72_FRITZBOX: Sperren/Entsperren von Netzwerkgeräten / DECT Telefonen u weiteres
Begonnen von JoWiemann, 25 Januar 2021, 10:30:32
juemuc
Hallo Jörg,
auch mit Wählhilfe funktioniert es nicht. Mit verbose=5 erhalte ich diese Infos:
2023.06.17 15:00:07 3: [Fritzbox | 6690 | 267.07.56 | Set.1168] - INFO: set Fritzbox ring 610 10
2023.06.17 15:00:07 5: [Fritzbox | 6690 | 267.07.56 | Set_Cmd_Start.4059] - DEBUG: Set_CMD_Start -> Set.1170 -> ring
2023.06.17 15:00:07 4: [Fritzbox | 6690 | 267.07.56 | Set_Cmd_Start.4171] - INFO: Fork process FRITZBOX_Ring_Run_Web
2023.06.17 15:00:07 5: [Fritzbox | 6690 | 267.07.56 | Ring_Run_Web.5240] - DEBUG: Internal number 610 (dect1) seems to be a Fritz!Fon.
2023.06.17 15:00:07 5: [Fritzbox | 6690 | 267.07.56 | Ring_Run_Web.5250] - DEBUG: Extracted ring duration of 10 s.
2023.06.17 15:00:07 4: [Fritzbox | 6690 | 267.07.56 | readPassword.7211] - INFO: Read FritzBox password from file
2023.06.17 15:00:07 5: [Fritzbox | 6690 | 267.07.56 | TR064_Cmd.5648] - DEBUG: Perform TR-064 call - X_AVM-DE_GetPhonePort => service='X_VoIP:1', control='x_voip', action='X_AVM-DE_GetPhonePort', parameter1='NewIndex' => '1'
2023.06.17 15:00:07 5: [Fritzbox | 6690 | 267.07.56 | TR064_Cmd.5648] - DEBUG: Perform TR-064 call - X_AVM-DE_DialSetConfig => service='X_VoIP:1', control='x_voip', action='X_AVM-DE_DialSetConfig', parameter1='NewX_AVM-DE_PhoneName' => 'FON1: Telefon 1'
2023.06.17 15:00:07 4: [Fritzbox | 6690 | 267.07.56 | TR064_Cmd.5680] - DEBUG: TR064 error 866:second factor authentication required (service='X_VoIP:1', control='x_voip', action='X_AVM-DE_DialSetConfig', parameter1='NewX_AVM-DE_PhoneName' => 'FON1: Telefon 1')
2023.06.17 15:00:07 4: [Fritzbox | 6690 | 267.07.56 | Ring_Run_Web.5268] - INFO: Switch ClickToDial on, set dial port 'FON1: Telefon 1'
2023.06.17 15:00:07 4: [Fritzbox | 6690 | 267.07.56 | Ring_Run_Web.5285] - INFO: Ringing 610 for 10 seconds
2023.06.17 15:00:07 5: [Fritzbox | 6690 | 267.07.56 | TR064_Cmd.5648] - DEBUG: Perform TR-064 call - X_AVM-DE_DialNumber => service='X_VoIP:1', control='x_voip', action='X_AVM-DE_DialNumber', parameter1='NewX_AVM-DE_PhoneNumber' => '**610#'
2023.06.17 15:00:08 4: [Fritzbox | 6690 | 267.07.56 | TR064_Cmd.5680] - DEBUG: TR064 error 501:Action Failed (service='X_VoIP:1', control='x_voip', action='X_AVM-DE_DialNumber', parameter1='NewX_AVM-DE_PhoneNumber' => '**610#')
2023.06.17 15:00:18 4: [Fritzbox | 6690 | 267.07.56 | readPassword.7211] - INFO: Read FritzBox password from file
2023.06.17 15:00:18 5: [Fritzbox | 6690 | 267.07.56 | TR064_Cmd.5648] - DEBUG: Perform TR-064 call - X_AVM-DE_DialHangup => service='X_VoIP:1', control='x_voip', action='X_AVM-DE_DialHangup'
2023.06.17 15:00:18 5: [Fritzbox | 6690 | 267.07.56 | Readout_Add_Reading.4013] - DEBUG: fhem->sidTime: 1687006818.37717
2023.06.17 15:00:18 5: [Fritzbox | 6690 | 267.07.56 | Readout_Add_Reading.4013] - DEBUG: readoutTime: 10.99
2023.06.17 15:00:18 5: [Fritzbox | 6690 | 267.07.56 | Ring_Run_Web.5312] - DEBUG: Handover to main process: fhem->sidTime|1687006818.37717|readoutTime|10.99
2023.06.17 15:00:18 4: [Fritzbox | 6690 | 267.07.56 | Set_Cmd_Done.4192] - INFO: Back at main process
2023.06.17 15:00:18 5: [Fritzbox | 6690 | 267.07.56 | Readout_Process.3703] - DEBUG: box_ disable list: box_docsis30_Ds_powerLevels|box_docsis30_Ds_latencys|box_docsis30_Ds_frequencys|box_docsis30_Ds_corrErrors|box_docsis30_Ds_mses
2023.06.17 15:00:18 5: [Fritzbox | 6690 | 267.07.56 | Readout_Process.3879] - DEBUG: BulkUpdate lastReadout: 2 values captured in 10.99 s
Jürgen
3x Sonos Play 1, 1x Sonos Arc + Sub, 1 Sonos-One, 1x Sonos Playbar
FB6690 + FB7490 mit 4x Dect 200 und 3 Dect-ULE-Thermostate,  raspberry3B+, HM Funkmodul HM-MOD-RPI-PCB, HM Klingelsensor HM-Sen-DB-PCB, HM (IP) Fensterkontakte und  Amazon Echo Dot,  piVCCU, pi OS (bookworm).
