 5: WEB ._icoTempHausOG => default/._icoTempHausOG.png
2012.11.13 22:06:36.093 5: WEB ._icoTempHausReg => default/._icoTempHausReg.png
2012.11.13 22:06:36.094 5: WEB ._icoTempHausRegEG => default/._icoTempHausRegEG.png
2012.11.13 22:06:36.094 5: WEB ._icoTempHausRegOG => default/._icoTempHausRegOG.png
2012.11.13 22:06:36.094 5: WEB ._icoTempHeizung => default/._icoTempHeizung.png
2012.11.13 22:06:36.095 5: WEB ._icoTempWasser => default/._icoTempWasser.png
2012.11.13 22:06:36.095 5: WEB ._icoTermHaus => default/._icoTermHaus.png
2012.11.13 22:06:36.095 5: WEB ._icoTool => default/._icoTool.png
2012.11.13 22:06:36.095 5: WEB ._icoUhr => default/._icoUhr.png
2012.11.13 22:06:36.096 5: WEB ._icoWelt => default/._icoWelt.png
2012.11.13 22:06:36.096 5: WEB ._icoZirkulationAn => default/._icoZirkulationAn.png
2012.11.13 22:06:36.096 5: WEB ._leer => default/._leer.png
2012.11.13 22:06:36.096 5: WEB ._off => default/._off.png
2012.11.13 22:06:36.097 5: WEB ._off-for-timer => default/._off-for-timer.png
2012.11.13 22:06:36.097 5: WEB ._on => default/._on.png
2012.11.13 22:06:36.097 5: WEB ._on-for-timer => default/._on-for-timer.png
2012.11.13 22:06:36.098 5: WEB ._on-till => default/._on-till.png
2012.11.13 22:06:36.098 5: WEB ._signal_Fenster_Offen.off => default/._signal_Fenster_Offen.off.png
2012.11.13 22:06:36.098 5: WEB ._signal_Fenster_Offen.on => default/._signal_Fenster_Offen.on.png
2012.11.13 22:06:36.098 5: WEB ._toggle => default/._toggle.png
2012.11.13 22:06:36.099 5: WEB FS20.off => default/FS20.off.png
2012.11.13 22:06:36.099 5: WEB FS20.on => default/FS20.on.png
2012.11.13 22:06:36.099 5: WEB HOME_Status.0 => default/HOME_Status.0.png
2012.11.13 22:06:36.100 5: WEB HOME_Status.1 => default/HOME_Status.1.png
2012.11.13 22:06:36.100 5: WEB HOME_Status.3 => default/HOME_Status.3.png
2012.11.13 22:06:36.100 5: WEB HOME_Status.4 => default/HOME_Status.4.png
2012.11.13 22:06:36.100 5: WEB Heizung_Hauptschalter.off => default/Heizung_Hauptschalter.off.png
2012.11.13 22:06:36.101 5: WEB Heizung_Hauptschalter.off-for-timer => default/Heizung_Hauptschalter.off-for-timer.png
2012.11.13 22:06:36.101 5: WEB Heizung_Hauptschalter.on => default/Heizung_Hauptschalter.on.png
2012.11.13 22:06:36.101 5: WEB Next => default/Next.png
2012.11.13 22:06:36.102 5: WEB Prev => default/Prev.png
2012.11.13 22:06:36.102 5: WEB Restart => default/Restart.png
2012.11.13 22:06:36.102 5: WEB Shutdown => default/Shutdown.png
2012.11.13 22:06:36.102 5: WEB StandBy => default/StandBy.png
2012.11.13 22:06:36.103 5: WEB Update => default/Update.png
2012.11.13 22:06:36.103 5: WEB WLAN_Status.0 => default/WLAN_Status.0.png
2012.11.13 22:06:36.103 5: WEB WLAN_Status.1 => default/WLAN_Status.1.png
2012.11.13 22:06:36.103 5: WEB Wecker.Aus => default/Wecker.Aus.png
2012.11.13 22:06:36.104 5: WEB Wecker.Immer => default/Wecker.Immer.png
2012.11.13 22:06:36.104 5: WEB Wecker.Wochenende => default/Wecker.Wochenende.png
2012.11.13 22:06:36.104 5: WEB Wecker.Wochentags => default/Wecker.Wochentags.png
2012.11.13 22:06:36.105 5: WEB Zoom-in => default/Zoom-in.png
2012.11.13 22:06:36.105 5: WEB Zoom-out => default/Zoom-out.png
2012.11.13 22:06:36.105 5: WEB back => default/back.png
2012.11.13 22:06:36.105 5: WEB black_FS20.off => default/black_FS20.off.png
2012.11.13 22:06:36.106 5: WEB black_FS20.on => default/black_FS20.on.png
2012.11.13 22:06:36.106 5: WEB black_Steckdose.off => default/black_Steckdose.off.png
2012.11.13 22:06:36.106 5: WEB black_Steckdose.on => default/black_Steckdose.on.png
2012.11.13 22:06:36.106 5: WEB black_down => default/black_down.png
2012.11.13 22:06:36.107 5: WEB black_up => default/black_up.png
2012.11.13 22:06:36.107 5: WEB close => default/close.png
2012.11.13 22:06:36.107 5: WEB closeG => default/closeG.png
2012.11.13 22:06:36.108 5: WEB dim06% => default/dim06%.png
2012.11.13 22:06:36.108 5: WEB dim100% => default/dim100%.png
2012.11.13 22:06:36.108 5: WEB dim12% => default/dim12%.png
2012.11.13 22:06:36.108 5: WEB dim18% => default/dim18%.png
2012.11.13 22:06:36.109 5: WEB dim25% => default/dim25%.png
2012.11.13 22:06:36.109 5: WEB dim31% => default/dim31%.png
2012.11.13 22:06:36.109 5: WEB dim37% => default/dim37%.png
2012.11.13 22:06:36.110 5: WEB dim43% => default/dim43%.png
2012.11.13 22:06:36.110 5: WEB dim50% => default/dim50%.png
2012.11.13 22:06:36.110 5: WEB dim56% => default/dim56%.png
2012.11.13 22:06:36.112 5: WEB dim62% => default/dim62%.png
2012.11.13 22:06:36.112 5: WEB dim68% => default/dim68%.png
2012.11.13 22:06:36.113 5: WEB dim75% => default/dim75%.png
2012.11.13 22:06:36.113 5: WEB dim81% => default/dim81%.png
2012.11.13 22:06:36.113 5: WEB dim87% => default/dim87%.png
2012.11.13 22:06:36.113 5: WEB dim93% => default/dim93%.png
2012.11.13 22:06:36.114 5: WEB dimdown => default/dimdown.png
2012.11.13 22:06:36.114 5: WEB dimup => default/dimup.png
2012.11.13 22:06:36.114 5: WEB favicon => default/favicon.ico
2012.11.13 22:06:36.115 5: WEB fhemicon => default/fhemicon.png
2012.11.13 22:06:36.115 5: WEB heizung.0 => default/heizung.0.png
2012.11.13 22:06:36.115 5: WEB icoAUSSEN => default/icoAUSSEN.png
2012.11.13 22:06:36.115 5: WEB icoAUSSENBEREICH => default/icoAUSSENBEREICH.png
2012.11.13 22:06:36.116 5: WEB icoBELEUCHTUNG => default/icoBELEUCHTUNG.png
2012.11.13 22:06:36.116 5: WEB icoBaum => default/icoBaum.png
2012.11.13 22:06:36.116 5: WEB icoBlitz => default/icoBlitz.png
2012.11.13 22:06:36.116 5: WEB icoEverything => default/icoEverything.png
2012.11.13 22:06:36.117 5: WEB icoGraph => default/icoGraph.png
2012.11.13 22:06:36.117 5: WEB icoHEIZUNG => default/icoHEIZUNG.png
2012.11.13 22:06:36.117 5: WEB icoHISTORIE => default/icoHISTORIE.png
2012.11.13 22:06:36.118 5: WEB icoHaus => default/icoHaus.png
2012.11.13 22:06:36.118 5: WEB icoHeizungAn => default/icoHeizungAn.png
2012.11.13 22:06:36.118 5: WEB icoHeizungReg => default/icoHeizungReg.png
2012.11.13 22:06:36.118 5: WEB icoHouse => default/icoHouse.png
2012.11.13 22:06:36.119 5: WEB icoKLIMA => default/icoKLIMA.png
2012.11.13 22:06:36.119 5: WEB icoLicht => default/icoLicht.png
2012.11.13 22:06:36.119 5: WEB icoLichtBaum => default/icoLichtBaum.png
2012.11.13 22:06:36.120 5: WEB icoLichtHaus => default/icoLichtHaus.png
2012.11.13 22:06:36.120 5: WEB icoLog => default/icoLog.png
2012.11.13 22:06:36.120 5: WEB icoLuefter => default/icoLuefter.png
2012.11.13 22:06:36.120 5: WEB icoMail => default/icoMail.png
2012.11.13 22:06:36.121 5: WEB icoPfeil => default/icoPfeil.png
2012.11.13 22:06:36.121 5: WEB icoPirAuto => default/icoPirAuto.png
2012.11.13 22:06:36.121 5: WEB icoPirBaum => default/icoPirBaum.png
2012.11.13 22:06:36.122 5: WEB icoSYSTEM => default/icoSYSTEM.png
2012.11.13 22:06:36.122 5: WEB icoTemp => default/icoTemp.png
2012.11.13 22:06:36.122 5: WEB icoTempBaum => default/icoTempBaum.png
2012.11.13 22:06:36.122 5: WEB icoTempHausEG => default/icoTempHausEG.png
2012.11.13 22:06:36.123 5: WEB icoTempHausOG => default/icoTempHausOG.png
2012.11.13 22:06:36.123 5: WEB icoTempHausReg => default/icoTempHausReg.png
2012.11.13 22:06:36.123 5: WEB icoTempHausRegEG => default/icoTempHausRegEG.png
2012.11.13 22:06:36.124 5: WEB icoTempHausRegOG => default/icoTempHausRegOG.png
2012.11.13 22:06:36.124 5: WEB icoTempHeizung => default/icoTempHeizung.png
2012.11.13 22:06:36.124 5: WEB icoTempWasser => default/icoTempWasser.png
2012.11.13 22:06:36.124 5: WEB icoTermHaus => default/icoTermHaus.png
2012.11.13 22:06:36.125 5: WEB icoTool => default/icoTool.png
2012.11.13 22:06:36.125 5: WEB icoUhr => default/icoUhr.png
2012.11.13 22:06:36.125 5: WEB icoWelt => default/icoWelt.png
2012.11.13 22:06:36.125 5: WEB icoZirkulationAn => default/icoZirkulationAn.png
2012.11.13 22:06:36.126 5: WEB leer => default/leer.png
2012.11.13 22:06:36.126 5: WEB off => default/off.png
2012.11.13 22:06:36.126 5: WEB off-for-timer => default/off-for-timer.png
2012.11.13 22:06:36.127 5: WEB on => default/on.png
2012.11.13 22:06:36.127 5: WEB on-for-timer => default/on-for-timer.png
2012.11.13 22:06:36.127 5: WEB on-till => default/on-till.png
2012.11.13 22:06:36.127 5: WEB open => default/open.png
2012.11.13 22:06:36.128 5: WEB open_G => default/open_G.png
2012.11.13 22:06:36.128 5: WEB signal_Fenster_Offen.off => default/signal_Fenster_Offen.off.png
2012.11.13 22:06:36.128 5: WEB signal_Fenster_Offen.on => default/signal_Fenster_Offen.on.png
2012.11.13 22:06:36.129 5: WEB toggle => default/toggle.png
2012.11.13 22:06:36.129 5: WEB weather/._chance_of_rain => default/weather/._chance_of_rain.png
2012.11.13 22:06:36.129 5: WEB weather/._chance_of_rain_night => default/weather/._chance_of_rain_night.png
2012.11.13 22:06:36.129 5: WEB weather/._chance_of_sleet => default/weather/._chance_of_sleet.png
2012.11.13 22:06:36.130 5: WEB weather/._chance_of_snow => default/weather/._chance_of_snow.png
2012.11.13 22:06:36.130 5: WEB weather/._chance_of_storm => default/weather/._chance_of_storm.png
2012.11.13 22:06:36.132 5: WEB weather/._chance_of_storm_night => default/weather/._chance_of_storm_night.png
2012.11.13 22:06:36.132 5: WEB weather/._clear => default/weather/._clear.png
2012.11.13 22:06:36.132 5: WEB weather/._cloudy => default/weather/._cloudy.png
2012.11.13 22:06:36.133 5: WEB weather/._drizzle => default/weather/._drizzle.png
2012.11.13 22:06:36.133 5: WEB weather/._drizzle_night => default/weather/._drizzle_night.png
2012.11.13 22:06:36.133 5: WEB weather/._dust => default/weather/._dust.png
2012.11.13 22:06:36.133 5: WEB weather/._flurries => default/weather/._flurries.png
2012.11.13 22:06:36.134 5: WEB weather/._fog => default/weather/._fog.png
2012.11.13 22:06:36.134 5: WEB weather/._haze => default/weather/._haze.png
2012.11.13 22:06:36.134 5: WEB weather/._haze_night => default/weather/._haze_night.png
2012.11.13 22:06:36.134 5: WEB weather/._heavyrain => default/weather/._heavyrain.png
2012.11.13 22:06:36.135 5: WEB weather/._heavysnow => default/weather/._heavysnow.png
2012.11.13 22:06:36.135 5: WEB weather/._icy => default/weather/._icy.png
2012.11.13 22:06:36.135 5: WEB weather/._mist => default/weather/._mist.png
2012.11.13 22:06:36.136 5: WEB weather/._mostly_clear_night => default/weather/._mostly_clear_night.png
2012.11.13 22:06:36.136 5: WEB weather/._mostly_cloudy => default/weather/._mostly_cloudy.png
2012.11.13 22:06:36.136 5: WEB weather/._mostly_cloudy_night => default/weather/._mostly_cloudy_night.png
2012.11.13 22:06:36.136 5: WEB weather/._mostly_sunny => default/weather/._mostly_sunny.png
2012.11.13 22:06:36.137 5: WEB weather/._mostlycloudy => default/weather/._mostlycloudy.png
2012.11.13 22:06:36.137 5: WEB weather/._mostlycloudy_night => default/weather/._mostlycloudy_night.png
2012.11.13 22:06:36.137 5: WEB weather/._na => default/weather/._na.png
2012.11.13 22:06:36.138 5: WEB weather/._overcast => default/weather/._overcast.png
2012.11.13 22:06:36.138 5: WEB weather/._partly_cloudy => default/weather/._partly_cloudy.png
2012.11.13 22:06:36.138 5: WEB weather/._partly_cloudy_night => default/weather/._partly_cloudy_night.png
2012.11.13 22:06:36.138 5: WEB weather/._partlycloudy => default/weather/._partlycloudy.png
2012.11.13 22:06:36.139 5: WEB weather/._partlycloudy_night => default/weather/._partlycloudy_night.png
2012.11.13 22:06:36.139 5: WEB weather/._rain => default/weather/._rain.png
2012.11.13 22:06:36.139 5: WEB weather/._rainsnow => default/weather/._rainsnow.png
2012.11.13 22:06:36.139 5: WEB weather/._scatteredshowers => default/weather/._scatteredshowers.png
2012.11.13 22:06:36.140 5: WEB weather/._scatteredshowers_night => default/weather/._scatteredshowers_night.png
2012.11.13 22:06:36.140 5: WEB weather/._scatteredthunderstorms => default/weather/._scatteredthunderstorms.png
2012.11.13 22:06:36.140 5: WEB weather/._scatteredthunderstorms_night => default/weather/._scatteredthunderstorms_night.png
2012.11.13 22:06:36.141 5: WEB weather/._showers => default/weather/._showers.png
2012.11.13 22:06:36.141 5: WEB weather/._showers_night => default/weather/._showers_night.png
2012.11.13 22:06:36.141 5: WEB weather/._sleet => default/weather/._sleet.png
2012.11.13 22:06:36.142 5: WEB weather/._smoke => default/weather/._smoke.png
2012.11.13 22:06:36.142 5: WEB weather/._snow => default/weather/._snow.png
2012.11.13 22:06:36.142 5: WEB weather/._snowflurries => default/weather/._snowflurries.png
2012.11.13 22:06:36.142 5: WEB weather/._storm => default/weather/._storm.png
2012.11.13 22:06:36.143 5: WEB weather/._sunny => default/weather/._sunny.png
2012.11.13 22:06:36.143 5: WEB weather/._sunny_night => default/weather/._sunny_night.png
2012.11.13 22:06:36.143 5: WEB weather/._thunderstorm => default/weather/._thunderstorm.png
2012.11.13 22:06:36.143 5: WEB weather/._windy => default/weather/._windy.png
2012.11.13 22:06:36.144 5: WEB weather/chance_of_rain => default/weather/chance_of_rain.png
2012.11.13 22:06:36.144 5: WEB weather/chance_of_rain_night => default/weather/chance_of_rain_night.png
2012.11.13 22:06:36.144 5: WEB weather/chance_of_sleet => default/weather/chance_of_sleet.png
2012.11.13 22:06:36.145 5: WEB weather/chance_of_snow => default/weather/chance_of_snow.png
2012.11.13 22:06:36.145 5: WEB weather/chance_of_storm => default/weather/chance_of_storm.png
2012.11.13 22:06:36.145 5: WEB weather/chance_of_storm_night => default/weather/chance_of_storm_night.png
2012.11.13 22:06:36.145 5: WEB weather/clear => default/weather/clear.png
2012.11.13 22:06:36.146 5: WEB weather/cloudy => default/weather/cloudy.png
2012.11.13 22:06:36.146 5: WEB weather/drizzle => default/weather/drizzle.png
2012.11.13 22:06:36.146 5: WEB weather/drizzle_night => default/weather/drizzle_night.png
2012.11.13 22:06:36.147 5: WEB weather/dust => default/weather/dust.png
2012.11.13 22:06:36.147 5: WEB weather/flurries => default/weather/flurries.png
2012.11.13 22:06:36.147 5: WEB weather/fog => default/weather/fog.png
2012.11.13 22:06:36.147 5: WEB weather/haze => default/weather/haze.png
2012.11.13 22:06:36.148 5: WEB weather/haze_night => default/weather/haze_night.png
2012.11.13 22:06:36.148 5: WEB weather/heavyrain => default/weather/heavyrain.png
2012.11.13 22:06:36.148 5: WEB weather/heavysnow => default/weather/heavysnow.png
2012.11.13 22:06:36.148 5: WEB weather/icy => default/weather/icy.png
2012.11.13 22:06:36.149 5: WEB weather/mist => default/weather/mist.png
2012.11.13 22:06:36.149 5: WEB weather/mostly_clear_night => default/weather/mostly_clear_night.png
2012.11.13 22:06:36.149 5: WEB weather/mostly_cloudy => default/weather/mostly_cloudy.png
2012.11.13 22:06:36.150 5: WEB weather/mostly_cloudy_night => default/weather/mostly_cloudy_night.png
2012.11.13 22:06:36.150 5: WEB weather/mostly_sunny => default/weather/mostly_sunny.png
2012.11.13 22:06:36.150 5: WEB weather/mostlycloudy => default/weather/mostlycloudy.png
2012.11.13 22:06:36.152 5: WEB weather/mostlycloudy_night => default/weather/mostlycloudy_night.png
2012.11.13 22:06:36.152 5: WEB weather/na => default/weather/na.png
2012.11.13 22:06:36.153 5: WEB weather/overcast => default/weather/overcast.png
2012.11.13 22:06:36.153 5: WEB weather/partly_cloudy => default/weather/partly_cloudy.png
2012.11.13 22:06:36.153 5: WEB weather/partly_cloudy_night => default/weather/partly_cloudy_night.png
2012.11.13 22:06:36.153 5: WEB weather/partlycloudy => default/weather/partlycloudy.png
2012.11.13 22:06:36.154 5: WEB weather/partlycloudy_night => default/weather/partlycloudy_night.png
2012.11.13 22:06:36.154 5: WEB weather/rain => default/weather/rain.png
2012.11.13 22:06:36.154 5: WEB weather/rainsnow => default/weather/rainsnow.png
2012.11.13 22:06:36.155 5: WEB weather/scatteredshowers => default/weather/scatteredshowers.png
2012.11.13 22:06:36.155 5: WEB weather/scatteredshowers_night => default/weather/scatteredshowers_night.png
2012.11.13 22:06:36.155 5: WEB weather/scatteredthunderstorms => default/weather/scatteredthunderstorms.png
2012.11.13 22:06:36.155 5: WEB weather/scatteredthunderstorms_night => default/weather/scatteredthunderstorms_night.png
2012.11.13 22:06:36.156 5: WEB weather/showers => default/weather/showers.png
2012.11.13 22:06:36.156 5: WEB weather/showers_night => default/weather/showers_night.png
2012.11.13 22:06:36.156 5: WEB weather/sleet => default/weather/sleet.png
2012.11.13 22:06:36.156 5: WEB weather/smoke => default/weather/smoke.png
2012.11.13 22:06:36.157 5: WEB weather/snow => default/weather/snow.png
2012.11.13 22:06:36.157 5: WEB weather/snowflurries => default/weather/snowflurries.png
2012.11.13 22:06:36.157 5: WEB weather/storm => default/weather/storm.png
2012.11.13 22:06:36.158 5: WEB weather/sunny => default/weather/sunny.png
2012.11.13 22:06:36.158 5: WEB weather/sunny_night => default/weather/sunny_night.png
2012.11.13 22:06:36.158 5: WEB weather/thunderstorm => default/weather/thunderstorm.png
2012.11.13 22:06:36.158 5: WEB weather/windy => default/weather/windy.png
2012.11.13 22:06:36.161 3: WEB: port 8083 opened
2012.11.13 22:06:36.161 5: Triggering global (1 changes)
2012.11.13 22:06:36.162 5: global trigger: Checking telnetPort for notify
2012.11.13 22:06:36.163 5: Cmd: >attr WEB fwcompress 0<
2012.11.13 22:06:36.164 5: Cmd: >attr WEB stylesheetPrefix dark<
2012.11.13 22:06:36.209 5: WEB Icon dictionary for /opt/share/fhem-5.3/www/images follows...
2012.11.13 22:06:36.212 5: WEB ._FS20.off => default/._FS20.off.png
2012.11.13 22:06:36.212 5: WEB ._FS20.on => default/._FS20.on.png
2012.11.13 22:06:36.213 5: WEB ._HOME_Status.0 => default/._HOME_Status.0.png
2012.11.13 22:06:36.213 5: WEB ._HOME_Status.1 => default/._HOME_Status.1.png
2012.11.13 22:06:36.213 5: WEB ._HOME_Status.3 => default/._HOME_Status.3.png
2012.11.13 22:06:36.213 5: WEB ._HOME_Status.4 => default/._HOME_Status.4.png
2012.11.13 22:06:36.214 5: WEB ._Heizung_Hauptschalter.off => default/._Heizung_Hauptschalter.off.png
2012.11.13 22:06:36.214 5: WEB ._Heizung_Hauptschalter.off-for-timer => default/._Heizung_Hauptschalter.off-for-timer.png
2012.11.13 22:06:36.214 5: WEB ._Heizung_Hauptschalter.on => default/._Heizung_Hauptschalter.on.png
2012.11.13 22:06:36.215 5: WEB ._Next => default/._Next.png
2012.11.13 22:06:36.215 5: WEB ._Prev => default/._Prev.png
2012.11.13 22:06:36.215 5: WEB ._Restart => default/._Restart.png
2012.11.13 22:06:36.215 5: WEB ._Shutdown => default/._Shutdown.png
2012.11.13 22:06:36.216 5: WEB ._StandBy => default/._StandBy.png
2012.11.13 22:06:36.216 5: WEB ._Update => default/._Update.png
2012.11.13 22:06:36.216 5: WEB ._WLAN_Status.0 => default/._WLAN_Status.0.png
2012.11.13 22:06:36.217 5: WEB ._WLAN_Status.1 => default/._WLAN_Status.1.png
2012.11.13 22:06:36.217 5: WEB ._Zoom-in => default/._Zoom-in.png
2012.11.13 22:06:36.217 5: WEB ._Zoom-out => default/._Zoom-out.png
2012.11.13 22:06:36.217 5: WEB ._back => default/._back.png
2012.11.13 22:06:36.218 5: WEB ._black_FS20.off => default/._black_FS20.off.png
2012.11.13 22:06:36.218 5: WEB ._black_FS20.on => default/._black_FS20.on.png
2012.11.13 22:06:36.218 5: WEB ._black_Steckdose.off => default/._black_Steckdose.off.png
2012.11.13 22:06:36.219 5: WEB ._black_Steckdose.on => default/._black_Steckdose.on.png
2012.11.13 22:06:36.219 5: WEB ._black_down => default/._black_down.png
2012.11.13 22:06:36.219 5: WEB ._black_up => default/._black_up.png
2012.11.13 22:06:36.219 5: WEB ._darklogo => dark/._darklogo.png
2012.11.13 22:06:36.220 5: WEB ._dim06% => default/._dim06%.png
2012.11.13 22:06:36.220 5: WEB ._dim100% => default/._dim100%.png
2012.11.13 22:06:36.220 5: WEB ._dim12% => default/._dim12%.png
2012.11.13 22:06:36.221 5: WEB ._dim18% => default/._dim18%.png
2012.11.13 22:06:36.221 5: WEB ._dim25% => default/._dim25%.png
2012.11.13 22:06:36.221 5: WEB ._dim31% => default/._dim31%.png
2012.11.13 22:06:36.221 5: WEB ._dim37% => default/._dim37%.png
2012.11.13 22:06:36.222 5: WEB ._dim43% => default/._dim43%.png
2012.11.13 22:06:36.222 5: WEB ._dim50% => default/._dim50%.png
2012.11.13 22:06:36.222 5: WEB ._dim56% => default/._dim56%.png
2012.11.13 22:06:36.223 5: WEB ._dim62% => default/._dim62%.png
2012.11.13 22:06:36.223 5: WEB ._dim68% => default/._dim68%.png
2012.11.13 22:06:36.223 5: WEB ._dim75% => default/._dim75%.png
2012.11.13 22:06:36.223 5: WEB ._dim81% => default/._dim81%.png