RalfRog
Zitat von: JoWiemann am 16 Juni 2023, 16:44:38
Zitat von: Intruder1956 am 16 Juni 2023, 16:22:10...
set Fritzbox ring 610 mit der Fritzbox6660 und dem neuesten Update vom FritzboxModul nicht mehr funktioniert?
... mit der FB7590 funktioniert es. Sowohl mit FritzOS 7.50 als auch 7.56
Bei mir funktioniert es wie bei Jörg auf Anhieb (DECT Telefon 610) ohne dass ich auf der FritzBox noch was geprüft habe.
Box 7590 noch mit 7.55 und Modul 07.50.17g
juemuc
Die Kabelboxen scheinen auch hier eine "Besonderheit" zu sein 😁
JoWiemann
ich habe mir eine FB 6660 leihen können. Mal sehen, ob ich etwas herausfinden kann. Wird aber dauern.
Grüße Jörg
Jörg Wiemann
Intruder1956
Vielen Dank Jörg,
das liest sich gut, da habe ich ja Hoffnung.
Wie oben geschrieben, mit der FB 6591 hatte es noch funktioniert.
Gruß Werner
Zotac CI547 32GB RAM 500GB SSD,ESXI 6.5, VM-Fhem5.8, VM-ioBroker, Cul 868Mhz;Cul 433Mhz = Busware, LGW, HM-MOD-RPI-PCB, Uniroll, IT YCR-100 TMT2100,ITR-1500, LD382 mit Wifilight, ESA 2000 + SENSOR WZ SET,FS20 TFK, HM-Sec-SC, HM-CC-RT-DN,PCA301,
JoWiemann
Zitat von: Intruder1956 am 19 Juni 2023, 09:49:06Vielen Dank Jörg,
Gruß Werner
Hallo Werner,
auf welches Telefon hast Du die Wählhilfe eingestellt. Wenn ich bei mir "Telefon" auswähle funktioniert das set ... ring.
Würdest Du das bitte einmal prüfen.
Grüße Jörg
Jörg Wiemann
RalfRog
Zitat von: RalfRog am 18 Juni 2023, 08:32:32Bei mir funktioniert es wie bei Jörg auf Anhieb (DECT Telefon 610) ohne dass ich auf der FritzBox noch was geprüft habe.
Ehrlicherweise muss ich zugeben, dass die Wählhilfe tatsächlich aktiviert ist und die Auswahl auf "ISDN- und Schnurlostelefone" steht.
Angeboten werden die DECT-Apparate auch einzeln - die Analogen fehlen weil ich sie beide gelöscht habe.
Bei AVM in der Hilfe ist folgendes erwähnt: "Die Wählhilfe ist nicht verfügbar, wenn Sie ein IP-Telefon oder FRITZ!⁠App Fon verwenden."
Solange es mindestens noch einen analogen Anschluss gibt müsste es also auch bei ausschließliher Verwendung von SIP-Endgeräten funktionieren. Sofern dann auch ausgewählt.
Intruder1956
[/quote]
Grüße Jörg
Hallo Jörg, jaaaaa :-)
Ich hatte das DECT1 mit dem Namen Werner in der Wahlhilfe übernommen und jetzt habe ich Telefon eingetragen.
Tja und schon funktioniert es wieder richtig.
Vielen vielen Dank, jetzt vereinsame ich auch nicht mehr und bekomme mit wenn jemand an der Türe klingelt.
Gruß Werner
RalfRog
Ich habe auch nochmal gespielt.
  • Wenn kein spezielles Telefon gewählt ist sondern die unspezifische Einstellung "ISDN- und Schnurlostelefone" dann funktioniert "set ring" auf allen meinen DECTs.
  • Wenn ein spezielles Telefon gewählt ist (Test mit 610) geht ein "set ring 610" nicht aber "set ring 611 oder 612".