2012.11.13 22:06:36.224 5: WEB ._dim87% => default/._dim87%.png
2012.11.13 22:06:36.224 5: WEB ._dim93% => default/._dim93%.png
2012.11.13 22:06:36.224 5: WEB ._dimdown => default/._dimdown.png
2012.11.13 22:06:36.225 5: WEB ._dimup => default/._dimup.png
2012.11.13 22:06:36.225 5: WEB ._favicon => default/._favicon.ico
2012.11.13 22:06:36.225 5: WEB ._fhemicon => default/._fhemicon.png
2012.11.13 22:06:36.225 5: WEB ._heizung.0 => default/._heizung.0.png
2012.11.13 22:06:36.226 5: WEB ._icoAUSSEN => default/._icoAUSSEN.png
2012.11.13 22:06:36.226 5: WEB ._icoAUSSENBEREICH => default/._icoAUSSENBEREICH.png
2012.11.13 22:06:36.226 5: WEB ._icoBELEUCHTUNG => default/._icoBELEUCHTUNG.png
2012.11.13 22:06:36.227 5: WEB ._icoBaum => default/._icoBaum.png
2012.11.13 22:06:36.227 5: WEB ._icoBlitz => default/._icoBlitz.png
2012.11.13 22:06:36.227 5: WEB ._icoEverything => default/._icoEverything.png
2012.11.13 22:06:36.227 5: WEB ._icoGraph => default/._icoGraph.png
2012.11.13 22:06:36.228 5: WEB ._icoHEIZUNG => default/._icoHEIZUNG.png
2012.11.13 22:06:36.228 5: WEB ._icoHISTORIE => default/._icoHISTORIE.png
2012.11.13 22:06:36.228 5: WEB ._icoHaus => default/._icoHaus.png
2012.11.13 22:06:36.229 5: WEB ._icoHeizungAn => default/._icoHeizungAn.png
2012.11.13 22:06:36.229 5: WEB ._icoHeizungReg => default/._icoHeizungReg.png
2012.11.13 22:06:36.229 5: WEB ._icoHouse => default/._icoHouse.png
2012.11.13 22:06:36.229 5: WEB ._icoKLIMA => default/._icoKLIMA.png
2012.11.13 22:06:36.230 5: WEB ._icoLicht => default/._icoLicht.png
2012.11.13 22:06:36.230 5: WEB ._icoLichtBaum => default/._icoLichtBaum.png
2012.11.13 22:06:36.232 5: WEB ._icoLichtHaus => default/._icoLichtHaus.png
2012.11.13 22:06:36.232 5: WEB ._icoLog => default/._icoLog.png
2012.11.13 22:06:36.232 5: WEB ._icoLuefter => default/._icoLuefter.png
2012.11.13 22:06:36.233 5: WEB ._icoMail => default/._icoMail.png
2012.11.13 22:06:36.233 5: WEB ._icoPfeil => default/._icoPfeil.png
2012.11.13 22:06:36.233 5: WEB ._icoPirAuto => default/._icoPirAuto.png
2012.11.13 22:06:36.233 5: WEB ._icoPirBaum => default/._icoPirBaum.png
2012.11.13 22:06:36.234 5: WEB ._icoSYSTEM => default/._icoSYSTEM.png
2012.11.13 22:06:36.234 5: WEB ._icoTemp => default/._icoTemp.png
2012.11.13 22:06:36.234 5: WEB ._icoTempBaum => default/._icoTempBaum.png
2012.11.13 22:06:36.235 5: WEB ._icoTempHausEG => default/._icoTempHausEG.png
2012.11.13 22:06:36.235 5: WEB ._icoTempHausOG => default/._icoTempHausOG.png
2012.11.13 22:06:36.235 5: WEB ._icoTempHausReg => default/._icoTempHausReg.png
2012.11.13 22:06:36.235 5: WEB ._icoTempHausRegEG => default/._icoTempHausRegEG.png
2012.11.13 22:06:36.236 5: WEB ._icoTempHausRegOG => default/._icoTempHausRegOG.png
2012.11.13 22:06:36.236 5: WEB ._icoTempHeizung => default/._icoTempHeizung.png
2012.11.13 22:06:36.236 5: WEB ._icoTempWasser => default/._icoTempWasser.png
2012.11.13 22:06:36.237 5: WEB ._icoTermHaus => default/._icoTermHaus.png
2012.11.13 22:06:36.237 5: WEB ._icoTool => default/._icoTool.png
2012.11.13 22:06:36.237 5: WEB ._icoUhr => default/._icoUhr.png
2012.11.13 22:06:36.237 5: WEB ._icoWelt => default/._icoWelt.png
2012.11.13 22:06:36.238 5: WEB ._icoZirkulationAn => default/._icoZirkulationAn.png
2012.11.13 22:06:36.238 5: WEB ._leer => default/._leer.png
2012.11.13 22:06:36.238 5: WEB ._off => default/._off.png
2012.11.13 22:06:36.239 5: WEB ._off-for-timer => default/._off-for-timer.png
2012.11.13 22:06:36.239 5: WEB ._on => default/._on.png
2012.11.13 22:06:36.239 5: WEB ._on-for-timer => default/._on-for-timer.png
2012.11.13 22:06:36.239 5: WEB ._on-till => default/._on-till.png
2012.11.13 22:06:36.240 5: WEB ._signal_Fenster_Offen.off => default/._signal_Fenster_Offen.off.png
2012.11.13 22:06:36.240 5: WEB ._signal_Fenster_Offen.on => default/._signal_Fenster_Offen.on.png
2012.11.13 22:06:36.240 5: WEB ._toggle => default/._toggle.png
2012.11.13 22:06:36.241 5: WEB FS20.off => default/FS20.off.png
2012.11.13 22:06:36.241 5: WEB FS20.on => default/FS20.on.png
2012.11.13 22:06:36.241 5: WEB HOME_Status.0 => default/HOME_Status.0.png
2012.11.13 22:06:36.241 5: WEB HOME_Status.1 => default/HOME_Status.1.png
2012.11.13 22:06:36.242 5: WEB HOME_Status.3 => default/HOME_Status.3.png
2012.11.13 22:06:36.242 5: WEB HOME_Status.4 => default/HOME_Status.4.png
2012.11.13 22:06:36.242 5: WEB Heizung_Hauptschalter.off => default/Heizung_Hauptschalter.off.png
2012.11.13 22:06:36.243 5: WEB Heizung_Hauptschalter.off-for-timer => default/Heizung_Hauptschalter.off-for-timer.png
2012.11.13 22:06:36.243 5: WEB Heizung_Hauptschalter.on => default/Heizung_Hauptschalter.on.png
2012.11.13 22:06:36.243 5: WEB Next => default/Next.png
2012.11.13 22:06:36.243 5: WEB Prev => default/Prev.png
2012.11.13 22:06:36.244 5: WEB Restart => default/Restart.png
2012.11.13 22:06:36.244 5: WEB Shutdown => default/Shutdown.png
2012.11.13 22:06:36.244 5: WEB StandBy => default/StandBy.png
2012.11.13 22:06:36.245 5: WEB Update => default/Update.png
2012.11.13 22:06:36.245 5: WEB WLAN_Status.0 => default/WLAN_Status.0.png
2012.11.13 22:06:36.245 5: WEB WLAN_Status.1 => default/WLAN_Status.1.png
2012.11.13 22:06:36.245 5: WEB Wecker.Aus => default/Wecker.Aus.png
2012.11.13 22:06:36.246 5: WEB Wecker.Immer => default/Wecker.Immer.png
2012.11.13 22:06:36.246 5: WEB Wecker.Wochenende => default/Wecker.Wochenende.png
2012.11.13 22:06:36.246 5: WEB Wecker.Wochentags => default/Wecker.Wochentags.png
2012.11.13 22:06:36.247 5: WEB Zoom-in => default/Zoom-in.png
2012.11.13 22:06:36.247 5: WEB Zoom-out => default/Zoom-out.png
2012.11.13 22:06:36.247 5: WEB back => default/back.png
2012.11.13 22:06:36.247 5: WEB black_FS20.off => default/black_FS20.off.png
2012.11.13 22:06:36.248 5: WEB black_FS20.on => default/black_FS20.on.png
2012.11.13 22:06:36.248 5: WEB black_Steckdose.off => default/black_Steckdose.off.png
2012.11.13 22:06:36.248 5: WEB black_Steckdose.on => default/black_Steckdose.on.png
2012.11.13 22:06:36.249 5: WEB black_down => default/black_down.png
2012.11.13 22:06:36.249 5: WEB black_up => default/black_up.png
2012.11.13 22:06:36.249 5: WEB close => default/close.png
2012.11.13 22:06:36.249 5: WEB closeG => default/closeG.png
2012.11.13 22:06:36.250 5: WEB darklogo => dark/darklogo.png
2012.11.13 22:06:36.250 5: WEB dim06% => default/dim06%.png
2012.11.13 22:06:36.252 5: WEB dim100% => default/dim100%.png
2012.11.13 22:06:36.252 5: WEB dim12% => default/dim12%.png
2012.11.13 22:06:36.252 5: WEB dim18% => default/dim18%.png
2012.11.13 22:06:36.253 5: WEB dim25% => default/dim25%.png
2012.11.13 22:06:36.253 5: WEB dim31% => default/dim31%.png
2012.11.13 22:06:36.253 5: WEB dim37% => default/dim37%.png
2012.11.13 22:06:36.253 5: WEB dim43% => default/dim43%.png
2012.11.13 22:06:36.254 5: WEB dim50% => default/dim50%.png
2012.11.13 22:06:36.254 5: WEB dim56% => default/dim56%.png
2012.11.13 22:06:36.254 5: WEB dim62% => default/dim62%.png
2012.11.13 22:06:36.255 5: WEB dim68% => default/dim68%.png
2012.11.13 22:06:36.255 5: WEB dim75% => default/dim75%.png
2012.11.13 22:06:36.255 5: WEB dim81% => default/dim81%.png
2012.11.13 22:06:36.255 5: WEB dim87% => default/dim87%.png
2012.11.13 22:06:36.256 5: WEB dim93% => default/dim93%.png
2012.11.13 22:06:36.256 5: WEB dimdown => default/dimdown.png
2012.11.13 22:06:36.256 5: WEB dimup => default/dimup.png
2012.11.13 22:06:36.257 5: WEB favicon => default/favicon.ico
2012.11.13 22:06:36.257 5: WEB fhemicon => default/fhemicon.png
2012.11.13 22:06:36.257 5: WEB heizung.0 => default/heizung.0.png
2012.11.13 22:06:36.257 5: WEB icoAUSSEN => default/icoAUSSEN.png
2012.11.13 22:06:36.258 5: WEB icoAUSSENBEREICH => default/icoAUSSENBEREICH.png
2012.11.13 22:06:36.258 5: WEB icoBELEUCHTUNG => default/icoBELEUCHTUNG.png
2012.11.13 22:06:36.258 5: WEB icoBaum => default/icoBaum.png
2012.11.13 22:06:36.258 5: WEB icoBlitz => default/icoBlitz.png
2012.11.13 22:06:36.259 5: WEB icoEverything => default/icoEverything.png
2012.11.13 22:06:36.259 5: WEB icoGraph => default/icoGraph.png
2012.11.13 22:06:36.259 5: WEB icoHEIZUNG => default/icoHEIZUNG.png
2012.11.13 22:06:36.260 5: WEB icoHISTORIE => default/icoHISTORIE.png
2012.11.13 22:06:36.260 5: WEB icoHaus => default/icoHaus.png
2012.11.13 22:06:36.260 5: WEB icoHeizungAn => default/icoHeizungAn.png
2012.11.13 22:06:36.261 5: WEB icoHeizungReg => default/icoHeizungReg.png
2012.11.13 22:06:36.261 5: WEB icoHouse => default/icoHouse.png
2012.11.13 22:06:36.261 5: WEB icoKLIMA => default/icoKLIMA.png
2012.11.13 22:06:36.261 5: WEB icoLicht => default/icoLicht.png
2012.11.13 22:06:36.262 5: WEB icoLichtBaum => default/icoLichtBaum.png
2012.11.13 22:06:36.262 5: WEB icoLichtHaus => default/icoLichtHaus.png
2012.11.13 22:06:36.262 5: WEB icoLog => default/icoLog.png
2012.11.13 22:06:36.263 5: WEB icoLuefter => default/icoLuefter.png
2012.11.13 22:06:36.263 5: WEB icoMail => default/icoMail.png
2012.11.13 22:06:36.263 5: WEB icoPfeil => default/icoPfeil.png
2012.11.13 22:06:36.264 5: WEB icoPirAuto => default/icoPirAuto.png
2012.11.13 22:06:36.264 5: WEB icoPirBaum => default/icoPirBaum.png
2012.11.13 22:06:36.264 5: WEB icoSYSTEM => default/icoSYSTEM.png
2012.11.13 22:06:36.264 5: WEB icoTemp => default/icoTemp.png
2012.11.13 22:06:36.265 5: WEB icoTempBaum => default/icoTempBaum.png
2012.11.13 22:06:36.265 5: WEB icoTempHausEG => default/icoTempHausEG.png
2012.11.13 22:06:36.265 5: WEB icoTempHausOG => default/icoTempHausOG.png
2012.11.13 22:06:36.265 5: WEB icoTempHausReg => default/icoTempHausReg.png
2012.11.13 22:06:36.266 5: WEB icoTempHausRegEG => default/icoTempHausRegEG.png
2012.11.13 22:06:36.266 5: WEB icoTempHausRegOG => default/icoTempHausRegOG.png
2012.11.13 22:06:36.266 5: WEB icoTempHeizung => default/icoTempHeizung.png
2012.11.13 22:06:36.267 5: WEB icoTempWasser => default/icoTempWasser.png
2012.11.13 22:06:36.267 5: WEB icoTermHaus => default/icoTermHaus.png
2012.11.13 22:06:36.267 5: WEB icoTool => default/icoTool.png
2012.11.13 22:06:36.267 5: WEB icoUhr => default/icoUhr.png
2012.11.13 22:06:36.268 5: WEB icoWelt => default/icoWelt.png