Gruß Ralf
Intruder1956
Hallo Jörg,
hier noch mein letzter verbose 4 log
2023.06.21 11:54:14 4: [Fritzbox | 6660 | 252.07.29 | Readout_Run_Web.3656] - INFO: Captured 326 values
2023.06.21 11:54:15 3: [Fritzbox | 6660 | 252.07.29 | Set.1163] - INFO: set Fritzbox ring 610 10 say:Tuerklingel
2023.06.21 11:54:15 4: [Fritzbox | 6660 | 252.07.29 | Set_Cmd_Start.4168] - INFO: Fork process FRITZBOX_Ring_Run_Web
2023.06.21 11:54:15 4: [Fritzbox | 6660 | 252.07.29 | readPassword.7101] - INFO: Read FritzBox password from file
2023.06.21 11:54:16 4: [Fritzbox | 6660 | 252.07.29 | TR064_Cmd.5570] - DEBUG: TR064 error 866:second factor authentication required (service='X_VoIP:1', control='x_voip', action='X_AVM-DE_DialSetConfig', parameter1='NewX_AVM-DE_PhoneName' => 'FON1: Telefon')
2023.06.21 11:54:16 4: [Fritzbox | 6660 | 252.07.29 | Ring_Run_Web.5265] - INFO: Switch ClickToDial on, set dial port 'FON1: Telefon'
2023.06.21 11:54:16 4: [Fritzbox | 6660 | 252.07.29 | Ring_Run_Web.5282] - INFO: Ringing 610 for 10 seconds
2023.06.21 11:54:16 4: [Fritzbox | 6660 | 252.07.29 | readPassword.7101] - INFO: Read FritzBox password from file
2023.06.21 11:54:28 4: [Fritzbox | 6660 | 252.07.29 | Set_Cmd_Done.4189] - INFO: Back at main process
Es klingelt, aber say geht wohl nicht. bei Rufannahme kommt nur Verbindung wird gehalten, wenn die 10 Sek. vorbei sind, ist Gespräch beendet.
Gruß Werner
RalfRog
Zitat von: Intruder1956 am 21 Juni 2023, 12:00:39Es klingelt, aber say geht wohl nicht. bei Rufannahme kommt nur Verbindung wird gehalten, wenn die 10 Sek. vorbei sind, ist Gespräch beendet.
Gruß Werner
Schau mal in die Hilfe bei AVM. Die Ansage scheint richtig zu sein bis man an ein Telefon dran geht.
Ich hatte den Text gerade. Hänge ihn gleich dran.
Gruß Ralf
Edit
http://help.avm.de/fritzbox.php?hardware=139&language=de&set=008&topic=hilfe_fon_waehlhilfe
Telefongespräch aus Anrufliste oder Telefonbuch heraus aufbauen
Haben Sie die Wählhilfe aktiviert, können Sie Telefongespräche direkt aus der Anrufliste und aus dem Telefonbuch heraus aufbauen:
    Klicken Sie im Telefonbuch oder in der Anrufliste auf eine blaue Rufnummer.
    Bestätigen Sie mit "OK".
    Klicken Sie im Fenster "Verbindung mit <Rufnummer> wird hergestellt..." auf "OK". Das Gespräch wird dann wie gewohnt aufgebaut.
    oder
    Klicken Sie nicht auf "OK", sondern warten Sie ab, bis Ihr Telefon klingelt. Heben Sie dann den Hörer ab oder drücken Sie die Gesprächstaste an Ihrem Telefon. Jetzt sind Sie mit Ihrem Gesprächspartner verbunden.
    Ihr Telefon klingelt, sobald der angerufene Teilnehmer den Anruf entgegennimmt. Bis Sie den Hörer abheben, hört der angerufene Teilnehmer einen Warteton.
JoWiemann
Gruß Werner
Hallo Werner.
"say" geht schon eine Weile nicht mehr. Ich glaube ab FritzOS 6.80. Da wurden die restlichen WebCMD Funktionen von AVK deaktiviert. Mit TR064 gibt es keine Möglichkeit für "say" oder Auswahl von Klingeltönen. Über die Lua Funktionen bin ich auch nicht weiter gekommen. Auch im Netz findet sich nicht dazu. Alle Hinweise sind Jahre veraltet und gingen nur mit Telnet oder WebCMD.
Grüße Jörg
Jörg Wiemann
JoWiemann
Gruß Werner
Hallo Ralf,
soweit richtig. Aber der Parameter "say" wandelte einen beliebigen Text in mp4 um und übertrug das Soundfile an die FritzBox, die es dann an die FritzFon auslieferte. Das ging aber nur mit Telnet oder WebCMD. Beides ist aber nicht mehr vorhanden und TR064 oder .lua kann das nicht.
Grüße Jörg
Jörg Wiemann
Intruder1956
OK, vielen Dank. Ich habe mein klingeln der Wohnungstür wieder im Hörgerät un das ist mir wichtig.
Das "say" wäre nur ein zusätzliche Hilfe gewesen.
Alles gut und vielen Dank nochmal
Gruß Werner
RalfRog
Würde helfen die Hilfe "aufzuräumen".
Muss aber feststellen, dass es im Detail dann am Hintergrundwissen fehlt - z.B. was bis wann (FritzOS-Version) ging und aufgrund entfallener Funktionen im Modul nicht mehr realisiert werden kann.