2012.11.13 22:06:36.268 5: WEB icoZirkulationAn => default/icoZirkulationAn.png
2012.11.13 22:06:36.268 5: WEB leer => default/leer.png
2012.11.13 22:06:36.269 5: WEB off => default/off.png
2012.11.13 22:06:36.269 5: WEB off-for-timer => default/off-for-timer.png
2012.11.13 22:06:36.269 5: WEB on => default/on.png
2012.11.13 22:06:36.269 5: WEB on-for-timer => default/on-for-timer.png
2012.11.13 22:06:36.270 5: WEB on-till => default/on-till.png
2012.11.13 22:06:36.270 5: WEB open => default/open.png
2012.11.13 22:06:36.272 5: WEB open_G => default/open_G.png
2012.11.13 22:06:36.272 5: WEB signal_Fenster_Offen.off => default/signal_Fenster_Offen.off.png
2012.11.13 22:06:36.272 5: WEB signal_Fenster_Offen.on => default/signal_Fenster_Offen.on.png
2012.11.13 22:06:36.273 5: WEB toggle => default/toggle.png
2012.11.13 22:06:36.273 5: WEB weather/._chance_of_rain => default/weather/._chance_of_rain.png
2012.11.13 22:06:36.273 5: WEB weather/._chance_of_rain_night => default/weather/._chance_of_rain_night.png
2012.11.13 22:06:36.273 5: WEB weather/._chance_of_sleet => default/weather/._chance_of_sleet.png
2012.11.13 22:06:36.274 5: WEB weather/._chance_of_snow => default/weather/._chance_of_snow.png
2012.11.13 22:06:36.274 5: WEB weather/._chance_of_storm => default/weather/._chance_of_storm.png
2012.11.13 22:06:36.274 5: WEB weather/._chance_of_storm_night => default/weather/._chance_of_storm_night.png
2012.11.13 22:06:36.275 5: WEB weather/._clear => default/weather/._clear.png
2012.11.13 22:06:36.275 5: WEB weather/._cloudy => default/weather/._cloudy.png
2012.11.13 22:06:36.275 5: WEB weather/._drizzle => default/weather/._drizzle.png
2012.11.13 22:06:36.275 5: WEB weather/._drizzle_night => default/weather/._drizzle_night.png
2012.11.13 22:06:36.276 5: WEB weather/._dust => default/weather/._dust.png
2012.11.13 22:06:36.276 5: WEB weather/._flurries => default/weather/._flurries.png
2012.11.13 22:06:36.276 5: WEB weather/._fog => default/weather/._fog.png
2012.11.13 22:06:36.277 5: WEB weather/._haze => default/weather/._haze.png
2012.11.13 22:06:36.277 5: WEB weather/._haze_night => default/weather/._haze_night.png
2012.11.13 22:06:36.277 5: WEB weather/._heavyrain => default/weather/._heavyrain.png
2012.11.13 22:06:36.277 5: WEB weather/._heavysnow => default/weather/._heavysnow.png
2012.11.13 22:06:36.278 5: WEB weather/._icy => default/weather/._icy.png
2012.11.13 22:06:36.278 5: WEB weather/._mist => default/weather/._mist.png
2012.11.13 22:06:36.278 5: WEB weather/._mostly_clear_night => default/weather/._mostly_clear_night.png
2012.11.13 22:06:36.279 5: WEB weather/._mostly_cloudy => default/weather/._mostly_cloudy.png
2012.11.13 22:06:36.279 5: WEB weather/._mostly_cloudy_night => default/weather/._mostly_cloudy_night.png
2012.11.13 22:06:36.279 5: WEB weather/._mostly_sunny => default/weather/._mostly_sunny.png
2012.11.13 22:06:36.279 5: WEB weather/._mostlycloudy => default/weather/._mostlycloudy.png
2012.11.13 22:06:36.280 5: WEB weather/._mostlycloudy_night => default/weather/._mostlycloudy_night.png
2012.11.13 22:06:36.280 5: WEB weather/._na => default/weather/._na.png
2012.11.13 22:06:36.280 5: WEB weather/._overcast => default/weather/._overcast.png
2012.11.13 22:06:36.281 5: WEB weather/._partly_cloudy => default/weather/._partly_cloudy.png
2012.11.13 22:06:36.281 5: WEB weather/._partly_cloudy_night => default/weather/._partly_cloudy_night.png
2012.11.13 22:06:36.281 5: WEB weather/._partlycloudy => default/weather/._partlycloudy.png
2012.11.13 22:06:36.281 5: WEB weather/._partlycloudy_night => default/weather/._partlycloudy_night.png
2012.11.13 22:06:36.282 5: WEB weather/._rain => default/weather/._rain.png
2012.11.13 22:06:36.282 5: WEB weather/._rainsnow => default/weather/._rainsnow.png
2012.11.13 22:06:36.282 5: WEB weather/._scatteredshowers => default/weather/._scatteredshowers.png
2012.11.13 22:06:36.283 5: WEB weather/._scatteredshowers_night => default/weather/._scatteredshowers_night.png
2012.11.13 22:06:36.283 5: WEB weather/._scatteredthunderstorms => default/weather/._scatteredthunderstorms.png
2012.11.13 22:06:36.283 5: WEB weather/._scatteredthunderstorms_night => default/weather/._scatteredthunderstorms_night.png
2012.11.13 22:06:36.283 5: WEB weather/._showers => default/weather/._showers.png
2012.11.13 22:06:36.284 5: WEB weather/._showers_night => default/weather/._showers_night.png
2012.11.13 22:06:36.284 5: WEB weather/._sleet => default/weather/._sleet.png
2012.11.13 22:06:36.284 5: WEB weather/._smoke => default/weather/._smoke.png
2012.11.13 22:06:36.285 5: WEB weather/._snow => default/weather/._snow.png
2012.11.13 22:06:36.285 5: WEB weather/._snowflurries => default/weather/._snowflurries.png
2012.11.13 22:06:36.285 5: WEB weather/._storm => default/weather/._storm.png
2012.11.13 22:06:36.285 5: WEB weather/._sunny => default/weather/._sunny.png
2012.11.13 22:06:36.286 5: WEB weather/._sunny_night => default/weather/._sunny_night.png
2012.11.13 22:06:36.286 5: WEB weather/._thunderstorm => default/weather/._thunderstorm.png
2012.11.13 22:06:36.286 5: WEB weather/._windy => default/weather/._windy.png
2012.11.13 22:06:36.287 5: WEB weather/chance_of_rain => default/weather/chance_of_rain.png
2012.11.13 22:06:36.287 5: WEB weather/chance_of_rain_night => default/weather/chance_of_rain_night.png
2012.11.13 22:06:36.287 5: WEB weather/chance_of_sleet => default/weather/chance_of_sleet.png
2012.11.13 22:06:36.287 5: WEB weather/chance_of_snow => default/weather/chance_of_snow.png
2012.11.13 22:06:36.288 5: WEB weather/chance_of_storm => default/weather/chance_of_storm.png
2012.11.13 22:06:36.288 5: WEB weather/chance_of_storm_night => default/weather/chance_of_storm_night.png
2012.11.13 22:06:36.288 5: WEB weather/clear => default/weather/clear.png
2012.11.13 22:06:36.289 5: WEB weather/cloudy => default/weather/cloudy.png
2012.11.13 22:06:36.289 5: WEB weather/drizzle => default/weather/drizzle.png
2012.11.13 22:06:36.289 5: WEB weather/drizzle_night => default/weather/drizzle_night.png
2012.11.13 22:06:36.289 5: WEB weather/dust => default/weather/dust.png
2012.11.13 22:06:36.290 5: WEB weather/flurries => default/weather/flurries.png
2012.11.13 22:06:36.290 5: WEB weather/fog => default/weather/fog.png
2012.11.13 22:06:36.290 5: WEB weather/haze => default/weather/haze.png
2012.11.13 22:06:36.292 5: WEB weather/haze_night => default/weather/haze_night.png
2012.11.13 22:06:36.292 5: WEB weather/heavyrain => default/weather/heavyrain.png
2012.11.13 22:06:36.293 5: WEB weather/heavysnow => default/weather/heavysnow.png
2012.11.13 22:06:36.293 5: WEB weather/icy => default/weather/icy.png
2012.11.13 22:06:36.293 5: WEB weather/mist => default/weather/mist.png
2012.11.13 22:06:36.293 5: WEB weather/mostly_clear_night => default/weather/mostly_clear_night.png
2012.11.13 22:06:36.294 5: WEB weather/mostly_cloudy => default/weather/mostly_cloudy.png
2012.11.13 22:06:36.294 5: WEB weather/mostly_cloudy_night => default/weather/mostly_cloudy_night.png
2012.11.13 22:06:36.294 5: WEB weather/mostly_sunny => default/weather/mostly_sunny.png
2012.11.13 22:06:36.295 5: WEB weather/mostlycloudy => default/weather/mostlycloudy.png
2012.11.13 22:06:36.295 5: WEB weather/mostlycloudy_night => default/weather/mostlycloudy_night.png
2012.11.13 22:06:36.295 5: WEB weather/na => default/weather/na.png
2012.11.13 22:06:36.295 5: WEB weather/overcast => default/weather/overcast.png
2012.11.13 22:06:36.296 5: WEB weather/partly_cloudy => default/weather/partly_cloudy.png
2012.11.13 22:06:36.296 5: WEB weather/partly_cloudy_night => default/weather/partly_cloudy_night.png
2012.11.13 22:06:36.296 5: WEB weather/partlycloudy => default/weather/partlycloudy.png
2012.11.13 22:06:36.297 5: WEB weather/partlycloudy_night => default/weather/partlycloudy_night.png
2012.11.13 22:06:36.297 5: WEB weather/rain => default/weather/rain.png
2012.11.13 22:06:36.297 5: WEB weather/rainsnow => default/weather/rainsnow.png
2012.11.13 22:06:36.297 5: WEB weather/scatteredshowers => default/weather/scatteredshowers.png
2012.11.13 22:06:36.298 5: WEB weather/scatteredshowers_night => default/weather/scatteredshowers_night.png
2012.11.13 22:06:36.298 5: WEB weather/scatteredthunderstorms => default/weather/scatteredthunderstorms.png
2012.11.13 22:06:36.298 5: WEB weather/scatteredthunderstorms_night => default/weather/scatteredthunderstorms_night.png
2012.11.13 22:06:36.299 5: WEB weather/showers => default/weather/showers.png
2012.11.13 22:06:36.299 5: WEB weather/showers_night => default/weather/showers_night.png
2012.11.13 22:06:36.299 5: WEB weather/sleet => default/weather/sleet.png
2012.11.13 22:06:36.299 5: WEB weather/smoke => default/weather/smoke.png
2012.11.13 22:06:36.300 5: WEB weather/snow => default/weather/snow.png
2012.11.13 22:06:36.300 5: WEB weather/snowflurries => default/weather/snowflurries.png
2012.11.13 22:06:36.300 5: WEB weather/storm => default/weather/storm.png
2012.11.13 22:06:36.301 5: WEB weather/sunny => default/weather/sunny.png
2012.11.13 22:06:36.301 5: WEB weather/sunny_night => default/weather/sunny_night.png
2012.11.13 22:06:36.301 5: WEB weather/thunderstorm => default/weather/thunderstorm.png
2012.11.13 22:06:36.302 5: WEB weather/windy => default/weather/windy.png
2012.11.13 22:06:36.303 5: Cmd: >define WEBphone FHEMWEB 8084 global<
2012.11.13 22:06:36.304 4: FHEMWEB directories:
2012.11.13 22:06:36.304 4:   web server root: /opt/share/fhem-5.3/www
2012.11.13 22:06:36.304 4:   icon directory: /opt/share/fhem-5.3/www/images
2012.11.13 22:06:36.305 4:     Notice: if style-specific subdirectories /opt/share/fhem-5.3/www/images/default etc. exist, icons are only read from there and not from /opt/share/fhem-5.3/www/images!
2012.11.13 22:06:36.305 4:   doc directory: /opt/share/fhem-5.3/docs
2012.11.13 22:06:36.305 4:   css directory: /opt/share/fhem-5.3/www/pgm2
2012.11.13 22:06:36.306 4:   gplot directory: /opt/share/fhem-5.3/www/gplot
2012.11.13 22:06:36.306 4:   javascript directory: /opt/share/fhem-5.3/www/pgm2
2012.11.13 22:06:36.349 5: WEBphone Icon dictionary for /opt/share/fhem-5.3/www/images follows...
2012.11.13 22:06:36.352 5: WEBphone ._FS20.off => default/._FS20.off.png
2012.11.13 22:06:36.352 5: WEBphone ._FS20.on => default/._FS20.on.png
2012.11.13 22:06:36.353 5: WEBphone ._HOME_Status.0 => default/._HOME_Status.0.png
2012.11.13 22:06:36.353 5: WEBphone ._HOME_Status.1 => default/._HOME_Status.1.png
2012.11.13 22:06:36.353 5: WEBphone ._HOME_Status.3 => default/._HOME_Status.3.png
2012.11.13 22:06:36.354 5: WEBphone ._HOME_Status.4 => default/._HOME_Status.4.png
2012.11.13 22:06:36.354 5: WEBphone ._Heizung_Hauptschalter.off => default/._Heizung_Hauptschalter.off.png
2012.11.13 22:06:36.354 5: WEBphone ._Heizung_Hauptschalter.off-for-timer => default/._Heizung_Hauptschalter.off-for-timer.png
2012.11.13 22:06:36.354 5: WEBphone ._Heizung_Hauptschalter.on => default/._Heizung_Hauptschalter.on.png
2012.11.13 22:06:36.355 5: WEBphone ._Next => default/._Next.png
2012.11.13 22:06:36.355 5: WEBphone ._Prev => default/._Prev.png
2012.11.13 22:06:36.355 5: WEBphone ._Restart => default/._Restart.png
2012.11.13 22:06:36.356 5: WEBphone ._Shutdown => default/._Shutdown.png
2012.11.13 22:06:36.356 5: WEBphone ._StandBy => default/._StandBy.png
2012.11.13 22:06:36.356 5: WEBphone ._Update => default/._Update.png
2012.11.13 22:06:36.356 5: WEBphone ._WLAN_Status.0 => default/._WLAN_Status.0.png
2012.11.13 22:06:36.357 5: WEBphone ._WLAN_Status.1 => default/._WLAN_Status.1.png
2012.11.13 22:06:36.357 5: WEBphone ._Zoom-in => default/._Zoom-in.png
2012.11.13 22:06:36.357 5: WEBphone ._Zoom-out => default/._Zoom-out.png
2012.11.13 22:06:36.358 5: WEBphone ._back => default/._back.png
2012.11.13 22:06:36.358 5: WEBphone ._black_FS20.off => default/._black_FS20.off.png
2012.11.13 22:06:36.358 5: WEBphone ._black_FS20.on => default/._black_FS20.on.png
2012.11.13 22:06:36.358 5: WEBphone ._black_Steckdose.off => default/._black_Steckdose.off.png
2012.11.13 22:06:36.359 5: WEBphone ._black_Steckdose.on => default/._black_Steckdose.on.png
2012.11.13 22:06:36.359 5: WEBphone ._black_down => default/._black_down.png
2012.11.13 22:06:36.359 5: WEBphone ._black_up => default/._black_up.png
2012.11.13 22:06:36.360 5: WEBphone ._dim06% => default/._dim06%.png
2012.11.13 22:06:36.360 5: WEBphone ._dim100% => default/._dim100%.png
2012.11.13 22:06:36.360 5: WEBphone ._dim12% => default/._dim12%.png
2012.11.13 22:06:36.361 5: WEBphone ._dim18% => default/._dim18%.png
2012.11.13 22:06:36.361 5: WEBphone ._dim25% => default/._dim25%.png
2012.11.13 22:06:36.361 5: WEBphone ._dim31% => default/._dim31%.png
2012.11.13 22:06:36.361 5: WEBphone ._dim37% => default/._dim37%.png
2012.11.13 22:06:36.362 5: WEBphone ._dim43% => default/._dim43%.png
2012.11.13 22:06:36.362 5: WEBphone ._dim50% => default/._dim50%.png
2012.11.13 22:06:36.362 5: WEBphone ._dim56% => default/._dim56%.png
2012.11.13 22:06:36.362 5: WEBphone ._dim62% => default/._dim62%.png
2012.11.13 22:06:36.363 5: WEBphone ._dim68% => default/._dim68%.png
2012.11.13 22:06:36.363 5: WEBphone ._dim75% => default/._dim75%.png
2012.11.13 22:06:36.363 5: WEBphone ._dim81% => default/._dim81%.png
2012.11.13 22:06:36.364 5: WEBphone ._dim87% => default/._dim87%.png
2012.11.13 22:06:36.364 5: WEBphone ._dim93% => default/._dim93%.png
2012.11.13 22:06:36.364 5: WEBphone ._dimdown => default/._dimdown.png
2012.11.13 22:06:36.364 5: WEBphone ._dimup => default/._dimup.png
2012.11.13 22:06:36.365 5: WEBphone ._favicon => default/._favicon.ico
2012.11.13 22:06:36.365 5: WEBphone ._fhemicon => default/._fhemicon.png
2012.11.13 22:06:36.365 5: WEBphone ._heizung.0 => default/._heizung.0.png
2012.11.13 22:06:36.366 5: WEBphone ._icoAUSSEN => default/._icoAUSSEN.png
2012.11.13 22:06:36.366 5: WEBphone ._icoAUSSENBEREICH => default/._icoAUSSENBEREICH.png
2012.11.13 22:06:36.366 5: WEBphone ._icoBELEUCHTUNG => default/._icoBELEUCHTUNG.png
2012.11.13 22:06:36.366 5: WEBphone ._icoBaum => default/._icoBaum.png
2012.11.13 22:06:36.367 5: WEBphone ._icoBlitz => default/._icoBlitz.png
2012.11.13 22:06:36.367 5: WEBphone ._icoEverything => default/._icoEverything.png
2012.11.13 22:06:36.367 5: WEBphone ._icoGraph => default/._icoGraph.png
2012.11.13 22:06:36.368 5: WEBphone ._icoHEIZUNG => default/._icoHEIZUNG.png
2012.11.13 22:06:36.368 5: WEBphone ._icoHISTORIE => default/._icoHISTORIE.png
2012.11.13 22:06:36.368 5: WEBphone ._icoHaus => default/._icoHaus.png
2012.11.13 22:06:36.368 5: WEBphone ._icoHeizungAn => default/._icoHeizungAn.png
2012.11.13 22:06:36.369 5: WEBphone ._icoHeizungReg => default/._icoHeizungReg.png
2012.11.13 22:06:36.369 5: WEBphone ._icoHouse => default/._icoHouse.png
2012.11.13 22:06:36.369 5: WEBphone ._icoKLIMA => default/._icoKLIMA.png
2012.11.13 22:06:36.369 5: WEBphone ._icoLicht => default/._icoLicht.png
2012.11.13 22:06:36.370 5: WEBphone ._icoLichtBaum => default/._icoLichtBaum.png
2012.11.13 22:06:36.370 5: WEBphone ._icoLichtHaus => default/._icoLichtHaus.png
2012.11.13 22:06:36.371 5: WEBphone ._icoLog => default/._icoLog.png
2012.11.13 22:06:36.372 5: WEBphone ._icoLuefter => default/._icoLuefter.png
2012.11.13 22:06:36.373 5: WEBphone ._icoMail => default/._icoMail.png
2012.11.13 22:06:36.373 5: WEBphone ._icoPfeil => default/._icoPfeil.png
2012.11.13 22:06:36.373 5: WEBphone ._icoPirAuto => default/._icoPirAuto.png
2012.11.13 22:06:36.374 5: WEBphone ._icoPirBaum => default/._icoPirBaum.png
2012.11.13 22:06:36.374 5: WEBphone ._icoSYSTEM => default/._icoSYSTEM.png
2012.11.13 22:06:36.374 5: WEBphone ._icoTemp => default/._icoTemp.png
2012.11.13 22:06:36.374 5: WEBphone ._icoTempBaum => default/._icoTempBaum.png
2012.11.13 22:06:36.375 5: WEBphone ._icoTempHausEG => default/._icoTempHausEG.png
2012.11.13 22:06:36.375 5: WEBphone ._icoTempHausOG => default/._icoTempHausOG.png
2012.11.13 22:06:36.375 5: WEBphone ._icoTempHausReg => default/._icoTempHausReg.png
2012.11.13 22:06:36.375 5: WEBphone ._icoTempHausRegEG => default/._icoTempHausRegEG.png
2012.11.13 22:06:36.376 5: WEBphone ._icoTempHausRegOG => default/._icoTempHausRegOG.png
2012.11.13 22:06:36.376 5: WEBphone ._icoTempHeizung => default/._icoTempHeizung.png
2012.11.13 22:06:36.376 5: WEBphone ._icoTempWasser => default/._icoTempWasser.png
2012.11.13 22:06:36.377 5: WEBphone ._icoTermHaus => default/._icoTermHaus.png
2012.11.13 22:06:36.377 5: WEBphone ._icoTool => default/._icoTool.png
2012.11.13 22:06:36.377 5: WEBphone ._icoUhr => default/._icoUhr.png
2012.11.13 22:06:36.377 5: WEBphone ._icoWelt => default/._icoWelt.png
2012.11.13 22:06:36.378 5: WEBphone ._icoZirkulationAn => default/._icoZirkulationAn.png
2012.11.13 22:06:36.378 5: WEBphone ._leer => default/._leer.png
2012.11.13 22:06:36.378 5: WEBphone ._off => default/._off.png
2012.11.13 22:06:36.379 5: WEBphone ._off-for-timer => default/._off-for-timer.png
2012.11.13 22:06:36.379 5: WEBphone ._on => default/._on.png
2012.11.13 22:06:36.379 5: WEBphone ._on-for-timer => default/._on-for-timer.png
2012.11.13 22:06:36.379 5: WEBphone ._on-till => default/._on-till.png
2012.11.13 22:06:36.380 5: WEBphone ._signal_Fenster_Offen.off => default/._signal_Fenster_Offen.off.png
2012.11.13 22:06:36.380 5: WEBphone ._signal_Fenster_Offen.on => default/._signal_Fenster_Offen.on.png
2012.11.13 22:06:36.380 5: WEBphone ._toggle => default/._toggle.png
2012.11.13 22:06:36.381 5: WEBphone FS20.off => default/FS20.off.png
2012.11.13 22:06:36.381 5: WEBphone FS20.on => default/FS20.on.png
2012.11.13 22:06:36.381 5: WEBphone HOME_Status.0 => default/HOME_Status.0.png
2012.11.13 22:06:36.382 5: WEBphone HOME_Status.1 => default/HOME_Status.1.png
2012.11.13 22:06:36.382 5: WEBphone HOME_Status.3 => default/HOME_Status.3.png
2012.11.13 22:06:36.382 5: WEBphone HOME_Status.4 => default/HOME_Status.4.png
2012.11.13 22:06:36.382 5: WEBphone Heizung_Hauptschalter.off => default/Heizung_Hauptschalter.off.png
2012.11.13 22:06:36.383 5: WEBphone Heizung_Hauptschalter.off-for-timer => default/Heizung_Hauptschalter.off-for-timer.png
2012.11.13 22:06:36.383 5: WEBphone Heizung_Hauptschalter.on => default/Heizung_Hauptschalter.on.png
2012.11.13 22:06:36.383 5: WEBphone Next => default/Next.png
2012.11.13 22:06:36.384 5: WEBphone Prev => default/Prev.png
2012.11.13 22:06:36.384 5: WEBphone Restart => default/Restart.png
2012.11.13 22:06:36.384 5: WEBphone Shutdown => default/Shutdown.png
2012.11.13 22:06:36.384 5: WEBphone StandBy => default/StandBy.png
2012.11.13 22:06:36.385 5: WEBphone Update => default/Update.png
2012.11.13 22:06:36.385 5: WEBphone WLAN_Status.0 => default/WLAN_Status.0.png
2012.11.13 22:06:36.385 5: WEBphone WLAN_Status.1 => default/WLAN_Status.1.png
2012.11.13 22:06:36.386 5: WEBphone Wecker.Aus => default/Wecker.Aus.png
2012.11.13 22:06:36.386 5: WEBphone Wecker.Immer => default/Wecker.Immer.png
2012.11.13 22:06:36.386 5: WEBphone Wecker.Wochenende => default/Wecker.Wochenende.png
2012.11.13 22:06:36.386 5: WEBphone Wecker.Wochentags => default/Wecker.Wochentags.png
2012.11.13 22:06:36.387 5: WEBphone Zoom-in => default/Zoom-in.png
2012.11.13 22:06:36.387 5: WEBphone Zoom-out => default/Zoom-out.png
2012.11.13 22:06:36.387 5: WEBphone back => default/back.png
2012.11.13 22:06:36.387 5: WEBphone black_FS20.off => default/black_FS20.off.png
2012.11.13 22:06:36.388 5: WEBphone black_FS20.on => default/black_FS20.on.png
2012.11.13 22:06:36.388 5: WEBphone black_Steckdose.off => default/black_Steckdose.off.png
2012.11.13 22:06:36.388 5: WEBphone black_Steckdose.on => default/black_Steckdose.on.png
2012.11.13 22:06:36.389 5: WEBphone black_down => default/black_down.png
2012.11.13 22:06:36.389 5: WEBphone black_up => default/black_up.png
2012.11.13 22:06:36.389 5: WEBphone close => default/close.png
2012.11.13 22:06:36.389 5: WEBphone closeG => default/closeG.png
2012.11.13 22:06:36.390 5: WEBphone dim06% => default/dim06%.png
2012.11.13 22:06:36.390 5: WEBphone dim100% => default/dim100%.png
2012.11.13 22:06:36.390 5: WEBphone dim12% => default/dim12%.png
2012.11.13 22:06:36.392 5: WEBphone dim18% => default/dim18%.png
2012.11.13 22:06:36.392 5: WEBphone dim25% => default/dim25%.png
2012.11.13 22:06:36.393 5: WEBphone dim31% => default/dim31%.png
2012.11.13 22:06:36.393 5: WEBphone dim37% => default/dim37%.png
2012.11.13 22:06:36.393 5: WEBphone dim43% => default/dim43%.png
2012.11.13 22:06:36.393 5: WEBphone dim50% => default/dim50%.png
2012.11.13 22:06:36.394 5: WEBphone dim56% => default/dim56%.png
2012.11.13 22:06:36.394 5: WEBphone dim62% => default/dim62%.png
2012.11.13 22:06:36.394 5: WEBphone dim68% => default/dim68%.png
2012.11.13 22:06:36.395 5: WEBphone dim75% => default/dim75%.png
2012.11.13 22:06:36.395 5: WEBphone dim81% => default/dim81%.png
2012.11.13 22:06:36.395 5: WEBphone dim87% => default/dim87%.png
2012.11.13 22:06:36.395 5: WEBphone dim93% => default/dim93%.png
2012.11.13 22:06:36.396 5: WEBphone dimdown => default/dimdown.png
2012.11.13 22:06:36.396 5: WEBphone dimup => default/dimup.png
2012.11.13 22:06:36.396 5: WEBphone favicon => default/favicon.ico
2012.11.13 22:06:36.397 5: WEBphone fhemicon => default/fhemicon.png
2012.11.13 22:06:36.397 5: WEBphone heizung.0 => default/heizung.0.png
2012.11.13 22:06:36.397 5: WEBphone icoAUSSEN => default/icoAUSSEN.png
2012.11.13 22:06:36.397 5: WEBphone icoAUSSENBEREICH => default/icoAUSSENBEREICH.png
2012.11.13 22:06:36.398 5: WEBphone icoBELEUCHTUNG => default/icoBELEUCHTUNG.png
2012.11.13 22:06:36.398 5: WEBphone icoBaum => default/icoBaum.png
2012.11.13 22:06:36.398 5: WEBphone icoBlitz => default/icoBlitz.png
2012.11.13 22:06:36.398 5: WEBphone icoEverything => default/icoEverything.png
2012.11.13 22:06:36.399 5: WEBphone icoGraph => default/icoGraph.png
2012.11.13 22:06:36.399 5: WEBphone icoHEIZUNG => default/icoHEIZUNG.png
2012.11.13 22:06:36.399 5: WEBphone icoHISTORIE => default/icoHISTORIE.png
2012.11.13 22:06:36.400 5: WEBphone icoHaus => default/icoHaus.png
2012.11.13 22:06:36.400 5: WEBphone icoHeizungAn => default/icoHeizungAn.png
2012.11.13 22:06:36.400 5: WEBphone icoHeizungReg => default/icoHeizungReg.png
2012.11.13 22:06:36.400 5: WEBphone icoHouse => default/ic
Guest
Hallo Merhan,
schon einmal beruhigend zu hoeren. Ich schaue mir  die Traces noch an..
dauert noch etwas
Dumme Frage - 2110 hast du fuer HMLAN und CUL_HM - richtig? HMLAN macht das
micro-timing...
Gruss
Martin
Guest
Hallo Christian,
wie ich an den Traces sehe hast du hmProtocolEvents auf 3 gesetzt. Das ist
schon einmal schlecht.
Kannst du noch einmal testen mit hmProtocolEvents = 0?
Dann brauch ich die Logs, wenn "global att verbose 5" (ich muss mal eine
Einschraengung probieren es sollte auch gehen
attr global verbose 2
attr cul loglevel 1
Kannst du mir auch ein "list" deiner CUNO schicken?
Gruss
Martin
Am Dienstag, 13. November 2012 22:01:55 UTC+1 schrieb kohrti:
> Hallo Martin & der Rest der fhem Welt,
> ich war die Tage etwas eingespannt und konnte endlich wieder mehr Zeit in
> fhem investieren. Leider sieht es bei mir nicht so gut aus.
> Hier das Setzen der desired-temp am Thermostaten az_Thermostat:
> 2012.11.13 21:50:32.532 4: RCV L:10 N:21 F:A4 CMD:10 SRC:az_Thermostat
> DST:F11234 06021900000000 (INFO_ACTUATOR_STATUS RSSI:0 CHANNEL:0x02
> STATUS:0x19 UNKNOWN:0x00) (,BCAST,BIDI,RPTEN)
> 2012.11.13 21:50:32.695 4: SND L:0A N:21 F:80 CMD:02 SRC:F11234
> DST:az_Thermostat 00 (ACK) (,RPTEN)
> 2012.11.13 21:50:33.050 4: RCV L:10 N:23 F:A4 CMD:10 SRC:az_Thermostat
> 2012.11.13 21:50:33.217 4: SND L:0A N:23 F:80 CMD:02 SRC:F11234
> Hier setze ich über die Web GUI:
> 2012.11.13 21:59:32.666 4: RCV L:0C N:24 F:86 CMD:70 SRC:az_Thermostat
> DST:broadcast 00E135 (WeatherEvent TEMP:22.5 HUM:53) (,WAKEMEUP,BCAST,RPTEN)
> 2012.11.13 21:59:32.834 4: SND L:09 N:2B F:A1 CMD:12 SRC:F11234
> DST:az_Thermostat  (HAVE_DATA) (,WAKEUP,BIDI,RPTEN)
> 2012.11.13 21:59:35.001 4: CUL_HM_Resend: az_Thermostat nr 2
> 2012.11.13 21:59:36.017 4: CUL_HM_Resend: az_Thermostat nr 3
> Gruß
> Christian
> PS
> Ich habe eine CUNO und FB7390.
> Am Donnerstag, 8. November 2012 22:10:59 UTC+1 schrieb Martin:
>> Ich habe heute um20 Uhr ein Update gemacht und da waren auch seit gestern
>>> einige Dateien dabei, jedoch bekomme ich immer noch MissingAck wenn ich
>>> versuche die ,,desired-temp" einzustellen.
>> eine CUNO habe ich nicht zum testen - erwarte aber das die im Prinzip wie
>> eine CUL arbeitet - also full-transparent, nicht wie HMLAN.
>> Aber auch bei der CUL habe ich noch Defizite - wenn man etwas schneller
>> sendet steigt sie komplett aus. Die CUNO koennte also ein anderes Timing
>> haben/brauchen.
>> Kannst du noch einmal eine log ziehen?   Einfach nur von Temp setzen.
>> Kannst du die Temp auch am TC verstellen? Auch loggen
>> Danke
>> Martin
Guest
Hi Martin,
kommt heute abend.
Danke & Gruß,
Christian
PS
Ich hatte bei meinen Versuchen auch jegliches Logging aus geschaltet - ging
trotzdem nicht. Ich ich dachte du brauchst die hmprotocolevents um mehr zu
sehen. Ich habe übrigens gestern auch ein Update gemacht.
Martin hat am 14. November 2012 um 15:56 geschrieben:
> Hallo Christian,
>  attr cul loglevel 1
>  Gruss
>  Martin
>    > > Hallo Martin & der Rest der fhem Welt,
> >    Gruß
> >    Christian
> >    PS
> > > > gestern einige Dateien dabei, jedoch bekomme ich immer noch MissingAck
> > > > wenn ich versuche die ,,desired-temp" einzustellen.
> > > wie eine CUL arbeitet - also full-transparent, nicht wie HMLAN.
> > > schneller sendet steigt sie komplett aus. Die CUNO koennte also ein
> > > anderes Timing haben/brauchen.
> > >      Danke
> > >      Martin
Guest
Hallo Martin,
> micro-timing...
Jawohl - beides Stand 2110.
Bin gespannt auf Dein Feedback.
Ich nehme mir mal aus dem Büro eine Firtzbox mit und teste mal das ganze
Setup damit. Die kann ich mir aber erst am WE mitnehmen.
Viele Grüße,
Merhan
Guest
Hi Christian,
logs brauche ich schon - aber die Impementierung der hmProtocol-Events geht
ueber Trigger in Stufe 3.Das geht ist der 'performance-killer' ;-)
am einfachsten und kompaktesten ist den loglevel der IO-Unit (bei dir CUL)
auf 1 zu setzen.
Verbose dann auch auf 1 (die beiden Nummern laufen genau genommen
gegenlaeufig).
Wenn du schon ohne hmProtokolEvents getestet hast sind die Aussichten
schlecht.
Aber die Logs kann ich mir einmal ansehen.
Gruss
Martin
hm
Am Mittwoch, 14. November 2012 16:01:53 UTC+1 schrieb kohrti:
>  Hi Martin,
>  kommt heute abend.
>  Danke & Gruß,
>  Christian
>  PS
> ging trotzdem nicht. Ich ich dachte du brauchst die hmprotocolevents um
> mehr zu sehen. Ich habe übrigens gestern auch ein Update gemacht.
> Martin > hat am 14. November 2012 um
> 15:56 geschrieben:
> Hallo Christian,
> attr cul loglevel 1
> Gruss
> Martin
> Gruß
> Christian
> PS
> gestern einige Dateien dabei, jedoch bekomme ich immer noch MissingAck wenn
> haben/brauchen.
> Danke
> Martin
> fhem-users+...@googlegroups.com
Guest
Hallo Martin,
ich habe hier die Logs.
List ("list CUNO"):
   CMDS       mBCFiAIGMRTVWXOefltuxEcq
   CUNO_MSGCNT 5748
   CUNO_TIME  2012-11-14 22:17:53
   Clients    :CUL_HM:HMS:CUL_IR:
   DEF        192.168.2.34:2323 1234
   DeviceName 192.168.2.34:2323
   FD         9
   FHTID      1234
   HM_CMDNR   102
   NAME       CUNO
   NR         18
   PARTIAL
   RAWMSG     A0E6680021A5C61F112340104C8004EEF
   RSSI       -82.5
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.46 CUNO868
   initString X21
Ar
   Matchlist:
     1:CUL_HM   ^A....................
     8:HMS      ^810e04....(1|5|9).a001
     D:CUL_IR   ^I............
   Readings:
     2012-11-13 22:37:11   cmds             m B C F i A I G M R T V W X O e
f l t u x E c q
     2012-11-13 22:37:11   raw             02
   Helper:
     HMnextTR   1352927873.31878
   rfmode     HomeMatic
   room       CUL_HM
Temperatur am Thermostat manuell von 21 auf 23 °C eingestellt:
Einstellungen: attr global verbose 2 und attr cul loglevel 1
2012.11.14 22:26:36.971 1: CUNO: A0C6786701D6A4300000000D935 -77
2012.11.14 22:26:47.636 1: CUNO: A1068A4101D6A43F1123406022E00000000 -75.5
2012.11.14 22:26:47.748 1: SW: As0A688002F112341D6A4300
2012.11.14 22:26:47.903 1: CUNO: A1069A4101D6A43F1123406022E00000000 -75.5
2012.11.14 22:26:48.058 1: SW: As0A698002F112341D6A4300
2012.11.14 22:26:48.094 1: CUNO: A106AA4101D6A43F1123406022E00000000 -75.5
2012.11.14 22:26:48.250 1: SW: As0A6A8002F112341D6A4300
2012.11.14 22:27:09.460 1: CUNO: A0C8E86701D6B8500000000DC38 -35.5
2012.11.14 22:27:09.707 1: CUNO: A0C7686701AC375000000003757 -90
Manuell von 23°C auf 23.5°C:
2012.11.14 22:28:18.401 1: CUNO: A0C8C86701D6AB500000000E237 -62
2012.11.14 22:28:19.393 1: CUNO: A106BA4101D6A43F1123406022F00000000 -76
2012.11.14 22:28:19.504 1: SW: As0A6B8002F112341D6A4300
2012.11.14 22:28:19.660 1: CUNO: A106CA4101D6A43F1123406022F00000000 -73
2012.11.14 22:28:19.815 1: SW: As0A6C8002F112341D6A4300
2012.11.14 22:28:19.851 1: CUNO: A106DA4101D6A43F1123406022F00000000 -73
2012.11.14 22:28:20.018 1: SW: As0A6D8002F112341D6A4300
2012.11.14 22:28:43.698 1: CUNO: A0CF186701D6B3200000000D236 -54.5
2012.11.14 22:29:05.275 1: CUNO: A0C6886701D6A4300000000DA35 -76.5
2012.11.14 22:29:23.872 1: CUNO: A0C2986701D6D8B00000000DE3A -66
Über Web desired-temp auf "on":
2012.11.14 22:30:20.415 1: CUNO: A0C8D86701D6AB500000000E237 -60.5
2012.11.14 22:30:43.231 1: CUNO: A0B84A440173799192F9701D3 -65
2012.11.14 22:30:43.525 1: CUNO: A0E848002192F97173799010100003C -62.5
2012.11.14 22:30:43.729 1: CUNO: A0B6FA44019D601185A890124 -63.5
2012.11.14 22:30:44.023 1: CUNO: A0E6F8002185A8919D601010200004D -59.5
2012.11.14 22:30:44.227 1: CUNO: A0B93A440142ABB175ADC01CE -57.5
2012.11.14 22:30:44.525 1: CUNO: A0F938002175ADC142ABB0101BE203EEC -52.5
2012.11.14 22:30:44.968 1: CUNO: A0B70A44019D601185A8903D6 -62
2012.11.14 22:30:45.262 1: CUNO: A0E708002185A8919D6010101000046 -62.5
2012.11.14 22:30:46.952 1: CUNO: A0F94A410175ADCF11234060100008000 -52.5
2012.11.14 22:30:47.063 1: SW: As0A948002F11234175ADC00
2012.11.14 22:30:49.434 1: CUNO: A0C9986701953E7000000016E64 -78.5
2012.11.14 22:30:50.426 1: CUNO: A0F94A410175ADCF11234060100008000 -53
2012.11.14 22:30:54.143 1: CUNO: A0F94A410175ADCF11234060100008000 -53.5
2012.11.14 22:30:57.118 1: CUNO: A0B5BA440175FE615C7D80233 -51
2012.11.14 22:30:57.369 1: CUNO: A0B5CA040175FE6185A9C0233 -50.5
2012.11.14 22:30:57.616 1: CUNO: A0E5C8002185A9C175FE60101C80049 -61
2012.11.14 22:30:57.788 1: CUNO: A0B5BA040175FE615C7D80233 -50.5
2012.11.14 22:30:57.863 1: CUNO: A0B5BA040175FE615C7D80233 -50
2012.11.14 22:30:58.855 1: CUNO: A0F94A410175ADCF11234060100008000 -53.5
2012.11.14 22:31:02.823 1: CUNO: A0CC886701D6A8B00000000DE35 -67
2012.11.14 22:31:05.552 1: CUNO: A0F94A410175ADCF11234060100008000 -53
2012.11.14 22:31:10.014 1: CUNO: A0B5DA440175FE615C7D80140 -52
2012.11.14 22:31:10.261 1: CUNO: A0B5EA040175FE6185A9C0140 -50
2012.11.14 22:31:10.512 1: CUNO: A0E5E8002185A9C175FE6010100003B -60
2012.11.14 22:31:10.680 1: CUNO: A0B5DA040175FE615C7D80140 -50
2012.11.14 22:31:10.759 1: CUNO: A0B5DA040175FE615C7D80140 -51.5
2012.11.14 22:31:16.464 1: CUNO: A0F94A410175ADCF11234060100008000 -53.5
2012.11.14 22:31:19.440 1: CUNO: A0C6986701D6A4300000000DA35 -68.5
2012.11.14 22:31:19.548 1: SW: As0995A112F112341D6A43
2012.11.14 22:31:19.934 1: CUNO: A0CF286701D6B3200000000D236 -54
2012.11.14 22:31:21.564 1: SW: As0995A112F112341D6A43
2012.11.14 22:31:22.583 1: SW: As0995A112F112341D6A43
2012.11.14 22:31:30.846 1: CUNO: A0C7886701AC375000000003658 -84
2012.11.14 22:31:33.575 1: CUNO: A0C9086701D6B8500000000DC38 -35.5
Einstellungen: attr global verbose 5 und attr cul loglevel 1
2012.11.14 22:33:41.294 5: CUL/RAW: /A0CF386701D6B3200000000D33628
2012.11.14 22:33:41.294 1: CUNO: A0CF386701D6B3200000000D336 -54
2012.11.14 22:33:41.294 5: CUNO dispatch A0CF386701D6B3200000000D336
2012.11.14 22:33:41.310 5: Triggering sz_Thermostat (3 changes)
2012.11.14 22:33:41.318 5: sz_Thermostat trigger: Checking
FileLog_ActionDetector for notify
2012.11.14 22:33:41.322 5: sz_Thermostat trigger: Checking
FileLog_Aussentemperatur for notify
2012.11.14 22:33:41.326 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_142ABB for notify
FileLog_CUL_HM_remote_142ABB_Btn_01 for notify
2012.11.14 22:33:41.330 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_142ABB_Btn_02 for notify
FileLog_CUL_HM_remote_175E59 for notify
2012.11.14 22:33:41.334 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_175E59_Btn_01 for notify
FileLog_CUL_HM_remote_175E59_Btn_02 for notify
2012.11.14 22:33:41.338 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_175E59_Btn_03 for notify
2012.11.14 22:33:41.342 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_175E59_Btn_04 for notify
FileLog_CUL_HM_remote_19C179 for notify
2012.11.14 22:33:41.346 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_19C179_Btn_01 for notify
FileLog_CUL_HM_remote_19C179_Btn_02 for notify
2012.11.14 22:33:41.350 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_19D5B7 for notify
FileLog_CUL_HM_remote_19D5B7_Btn_01 for notify
2012.11.14 22:33:41.354 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_19D5B7_Btn_02 for notify
2012.11.14 22:33:41.358 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_19D5B7_Btn_03 for notify
FileLog_CUL_HM_remote_19D5B7_Btn_04 for notify
2012.11.14 22:33:41.362 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_19D601 for notify
FileLog_CUL_HM_remote_19D601_Btn_01 for notify
2012.11.14 22:33:41.366 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_19D601_Btn_02 for notify
FileLog_CUL_HM_remote_19D601_Btn_03 for notify
2012.11.14 22:33:41.370 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_19D601_Btn_04 for notify
FileLog_CUL_HM_remote_19D629_Btn_01 for notify
2012.11.14 22:33:41.374 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_19D629_Btn_02 for notify
2012.11.14 22:33:41.378 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_remote_19D629_Btn_03 for notify
FileLog_CUL_HM_remote_19D629_Btn_04 for notify
2012.11.14 22:33:41.382 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_swi_1736FA for notify
FileLog_CUL_HM_swi_1736FA_Sw_01 for notify
2012.11.14 22:33:41.386 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_swi_1736FA_Sw_02 for notify
FileLog_CUL_HM_swi_1736FA_Sw_03 for notify
2012.11.14 22:33:41.390 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_swi_173799 for notify
2012.11.14 22:33:41.394 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_swi_173799_Sw_01 for notify
FileLog_CUL_HM_swi_173799_Sw_02 for notify
2012.11.14 22:33:41.398 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_swi_173799_Sw_03 for notify
FileLog_CUL_HM_switch_185A89 for notify
2012.11.14 22:33:41.402 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_switch_185AA8 for notify
FileLog_CUL_HM_switch_185AA8_Sw_01 for notify
2012.11.14 22:33:41.406 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_switch_185AA8_Sw_02 for notify
2012.11.14 22:33:41.410 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_switch_185AAA_Sw_01 for notify
FileLog_CUL_HM_switch_185AAA_Sw_02 for notify
2012.11.14 22:33:41.414 5: sz_Thermostat trigger: Checking
FileLog_CUL_HM_threeStateSensor_19F495 for notify
2012.11.14 22:33:41.414 5: sz_Thermostat trigger: Checking FileLog_Switch1
for notify
2012.11.14 22:33:41.418 5: sz_Thermostat trigger: Checking
FileLog_Vorlauftemperatur for notify
FileLog_az2_PIDPWM for notify
2012.11.14 22:33:41.422 5: sz_Thermostat trigger: Checking
FileLog_az_PIDPWM for notify
FileLog_az_Rauchmelder for notify
2012.11.14 22:33:41.426 5: sz_Thermostat trigger: Checking
FileLog_az_Stehlampe1 for notify
2012.11.14 22:33:41.430 5: sz_Thermostat trigger: Checking
FileLog_az_Stehlampe2 for notify
FileLog_az_Thermostat for notify
2012.11.14 22:33:41.434 5: sz_Thermostat trigger: Checking
FileLog_az_Thermostat_Climate for notify
FileLog_az_Thermostat_Weather for notify
2012.11.14 22:33:41.438 5: sz_Thermostat trigger: Checking
FileLog_az_Thermostat_WindowRec for notify
FileLog_ba_PIDPWM for notify
2012.11.14 22:33:41.442 5: sz_Thermostat trigger: Checking
FileLog_ba_Thermostat for notify
FileLog_ba_Thermostat_Climate for notify
2012.11.14 22:33:41.446 5: sz_Thermostat trigger: Checking
FileLog_ba_Thermostat_Weather for notify
2012.11.14 22:33:41.450 5: sz_Thermostat trigger: Checking
FileLog_ba_Thermostat_WindowRec for notify
2012.11.14 22:33:41.450 5: sz_Thermostat trigger: Checking FileLog_ez_Lampe
for notify
2012.11.14 22:33:41.453 5: sz_Thermostat trigger: Checking
FileLog_fl_Rauchmelder for notify
2012.11.14 22:33:41.457 5: sz_Thermostat trigger: Checking
FileLog_gz_PIDPWM for notify
FileLog_gz_Thermostat for notify
2012.11.14 22:33:41.461 5: sz_Thermostat trigger: Checking
FileLog_gz_Thermostat_Climate for notify
FileLog_gz_Thermostat_Weather for notify
2012.11.14 22:33:41.465 5: sz_Thermostat trigger: Checking
FileLog_gz_Thermostat_WindowRec for notify
FileLog_ka_Heizkreis1 for notify
2012.11.14 22:33:41.469 5: sz_Thermostat trigger: Checking
FileLog_ka_Heizkreis2 for notify
FileLog_ka_Heizkreis3 for notify
2012.11.14 22:33:41.473 5: sz_Thermostat trigger: Checking
FileLog_ka_Heizkreis4 for notify
2012.11.14 22:33:41.477 5: sz_Thermostat trigger: Checking
FileLog_ka_Heizkreis5 for notify
FileLog_ka_Heizkreis5to8 for notify
2012.11.14 22:33:41.481 5: sz_Thermostat trigger: Checking
FileLog_ka_Heizkreis6 for notify
FileLog_ka_Heizkreis7 for notify
2012.11.14 22:33:41.485 5: sz_Thermostat trigger: Checking
FileLog_ka_Heizkreis8 for notify
FileLog_ku_PIDPWM for notify
2012.11.14 22:33:41.489 5: sz_Thermostat trigger: Checking
FileLog_ku_Rauchmelder for notify
2012.11.14 22:33:41.493 5: sz_Thermostat trigger: Checking
FileLog_ku_Speaker for notify
FileLog_ku_Stripe for notify
2012.11.14 22:33:41.497 5: sz_Thermostat trigger: Checking
FileLog_ku_StripeSpeaker for notify
FileLog_ku_Thermostat for notify
2012.11.14 22:33:41.501 5: sz_Thermostat trigger: Checking
FileLog_ku_Thermostat_Climate for notify
FileLog_ku_Thermostat_Weather for notify
2012.11.14 22:33:41.505 5: sz_Thermostat trigger: Checking
FileLog_ku_Thermostat_WindowRec for notify
2012.11.14 22:33:41.509 5: sz_Thermostat trigger: Checking
FileLog_sz_BettlampeChri for notify
FileLog_sz_BettlampeEri for notify
2012.11.14 22:33:41.513 5: sz_Thermostat trigger: Checking
FileLog_sz_PIDPWM for notify
FileLog_sz_Schranklicht for notify
2012.11.14 22:33:41.517 5: sz_Thermostat trigger: Checking
FileLog_sz_Stripe for notify
FileLog_sz_Thermostat for notify
2012.11.14 22:33:41.533 5: sz_Thermostat trigger: Checking
FileLog_sz_Thermostat_Climate for notify
2012.11.14 22:33:41.537 5: sz_Thermostat trigger: Checking
FileLog_sz_Thermostat_Weather for notify
FileLog_sz_Thermostat_WindowRec for notify
2012.11.14 22:33:41.541 5: sz_Thermostat trigger: Checking
FileLog_wz_LampeCouch for notify
FileLog_wz_PIDPWM for notify
2012.11.14 22:33:41.545 5: sz_Thermostat trigger: Checking
FileLog_wz_StehlampeNeu for notify
FileLog_wz_StripeDach for notify
2012.11.14 22:33:41.549 5: sz_Thermostat trigger: Checking
FileLog_wz_Taster2 for notify
2012.11.14 22:33:41.553 5: sz_Thermostat trigger: Checking
FileLog_wz_Thermostat for notify
FileLog_wz_Thermostat_Climate for notify
2012.11.14 22:33:41.557 5: sz_Thermostat trigger: Checking
FileLog_wz_Thermostat_Weather for notify
FileLog_wz_Thermostat_WindowRec for notify
2012.11.14 22:33:41.561 5: sz_Thermostat trigger: Checking Logfile for
notify
2012.11.14 22:33:41.565 5: sz_Thermostat trigger: Checking WEB for notify
2012.11.14 22:33:41.565 5: sz_Thermostat trigger: Checking WEBphone for
notify
2012.11.14 22:33:41.565 5: sz_Thermostat trigger: Checking WEBtablet for
notify
2012.11.14 22:33:41.565 5: sz_Thermostat trigger: Checking autocreate for
notify
2012.11.14 22:33:41.569 5: sz_Thermostat trigger: Checking telnetPort for
notify
2012.11.14 22:33:43.772 5: CUL/RAW: /A0CC986701D6A8B00000000DE3511
2012.11.14 22:33:43.776 1: CUNO: A0CC986701D6A8B00000000DE35 -65.5
2012.11.14 22:33:43.776 5: CUNO dispatch A0CC986701D6A8B00000000DE35
2012.11.14 22:33:43.792 5: Triggering gz_Thermostat (3 changes)
2012.11.14 22:33:43.800 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.804 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.808 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.812 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.816 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.820 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.824 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.828 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.832 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.836 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.840 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.844 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.848 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.852 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.856 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.860 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.864 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.868 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.872 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.876 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.880 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.884 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.888 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.892 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.896 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.896 5: gz_Thermostat trigger: Checking FileLog_Switch1
for notify
2012.11.14 22:33:43.900 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.904 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.908 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.912 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.916 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.920 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.927 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.931 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.935 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.935 5: gz_Thermostat trigger: Checking FileLog_ez_Lampe
for notify
2012.11.14 22:33:43.939 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.943 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.955 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.959 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.963 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.967 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.971 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.975 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.979 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.983 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.987 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.991 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.995 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.999 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:43.003 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.003 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.007 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.011 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.015 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.019 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.023 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.027 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.031 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.035 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.039 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.043 5: gz_Thermostat trigger: Checking
2012.11.14 22:33:44.043 5: gz_Thermostat trigger: Checking Logfile for
notify
2012.11.14 22:33:44.047 5: gz_Thermostat trigger: Checking WEB for notify
2012.11.14 22:33:44.047 5: gz_Thermostat trigger: Checking WEBphone for
notify
2012.11.14 22:33:44.047 5: gz_Thermostat trigger: Checking WEBtablet for
notify
2012.11.14 22:33:44.051 5: gz_Thermostat trigger: Checking autocreate for
notify
2012.11.14 22:33:44.051 5: gz_Thermostat trigger: Checking telnetPort for
notify
2012.11.14 22:33:44.270 4: HTTP FHEMWEB:192.168.2.20:49603 GET
/fhem?detail=az_Thermostat&detail=az_Thermostat&dev.setaz_Thermostat=az_Thermostat&cmd.setaz_Thermostat=set&arg.setaz_Thermostat=desired-temp&val.setaz_Thermostat=on
2012.11.14 22:33:44.274 5: Cmd: >set az_Thermostat desired-temp on<
2012.11.14 22:33:44.278 5: Triggering az_Thermostat (1 changes)
2012.11.14 22:33:44.294 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.298 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.302 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.306 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.310 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.314 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.318 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.322 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.326 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.330 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.334 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.338 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.342 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.346 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.350 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.354 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.358 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.362 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.366 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.370 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.374 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.378 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.382 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.382 5: az_Thermostat trigger: Checking FileLog_Switch1
for notify
2012.11.14 22:33:44.386 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.390 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.394 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.398 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.402 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.406 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.410 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.414 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.418 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.418 5: az_Thermostat trigger: Checking FileLog_ez_Lampe
for notify
2012.11.14 22:33:44.421 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.425 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.429 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.433 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.437 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.441 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.445 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.449 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.453 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.457 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.461 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.465 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.469 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.473 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.477 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.481 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.485 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.489 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.493 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.501 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.505 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.509 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.513 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.517 5: az_Thermostat trigger: Checking
2012.11.14 22:33:44.517 5: az_Thermostat trigger: Checking Logfile for
notify
2012.11.14 22:33:44.521 5: az_Thermostat trigger: Checking WEB for notify
2012.11.14 22:33:44.521 5: az_Thermostat trigger: Checking WEBphone for
notify
2012.11.14 22:33:44.521 5: az_Thermostat trigger: Checking WEBtablet for
notify
2012.11.14 22:33:44.525 5: az_Thermostat trigger: Checking autocreate for
notify
2012.11.14 22:33:44.525 5: az_Thermostat trigger: Checking telnetPort for
notify
2012.11.14 22:33:44.525 3: CUL_HM set az_Thermostat desired-temp on rxt:12
2012.11.14 22:33:44.533 4: HTTP FHEMWEB:192.168.2.20:49603 GET
2012.11.14 22:33:44.780 4: /fhem?detail=az_Thermostat / RL: 4445 /
text/html; charset=UTF-8 / Content-Encoding: gzip
2012.11.14 22:34:22.958 5: CUL/RAW: /A0C6A86701D6A4300000000DA36FE
2012.11.14 22:34:22.958 1: CUNO: A0C6A86701D6A4300000000DA36 -75
2012.11.14 22:34:22.962 5: CUNO dispatch A0C6A86701D6A4300000000DA36
2012.11.14 22:34:22.973 5: CUNO sending As0996A112F112341D6A43
2012.11.14 22:34:23.069 1: SW: As0996A112F112341D6A43
2012.11.14 22:34:23.085 5: Triggering az_Thermostat (3 changes)
2012.11.14 22:34:23.093 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.097 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.101 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.105 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.109 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.113 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.117 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.121 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.125 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.129 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.133 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.137 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.141 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.145 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.149 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.153 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.157 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.161 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.165 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.169 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.173 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.177 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.181 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.185 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.189 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.189 5: az_Thermostat trigger: Checking FileLog_Switch1
for notify
2012.11.14 22:34:23.193 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.197 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.201 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.205 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.217 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.220 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.224 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.228 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.232 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.236 5: az_Thermostat trigger: Checking FileLog_ez_Lampe
for notify
2012.11.14 22:34:23.240 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.244 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.248 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.252 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.256 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.260 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.264 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.268 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.272 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.276 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.280 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.284 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.288 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.292 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.296 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.300 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.304 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.308 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.312 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.316 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.320 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.324 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.328 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.332 5: az_Thermostat trigger: Checking
2012.11.14 22:34:23.332 5: az_Thermostat trigger: Checking Logfile for
notify
2012.11.14 22:34:23.336 5: az_Thermostat trigger: Checking WEB for notify
2012.11.14 22:34:23.336 5: az_Thermostat trigger: Checking WEBphone for
notify
2012.11.14 22:34:23.340 5: az_Thermostat trigger: Checking WEBtablet for
notify
2012.11.14 22:34:23.340 5: az_Thermostat trigger: Checking autocreate for
notify
2012.11.14 22:34:23.340 5: az_Thermostat trigger: Checking telnetPort for
notify
2012.11.14 22:34:23.452 5: CUL/RAW: /A0C7986701AC375000000003658E7
2012.11.14 22:34:23.452 1: CUNO: A0C7986701AC375000000003658 -86.5
2012.11.14 22:34:23.456 5: CUNO dispatch A0C7986701AC375000000003658
2012.11.14 22:34:23.467 5: Triggering Aussentemperatur (3 changes)
2012.11.14 22:34:23.479 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.483 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.487 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.491 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.495 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.499 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.503 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.507 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.511 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.515 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.519 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.523 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.527 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.531 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.535 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.539 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.543 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.547 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.551 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.555 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.559 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.571 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.575 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.579 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.583 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.587 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.591 5: Aussentemperatur trigger: Checking
FileLog_Switch1 for notify
2012.11.14 22:34:23.595 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.599 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.603 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.607 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.611 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.615 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.619 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.623 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.627 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.631 5: Aussentemperatur trigger: Checking
FileLog_ez_Lampe for notify
2012.11.14 22:34:23.635 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.639 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.643 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.647 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.651 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.655 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.659 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.663 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.667 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.671 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.675 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.679 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.683 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.687 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.691 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.695 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.699 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.703 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.707 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.711 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:23.714 5: Aussentemperatur trigger: Checking
2012.11.14 22:34:
Guest
Hallo
da ist kaum ein Problem zu sehen.
Beim manuellen Setzen der Temp akzeptiert der TC scheinbar das ACK nicht.
Das kommt nach 100 ms, sollte ok sein.
Bein setzen der Temperatur ist dein Sender sehr schnell.Sollte eigentlich
100ms warten.
Ich nehme an, du hast das neust 00_CUL modul - richtig?
Evtl muss man hier laenger warten? Ich weiss nicht, wie schnell die CUNO
ist.
Funktioniert das ganze bei dir, wenn du es mit config uebertraegst? Also
Anlernen nach dem Absetzen des Kommandos?
Gruss
Martin
Guest
Hallo martin,
ich habe folgendes Timeout nach getConfig:
2012-11-15_22:06:03 az_Thermostat measured-temp: 22.4
2012-11-15_22:06:03 az_Thermostat humidity: 54
2012-11-15_22:08:00 az_Thermostat Activity:unknown
2012-11-15_22:08:02 az_Thermostat RESPONSE TIMEOUT
2012-11-15_22:08:04 az_Thermostat RESPONSE TIMEOUT
2012-11-15_22:08:05 az_Thermostat RESPONSE TIMEOUT
2012-11-15_22:08:28 az_Thermostat Activity:alive
2012-11-15_22:08:42 az_Thermostat T: 22.4 H: 54
2012-11-15_22:08:42 az_Thermostat measured-temp: 22.4
2012-11-15_22:08:42 az_Thermostat humidity: 54
Ich verwende die 00_CUL Version:
# $Id: 00_CUL.pm 2105 2012-11-10 00:00:44Z martinp876 $
Das ist die, die beim letzten update vor 2 Tagen reingekommen ist.
Christian
Am Donnerstag, 15. November 2012 20:35:02 UTC+1 schrieb Martin:
> Hallo
> 100ms warten.
> ist.
> Gruss
> Martin
Guest
Hallo Merhan,
anbei eine Versuchsfile HMLAN.
hat bei mir die Situation verbessert - nachdem mein TC einen einbruch
erlitten hat. ...:-(
Falls dies klappt werde ich es entsprechend einbauen....
Ich warte also auf deinen Test
Gruss
Martin
Guest
Hallo Martin,
gute Nachrichten: Es funktioniert!!!!!
Mit meinem Testsetup (1 TC, 1VD, 1 HM-Lichtschalter) konnte ich erfolgreich
Befehle absetzen.
Beim Starten bekomme ich in der Konsole folgende Fehlermeldungen:
Use of uninitialized value in length at
/opt/share/fhem-5.3/FHEM/00_HMLAN.pm line 291.
Jedoch startet das System.
Mit meiner eigentlichen fhem.cfg bricht der Startvorgang mit folgenden
Fehlermeldungen ab:
Use of uninitialized value in concatenation (.) or string at fhem.pl line
2926.
fhem.pl: readingsUpdate(,state,T: 19.2 H: 44): you must call
readingsBeginUpdate first. at fhem.pl line 2926.
Ich habe mein Statefile gelöscht. Was hat es mit der Meldung auf sich?
Vielen vielen Dank!
Grüße,
Merhan
Am Freitag, 16. November 2012 00:11:38 UTC+1 schrieb Martin:
> Hallo Merhan,
> Gruss
> Martin
Guest
Eine Frage noch:
War ist das Setzen vom TC Control-Mode von weiteren Aspekten abhängig?
set CUL_HM_thermostat_1A7B01 controlMode auto
please complete settings for displayMode decalcDay displayTempUnit
displayTemp
Guest
Hallo Martin
ist bei dem heutigen Update von 10_CUL_HM.pm ein Problem?
Bei mir ist die CUL jetzt "diskonnectet".
Meldung nach dem Update war folgende:
 Backup:
tar: Removing leading `/' from member names
backup done: FHEM-20121117_143049.tar.gz (1914627 Bytes)
8 file(s) have been updated:
==> 2012-11-17 07:45:14 FHEM/00_HMLAN.pm
==> 2012-11-17 07:45:14 FHEM/10_CUL_HM.pm
==> 2012-11-17 07:45:14 FHEM/40_RFXCOM.pm
==> 2012-11-17 07:45:14 FHEM/45_TRX.pm
==> 2012-11-17 07:45:14 FHEM/46_TRX_WEATHER.pm
==> 2012-11-17 07:45:14 FHEM/71_YAMAHA_AVR.pm
==> 2012-11-17 07:45:14 FHEM/98_XmlList.pm
==> 2012-11-17 07:45:15 docs/commandref.html
Module(s) reloaded:
==> 10_CUL_HM:
Not enough arguments for main::CUL_HM_SendCmd at /usr/share/fhem/FHEM/10_CUL_HM.pm line 572, near ""++803F$id${src}0204$s2000")"
Not enough arguments for main::CUL_HM_SendCmd at /usr/share/fhem/FHEM/10_CUL_HM.pm line 826, near ""0101${state}00")"
Not enough arguments for main::CUL_HM_SendCmd at /usr/share/fhem/FHEM/10_CUL_HM.pm line 884, near "))"
Not enough arguments for main::CUL_HM_SendCmd at /usr/share/fhem/FHEM/10_CUL_HM.pm line 928, near ""8002$id$src${chn}00")"
Not enough arguments for main::CUL_HM_SendCmd at /usr/share/fhem/FHEM/10_CUL_HM.pm line 961, near ""00")
Not enough arguments for main::CUL_HM_SendCmd at /usr/share/fhem/FHEM/10_CUL_HM.pm line 1030, near ""00")"
Not enough arguments for main::CUL_HM_SendCmd at /usr/share/fhem/FHEM/10_CUL_HM.pm line 1038, near ""00")"
Not enough arguments for main::CUL_HM_SendCmd at /usr/share/fhem/FHEM/10_CUL_HM.pm line 1047, near ""00")  # Send Ack
BEGIN not safe after errors--compilation aborted at /usr/share/fhem/FHEM/10_CUL_HM.pm line 1656.
==> 98_XmlList
Update completed!
   Was ist denn da im Argen?
Aloys
Guest
das gleiche bei mir... ich führe gerade einen downgrade durch
Am Samstag, 17. November 2012 15:17:15 UTC+1 schrieb AlLe:
> Hallo Martin
>  Backup:
> Module(s) reloaded:
> ==> 10_CUL_HM:
> ==> 98_XmlList
> Update completed!
> LG
> Aloys
Guest
Hallo Merhan
super.
> erfolgreich Befehle absetzen.
ok - ist ein debug string - nichts dramatisches. werde ich beheben
> Fehlermeldungen ab:
> 2926.
mein Fehler. Kommt wenn du einen TC ohne Channel 01 (Weather) hast und die
Readings geschrieben werden.
Ein Bug  behebe ich gleich (hatte es nicht gesehen, da ich immer alle
Kanaele habe... mus man aber nicht)
Gruss
Martin
